TDM3053
TDM3053
    LIGHTNING(天电光电)
    SOP-4
    直流输入,随机相位光电 光电耦合器 3750Vrms
TDM3053 数据手册
TDM301X,TDM302X,TDM305X Series www.tdled.com SOP4, DC Input, Random-Phase Photo TRIAC Photo Coupler SCHEMATIC Description The TDM301X, TDM302X and TDM305X series combine an AlGaAs infrared emitting diode as the emitter which is optically coupled to a monolithic 1 4 2 3 silicon random-phase photo triac in a plastic SOP4 package. With the robust coplanar double mold structure, TDM301X, TDM302X and TDM305X series provide the most stable isolation feature. Features  High isolation 3750 VRMS  DC input with random-phase photo triac output  Operating temperature range - 40 °C to PIN DEFINITION 1. Anode 2. Cathode 3. Terminal 4. Terminal PACKAGE OUTLINE 100 °C  REACH & RoHS compliance  Halogen free  MSL class 1  Regulatory Approvals  UL - UL1577  VDE - EN60747-5-5(VDE0884-5)  CQC – GB4943.1, GB8898 Applications  Solenoid/valve controls  Lighting controls  Motor controls  Temperature controls  Static AC power switches  Solid state relays  Interfacing microprocessors to 115 to 240VAC peripherals Document No: Preliminary Rev: 0.2 Release Date: 2019/2/22 1 TDM301X,TDM302X,TDM305X Series www.tdled.com SOP4, DC Input, Random-Phase Photo TRIAC Photo Coupler ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL VALUE UNIT Forward Current IF 60 mA Reverse Voltage VR 6 V Junction Temperature Tj 125 °C Input Power Dissipation PI 100 mW NOTE INPUT OUTPUT TDM301X Off-state Output Terminal Voltage TDM302X 250 VDRM TDM305X 400 V 600 Peak Repetitive Surge Current PW=100μs, 120pps ITSM 1 A Junction Temperature Tj 125 °C Output Power Dissipation PO 300 mW Total Power Dissipation Ptot 330 mW Isolation Voltage Viso 3750 Vrms Operating Temperature Topr -40~100 °C Storage Temperature Tstg -55~125 °C Soldering Temperature Tsol 260 °C COMMON 1 2 Note 1. AC For 1 Minute, R.H. = 40 ~ 60% Note 2. For 10 seconds Document No: Preliminary Rev: 0.2 Release Date: 2019/2/22 2 TDM301X,TDM302X,TDM305X Series www.tdled.com SOP4, DC Input, Random-Phase Photo TRIAC Photo Coupler ELECTRICAL OPTICAL CHARACTERISTICS at Ta=25°C PARAMETER SYMBOL MIN. TYP. MAX. UNIT TEST CONDITION NOTE INPUT Forward Voltage VF - 1.24 1.4 V IF=10mA Reverse Current IR - - 10 μA VR=6V Input Capacitance Cin - 8.5 250 pF V=0, f=1kHz OUTPUT Peak Off-state Current, Either Direction Peak On-state Current, Either Direction Critical Rate of Rise of Off-state Voltage VDRM=Rated VDRM IDRM - - 100 nA VTM - 1.58 2.5 V ITM=100mA dV/dt 1000 - - V/μs VPEAK =Rated VDRM IF=0 3 4 TRANSFER CHARACTERISTICS LED TDM3010,TDM3021,TDM3051 Trigger TDM3011,TDM3022,TDM3052 IFT Current TDM3012,TDM3023,TDM3053 Holding Current IH Isolation Resistance Riso Floating Capacitance CIO - - 15 - - 10 - - 5 - 257 - μA - Ω DC500V, 40 ~ 60% R.H. 1 pF V=0, f=1MHz 10^12 10^14 - 0.4 mA Terminal Voltage = 3V ITM=100mA Note3. Test voltage must be applied within dV/dt rating. Note4. Refer to Fig.15 & Fig.16 Document No: Preliminary Rev: 0.2 Release Date: 2019/2/22 3 TDM301X,TDM302X,TDM305X Series www.tdled.com SOP4, DC Input, Random-Phase Photo TRIAC Photo Coupler CHARACTERISTIC CURVES Fig.1 Forward Current vs. Ambient Temperature Fig.2 On-state Terminal Current vs. Ambient