H6OSC-SUG-25M
H6OSC-SUG-25M
    YXC(扬兴科技)
    HC-49S/SMD
    无源晶振 25MHz ±20ppm 20pF -20℃~+70℃
H6OSC-SUG-25M 数据手册
Crystal Unit HC-49SMD Applications Features ‧Industrial Control Consumers. ‧Dimensions: 11.5 x 4.80 x3.8mm. ‧Standard Frequency: 3.2768~64MHz ‧Surface mount type crystal units. ‧A great number of standard frequencies. Specifications(规格参数) Item Nominal Frequency Range(额定频率范围) Vibration Mode(震动模式) Load Capacitance(负载电容) Frequency Tolerance(频率偏差) (at 25℃ ) Frequency Versus Temperature Characteristics(频率-温度特性) Operating Temperature(工作温度) Storage Temperature(储存温度) Shunt Capacitance(静态电容) Level of Drive(激励电平) Aging (老化)(at 25℃ ) Symbol Specifications f_nom 3.2768~64MHz - AT Fundamental CL 12pF, 20pF, or specify f_tol ±10ppm, ±20ppm, or specify f_tem ±20ppm, or specify T_use -20~+70℃, or specify T_stg -40~+85℃ C0 7pF Max. DL 1~500μW Max.(100μW typical) f_age ±3ppm/year Max. Equivalent Series Resistance(等效串联电阻(ESR)) HC-49SMD 3.2768 ~ 4MHz 180 Ω Max. 6 ~ 7MHz 80 Ω Max. 4 ~ 5MHz 120 Ω Max. 7 ~ 10MHz 60 Ω Max. 5 ~ 6 MHz 100 Ω Max. 10 ~ 30MHz 40 Ω Max. Dimensions and Recommended land pattern(外观尺寸及推荐焊盘) Dimensions (Unit: mm) Recommended land pattern(Unit: mm) www.yxc.hk 1
H6OSC-SUG-25M 价格&库存
很抱歉,暂时无法提供与“H6OSC-SUG-25M”相匹配的价格&库存,您可以联系我们找货
H6OSC-SUG-25M
  • 1+0.36000
  • 100+0.33600
  • 300+0.31200
  • 500+0.28800
  • 2000+0.27600
  • 5000+0.26880
库存:4289
H6OSC-SUG-25M
  • 5+0.62200
  • 50+0.48920
  • 150+0.42370
  • 1000+0.37520
  • 2000+0.33640
  • 5000+0.31690
库存:1024
H6OSC-SUG-25M
  • 1+0.30210
库存:4
H6OSC-SUG-25M
  • 1+0.53760
  • 50+0.31605
  • 1000+0.28455
库存:262
H6OSC-SUG-25M
  • 5+0.63040
  • 50+0.49832
  • 150+0.43222
  • 1000+0.38276
  • 2000+0.34312
  • 5000+0.32336
库存:1260
