HD014P-1AH-F-C 12VDC
    SONGCHUAN(松川)
    RELAY_35.3X31.6MM_TM
    功率继电器 12VDC 266.6mA 3.2W
HD014P-1AH-F-C 12VDC 数据手册
HD014 Features 特点 □ High voltage DC load control. 高电压DC负载控制。 □ High performance DC relay for photovoltaic power generation systems, energy storage system and xEV charging device, etc. 高性能DC继电器,适用于太阳能发电系统、储能系统、xEV充电设备等。 □ RoHS Compliant. 符合RoHS。 Type List 型号列表 Terminal style Contact form 引出端形状 触点形状 Designation (provided with) 分类名称 Flux tight 防助焊剂型 PCB terminal PCB 用引出端 1A (SPDM) HD014P-1AH-F-C Ordering Information 型号命名 HD014 1 P 2 - 1A 3 H 4 - F 5 - 1. HD014 -- Basic series designation C 6 □ 7 5. F -- Class F F级绝缘 -- PCB terminal PCB用引出端 6. C -- Flux tight -- Form A, single-pole, double-make (SPDM) 7. □ 基本型号 2. P 3. 1A 防助焊剂型 常开触点,一组动合(SPDM) -- Coil voltage (please refer to the coil rating data for the availability) 线圈电压(请参考线圈参数) 4. H -- Contact material Ag alloy 銀合金触点 Contact Rating 触点额定负载 ♦ Each 1 form A contact 单一常开触点 Rated load (Resistive) 阻性负载 30A 450VDC, On 1s/ Off 19s, 5000 ops. 40A 450VDC, On 1s/ Off 19s, 1000 ops. Breaking voltage Max. 450VDC 断开电压 Continuous carrying current Max. 40A 连续通电电流 ♦ Each 1 form A contact connected in series 串联常开触点 Rated load (Resistive) 阻性负载 Breaking voltage 断开电压 Continuous carrying current 连续通电电流 20A 1000VDC, On 1s/ Off 19s, 5 ops. 25A 800VDC, On 1s/ Off 19s, 50 ops. 30A 660VDC, On 1s/ Off 19s, 300 ops. 30A 500VDC, On 1s/ Off 19s, 500 ops. Max. 1000VDC Max. 40A 67 HD014 Notes : (1) Reference circuit for above series connection, please refer to figure 1. 上述串联请参见图1参考回路图。 (2) With above 2 cm mounting distance between two relays. 两个继电器安装距离间隔2公分以上。 (3) Coil terminal with polarity sensitivity, please follow the layout instruction. 线轮端子带极性,请参见接线图。 ♦ Figure 1 图1 Current (-) Power supply Load Power supply (+) (+) (-) Current Coil Rating 线圈参数 (DC) Rated voltage 额定 电压 Rated current Coil resistance 额定电流 线圈电阻 Pick up voltage (Max.) Drop out voltage (Min.) Continuous voltage 吸合电压 (最大值) 释放电压 (最小值) at 85°C (2) 75 % of rated voltage 5 % of rated voltage 35~40 % of rated voltage 额定电压 的80% 额定电压 的5% 额定电压的 45~55% ±10 % at 23°C ±10 % at 23°C (mA) (Ω) (V) 12 266.6 45 at 23°C (1) at 23°C 持续电压 Power consumption at rated / holding voltage 额定/保持电压 功耗 approx. 约 3.2W / 0.39W (2) Notes : (1) To energize relay properly apply 100%~120% nominal coil voltage for 200ms. 继电器施加全额线圈电压的100%~120%维持200毫秒。 (2) Coil holding voltage is 35~40% of nominal voltage after applying nominal voltage for 200ms. 线圈保持电压是全额线圈电压维持200毫秒后,降至全额线圈电压的35~40%。 Specification 技术参数 Contact material Ag alloy 触点材料 银合金 Contact gap 触点间距 Voltage drop (1) 接触压降 (1) Operate time (1) 吸合时间 (1) Release time (1) 释放时间 (1) Vibration resistance 振动 ≥ 4.0mm Typ. 40mV at 10A 30ms Max. 15ms Max. Operating extremes 稳定工作 Damage limits 10~500Hz, 5.0G 损坏极限 Shock resistance 冲击 Operating extremes 稳定工作 Damage limits 损坏极限 Life expectancy Mechanical 预期寿命 机械 Operating ambient temperature 工作环境温度 Weight 重量 68 10~500Hz, 5.0G 10G 100G 500,000 ops. (frequency 动作频率 9,000 ops./hr) -40~+105°C (no freezing 不结冰) Approx. 