13005
13005
    ST(先科)
    TO-220FB-3
    通用三极管 TO220FB-3L NPN Ic=4A
13005 数据手册
13005-HAF NPN Silicon Epitaxial Planar Power Transistor Features • Halogen and Antimony Free(HAF), RoHS compliant TO-220FB Plastic Package 1.Base 2.Collector 3.Emitter Applications • For high-voltage, high-speed power switching Absolute Maximum Ratings (Ta = 25 OC) Parameter Symbol Value Unit Collector Base Voltage VCBO 700 V Collector Emitter Voltage VCEO 400 V Emitter Base Voltage VEBO 9 V IC 4 A Power Dissipation (Ta = 25 OC) Ptot 2 W Power Dissipation (Tc = 25 OC) Ptot 29 W Tj 150 O C Tstg - 55 to + 150 O C Symbol Max. Unit Thermal Resistance from Junction to Ambient RθJA 62.5 /W Thermal Resistance from Junction to Case RθJC 4.31 /W Collector Current Junction Temperature Storage Temperature Range Thermal Characteristics Parameter ® 1/5 Dated: 18/03/2022 Rev:03 13005-HAF Characteristics at Ta = 25 OC Parameter DC Current Gain at VCE = 5 V, IC = 1 A at VCE = 5 V, IC = 2 A Collector Base Cutoff Current at VCB = 700 V Emitter Base Cutoff Current at VEB = 9 V Collector Emitter Breakdown Voltage at IC = 10 mA Collector Emitter Saturation Voltage at IC = 1 A, IB = 0.2 A at IC = 2 A, IB = 0.5 A at IC = 4 A, IB = 1 A Base Emitter Saturation Voltage at IC = 1 A, IB = 0.2 A at IC = 2 A, IB = 0.5 A Gain Bandwidth Product at VCE = 10 V, IC = 500 mA, f = 1 MHz Collector Base Capacitance at VCB = 10 V, f = 0.1 MHz Symbol Min. Typ. Max. Unit hFE hFE 10 8 - 60 40 - ICBO - - 1 mA IEBO - - 1 mA V(BR)CEO 400 - - V - - 0.5 0.6 1 V V V VBE(sat) - - 1.2 1.6 V V fT 4 - - MHz Cob - 40 - pF VCE(sat) ® 2/5 Dated: 18/03/2022 Rev:03 13005-HAF Electrical Characteristics Curves Fig. 1 Output Characteristics Curve Fig. 2 Output Characteristics Curve Fig. 2 Collector Curren vs. VBE Fig. 4 hFE vs. Collector Current ® 3/5 Dated: 18/03/2022 Rev:03 13005-HAF Electrical Characteristics Curves Fig. 6 VCE(sat) vs. Collector Current Fig. 5 VBE(sat) vs. Collector Current Fig 7. Output Capacitance Fig. 8 Power Derating Curve ® 4/5 Dated: 18/03/2022 Rev:03 13005-HAF Package Outline Dimensions (Units: mm) UNIT TO-220FB A 2.9 B 6.8 C 0.7 D 15 E 1.5 F 0.9 2.7 6.4 0.3 11 1.1 0.7 UNIT P P1 Q mm 13.3 12.7 8.2 7.6 3.7 3.5 mm G 2.54 TYP. W 10.2 9.8 H 4.7 4.3 H1 2.5 2.2 K 3.1 2.7 L 16.8 14.8 L1 9.4 9.0 N 1.4 1.2 Marking information " 13005 " = Part No. " **** " = Date Code Marking Font type: Arial 13005 **** ® 5/5 Dated: 18/03/2022 Rev:03
13005
物料型号:13005-HAF 器件简介:NPN硅外延平面功率晶体管,符合RoHS标准,无卤素和锑,采用TO-220FB塑料封装。 引脚分配:1. 基极,2. 集电极,3. 发射极。 参数特性: - 集电极-基极电压(Vcbo):700V - 集电极-发射极电压(Vceo):400V - 发射极-基极电压(Vebo):9V - 集电极电流(Ic):4A - 总功耗(Ptot):在25°C时为2W,在25°C时为29W - 结温(Tj):最高150℃ - 存储温度范围(Tstg):-55至+150℃
热特性: - 从结到环境的热阻(RθJA):最大62.5℃/W - 从结到封装的热阻(RθJC):4.31℃/W
功能详解: - 适用于高电压、高速功率开关 - 在Vce=5V,Ic=1A时,直流电流增益(hFE):典型值8,最小值10,最大值60 - 在VcB=700V时,集电极-基极截止电流(IcBo):最大1mA - 在VEB=9V时,发射极-基极截止电流(IEBO):最大1mA - 在Ic=10mA时,集电极-发射极击穿电压(V(BR)CEO):400V - 在Ic=1A,Ib=0.2A时,集电极-发射极饱和电压(VcE(sat)):典型值0.5V - 在Ic=2A,Ib=0.5A时,集电极-发射极饱和电压:典型值0.6V - 在Ic=4A,Ib=1A时,集电极-发射极饱和电压:典型值1V - 在Ic=1A,Ib=0.2A时,基极-发射极饱和电压(VBE(sat)):典型值1.2V - 在Ic=2A,Ib=0.5A时,基极-发射极饱和电压:典型值1.6V - 在Vce=10V,Ic=500mA,f=1MHz时,增益-带宽积(fT):4MHz - 在VcB=10V,f=0.1MHz时,集电极-基极电容(Cob):典型值40pF
应用信息:用于高电压、高速功率开关。 封装信息:TO-220FB塑料封装,详细尺寸和标记信息已列出。
13005 价格&库存
很抱歉,暂时无法提供与“13005”相匹配的价格&库存,您可以联系我们找货
