PTVSLC3D8VB
PTVSLC3D8VB
    PRISEMI(上海芯导电子)
    SOD-323
    ESD抑制器/TVS二极管 VRWM=8V VBR(Min)=8.5V VC=31.6V@18A SOD323
PTVSLC3D8VB 数据手册
PTVSLC3D8VB Low Capacitance TVS Description The PTVSLC3D8VB is a low capacitance transient voltage suppressor for high speed data interface that designed to protect sensitive electronics from damage or latch-up due to ESD lightning, and other voltage induced transient events. All pins are rated to withstand 15kV ESD pulses using the IEC61000-4-2 air discharge method, which can meet the requirement of level 4. Applications Feature  350W peak pulse power per line (tP = 8/20μs)  Ethernet – 10/100/1000 Base T  SOD-323 package  Cellular phones  Replacement for MLV(0805)  Handheld-wireless systems  Bidirectional configurations  PDAs  Protects one power or I/O port  USB interface  Low clamping voltage  RoHS compliant  Transient protection for data lines to IEC61000-4-2(ESD) ±30kV(air), ±30kV(contact); IEC61000-4-4 (EFT) 80A (5/50ns) Mechanical Characteristics  Lead finish:100% matte Sn(Tin)  Mounting position: Any  Qualified max reflow temperature:260℃  Pure tin plating: 7 ~ 17 um  Pin flatness:≤3mil Electronics Parameter Symbol VRWM IR VBR Rev.06.2 Parameter Peak Reverse Working Voltage IPP Reverse Leakage Current @ VRWM I Breakdown Voltage @ IT IT Test Current IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP PPP Peak Pulse Power CJ Junction Capacitance IF Forward Current VF Forward Voltage @ IF VC VBR VRWM IT IR V IR IT VRWM VBR VC IPP 1 www.prisemi.com Low Capacitance TVS PTVSLC3D8VB Electrical characteristics per line@25℃( unless otherwise specified) Parameter Symbol Peak Reverse Working Voltage Conditions Min. Typ. VRWM Breakdown Voltage Max. Units 8 V VBR It = 1mA Reverse Leakage Current IR VRWM = 8V T=25℃ 1.0 μA Clamping Voltage VC IPP = 1A tP = 8/20μs 13.0 V Clamping Voltage VC IPP=18A tP = 8/20μs 31.6 V Junction Capacitance Cj VR=0V 8.5 f = 1MHz V 4.5 pF Absolute maximum rating@25℃ Rating Symbol Value Units Peak Pulse Power (tp=8/20μs) Ppp 350 W Operating Temperature TJ -55 to +150 ℃ TSTG -55 to +150 ℃ Storage Temperature Typical Characteristics 100 % Of Rated Power IPP – Peak Pulse Current - % of IPP tf=8μs 100 80 60 tP =20μs(IPP /2) 40 20 0 80 60 40 20 0 5 10 15 t - Time -μs 20 25 0 30 Fig 1.Pulse Waveform Rev.06.2 0 25 50 75 100 125 TL – Lead Temperature - ℃ 150 Fig 2.Power Derating Curve 2 www.prisemi.com Low Capacitance TVS PTVSLC3D8VB 10000 40 Pulse waveform: tp=8/20us 1000 Peak Pulse Power (W) VC-Clamping Voltage (V) 32 24 16 100 8 10 0 5 10 15 20 IPP-Peak pulse current(A) 25 30 Fig 3. Clamping voltage vs. Peak pulse current 1 10 100 Pulse Duration(us) 1000 Fig 4. Non Repetitive Peak Pulse Power vs. Pulse time Solder Reflow Recommendation Peak Temp=257℃, Ramp Rate=0.802deg. ℃/sec 280 240 200 160 120 80 40 0 0 30 60 90 120 150 180 240 210 270 300 330 360 390 420 450 480 Time (sec) PCB Design For TVS diodes a low-ohmic and low-inductive path to chassis earth is absolutely mandatory in order to achieve good ESD protection. Novices in the area of ESD protection should take following suggestions to heart:  Do not use stubs, but place the cathode of the TVS diode directly on the signal trace.  Do not make false economies and save copper for the ground connection.  Place via holes to ground as close as possible to the anode of the TVS diode.  Use as many via holes as possible for the ground connection.  Keep the length of via holes in mind! The longer the more inductance they will have. Rev.06.2 3 www.prisemi.com Low Capacitance TVS PTVSLC3D8VB Product dimension (SOD-323) C Dim A E B F D H Inches Millimeters MIN MAX MIN MAX A 0.063 0.075 1.60 1.90 B 0.045 0.057 1.15 1.45 C 0.090 0.106 2.30 2.70 D 0.031 0.043 0.80 1.00 E 0.010 0.01 0.25 0.40 F 0.004 0.007 0.09 0.18 H 0.000 0.004 0.00 0.10 3.00 0.90 0.80 Suggested PCB Layout Unit:mm Marking information HC Ordering information Device Package Reel Shipping PTVSLC3D8VB SOD-323 (Pb-Free) 7" 3000 / Tape & Reel Rev.06.2 4 www.prisemi.com Low Capacitance TVS PTVSLC3D8VB IMPORTANT NOTICE and are registered trademarks of Prisemi Electronics Co., Ltd (Prisemi) ,Prisemi reserves the right to make changes without further notice to any products herein. Prisemi makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does Prisemi assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. “Typical” parameters which may be provided in Prisemi data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. Prisemi does not convey any license under its patent rights nor the rights of others. The products listed in this document are designed to be used with ordinary electronic equipment or devices, Should you intend to use these products with equipment or devices which require an extremely high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), please be sure to consult with our sales representative in advance. Website: http://www.prisemi.com For additional information, please contact your local Sales Representative. ©Copyright 2009, Prisemi Electronics is a registered trademark of Prisemi Electronics. All rights are reserved. Rev.06.2 5 www.prisemi.com
PTVSLC3D8VB 价格&库存
很抱歉,暂时无法提供与“PTVSLC3D8VB”相匹配的价格&库存,您可以联系我们找货
PTVSLC3D8VB
  • 5+0.33151
  • 20+0.30226
  • 100+0.27301
  • 500+0.24375
  • 1000+0.23010
  • 2000+0.22035
