BAV199W
BAV199W
    ST(先科)
    SOT-323-3
    开关二极管(小信号) SOT323 VR=85V IR=5nA@75V
BAV199W 数据手册
BAV199W-HAF Silicon Epitaxial Planar Switching Diode 3 Feature • Very low leakage current • Medium speed switching times 1 • Series pair configuration 2 • Halogen and Antimony Free(HAF), RoHS compliant Applications • For low leakage current Absolute Maximum Ratings (Ta = 25 OC) Parameter Peak Repetitive Reverse Voltage Continuous Reverse Voltage Continuous Forward Current Single Diode Double Diode Repetitive Peak Forward Current Non-Repetitive Peak Forward Surge Current at t = 1 µs at t = 1 ms at t = 1 s Power Dissipation Operating and Storage Temperature Range Symbol Value Unit VRRM 85 V VR 85 V IF 160 140 mA IFRM 500 mA IFSM 4 1 0.5 A Ptot 250 mW Tj, Tstg - 65 to + 150 Symbol Max. Unit RθJA 500 /W O C Thermal Characteristics Parameter Thermal Resistance from Junction to Ambient 1) 1) Device mounted on FR-4 substrate PC board, 2oz copper, with minimum recommended pad layout. 1/4 ® Dated : 01/11/2022 Rev:02 BAV199W-HAF Characteristics at Ta = 25 OC Parameter Symbol Min. Max. Unit V(BR)R 85 - V Forward Voltage at IF = 1 mA at IF = 10 mA at IF = 50 mA at IF = 150 mA VF - 0.9 1 1.1 1.25 V Reverse Current at VR = 75 V at VR = 75 V, Tj = 150 OC IR - 5 80 nA Ctot - 2 pF trr - 3 µs Reverse Breakdown Voltage at IR = 100 µA Total Capacitance at VR = 0, f = 1 MHz Reverse Recovery Time at IF = IR = 10 mA, Irr = 0.1 X IR, RL = 100 Ω 2/4 ® Dated : 01/11/2022 Rev:02 BAV199W-HAF Electrical Characteristics Curves Fig 2. Capacitance Characteristics Curve PD, Power Dissipation (mW) Cj, Junction Capacitance(pF) Fig 1. Power Derating Curve Ta, Ambient Temperature VR, Reverse Voltage (V) Fig 4. Forward Characteristics Curve IR, Reverse Current (µA) IF, Forward Current(mA) Fig 3. Reverse Characteristics Curve VR, Reverse Voltage (V) VF, Forward Voltage (V) 3/4 ® Dated : 01/11/2022 Rev:02 BAV199W-HAF Package Outline Dimensions (Units: mm) SOT-323 UNIT A B C D H H1 HE F L W Q mm 0.1 MAX. 1.4 1.2 0.2 MIN. 2.1 1.9 1.0 0.8 0.7 TYP. 2.4 2.0 0.35 0.25 0.15 0.05 1.35 1.15 5° MAX. Recommended Soldering Footprint 1.6 0.8 0.8 0.8 0.8 1.3 Packing information Pitch Reel Size Package Tape Width (mm) mm inch mm inch SOT-323 8 4 ± 0.1 0.157 ± 0.004 178 7 Per Reel Packing Quantity 3,000 Marking information " JY " = Part No. " • " = HAF (Halogen and Antimony Free) " YM " = Date Code Marking " Y " = Year " M " = Month Font type: Arial . JY 4/4 ® Dated : 01/11/2022 Rev:02
BAV199W 价格&库存
很抱歉,暂时无法提供与“BAV199W”相匹配的价格&库存,您可以联系我们找货
