Y8OGC-STU-32.768K
Y8OGC-STU-32.768K
    YXC(扬兴科技)
    DT-38
    无源晶振 32.768kHz ±10ppm 12.5pF -20℃~+70℃
Y8OGC-STU-32.768K 数据手册
Crystal Unit 32.768KHZ YT-38 DIP Applications Features ‧RTC ‧Dimensions: 3.0 x 8.0mm.. ‧Standard Frequency: 32.768KHz ‧Resistance welded type crystal units. ‧Low impedance performance. Specifications(规格参数) Item Symbol Specifications f_nom 32.768KHz Frequency Tolerance(频率偏差) (at 25℃ ) CL 12.5pF, or specify f_tol ±5ppm, ±10ppm, or specify Operating Temperature(工作温度) B ( - 0.036 ± 0.01 ) * 10-6 / ℃2 T_use -20~+70℃, 40~+85℃, or specify T_stg -55~+125℃ C0 2.0pF Max. C1 3.8fF DL 1.0μW Typ. f_age ±3ppm/year Max. Nominal Frequency(额定频率范围) Load Capacitance(负载电容) Parabolic Coefficient(频率温度系数) Storage Temperature(储存温度) Shunt Capacitance(静态电容) Motional Capacitance(动态电容) Level of Drive(激励电平) Aging (老化)(at 25℃ ) Equivalent Series Resistance(等效串联电阻(ESR)) YT-38 40K Ω Max. Dimensions and Recommended land pattern(外观尺寸及推荐焊盘) Dimensions (Unit: mm) www.yxc.hk 1
Y8OGC-STU-32.768K 价格&库存
很抱歉,暂时无法提供与“Y8OGC-STU-32.768K”相匹配的价格&库存,您可以联系我们找货
Y8OGC-STU-32.768K
  • 1+0.26250
  • 100+0.24500
  • 300+0.22750
  • 500+0.21000
  • 2000+0.20125
  • 5000+0.19600
库存:2403
Y8OGC-STU-32.768K
  • 1+0.24790
库存:1107
Y8OGC-STU-32.768K
  • 10+0.47840
  • 100+0.38140
  • 300+0.33310
  • 1000+0.29690
库存:12760
Y8OGC-STU-32.768K
  • 1+0.38640
  • 50+0.22785
  • 1000+0.20475
库存:8825
Y8OGC-STU-32.768K
  • 10+0.57280
  • 100+0.42850
  • 500+0.33210
  • 1000+0.24070
  • 2000+0.22870
  • 10000+0.21180
库存:131
Y8OGC-STU-32.768K
  • 10+0.48762
  • 100+0.38913
  • 300+0.33988
  • 1000+0.30294
库存:4043