约65 g HD014 Notes : (1) Initial value. Operate and release time excluding contact bounce. 初始值。吸合/释放时间不包含触点弹跳时间。 (2) Coil and contact sides with polarities (+) and (-). 线圈和触点负载端带有正(+)负(-)极性。 (3) Unless otherwise specified, all tests are under room temperature and humidity. 所有测试皆在常温常湿下执行。 (4) Consider the heat of PCB is necessary, please check the actual condition of PCB. 必须考虑PC板温度,请检查实际PC板条件状态。 (5) Applying no diode to this relay. The life expectancy will be lower when a diode is used. To use a varistor (ZNR) could absorb the coil surge of relay that is recommended. 禁用二极管。若使用二极管会缩短预期寿命。建议使用突波吸收器(ZNR)来吸收继电器的线圈脉冲。 (6) Do not use the relay exceeding the coil rating, contact rating and life expectancy, or this may cause the risk of overheating. 使用继电器请勿超过线圈规格负载、触点额定负载和预期寿命,否则可能会造成过热的风险。 (7) To assure optimum performance, avoid the relay from dropping, hitting, or other unnecessary shocks. 为保障继电器的理想性能,请避免继电器遭受摔落、碰撞,以及不必要的冲击。 (8) To avoid mounting the relay in strong magnetic fields (near a transformer or magnet) or close to an object that radiates heat. 请避免将继电器安装在具有强烈磁场环境(例如变压器或磁铁附近),或是靠近发热源。 (9) Please pay attention to the phenomenon of freezing in the low temperature environment below 0°C. Please evaluate the actual use of the environment. 请注意0​​°C以下的低温环境中之结冰现象,并请评估环境的实际使用情况是否可能发生结冰。 (10) Please contact Song Chuan for the detailed information. 详细内容请与松川公司联系。 Insulation Data 绝缘参数 Insulation resistance (1) 绝缘电阻 (1) Dielectric strength (1) 介质耐压 (1) 100MΩ Min. (DC 500V) Between open contact 开路触点间 Between contact and coil 触点线圈间 : AC 2000V, 50/60Hz 1 min. : AC 2500V, 50/60Hz 1 min. Insulation of IEC 61810-1 / IEC 61810-1绝缘 Between coil to contact 触点线圈间 Between open contact 开路触点间 Rated insulation voltage 额定绝缘电压 Rated impulse withstand voltage 额定脉冲耐电压 Pollution degree 污染等级 Rated voltage : Basic 基本, ≥ 5.5mm / ≥ 4.5mm(for 450VDC) ≥ 5.5mm / ≥ 6.0mm(for 600VDC) ≥ 5.5mm / ≥ 10.0mm(for 1000VDC) : Functional 功能性 450, 600, 1000V 6000V 2 230/400/690/1000V 额定电压 Overvoltage category 过电压类别 II Notes : (1) Initial value. 初始值。 Safety Approval 安规认证 Certified UL / CUL TUV File No. E88991 R50387771 69 HD014 Safety Approval Rating 安规认证负载 UL / CUL TYPE: HD013, HD014,HD015 TUV TYPE: HD013, 12A 600VDC, Carrying current HD014,HD015 40A Making 12A , Carrying 40A , Breaking 12A /600VDC T105 40A 600VDC 40A 600VDC ; T105 TYPE: HD013, HD014,HD015 Outline Dimensions 20A 1000VDC, Carrying current 40A 20A 1000VDC ; T105 (1) (1) (1) (1) Outline Dimensions ◆ HD013P (-C cover type) → HD013的小標題 Notes : (1) Operating in a series connection. ◆ HD013P Outline Dimensions 于串联工作环境下。 ◆ HD015P (-C (-C cover cover type) type) → → HD013的小標題 HD015的小標題 1.5 33.5 (1.318) 33.5 (1.318) 33.5 (0.059) 1.5 1(+) Contact 2(-) terminal Contact terminal 2(-) Contact terminal 23 (0.905) 23 20 20 35.3 35.335.3 (1.389) (1.389) (1.389) (0.157) 1(+) Contact 2(-) terminal Contact terminal (0.905) 23 (0.905) 15 (0.590) 15 5(-) Coil (0.590) terminal 15 5(-) Coil terminal (0.059) 1.5 (0.059) (0.590) (1.318) 20 4-4 1(+) Contact terminal 6(+) Coil terminal 6(+) Coil terminal BOTTOM VIEW 1(+) 2(-) 1(+) 2(-) 1(+) 2(-) 5(-) 6(+) TOLERANCE: LESS THAN: 1(0.039) ±0.1(0.004) 6(+) Coil terminal TOLERANCE: 5(0.197) ±0.3(0.012) 5(-) Coil terminal Wiring Diagram Wiring Diagram BOTTOM VIEW Wiring Diagram 接线图 BOTTOM VIEW Wiring (Bottom viewDiagram 底视) (0.787) (0.787) (0.787) (0.157) (0.062) (0.062) (0.062) 1.6-21.6-2 1.6-2 (0.157) 4-4 6.3-2 0.8-40.8-4 0.8-4 6.3-26.3-2 4-4 (0.031) (0.031) (0.031) (0.248) (0.248) (0.248) 31.6 31.631.6 (1.244) (1.244) (1.244) HD013P (-C cover type) → HD013的小標題 ◆ HD015P HD015的小標題 Outline Dimensions 外形尺寸 ◆ HD015P (-C cover type) → HD015的小標題 ♦ HD015P (-C cover type) (-C外盖型式) LESS THAN: 20(0.787) 1(0.039) ±0.1(0.004) ±0.5(0.020) 5(0.197) ±1(0.039) ±0.3(0.012) MORE THAN: 20(0.787) TOLERANCE: 20(0.787) ±0.5(0.020) TOLERANCE: LESS THAN: 1(0.039) ±0.1(0.004) MORE THAN: 20(0.787) ±1(0.039) LESS THAN: 1(0.039) ±0.1(0.004) 5(0.197) ±0.3(0.012) 20(0.787) ±0.5(0.020) 5(0.197) ±0.3(0.012) MORE THAN: 20(0.787) ±1(0.039) 20(0.787) ±0.5(0.020) MORE THAN: 20(0.787) ±1(0.039) 6(+) 5(-) Load sides and coil terminals are with polarities (+) and (-). 5(-) are6(+) Load sides and coil terminals with polarities (+) and (-). Load sides and coil terminals are with polarities (+) and (-). □ 6.7x1.2 (0.263x0.047) □ 2.0x1.2 (0.078x0.047) □ 2.0x1.2 (0.078x0.047) □ 2.0x1.2 8.4 8.4 8.4 □ 6.7x1.2 (0.159) 4.3 (0.263x0.047) □ 6.7x1.2 (0.159) (0.263x0.047) (0.905) 23 (0.905) 1(+) 2(-) 1(+) 5(-) 1(+) 5(-) 2(-) 6(+) 2(-) 6(+) 5(-) 15 6(+) (0.330) (0.330) (0.330) 23 (0.905) 23 20 20 4.3 (0.159) 4.3 20 PC Board Layout PC板开孔图 BOTTOM VIEW (Bottom view 底视) Load线圈和触点负载端带有正(+)负(-)极性。 sides and coil terminals are with polarities (+) and (-). (0.787) (0.787) (0.787) PC Board Layout PC Board BOTTOM VIEWLayout BOTTOM VIEWLayout PC Board (0.590) 15 (0.590) 15 is for reference only; and further, the user should be in a right (0.078x0.047) All specifications subject to change without notice. This specification (0.590) position to choose the suitable product for their own application. Please contact Song Chuan for the technical service. 规格变更不另行通知。 本产品规格书仅提供客户参考,具体选型应依客户使用条件选择与其相匹配的产品,请联系松川以便获取更多技术支持。 70
HD014P-1AH-F-C 12VDC 价格&库存
很抱歉,暂时无法提供与“HD014P-1AH-F-C 12VDC”相匹配的价格&库存,您可以联系我们找货
