H1OSC-SUG-16M
H1OSC-SUG-16M
    YXC(扬兴科技)
    HC49S
    无源晶振 16MHz ±20ppm 20pF -20℃~+70℃
H1OSC-SUG-16M 数据手册
Crystal Unit HC-49US DIP Applications Features Consumers. ‧Standard Frequency: 3.2768~32MHz ‧Industrial Control ‧Dimensions: 11.5 x 4.50 x3.68mm. ‧Through hole type crystal units. ‧A great number of standard frequencies. Specifications(规格参数) Item Nominal Frequency Range(额定频率范围) Vibration Mode(震动模式) Load Capacitance(负载电容) Frequency Tolerance(频率偏差) (at 25℃ ) Frequency Versus Temperature Characteristics(频率-温度特性) Operating Temperature(工作温度) Storage Temperature(储存温度) Shunt Capacitance(静态电容) Level of Drive(激励电平) Aging (老化)(at 25℃ ) Symbol Specifications f_nom 3.2768~32MHz - AT Fundamental CL 12pF, 20pF, or specify f_tol ±10ppm, ±20ppm, or specify f_tem ±20ppm,or specify T_use -20~+70℃,or specify T_stg -40~+85℃ C0 7pF Max DL 1~500μW Max.(100μW typical) f_age ±3ppm/year Max. Equivalent Series Resistance(等效串联电阻(ESR)) HC-49US 3.2768 ~ 4MHz 180 Ω Max. 6 ~ 17MHz 80 Ω Max. 4 ~ 5MHz 120 Ω Max. 7 ~ 10MHz 60 Ω Max. 5 ~ 6 MHz 100 Ω Max. 10 ~ 32MHz 40 Ω Max. Dimensions and Recommended land pattern(外观尺寸及推荐焊盘) Dimensions (Unit: mm) www.yxc.hk 1
H1OSC-SUG-16M 价格&库存
很抱歉,暂时无法提供与“H1OSC-SUG-16M”相匹配的价格&库存,您可以联系我们找货
H1OSC-SUG-16M
  • 5+0.59830
  • 50+0.46530
  • 200+0.39910
  • 400+0.34970
  • 2400+0.31020
  • 5000+0.29060
库存:843
H1OSC-SUG-16M
  • 1+0.26560
库存:910
H1OSC-SUG-16M
  • 5+0.60826
  • 50+0.47412
  • 200+0.40706
  • 400+0.35673
  • 2400+0.31644
  • 5000+0.29636
库存:9794
H1OSC-SUG-16M
  • 1+0.33000
  • 100+0.30800
  • 300+0.28600
  • 500+0.26400
  • 2000+0.25300
  • 5000+0.24640
库存:3272
H1OSC-SUG-16M
  • 1+0.31824
  • 200+0.26520
库存:877
