2SD882
2SD882
    ST(先科)
    TO-220FB-3
    通用三极管 TO220FB-3L NPN Ic=3A
2SD882 数据手册
2SD882-HAF NPN Silicon Epitaxial Planar Power Transistor Features • Halogen and Antimony Free(HAF), RoHS compliant 1. Emitter 2.Collector 3. Base TO-220FB Plastic Package Absolute Maximum Ratings (Ta = 25 ) Parameter Symbol Value Unit Collector Base Voltage VCBO 40 V Collector Emitter Voltage VCEO 30 V Emitter Base Voltage VEBO 6 V Collector Current IC 3 A Peak Collector Current ICM 6 A Power Dissipation Ptot 2 W Tj 150 Tstg - 55 to + 150 Symbol Max. RθJA 62.5 Junction Temperature Storage Temperature Range Thermal Characteristics Parameter Thermal Resistance-Junction to Ambient Unit /W ® 1/4 Dated: 27/09/2022 Rev:01 2SD882-HAF Characteristics at Ta = 25 Parameter Symbol Min. Typ. Max. Unit hFE hFE hFE hFE 60 100 160 200 - 120 200 320 400 - Collector Base Cutoff Current at VCB = 40 V ICBO - - 1 µA Collector Emitter Cutoff Current at VCE = 30 V ICEO - - 10 µA Emitter Base Cutoff Current at VEB = 6 V IEBO - - 1 µA Collector Base Breakdown Voltage at IC = 100 µA V(BR)CBO 40 - - V Collector Emitter Breakdown Voltage at IC = 10 mA V(BR)CEO 30 - - V Emitter Base Breakdown Voltage at IE = 100 µA V(BR)EBO 6 - - V Collector Emitter Saturation Voltage at IC =2 A, IB = 200 mA VCE(sat) - - 0.5 V Base Emitter Saturation Voltage at IC = 2 A, IB = 200 mA VBE(sat) - - 1.5 V fT - 90 - MHz DC Current Gain at VCE = 2 V, IC = 1 A L O Y G Gain Bandwidth Product at VCE = 5 V, IC = 0.1 A, f = 10 MHz ® 2/4 Dated: 27/09/2022 Rev:01 2SD882-HAF Electrical Characteristics Curves Fig. 1 Output Characteristics Curve Fig. 2 Collector Current vs. Base to Emitter Voltage Fig. 4 VBESAT,VCESAT vs. Collector Current Fig. 3 DC Current Gain vs. Collector Current Fig. 6 Power Derating Curve Fig. 5 Output Capacitance ® 3/4 Dated: 27/09/2022 Rev:01 2SD882-HAF Package Outline Dimensions (Units: mm) UNIT A 2.9 B 6.8 C 0.7 D 15 E 1.5 F 0.9 2.7 6.4 0.3 11 1.1 0.7 UNIT P P1 Q mm 13.3 12.7 8.2 7.6 3.7 3.5 mm TO-220FB G 2.54 Typ. W 10.2 H 4.7 H1 2.5 K 3.1 L 16.8 L1 9.4 N 1.4 9.8 4.3 2.2 2.7 14.8 9.0 1.2 Packing information Package Carton Quantity Box Quantity Base Quantity Delivery Mode TO-220FB 5 K / Carton 1 K / Box 50 pcs / Tube Tube Marking information " 2SD882 * " = Part No. (" * " = HFE grouping Code) " ****** " = Date Code Marking 2SD882* Font type: Arial ****** ® 4/4 Dated: 27/09/2022 Rev:01
2SD882 价格&库存
很抱歉,暂时无法提供与“2SD882”相匹配的价格&库存,您可以联系我们找货
