XG1SI-111-11.0592M
XG1SI-111-11.0592M
    YXC(扬兴科技)
    SMD5032_2P
    无源晶振 11.0592MHz ±10ppm 20pF -40℃~+85℃
XG1SI-111-11.0592M 数据手册
Crystal Unit YSX530GA Applications ‧Industrial Control Consumers. Glass Sealed Features ‧Dimensions: 5.00 x 3.20 x 1.2 mm ‧2 pads SMD glass sealed crystal units. ‧Standard Frequency: 8~54MHz ‧Contains Pb in sealing glass exempted by ROHS directive. Specifications(规格参数) Item Nominal Frequency Range(额定频率范围) Vibration Mode(震动模式) Load Capacitance(负载电容) Frequency Tolerance(频率偏差) (at 25℃ ) Frequency Versus Temperature Characteristics(频率-温度特性) Operating Temperature(工作温度) Storage Temperature(储存温度) Shunt Capacitance(静态电容) Level of Drive(激励电平) Aging (老化)(at 25℃ ) Symbol Specifications f_nom 8~54MHz - AT Fundamental CL 10pF, 20pF, or specify f_tol ±10ppm, ±20ppm, or specify f_tem ±20ppm, or specify T_use -20~+70℃, -40~+85℃, or specify T_stg -55~+125℃ C0 5pF Max DL 1~300μW Max.(100μW typical) f_age ±3ppm/year Max. Equivalent Series Resistance(等效串联电阻(ESR)) YST530GA 8 ~ 16MHz 80 Ω Max. 16 ~ 25MHz 40~60 Ω Max. 25 ~ 54MHz 30~40 Ω Max. Dimensions and Recommended land pattern(外观尺寸及推荐焊盘) Dimensions (Unit: mm) Recommended land pattern(Unit: mm) www.yxc.hk 1
XG1SI-111-11.0592M 价格&库存
很抱歉,暂时无法提供与“XG1SI-111-11.0592M”相匹配的价格&库存,您可以联系我们找货
XG1SI-111-11.0592M
  • 5+1.69740
  • 50+1.30640
  • 150+1.14320
  • 1000+0.94050
  • 2000+0.85030
  • 5000+0.79610
库存:990
XG1SI-111-11.0592M
  • 1+1.04958
  • 50+0.80968
库存:91
XG1SI-111-11.0592M
  • 1+0.88200
  • 30+0.85050
  • 100+0.81900
  • 500+0.75600
  • 1000+0.72450
  • 2000+0.70560
库存:3817
XG1SI-111-11.0592M
库存:203
XG1SI-111-11.0592M
  • 1+1.06080
  • 50+0.81600
  • 1000+0.75174
库存:1000
XG1SI-111-11.0592M
  • 5+1.71666
  • 50+1.33089
  • 150+1.16554
  • 1000+0.95926
  • 2000+0.86735
  • 5000+0.81227
库存:1129
