CHM-9R0L155R-TW
CHM-9R0L155R-TW
    CDA(智烽维)
    CAP_26X9MM_TM
    超级电容器 CAP_26X9MM_TM 1.5F 9V
CHM-9R0L155R-TW 数据手册
● High power,high energy density ● Low leakage current, long life ● Plastic, Moisture Resistant Version ● Guaranteed 70℃ 5.5 V.DC 1000 h ● Guaranteed 85℃ 4.6 V.DC 1000 h ● Consumer electronics ● GSM/GPRS Pulse Applications ● Back up power ● Stand alone or augment existing ● energy/power source 5.5V Series Operating temperature -40°C to +65°C -40°C to +85°C 6.0V Series 7.5V Series 8.1V Series 9.0V Series Balanced Unbalanced Balanced Unbalanced Balanced Unbalanced Balanced Unbalanced Balanced Unbalanced 5.5V 5.1V 6.0V 5.6V 7.5V 7.1V 8.1V 7.7V 9.0V 8.6V 4.6V 4.2V 5.2V 4.8V 6.6V 6.2V 7.3V 6.9V 8.2V 7.8V *With appropriate voltage operating temperature can be extended to 85℃ Item Performance Storage temperature -40°C to +65°C Capacitance range 0.22F to 5.0F Capacitance tolerance -10%~+30%; -0%~+100% Rated voltage 5.5 V;7.5V;8.1V;9.0V High Temperature Load Life Temperature:+65℃ Voltage:Rated Voltage Test Duration:2,000 hours Endurance (At rated voltage & max. operating temp) After 2000 hours: Capacitance change: ±30% of initial rated value Internal resistance: Within 2 times of initial specified value Projected cycle life (From rated voltage to 1/2 rated voltage at 25°C) After 500,000 cycles: Capacitance change: Within ±30 % of initial rated value Internal resistance: Within 2 times of initial specified value Humidity Voltage:Rated Voltage RH:90% Temperature:++60℃ ; Test Duration:1,500 hours No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product, please be sure to contact our sales offices or agents immediately. Spec. Date:2021-04-10 L Type: H Type: For version with bent leads Rated Part Number Voltage (V) Rated Size Cap. (F) ФWxDxL D(mm) d(mm) P(mm) B(mm) 8 0.6 9.5 2.0 9 0.6 11.5 2.0 12 0.6 15.5 2.0 Max.ESR ESRAC (mm) (1kHz/mΩ) Maximum Maximum Endurance Peak Current(A) Current(A) Maximum Leakage Current (72hrs/mA) Power Density (W/Kg) Energy Maximum Energy (W.h) Density (Wh/kg) CHM-5R5L224R-TW 5.5 0.22 15X8X16 700 0.16 0.37 0.003 403.3 0.0009 0.31 CHM-5R5L334R-TW 5.5 0.33 18X9X16 600 0.21 0.51 0.003 398.0 0.0014 0.36 CHM-5R5L474R-TW 5.5 0.47 18X9X16 360 0.26 0.75 0.003 709.0 0.0020 0.62 CHM-5R5L474R-TWX 5.5 0.47 15X8X16 500 0.18 0.61 0.003 648.2 0.0020 0.71 CHM-5R5L105R-TW 5.5 1.0 18X9X20 240 0.44 1.59 0.006 938 0.0042 0.98 CHM-5R5L155R-TW 5.5 1.5 18X9X24 190 0.54 2.32 0.01 1171.0 0.0063 1.02 CHM-5R5L255R-TW 5.5 2.5 23X12X25 180 0.75 3.45 0.02 1114.2 0.0105 1.16 CHM-5R5L355R-TW 5.5 3.5 23X12X25 160 0.79 3.65 0.023 1078.4 0.0147 1.57 CHM-5R5L505R-TW 5.5 5.0 23X12X29 150 1.17 5.35 0.028 2063 0.0147 2.70 CHM-6R0L224R-TW 6.0 0.22 15X8X16 700 0.18 0.42 0.003 502.5 0.0013 0.42 CHM-6R0L334R-TW 6.0 0.33 18X9X16 600 0.26 0.58 0.003 614.3 0.0017 0.46 CHM-6R0L474R-TW 6.0 0.47 18X9X16 360 0.32 0.78 0.003 1029 0.0024 0.78 CHM-6R0L474R-TWX 6.0 0.47 15X8X16 500 0.25 0.69 0.003 1196 0.0024 0.85 CHM-6R0L105R-TW 6.0 1.0 18X9X20 240 0.51 1.72 0.006 1432 0.0042 1.12 CHM-6R0L155R-TW 6.0 1.5 18X9X24 190 0.59 2.45 0.01 1876 0.0075 2.03 CHM-6R0L255R-TW 6.0 2.5 23X12X25 180 0.81 3.59 0.02 2488 0.0125 2.42 No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product, please be sure to contact our sales offices or agents immediately. Spec. Date:2021-04-10 CHM-6R0L355R-TW 6.0 3.5 23X12X25 160 0.87 3.88 0.023 2762 0.0205 2.72 CHM-6R0L505R-TW 6.0 5.0 23X12X29 150 1.32 6.52 0.028 3151 0.0250 3.68 L Type: H Type: For version with bent leads Rated Part Number Voltage (V) Rated Size Cap. (F) ФWxDxL Max.ESR ESRAC (mm) (1kHz/mΩ) D(mm) d(mm) P(mm) B(mm) 9 0.6 13.5 2.0 Maximum Maximum Endurance Peak Current(A) Current(A) Maximum Leakage Current (72hrs/mA) Power Density (W/Kg) Energy Maximum Energy (W.h) Density (Wh/kg) CHM-7R5L334R-TW 7.5 0.33 26X9X16 600 0.26 0.75 0.006 511.4 0.0026 0.47 CHM-7R5L604R-TWX 7.5 0.6 26X9X16 460 0.26 1.04 0.008 544.8 0.0047 0.79 CHM-7R5L604R-TW 7.5 0.6 26X9X20 350 0.44 1.59 0.008 698.8 0.0047 0.68 CHM-7R5L105R-TW 7.5 1 26X9X24 285 0.54 2.32 0.01 1058.8 0.0078 0.92 CHM-8R1L334R-TW 8.1 0.33 26X9X16 540 0.26 0.75 0.003 627.8 0.0030 0.53 CHM-8R1L604R-TW 8.1 0.6 26X9X20 400 0.43 1.57 0.008 924.1 0.0055 0.77 CHM-8R1L105R-TW 8.1 1.0 26X9X24 350 0.53 2.28 0.01 914.4 0.0091 1.11 CHM-9R0L334R-TW 9.0 0.33 26X9X16 540 0.26 0.83 0.006 775.1 0.0037 0.65 CHM-9R0L604R-TW 9.0 0.6 26X9X20 400 0.43 1.74 0.01 1140.8 0.0068 0.95 CHM-9R0L105R-TW 9.0 1.0 26X9X24 350 0.53 2.53 0.014 1128.9 0.0113 1.37 CHM-9R0L155R-TW 9.0 1.5 26X9X24 300 0.54 3.13 0.014 1227.3 0.0169 1.92 Note: Adds passive balance. Balance options can be provided upon request. Customers can choose according to the applicati No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product, please be sure to contact our sales offices or agents immediately. Spec. Date:2021-04-10
CHM-9R0L155R-TW 价格&库存
很抱歉,暂时无法提供与“CHM-9R0L155R-TW”相匹配的价格&库存,您可以联系我们找货