Temperature Fig.3 Forward Current vs. Forward Voltage Fig.4 Off-state Terminal Current vs. Ambient Temperature Fig.5 Normalized Off-state Terminal Voltage vs. Ambient Temperature Fig.6 Normalized Trigger Current vs. LED Trigger Pulse Width Document No: Preliminary Rev: 0.2 Release Date: 2019/2/22 4 www.tdled.com TDM301X,TDM302X,TDM305X Series SOP4, DC Input, Random-Phase Photo TRIAC Photo Coupler CHARACTERISTIC CURVES Fig.7 Normalized Trigger Current vs. Ambient Temperature Fig.8 On-state Terminal Voltage vs. Ambient Temperature Fig.9 On-state Terminal Voltage vs. On-state Terminal Current Fig.10 Holding Current vs. Ambient Temperature Fig.11 Turn On Time vs. Forward Current Fig.12 Turn On Time vs. Ambient Temperature Document No: Preliminary Rev: 0.2 Release Date: 2019/2/22 5 www.tdled.com TDM301X,TDM302X,TDM305X Series SOP4, DC Input, Random-Phase Photo TRIAC Photo Coupler TEST CIRCUITS Fig.13 Test Circuits of Turn On Time Fig.14 Waveforms of Turn On Time Fig.15 Test Circuits of dV/dt Fig.16 Waveforms of dV/dt Document No: Preliminary Rev: 0.2 Release Date: 2019/2/22 6 www.tdled.com TDM301X,TDM302X,TDM305X Series SOP4, DC Input, Random-Phase Photo TRIAC Photo Coupler PACKAGE DIMENSIONS (Dimensions in mm unless otherwise stated) Recommended Solder Mask (Dimensions in mm unless otherwise stated) Document No: Preliminary Rev: 0.2 Release Date: 2019/2/22 7 www.tdled.com TDM301X,TDM302X,TDM305X Series SOP4, DC Input, Random-Phase Photo TRIAC Photo Coupler CARRIER TAPE SPECIFICATIONS (Dimensions in mm unless otherwise stated) Option T1 Option T2 Document No: Preliminary Rev: 0.2 Release Date: 2019/2/22 8 www.tdled.com TDM301X,TDM302X,TDM305X Series SOP4, DC Input, Random-Phase Photo TRIAC Photo Coupler REEL SPECIFICATIONS (Dimensions in mm unless otherwise stated) Option T1 & T2 Document No: Preliminary Rev: 0.2 Release Date: 2019/2/22 9 www.tdled.com TDM301X,TDM302X,TDM305X Series SOP4, DC Input, Random-Phase Photo TRIAC Photo Coupler BOX SPECIFICATIONS (Reel Type) Inner Box  L x W x H = 36cm x 36cm x 6.9cm Outer Box  L x W x H = 45cm x 38cm x 38cm Document No: Preliminary Rev: 0.2 Release Date: 2019/2/22 10 TDM301X,TDM302X,TDM305X Series www.tdled.com SOP4, DC Input, Random-Phase Photo TRIAC Photo Coupler ORDERING AND MARKING INFORMATION MARKING INFORMATION TD 30XX V Y A WW : Company Abbr. : Part Number & Rank : VDE Option : Fiscal Year : Manufacturing Code : Work Week ORDERING INFORMATION LABEL INFORMATION TDM30XX(Z)-GV TD – Company Abbr. M – SOP Package 30XX – Rank (10/11/12/21/22/23/51/52/53) Z – Tape and Reel Option (T1/T2) G – Green V – VDE Option (V or None) PACKING QUANTITY Option Quantity Quantity – Inner box Quantity – Outer box T1 3000 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 45k Units T2 3000 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 45k Units Document No: Preliminary Rev: 0.2 Release Date: 2019/2/22 11 www.tdled.com TDM301X,TDM302X,TDM305X Series SOP4, DC Input, Random-Phase Photo TRIAC Photo Coupler REFLOW INFORMATION REFLOW PROFILE Profile Feature Sn-Pb Assembly Profile Pb-Free Assembly Profile Temperature Min. (Tsmin) 100 150°C Temperature Max. (Tsmax) 150 200°C Time (ts) from (Tsmin to Tsmax) 60-120 seconds 