JST-5000JGQ40R38-V06
    JINSHUNTONG(金顺通)
    Module
    显示模块 3V~3.6V 120.70 x 75.80mm
JST-5000JGQ40R38-V06 数据手册
深圳市金顺通光电有限公司 SHENZHEN JINGSHUNTONG PHOTOELECTRIC CO.,LTD _______________________________________________________________________________________________ Specification TFT-LCD module Specification TFT-LCD module Module(型号): JST-5000JGQ40R38-V06 Customer(客户): Customer P/N(客户型号): Approved by(批准): Qualified(合格): PREPARED Unqualified(不合格): CHECKED APPROVED ------------------------------------------------------------------------------------------------------------------ 工厂地址:深圳市宝安区固戌航城大道华丰世纪科技园 B2 栋西座 7 楼 、 电话:0755-29430532 传真:0755-29961959 网址:WWW.JST-LCM.COM 深圳市金顺通光电有限公司 SHENZHEN JINSHUNTONG PHOTOELECTRIC CO.,LTD _______________________________________________________________________________________________ REVISION RECORD REV NO 1.0 REV DATE 2019-06-25 JST-5000JGQ40R38-V06 CONTENTS REMARKS First Release Ver: A -1- 800RGB480dots-matrix 深圳市金顺通光电有限公司 SHENZHEN JINSHUNTONG PHOTOELECTRIC CO.,LTD _______________________________________________________________________________________________ TABLE OF CONTENT 1.0 GENERAL SPECIFICATIONS 2.0 ELECTRICAL CHARACTERISTICS 3.0 BACKLIGHT CHARACTERISTICS 4.0 DIMENSIONAL DRAWING 5.0 INTERFACE PIN CONNECTIONS 6.0 ELECTRO-OPTICAL CHARACTERISTICS 7.0 INSPECTION CRITERIA 8.0 RELIABILITY 9.0 PRECAUTIONS FOR USING LCD MODULE 10.0 USING LCD MODULES JST-5000JGQ40R38-V06 Ver: A -2- 800RGB480dots-matrix 深圳市金顺通光电有限公司 SHENZHEN JINSHUNTONG PHOTOELECTRIC CO.,LTD _______________________________________________________________________________________________ 1.0 General Specifications JST-5000JGQ40R38-V06 is a color active matrix LCD module incorporating amorphous silicon TFT (Thin Film Transistor). It is composed of a color TFT-LCD panel, driver IC, FPC and a back light unit. The module display area contains 800x 480pixels. This product accords with RoHS environmental criterion. Item Contents Unit LCD Type TFT TRANSMISSIVE / Viewing direction ALL O' Clock Module outline (W x HxD) 120.8x75.95*2.8(Typ) mm Active area (WxH) 108.00*64.80 mm Number of Dots 800(RGB) x480 / Driver IC ST7262 / Backlight Type 6*3chips white LED / Interface Type Parallel RGB 24-bit / Input voltage 3.3 V JST-5000JGQ40R38-V06 Ver: A -3- 800RGB480dots-matrix 深圳市金顺通光电有限公司 SHENZHEN JINSHUNTONG PHOTOELECTRIC CO.,LTD _______________________________________________________________________________________________ 2.0 ELECTRICAL CHARACTERISTICS Values Typ. Unit Item Symbol Power Voltage DVDD AVDD VGH VGL 3.0 10.3 - 3.3 10.4 12 -12 3.6 10.5 15 -14 V V V V VIH 0.7VDD - DVDD V VIL 0 - 0.3DVDD V Input logic high voltage Input logic low voltage Min. Max. Remark Note1:If users use the product out off the environmemtal operation range(temperature and humidity),it will have visual quality concerns. Note2:Be sure to apply DVDD and VGL to the LCD first,and then apply VGH Note3:DVDD setting should match the signals output voltage(refer to Note4)of customer's system board. Note4:DCLK,HS,VS,RESET,U/D,L/R,DE,R0-R7.G0-G7,B0-B7,MODE,DITHB. Current Consumption Item Current for Driver 3.0 Symbol Min. Values Typ. Max. - 0.50 0.54 4.2 19 1 1 10 50 IGH IGL IVDD IAVDD Unit Remark mA mA mA mA VGH=16.0V VGL=-6.0V VDD=3.3V AVDD=10.4V BACKLIGHT CHARACTERISTICS Item