Crystal Unit
32.768KHZ
YSX146GA
Applications
‧RTC.
Glass Sealed
Features
‧Dimensions: 7.00 x 1.50 x 1.40mm
‧Reflow is possible.
‧Standard Frequency: 32.768KHz
‧Contains Pb in sealing glass exempted by ROHS directive.
Specifications(规格参数)
Item
Symbol
Specifications
f_nom
32.768KHz
Frequency Tolerance(频率偏差) (at 25℃ )
CL
7pF, 9pF, 12.5pF, or specify
f_tol
±10ppm, ±20ppm, or specify
Operating Temperature(工作温度)
B
( - 0.036 ± 0.01 ) * 10-6 / ℃2
T_use
-20~+70℃, -40~+85℃
T_stg
-55~+125℃
C0
2.0pF Max.
C1
3.0fF
DL
1.0μW Max
f_age
±5ppm/year Max.
Nominal Frequency(额定频率范围)
Load Capacitance(负载电容)
Parabolic Coefficient(频率温度系数)
Storage Temperature(储存温度)
Shunt Capacitance(静态电容)
Motional Capacitance(动态电容)
Level of Drive(激励电平)
Aging (老化)(at 25℃ )
Equivalent Series Resistance(等效串联电阻(ESR))
YST146GA
65K Ω Max.
Dimensions and Recommended land pattern(外观尺寸及推荐焊盘)
Dimensions (Unit: mm)
Recommended land pattern(Unit: mm)
www.yxc.hk
1
很抱歉,暂时无法提供与“XKYGI-112-32.768K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.10250
- 200+0.84525
- 1500+0.73395
- 3000+0.68355
- 国内价格
- 1+0.78400
- 30+0.75600
- 100+0.72800
- 500+0.67200
- 1000+0.64400
- 2000+0.62720
- 国内价格
- 1+1.39440
- 10+1.11470
- 50+0.92840
- 150+0.86290
- 500+0.80590
- 1000+0.75600
- 3000+0.71820
- 国内价格
- 5+1.40963
- 50+1.11622
- 600+1.10506
- 1200+1.08296
- 3000+1.05047
- 15000+1.00845