60-120 seconds Ramp-up Rate (tL to tP) 3°C/second max. 3°C/second max. Liquidous Temperature (TL) 183°C 217°C Time (tL) Maintained Above (TL) 60 – 150 seconds 60 – 150 seconds Peak Body Package Temperature 235°C +0°C / -5°C 260°C +0°C / -5°C Time (tP) within 5°C of 260°C 20 seconds 30 seconds Ramp-down Rate (TP to TL) 6°C/second max 6°C/second max Time 25°C to Peak Temperature 6 minutes max. 8 minutes max. Document No: Preliminary Rev: 0.2 Release Date: 2019/2/22 12 www.tdled.com TDM301X,TDM302X,TDM305X Series SOP4, DC Input, Random-Phase Photo TRIAC Photo Coupler DISCLAIMER  LIGHTNING is continually improving the quality, reliability, function and design. LIGHTNING reserves the right to make changes without further notices.  The characteristic curves shown in this datasheet are representing typical performance which are not guaranteed.  LIGHTNING makes no warranty, representation or guarantee regarding the suitability of the products for any particular purpose or the continuing production of any product. To the maximum extent permitted by applicable law, LIGHTNING disclaims (a) any and all liability arising out of the application or use of any product, (b) any and all liability, including without limitation special, consequential or incidental damages, and (c) any and all implied warranties, including warranties of fitness for particular  The products shown in this publication are designed for the general use in electronic applications such as office automation, equipment, communications devices, audio/visual equipment, electrical application and instrumentation purpose, non-infringement and merchantability.  This product is not intended to be used for military, aircraft, automotive, medical, life sustaining or lifesaving applications or any other application which can result in human injury or death.  Please contact LIGHTNING sales agent for special application request.  Immerge unit’s body in solder paste is not recommended.  Parameters provided in datasheets may vary in different applications and performance may vary over time. All operating parameters, including typical parameters, must be validated in each customer application by the customer’s technical experts. Product specifications do not expand or otherwise modify LIGHTNING’s terms and conditions of purchase, including but not limited to the warranty expressed therein.  Discoloration might be occurred on the package surface after soldering, reflow or long-time use. It neither impacts the performance nor reliability. Document No: Preliminary Rev: 0.2 Release Date: 2019/2/22 13
TDM3053
物料型号:TDM301X, TDM302X, TDM305X系列
器件简介:这些系列的光耦合器结合了AlGaAs红外发射二极管作为发射器,与单片硅随机相位光三极管在塑料SOP4封装中光耦合。
引脚分配:1. 阳极;2. 阴极;3. 终端;4. 终端
参数特性: - 高隔离电压3750 VRMS - DC输入,随机相位光三极管输出 - 工作温度范围-40°C至100°C - 符合REACH和RoHS标准 - 无卤素 - MSL等级1 - 通过UL、VDE和CQC等认证
功能详解: - 光耦合器提供了稳定的隔离特性,适用于多种电子应用。
应用信息: - 电磁阀/阀门控制 - 照明控制 - 电机控制 - 温度控制 - 静态交流电源开关 - 固态继电器 - 微处理器与115至240VAC外围设备的接口
封装信息:SOP4封装,详细尺寸和规格在文档中有图示说明。
绝对最大额定值和电气光学特性表格提供了详细的技术参数,如输入电流、反向电压、结温、输入功耗等。
特性曲线图展示了不同环境温度和工作条件下的器件性能。
订购和标记信息提供了如何订购这些光耦合器以及如何识别它们的标记。
回流信息提供了焊接这些光耦合器的推荐温度曲线。
免责声明说明了制造商对产品性能的一般性描述,并不保证特定应用的适用性,也不承担由此产生的任何责任。
TDM3053 价格&库存
很抱歉,暂时无法提供与“TDM3053”相匹配的价格&库存,您可以联系我们找货
