PF051101DG1CBNAD042
PF051101DG1CBNAD042
    WELL-JET(威尔杰)
    CONN_25.4X2.5MM_TM
    排针 间距2.54mm 10Pin(1x10) 镀金 直插
PF051101DG1CBNAD042 数据手册
REVISION DATA 1 2 REV DESCRIPTION DATE A0 NEW DRAWING 2023-03-17 Specification 3 Material: Contact Material: Brass Contact plating: Au or Sn Over30-50u" Ni Insulator Material: Black Polyester UL94V-0 Standard: PBT/PA6T/PA9T/LCP+30%G.F Electrical: Current rating: 3.0Amps/contact max. Contact resistance: ≤20mΩ/contact Insulation resistance: ≥1000MΩ at V=100V Withstanding Voltage: 1000V AC/minute Mechanical: Operaing temperature: -40°C to +105°C Wave soldering temperature: 255±5°C,10s P.C.B LAYOUT PF05 1XX1 D Product Descriptions PF05 H2.5 W2.5 No. of Positions 02-40P XX X B N A Angle Type Contact Plated D Straight SN MT GF G1 G3 G4 G6 G7 G8 GA S1 Insulator Material A PBT C PA6T E PA9T F LCP Insulator Color B Black Insulator Feature N Without Peg Packing Options A PE Bag Tin120u" 雾锡120u" Gold 0.8u" Au1u" Au3u" Au5u" Au10u" Au15u" Au30u" Au1.5u" 半金锡 1u" D042 Series No. D042 L11.2mm PA5.8 PC2.9 TOLERANCE ANGLE ±5° X.XXX ±0.10 X.XX ±0.20 X.X ±0.30 X. ±0.50 2 TITLE: PROJECTON DATE : DRAWN : CHECKED : APPROVED : 单排180度排针 PH2.54 H2.5 L11.2 PA5.8 PC2.9 2023-03-17 SAMTEK PART NO. PF051XX1DXXXBNAD042 DRAWING NO. REV: A0 UNIT: 1 mm SCALE: 3:1 SIZE: A4
PF051101DG1CBNAD042 价格&库存
很抱歉,暂时无法提供与“PF051101DG1CBNAD042”相匹配的价格&库存,您可以联系我们找货
