MBR1040 THRU MBR10200
Schottky Barrier Rectifiers
ITO- 220AB
FEATURES
• Plastic package has Underwriters Laboratory
Flammability Classification 94V-O.
Flame Retardant Epoxy Molding Compound.
• Metal silicon junction, majority carrier conduction
• Low power loss, high efficiency.
• High current capability
• For use in low voltage, high frequency inverters
free wheeling, and polarlity protection applications.
• Lead free in comply with EU RoHS
MECHANICAL DATA
• Case: ITO-220AB molded plastic
• Terminals: Solder plated, solderable per MIL-STD-750,
Method 2026
• Polarity: As marked.
• Mounting Position: Any
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25°C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%
SYMBOL
MBR
1040
MBR
1045
MBR
1050
MBR
1060
MBR
1080
MBR
10100
MBR
10150
MBR
10200
UNITS
Maxi mum Recurrent P eak Reverse Voltage
V RRM
40
45
50
60
80
100
150
200
V
Maxi mum RMS Voltage
V RMS
28
31.5
35
42
56
70
105
140
V
Maxi mum D C B locking Voltage
V DC
40
45
50
60
80
100
150
200
V
Maxi mum A verage Forward C urrent (S ee fi g.1)
IF( AV )
P eak Forward S urge C urrent : 8.3ms s i ngle half s i newave superi mposed on rated load (JE D E C method)
IFS M
PARAMETER
Maxi mum Forward Voltage at 5A , per leg
Maxi mum DC Reverse Current at Rated DC
Blocki ng Voltage
VF
T =25 O C
T =125 OC
Typi cal Thermal Resistance
Operati ng and S torage Juncti on Temperature Range
version: 02
http://www.trr-jx.com
IR
10
100
0 .6
110
0.75
0 .85
A
0.92
0.05
0.02
-55 to + 150
V
mA
3
R Θ JC
T J ,T STG
A
O
- 55 to + 175
C/W
O
C
Characteristic Curves (TA=25 ℃ unless otherwise noted)
Fig.2 - TYPICAL INSTANTANEOUS FORWAR
CHARACTERISTIC
100
FORWARD CURRENT, AM PER ES
A VERAGE FORWARD RECTIFIED
CURRENT AMPERES
Fig.1 - FORWARD CURRENT DERATING CURVE
20.0
= 40-100V
= 150-200V
16.0
12.0
8.0
RESISTIVE OR
INDUCTIVE LOAD
4.0
60
100
80
120
140
160
180
40-45V
50-60V
50-60V
10
80-100V
80-100V
150-200V
150-200V
1.0
O
T A =25 C
0.1
0.4
CASE TEMPERATURE, OC
0.6
0.8
1.0
1.2
FORWARD VOLTAGE, VOLTS
Fig.2 TYPICAL
Fig.3 - TYPICAL REVERSE CHARACTERISTICS
Fig.4 - TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
200
O
T J =100 C
1.0
PEAK FORWARD SURGE CURRENT,
INSTANTANEOUS REVERSE CURRENT, mA
10
T J = 75 O C
0.1
O
T J = 25 C
0.01
60
80
100 120
140
PERCENT OF INSTANTANEOUS REVERSE VOLTAGE,(%)
8.3ms Single Half Since-Wave
JEDEC Method
150
125
80~200V
100
75
40~60V
50
25
version: 02
175
1
2
5
10
NO. OF CYCLE AT 60Hz
50
100
很抱歉,暂时无法提供与“MBR1045”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.02287
- 50+0.80320
- 150+0.70902
- 500+0.59152
- 2500+0.53925
- 5000+0.50782
