ZMM1PF...ZMM75PF
Silicon Epitaxial Planar Zener Diodes
MiniMELF case especially for automatic insertion. The
Zener voltages are graded according to the
international E24 standard. Smaller voltage tolerances
and higher Zener voltages are upon request.
LL-34
These diodes are also available in DO-35 case with
the type designation BZX55C...
Features
• Lead Free
Absolute Maximum Ratings (Ta = 25℃)
Parameter
Power Dissipation
1)
Junction Temperature
Storage Temperature Range
Thermal Characteristics
Parameter
Thermal Resistance Junction to Ambient
1)
1)
Symbol
Value
Unit
Ptot
500
mW
Tj
175
Tstg
- 55 to + 175
Symbol
Max.
Unit
RθJA
300
℃/W
Valid provided that electrodes are kept at ambient temperature.
1/3
Dated :25/08/2021 Rev:02
ZMM1PF...ZMM75PF
Characteristics at Ta = 25℃ (VF max : 1 V at IF = 100 mA)
Zener Voltage Range
Type
VZnom
2)
ZMM1PF
1)
Dynamic Resistance
Reverse Leakage Current
Temp. Coefficient
of Zener Voltage
VZT
at lZT
ZZT at IZT
ZZK
at IZK
Ta = 25℃
Ta = 125℃
at VR
(V)
(V)
(mA)
Max. (Ω)
Max. (Ω)
(mA)
Max. (µA)
Max. (µA)
(V)
TKvz (%/K)
0.75
0.7...0.8
5
8
50
1
-0.26...-0.23
ZMM2V0PF
2
1.8...2.15
5
85
600
1
100
200
1
-0.09...-0.06
ZMM2V2PF
2.2
2.08...2.33
5
85
600
1
75
160
1
-0.09...-0.06
ZMM2V4PF
2.4
2.28...2.56
5
85
600
1
50
100
1
-0.09...-0.06
ZMM2V7PF
2.7
2.5...2.9
5
85
600
1
10
50
1
-0.09...-0.06
ZMM3V0PF
3
2.8...3.2
5
85
600
1
4
40
1
-0.08...-0.05
ZMM3V3PF
3.3
3.1...3.5
5
85
600
1
2
40
1
-0.08...-0.05
ZMM3V6PF
3.6
3.4...3.8
5
85
600
1
2
40
1
-0.08...-0.05
ZMM3V9PF
3.9
3.7...4.1
5
85
600
1
2
40
1
-0.08...-0.05
ZMM4V3PF
4.3
4...4.6
5
75
600
1
1
-0.06...-0.03
ZMM4V7PF
4.7
4.4...5
5
60
600
1
0.5
10
1
-0.05...+0.02
ZMM5V1PF
5.1
4.8...5.4
5
35
550
1
0.1
2
1
-0.02...+0.02
ZMM5V6PF
5.6
5.2...6
5
25
450
1
0.1
2
1
-0.05...+0.05
ZMM6V2PF
6.2
5.8...6.6
5
10
200
1
0.1
2
2
0.03...0.06
ZMM6V8PF
6.8
6.4...7.2
5
8
150
1
0.1
2
3
0.03...0.07
ZMM7V5PF
7.5
7...7.9
5
7
50
1
0.1
2
5
0.03...0.07
ZMM8V2PF
8.2
7.7...8.7
5
7
50
1
0.1
2
6.2
0.03...0.08
ZMM9V1PF
9.1
8.5...9.6
5
10
50
1
0.1
2
6.8
0.03...0.09
ZMM10PF
10
9.4...10.6
5
15
70
1
0.1
2
7.5
0.03...0.1
ZMM11PF
11
10.4...11.6
5
1
0.1
2
8.2
0.03...0.11
ZMM12PF
12
11.4...12.7
5
1
0.1
2
9.1
0.03...0.11
ZMM13PF
13
12.4...14.1
5
26
110
1
0.1
2
10
0.03...0.11
ZMM15PF
15
13.8...15.6
5
30
110
1
0.1
2
11
0.03...0.11
ZMM16PF
16
15.3...17.1
5
40
170
1
0.1
2
12
0.03...0.11
ZMM18PF
18
16.8...19.1
5
50
170
1
0.1
2
13
0.03...0.11
ZMM20PF
5
55
220
1
0.1
2
15
0.03...0.11
ZMM22PF
22
20.8...23.3
5
55
220
1
0.1
2
16
0.04...0.12
ZMM24PF
24
22.8...25.6
5
80
220
1
0.1
2
18
0.04...0.12
ZMM27PF
27
25.1...28.9
5
80
220
1
0.1
2
ZMM30PF
30
28...32
5
80
220
1
0.1
2
22
0.04...0.12
ZMM33PF
33
31...35
5
80
220
1
0.1
2
24
0.04...0.12
ZMM36PF
36
34...38
5
80
220
1
0.1
2
27
0.04...0.12
ZMM39PF
39
37...41
2.5
90
500
0.5
0.1
5
30
0.04...0.12
ZMM43PF
43
40...46
2.5
90
500
0.5
0.1
5
33
0.04...0.12
ZMM47PF
47
44...50
2.5
110
600
0.5
0.1
5
36
0.04...0.12
ZMM51PF
51
48...54
2.5
125
700
0.5
0.1
10
39
0.04...0.12
ZMM56PF
56
52...60
2.5
135
700
0.5
0.1
10
43
0.04...0.12
ZMM62PF
62
58...66
2.5
150
1000
0.5
0.1
10
47
0.04...0.12
ZMM68PF
68
64...72
2.5
200
1000
0.5
0.1
10
51
0.04...0.12
ZMM75PF
75
70...79
2.5
250
1000
0.5
0.1
10
56
0.04...0.12
1)
2)
Tested with pulses tp = 20 ms.
The ZMM1 is a silicon diode with operation in forward direction. Hence, the index of all parameters should be "F" instead of "Z". Connect
the cathode electrode to the negative pole.
2/3
ZMM1PF...ZMM75PF
Electrical Characteristics Curves
Fig 2. Zener Characteristics Curve
Zener Current (mA)
Zener Current (mA)
Fig 1. Zener Characteristics Curve
Zener Voltage (V)
Zener Voltage (V)
Fig 3. Zener Characteristics Curve
Zener Current (mA)
Forward Current (mA)
Fig 4. Forward Characteristics Curve
Zener Voltage (V)
Forward Voltage (V)
Fig 5. Power Derating Curve
Power Dissipation (mW)
500
400
300
200
100
100
150
200
Ambient Temperature (℃)
3/3
很抱歉,暂时无法提供与“ZMM5V1PF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.07958
- 50+0.07268
- 500+0.06348
- 1000+0.05658
- 2500+0.05336
