PS2801-4
PS2801-4
    ISOCOMMICRON(安芯微)
    SO16_10.3X4.55MM_SM
    光电耦合器 正向电压:1.4V SO16_10.3X4.55MM_SM 隔离电压:3.75KV
PS2801-4 数据手册
ISOCOM MICRON SEMICONDUCTOR CO., LTD PS2801x-4 Series SCHEMATIC Description The PS2801x-4 series combine an AlGaAs infrared emitting diode as the emitter which is optically coupled to a silicon planar phototransistor detector in a plastic SO16 package with different lead forming options. With the robust coplanar double mold structure, PIN DEFINITION 1,3,5,7 : Anode 2,4,6,8 : Cathode 9,11,13,15: Emitter 10,12,14,16: Collector PACKAGE OUTLINE PS2801x-4 series provide the most stable isolation feature. Features ⚫ High isolation 3750 VRMS ⚫ CTR flexibility available see order information ⚫ DC input with transistor output ⚫ Operating temperature range - 55 °C to 110 °C ⚫ REACH compliance ⚫ Halogen free ⚫ MSL class 1 Applications • Switch mode power supplies • Programmable controllers • Household appliances • Office equipment Rev: V02 Release Date: 2022/1/17 11 ISOCOM MICRON SEMICONDUCTOR CO., LTD PS2801x-4 Series ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL VALUE UNIT NOTE INPUT Forward Current IF 60 mA Peak Forward Current IFP 1 A Reverse Voltage VR 6 V Input Power Dissipation PI 100 mW Collector - Emitter Voltage VCEO 80 V Emitter - Collector Voltage VECO 7 V Collector Current IC 50 mA Output Power Dissipation PO 150 mW Total Power Dissipation Ptot 200 mW Isolation Voltage Viso 3750 Vrms Operating Temperature Topr -55~110 °C Storage Temperature Tstg -55~125 °C Soldering Temperature Tsol 260 °C 1 OUTPUT COMMON 2 Note 1. 100μs pulse, 100Hz frequency Note 2. AC For 1 Minute, R.H. = 40 ~ 60% Rev: V02 Release Date: 2022/1/17 22 ISOCOM MICRON SEMICONDUCTOR CO., LTD PS2801x-4 Series ELECTRICAL OPTICAL CHARACTERISTICS at Ta=25°C PARAMETER SYMBOL MIN TYP. MAX. UNIT TEST CONDITION NOTE INPUT Forward Voltage VF - - 1.4 V IF=10mA Reverse Current IR - - 10 μA VR=6V Input Capacitance Cin - 10 - pF V=0, f=1kHz OUTPUT Collector Dark Current ICEO - - 100 nA VCE=20V, IF=0 Collector-Emitter Breakdown Voltage BVCEO 80 - - V IC=0.1mA, IF=0 Emitter-Collector Breakdown Voltage BVECO 7 - - V IE=0.1mA, IF=0 TRANSFER CHARACTERISTICS PS2801-4 Current PS2801C-4 Transfer Ratio 80 - 600 100 - 400 CTR % IF=5mA, VCE=5V 0.2 V IF=10mA, IC=1mA - Ω DC500V, 40 ~ 60% R.H. Collector-Emitter Saturation Voltage VCE(sat) Isolation Resistance RISO Floating Capacitance CIO - 0.4 1 pF V=0, f=1MHz Response Time (Rise) tr - 3 18 μs Response Time (Fall) tf - 4 18 μs VCE=2V, IC=2mA RL=100Ω Cut-off Frequency fc - 80 - kHz - 0.1 10^12 10^14 VCE=2V, IC=2mA RL=100Ω,-3dB 3 3 4 Note 3. Fig.12&13 Note 4. Fig.14 Rev: V02 Release Date: 2022/1/17 33 ISOCOM MICRON SEMICONDUCTOR CO., LTD PS2801x-4 Series CHARACTERISTIC CURVES Fig.1 Forward Current Fig.2 Collector Power Dissipation vs. Ambient Temperature vs. Ambient Temperature Fig.3 Forward Current vs. Forward Voltage Fig.4 Collector Dark Current vs. Ambient Temperature Fig.5 Collector Current vs. Collector-emitter Voltage Fig.6 Collector Current vs. Collector-emitter Voltage Rev: V02 Release Date: 2022/1/17 44 ISOCOM MICRON SEMICONDUCTOR CO., LTD PS2801x-4 Series CHARACTERISTIC CURVES Fig.7 Normalized Current Transfer Ratio Fig.8 Normalized Current Transfer Ratio vs. Forward Current vs. Ambient Temperature Fig.9 Collector-emitter Saturation Voltage vs. Ambient Temperature Fig.10 Switching Time vs. Load Resistance Fig.11 Frequency Response Rev: V02 Release Date: 2022/1/17 55 ISOCOM MICRON SEMICONDUCTOR CO., LTD PS2801x-4 Series TEST CIRCUITS Fig.12 Test Circuits of Response Time Fig.13 Curves of Response Time Fig.14 Test Circuits of Frequency Response Rev: V02 Release Date: 2022/1/17 66 ISOCOM MICRON SEMICONDUCTOR CO., LTD PS2801x-4 Series PACKAGE DIMENSIONS (Dimensions in mm unless otherwise stated) Recommended Solder Mask (Dimensions in mm unless otherwise stated) Rev: V02 Release Date: 2022/1/17 77 ISOCOM MICRON SEMICONDUCTOR CO., LTD PS2801x-4 Series CARRIER TAPE SPECIFICATIONS (Dimensions in mm unless otherwise stated) Option T1 Description Symbol Dimension