DF800-001-05P-C1-00Z(H)
    DEGSON(高松)
    TERMINAL_25.7X14.8MM_TM
    接线端子 5Pin(1x5) P=5.00mm 弯插
DF800-001-05P-C1-00Z(H) 数据手册
FOR-1755 Rev.1.7 O 6 未注公差/General tolerances(mm) >3 >6 >10 >18 >30 >50 >80 >120 >180 >250 >315 >400 0 ~ >500 ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ 80 120 180 250 315 400 500 50 30 18 10 6 3 ±0.12 ±0.18 ±0.22 ±0.26 ±0.31 ±0.37 ±0.57 ±0.80 ±0.93 ±1.05 ±1.15 ±1.60 ±2.20 ±2.50 0.1/10 ±2° 2.3 3 12.15 A 25.7 15 3 1 21.9 14.8 B 2 2 5 0.5 3 ±0.3 1.5 5 PCB LAYOUT 24.85 2.425 5 3.85 O 1.8 1 00 REV 1 ECN 2 5 Pin-header Copper 4 Spring Steel / 3 Button PA66 UL94 V-0 2 Cover PA66 UL94 V-0 Update dimensions 马恩开 2023.03.01 DESCRIPTION DRFT DATE 3 APPD: 李根劳 CHKD: 马恩开 DRFT: 马恩开 A4 4 Sn Plated 1 Housing PA66 UL94 V-0 ITEM NAME OF PART MATERIAL NOTES UL 标准/UL Standard: 额定电压/电流/Rated Voltage(V)/Current(A) IEC 标准/IEC Standard: 过压类别/Overvoltage Category/污染等级/Pollution Degree 额定电压/电流/Rated Voltage(V)/Current(A) 额定脉冲电压(KV)/Rate Impulse Voltage(KV) 线径范围(硬线和软线)/Wire Range(rigid and flexible)(AWG/mm²) 间距/Pitch(mm)/线数范围/Poles 剥线长度/Stripping length(mm) 使用温度范围/Operating temperature(°C) 符合RoHS环保要求/Conform to RoHS 标准颜色编号/Standard color number: PANTONE / RAL 2.1 Transfer or duplication of this document as well as the utilization or communication of its contents are prohibited unless explicit authorization is granted. Violations will be liable for compensation. All rights reserved for patent, utility model or designs registrations. 除非给予明确授权,否则禁止转让、复制、利用、交流本文件的内容。侵犯者将负赔偿责任。本公司保留对涉及发明、实用新型和外观专利的所有权利。 4 5 4 3 2 MATERIAL: MAT NO./REV: 30060000140-1 / 00 2023.03.01 NAME 2023.03.01 TYPE 2023.03.01 DRAWING NO. mm CUSTOMER 200124412 (inch) B 300/10 Ⅲ/3 / / C / D 300/10 Ⅲ/2 Ⅱ/2 320/20 / 4 / 26~12 / 0.2~2.5 5.0/N=05P 9~10 ­40~+105 Yes / SURFACE/COLOR: MAT STATUS: 新物料 DF800-001-05P-C1-00Z(H) 5 DRAWING DRAWING STATUS SCALE SHEET work 2:1 1/1 6 C D
DF800-001-05P-C1-00Z(H) 价格&库存
很抱歉,暂时无法提供与“DF800-001-05P-C1-00Z(H)”相匹配的价格&库存,您可以联系我们找货
