MMBTA13-HAF
NPN Silicon Epitaxial Planar Darlington Transistor
Features
• Halogen and Antimony Free(HAF), RoHS compliant
1.Base 2.Emitter 3.Collector
TO-236 Plastic Package
Absolute Maximum Ratings (Ta = 25 OC)
Parameter
Symbol
Value
Unit
Collector Base Voltage
VCBO
30
V
Collector Emitter Voltage
VCES
30
V
Emitter Base Voltage
VEBO
10
V
Collector Current
IC
500
mA
Power Dissipation
Ptot
350
mW
Tj
150
O
C
TStg
- 55 to + 150
O
C
Junction Temperature
Storage Temperature Range
Thermal Resistance Ratings
Parameter
Thermal Resistance Junction to Ambient 1)
1)
Symbol
Max.
Unit
RθJA
357
/W
Device mounted on FR-4 substrate PC board, 2oz copper, with minimum recommended pad layout.
1/4
Dated: 26/05/2022 Rev: 02
MMBTA13-HAF
Characteristics at Ta = 25 OC
Parameter
DC Current Gain
at VCE = 5 V, IC =10 mA
at VCE = 5 V, IC =100 mA
Collector Base Cutoff Current
at VCB = 30 V
Emitter Base Cutoff Current
at VEB = 10 V
Collector Base Breakdown Voltage
at IC = 100 µA
Collector Emitter Breakdown Voltage
at IC = 100 μA
Emitter Base Breakdown Voltage
at IE = 100 µA
Collector Emitter Saturation Voltage
at IC = 100 mA, IB = 0.1 mA
Base Emitter On Voltage
at IC = 100 mA, VCE = 5 V
Transition Frequency
at VCE =10 V, IC =10 mA, f = 100 MHz
2/4
Symbol
Min.
Max.
Unit
hFE
hFE
5,000
10,000
ICBO
100
nA
IEBO
100
nA
V(BR)CBO
30
V
V(BR)CES
30
V
V(BR)EBO
10
V
VCE(sat)
1.5
V
VBE(on)
2
V
fT
125
MHz
MMBTA13-HAF
Electrical Characteristics Curves
Fig. 1 Collector Current vs. Base to Emitter Voltage
Fig. 2 DC Current Gain vs. Collector Current
Fig. 3 VBESAT vs. Collector Current
Fig. 4 VCESAT vs. Collector Current
Fig. 5 Output Capacitance
Fig. 6 Power Derating Curve
3/4
MMBTA13-HAF
Package Outline (Dimensions in mm)
Unit
mm
A
1.20
0.89
A1
0.100
0.013
B
1.40
1.20
TO-236
C
0.19
0.08
D
3.04
2.80
E
2.6
2.2
F
1.02
0.89
G
2.04
1.78
L
0.51
0.37
L1
0.2
MIN
Recommended Soldering Footprint
2.0
1.0
0.8
1.0
0.8
1.9
Packing information
Pitch
Reel Size
Package
Tape Width
(mm)
mm
inch
mm
inch
TO-236
8
4 ± 0.1
0.157 ± 0.004
178
7
Per Reel Packing Quantity
3,000
Marking information
" FH " = Part No.
" • " = HAF (Halogen and Antimony Free)
" YM " = Date Code Marking
.FH
" Y " = Year
" M " = Month
Font type: Arial
4/4
很抱歉,暂时无法提供与“MMBTA13”相匹配的价格&库存,您可以联系我们找货
