Crystal Unit
HC-49SMD
Applications
Features
‧Industrial Control
Consumers.
‧Dimensions: 11.5 x 4.80 x3.8mm.
‧Standard Frequency: 3.2768~64MHz
‧Surface mount type crystal units.
‧A great number of standard frequencies.
Specifications(规格参数)
Item
Nominal Frequency Range(额定频率范围)
Vibration Mode(震动模式)
Load Capacitance(负载电容)
Frequency Tolerance(频率偏差) (at 25℃ )
Frequency Versus Temperature Characteristics(频率-温度特性)
Operating Temperature(工作温度)
Storage Temperature(储存温度)
Shunt Capacitance(静态电容)
Level of Drive(激励电平)
Aging (老化)(at 25℃ )
Symbol
Specifications
f_nom
3.2768~64MHz
AT Fundamental
CL
12pF, 20pF, or specify
f_tol
±10ppm, ±20ppm, or specify
f_tem
±20ppm, or specify
T_use
-20~+70℃, or specify
T_stg
-40~+85℃
C0
7pF Max.
DL
1~500μW Max.(100μW typical)
f_age
±3ppm/year Max.
Equivalent Series Resistance(等效串联电阻(ESR))
HC-49SMD
3.2768 ~ 4MHz
180 Ω Max.
6 ~ 7MHz
80 Ω Max.
4 ~ 5MHz
120 Ω Max.
7 ~ 10MHz
60 Ω Max.
5 ~ 6 MHz
100 Ω Max.
10 ~ 30MHz
40 Ω Max.
Dimensions and Recommended land pattern(外观尺寸及推荐焊盘)
Dimensions (Unit: mm)
Recommended land pattern(Unit: mm)
www.yxc.hk
1
很抱歉,暂时无法提供与“H6OSC-SUG-4M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.39750
- 100+0.37100
- 300+0.34450
- 500+0.31800
- 2000+0.30475
- 5000+0.29680
- 国内价格
- 10+1.22910
- 100+0.73320
- 500+0.51320
- 1000+0.36660
- 2000+0.34830
- 10000+0.32260
- 国内价格
- 5+0.69261
- 50+0.54746
- 150+0.47488
- 1000+0.42056
- 2000+0.37703
- 5000+0.35522
- 国内价格
- 5+0.57590
- 50+0.46680
- 150+0.39240
- 500+0.36110
- 1000+0.33860
- 3000+0.31860
- 国内价格
- 1+0.54487
- 50+0.32033
- 1000+0.28840
