BC807-16/-25/-40
PNP Silicon Epitaxial Planar Transistor
Features
Epitaxial planar die construction
Complimentary to BC817
High collector current
High current gain
Low collector-emitter saturation voltage
SOT-23
Mechanic al Data
Case: SOT-23
Molding compound: UL flammability classification rating 94V-0
Terminals: Tin-plated; solderability per MIL-STD-202, Method 208
Ordering Information
nd
uc
to
r
Package
Shipping Quantity
Marking Code
BC807-16
SOT-23
3000 pcs / Tape & Reel
5A
BC807-25
SOT-23
5B
BC807-40
SOT-23
5C
mi
co
Part Number
Maximum Ratings (@ TA = 25°C unless otherwise specified)
Collector-Base Breakdown Voltage
Collector-Emitter Breakdown Voltage
Se
Parameter
Symbol
Value
Unit
VCBO
-50
V
VCEO
-45
V
VEBO
-5
V
IC
-0.5
A
O
Emitter-Base Breakdown Voltage
CR
Continuous Collector Current
MI
Thermal Characteristics
Symbol
Value
Unit
PD
300
mW
Thermal Resistance Junction-to-Air *1
RθJA
395
°C/W
Thermal Resistance Junction-to-Case *1
RθJC
218
°C/W
Thermal Resistance Junction-to-Lead *1
RθJL
191
°C/W
TJ
-55 ~ +150
°C
TSTG
-55 ~ +150
°C
JS
Parameter
Power Dissipation
Operating junction Temperature
Storage Temperature Range
Note 1: The data tested by surface mounted on a 15mm * 15mm * 1mm FR4-epoxy P.C.B
www.jsmsemi.com
第1页,共4页
BC807-16/-25/-40
Electrical Characteristics (@ TA = 25°C unless otherwise specified)
Parameter
Symbol
Test Condition
Min.
Typ.
Max.
Unit
V(BR)CBO
IC = -10μA, IE = 0
-50
V
V(BR)CEO
IC = -10mA, IB = 0
-45
V
V(BR)EBO
IE = -10μA, IC = 0
-5
V
Collector Cut-off Current
ICBO
VCB = -25V, IE = 0
-100
nA
Emitter Cut-off Current
IEBO
VEB = -4V, IC = 0
-100
nA
BC807-16
100
VCE = -1V, IC = -100mA
BC807-40
DC Current Gain
BC807-16
352
400
418
600
60
100
170
VCE = -1V, IC = -500mA
40
VCE = -1V, IC = -300mA
BC807-40
BC807-40
250
250
hFE
BC807-25
160
197
nd
uc
t
BC807-25
or
VCE(sat)
IC = -500mA, IB = -50mA
-0.7
V
Base-emitter Saturation Voltage
VBE(sat)
-1.2
V
IC = -10mA, VCE = -5V
200
MHz
VCB = -10V, IE = 0, f = 1MHZ
10
pF
fT
Transition Frequency
COBO
JS
MI
CR
O
Se
Collector Output Capacitance
mi
co
Collector-emitter Saturation Voltage
www.jsmsemi.com
第2页,共4页
BC807-16/-25/-40
Ratings and Characteristics Curves (@ TA = 25°C unless otherwise specified)
500
800
VCE = -1V
400
600
500
TA = 150 ℃
hFE
200
TA = 150 ℃
400
300
TA = 25℃
TA = -55 ℃
1
TA = -55 ℃
100
10
1000
100
0.1
hFE vs. IC (BC807-16)
1400
VCE = -1V
1200
-VBEon(mV)
700
TA = 150℃
400
TA = 2 5 ℃
Se
300
200
TA = -55℃
100
0.1
1
10
100
800
600
TA = 25℃
400
T = 1 50℃
A
200
1
0.1
10
-IC(mA)
O
CR
hFE vs. IC (BC807-40)
1400
-VBESAT(mV)
-VCESAT (mV)
IC/IB = 10
1200
IC /IB = 10
100
TA = 150℃
1000
TA = -5 5℃
800
T = 25℃
600
A
400
TA = 25℃
10
1000
Fig 4 VBE(ON) vs. IC
JS
1000
100
-IC(mA)
MI
Fig 3
1000
TA = -55 ℃
1000
600
500
100
VCE = -1V
mi
co
800
hFE
10
Fig 2 hFE vs. IC (BC807-25)
900
-IC(mA)
-IC(mA)
Fig 1
or
100
TA = 25℃
200
nd
uc
t
hFE
300
VCE = -1V
700
TA = 150℃
200
TA = -55 ℃
0.1
1
10
100
1000
Fig 5
1
10
100
1000
-IC(mA)
-IC(mA)
VCE(sat) vs. IC
Fig 6 VBE(sat) vs. IC
www.jsmsemi.com
第3页,共4页
BC807-16/-25/-40
Package Outline Dimensions (Unit: mm)
A
SOT-23
K
Dimension
Min.
Max.
A
2.70
3.10
B
1.10
1.50
C
0.9
1.1
D
0.3
0.5
E
0.35
0.48
G
1.80
2.00
H
0.02
0.1
J
0.05
0.15
K
2.20
2.60
B
J
D
G
0.95
Se
0.95
mi
co
SOT-23
nd
uc
t
H
C
or
E
2.00
CR
O
0.90
JS
MI
0.80
www.jsmsemi.com
第4页,共4页
很抱歉,暂时无法提供与“BC807”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.07210
- 500+0.05838
- 3000+0.04649
- 6000+0.04192
- 24000+0.03801
- 45000+0.03585