mm (inch) Tape Width W 16 ± 0.3 (0.63) Pitch of Sprocket Holes P0 4 ± 0.1 (0.15) Distance of Compartment to Sprocket Holes F 7.5 ± 0.1 (0.295) P2 2 ± 0.1 (0.079) P1 12 ± 0.1 (0.47) Distance of Compartment to Compartment Rev: V02 Release Date: 2022/1/17 88 ISOCOM MICRON SEMICONDUCTOR CO., LTD PS2801x-4 Series ORDERING AND MARKING INFORMATION MARKING INFORMATION 2801 THP4:Part Number I: ISOCOM MICRON Y: WW: denotes 2 digit Year code denotes 2 digit Week code ORDERING INFORMATION PS2801x-4 2801 THP4 – Part Number – CTR Rank (C/None) X PACKING QUANTITY Option Quantity Quantity – Inner box Quantity – Outer box T1 2000 Units/Reel 1 Reels/Inner box 5 Inner box/Outer box = 10k Units Rev: V02 Release Date: 2022/1/17 99 ISOCOM MICRON SEMICONDUCTOR CO., LTD PS2801x-4 Series REFLOW INFORMATION REFLOW PROFILE Profile Feature Sn-Pb Assembly Profile Pb-Free Assembly Profile Temperature Min. (Tsmin) 100 150°C Temperature Max. (Tsmax) 150 200°C Time (ts) from (Tsmin to Tsmax) 60-120 seconds 60-120 seconds Ramp-up Rate (tL to tP) 3°C/second max. 3°C/second max. Liquidous Temperature (TL) 183°C 217°C Time (tL) Maintained Above (TL) 60 – 150 seconds 60 – 150 seconds Peak Body Package Temperature 235°C +0°C / -5°C 260°C +0°C / -5°C Time (tP) within 5°C of 260°C 20 seconds 30 seconds Ramp-down Rate (TP to TL) 6°C/second max 6°C/second max Time 25°C to Peak Temperature 6 minutes max. 8 minutes max. Rev: V02 Release Date: 2022/1/17 10 10 ISOCOM MICRON SEMICONDUCTOR CO., LTD PS2801x-4 Series TEMPERATURE PROFILE OF SOLDERING WAVE SOLDERING (JESD22-A111 COMPLIANT) HAND SOLDERING BY SOLDERING IRON • • Soldering Temperature 380+0/-5°C Soldering Time 3 sec max. One time soldering is recommended for all soldering method. Do not solder more than three times for IR reflow soldering. Rev: V02 Release Date: 2022/1/17 11 11 ISOCOM MICRON SEMICONDUCTOR CO., LTD PS2801x-4 Series DISCLAIMER ⚫ ISOCOM MICRON is continually improving the quality, reliability, function and design. ISOCOM MICRON reserves the right to make changes without further notices. ⚫ The characteristic curves shown in this datasheet are representing typical performance which are not guaranteed. ⚫ ISOCOM MICRON makes no warranty, representation or guarantee regarding the suitability of the products for any particular purpose or the continuing production of any product. To the maximum extent permitted by applicable law, ISOCOM MICRON disclaims (a) any and all liability arising out of the application or use of any product, (b) any and all liability, including without limitation special, consequential or incidental damages, and (c) any and all implied warranties, including warranties of fitness for particular ⚫ The products shown in this publication are designed for the general use in electronic applications such as office automation, equipment, communications devices, audio/visual equipment, electrical application and instrumentation purpose, non-infringement and merchantability. ⚫ This product is not intended to be used for military, aircraft, automotive, medical, life sustaining or lifesaving applications or any other application which can result in human injury or death. ⚫ Please contact ISOCOM MICRON sales agent for special application request. ⚫ Immerge unit’s body in solder paste is not recommended. ⚫ Parameters provided in datasheets may vary in different applications and performance may vary over time. All operating parameters, including typical parameters, must be validated in each customer application by the customer’s technical experts. Product specifications do not expand or otherwise modify ISOCOM MICRON’s terms and conditions of purchase, including but not limited to the warranty expressed therein. ⚫ Discoloration might be occurred on the package surface after soldering, reflow or long-time use. It neither impacts the performance nor reliability. Rev: V02 Release Date: 2022/1/17 12 12
PS2801-4 价格&库存
很抱歉,暂时无法提供与“PS2801-4”相匹配的价格&库存,您可以联系我们找货
PS2801-4
  • 1+2.31183
  • 30+2.23183
  • 100+2.15183
  • 500+1.99183
  • 1000+1.91183
  • 2000+1.86383
库存:857
