30SQ045
Schottky Diodes
Features
● High frequency operation
● Low forward voltage drop
● High purity, high temperature epoxy encapsulation for
enhanced mechanical strength and moisture resistance
● Guard ring for enhanced ruggedness and long term reliability
● Solder dip 275 °C max. 7s, per JESD 22-B106
Typical Applications
Typical applications are in switching power supplies, converters,
freewheeling diodes, and reverse battery protection
Mechanical Data
● Package: R-6
Molding compound meets UL 94 V-0 flammability
rating, RoHS-compliant
● Terminals: Tin plated leads, solderable per J-STD002 and JESD22-B102
● Polarity: Color band denotes cathode end
■Maximum Ratings (Ta=25℃ Unless otherwise specified)
PARAMETER
SYMBOL
UNIT
30SQ045
30SQ045
Device Marking Code
Repetitive Peak Reverse Voltage
Average Rectified Output Current
@60Hz sine wave, R-load, Ta=25℃
Surge(Non-repetitive)Forward Current
@60Hz half sine wave, 1 cycle, Ta=25℃
Current Squared Time @1ms≤t≤8.3ms Tj=25℃
Storage Temperature
Junction Temperature
IN DC Forward Mode-Forward Operations,without
reverse bias, t ≤1 h (Fig. 1)①
VRRM
V
45
IO
A
30
IFSM
A
380
I2t
As
Tstg
-55 ~+150
Tj
-55 ~+200
2
599
NOTE
① Meets the requirements of IEC 61215 Ed. 2 bypass diode thermal test.
■Electrical Characteristics (Ta=25℃ Unless otherwise specified)
PARAMETER
Maximum instantaneous forward
voltage drop per diode
Maximum DC reverse current at
rated DC blocking voltage per diode
SYMBOL
UNIT
VFM
V
IRRM1
mA
IRRM2
TEST CONDITIONS
30SQ045
0.55
IFM=30.0A
VRM=VRRM
Ta=25℃
VRM=VRRM
Ta=100℃
0.5
50
■Thermal Characteristics (Ta=25℃ Unless otherwise specified)
PARAMETER
Thermal Resistance
Between junction and case
ht t p : //
Revision:20210701-P1
SYMBOL
UNIT
30SQ045
RθJ-C
℃/W
2.5
www.lgesem i .c o m
mail:lge@lgesemi.com
30SQ045
■Ordering Information (Example)
PREFERED P/N
UNIT WEIGHT(g)
MINIIMUM
PACKAGE(pcs)
INNER BOX
QUANTITY(pcs)
OUTER CARTON
QUANTITY(pcs)
DELIVERY MODE
30SQ045
Approximate 2.02
500
10
5000
Tape
30SQ045
Approximate 2.02
1000
4
4000
Reel
■Characteristics (Typical)
FIG1:Io -Tc Curve
FIG2:Surge Forward Current Capability
600
Peak Forward Surge Current (A)
Average Forward Output Current (A)
30.0
24.0
IN DC
18.0
12.0
6.0
8.3ms Single Half Sine-Wave
JEDEC Method
500
400
300
200
100
50
150
1
2
5
Case Temperature(℃)
100
FIG4: Typical Reverse Characteristics
Instantaneous Reverse Current (mA)
Instantaneous Forward Current (A)
50
100
100
10
1.0
0.8
0.6
Instantaneous Forward Voltage (V)
0.4
ht t p : //
10
Tj=100℃
1.0
0.1
Tj=25℃
Ta=25℃
Revision:20210701-P2
Number of Cycles
FIG3: Forward Voltage
0.1
10
1.0
0.01
60
80
Percent of Rated Peak Reverse Voltage (%)
100
www.lgesem i .c o m
30SQ045
■Outline Dimensions
R-6
R -6
Dim
Min
Max
A
25.4
B
C
1.2
1.3
8.6
9.1
D
8.6
9.1
D im ensions in m illim eters
ht t p : //
Revision:20210701-P3
www.lgesem i .c o m
很抱歉,暂时无法提供与“30SQ045”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.28800
- 50+1.74900
- 500+1.62800
- 国内价格
- 1+4.31946
- 10+3.65256
- 30+3.32424
- 100+2.99592
- 500+2.29824
- 1000+2.19564