Symbol Min Typ Max Unit Conditio n Forward voltage Vf - 18 - V If=60mA Luminance Lv - 500 - cd/m2 If=60mA Number of LED -- 18 Piece -- Connection mode P 6chips serial *3 -- -- JST-5000JGQ40R38-V06 Ver: A -4- 800RGB480dots-matrix 深圳市金顺通光电有限公司 SHENZHEN JINSHUNTONG PHOTOELECTRIC CO.,LTD _______________________________________________________________________________________________ 4.0 DIMENSIONAL DRAWING K A Approve Checked Drawn Approved 易撕贴 深圳市金顺通光电有限公司 SHENZHEN JINSHENTONG TECHNOLOGY CO.,LTD Dwg.No Unit Unmarked Tolerance mm A.0 ±0.2 Date Version 1.0 JST-5000JGQ40R38-V06 Ver: A -5- 800RGB480dots-matrix 深圳市金顺通光电有限公司 SHENZHEN JINSHUNTONG PHOTOELECTRIC CO.,LTD _______________________________________________________________________________________________ 5.0 INTERFACE PIN CONNECTIONS Pin.No Symbol Function 1 LEDK back light power supply negative 2 LEDA back light power supply positive 3 GND Ground 4 DVDD Power supply 5-12 R0-R7 Red Data 13-20 G0-G7 Green Data 21-28 B0-B7 Blue Data 29 GND Ground 30 CLK Colock signal 31 DISP Display on/off 32 HSYNC Horizontal sync input in RGB mode(short to GND if not used) 33 VSYNC Vertical sync input in RGB mode(short to GND if not used) 34 DE Data enable 35 NC No Connection 36 GND Ground 37 XR touch panel X-right 38 YD touch panel Y-bottom 39 XL touch panel X-left 40 YU touch panel Y-upl JST-5000JGQ40R38-V06 Ver: A -6- 800RGB480dots-matrix 深圳市金顺通光电有限公司 SHENZHEN JINSHUNTONG PHOTOELECTRIC CO.,LTD _______________________________________________________________________________________________ 5.1 Timing characteristics 5.1.1 AC Electrical Characteristics Item HS setup time HS hold time VS setup time VS hold time Data setup time Data hold time DE setup time DE hold time VDD Power On Slew rate RESET pulse width DCLK cycle time DCLK pulse duty Values Typ. Symb ol Min. Thst Thhd Tvst Tvhd Tdsu Tdhd Tesu Tehd 8 8 8 8 8 8 8 8 - - ns ns ns ns ns ns ns ns TPOR - - 20 ms TRST Tcoh Tcwh 1 20 40 50 60 Ms Ns % Max. Unit Remark From 0 to 90% VDD 5.1.2 Input Clock and Data Timing Diagram JST-5000JGQ40R38-V06 Ver: A -7- 800RGB480dots-matrix 深圳市金顺通光电有限公司 SHENZHEN JINSHUNTONG PHOTOELECTRIC CO.,LTD _______________________________________________________________________________________________ 5.1.3 Timing Item Symbol Horizontal Display Area DCLK Frequency One Horizontal Line HS pulse width HS Blanking HS Front Porch Vertical Display Area VS period time VS pulse width VS Blanking VS Front Porch thd fclk th thpw thb thfp tvd tv tvpw tvb tvfp Min. Values Typ. Max. 23 808 4 4 8 488 4 4 2 800 25 816 8 8 4 480 496 8 8 4 27 896 48 48 8 504 12 12 8 Unit Remark DCLK MHz DCLK DCLK DCLK DCLK TH TH TH TH TH 5.1.4 Data Input Format JST-5000JGQ40R38-V06 Ver: A -8- 800RGB480dots-matrix 深圳市金顺通光电有限公司 SHENZHEN JINSHUNTONG PHOTOELECTRIC CO.,LTD _______________________________________________________________________________________________ 5.2 POWER ON/OFF SEQUENCE JST-5000JGQ40R38-V06 Ver: A -9- 800RGB480dots-matrix 深圳市金顺通光电有限公司 SHENZHEN JINSHUNTONG PHOTOELECTRIC CO.,LTD _______________________________________________________________________________________________ 6. ELECTRO-OPTICAL CHARACTERISTICS Item Symbol Transmittance Tr Condition Rise Time (Tr) (Tr+Td) Min Typ -- 3.78 4.45 ---- ---- ---- ---- ---- ---- ---- ---- 15 30 ---- ---- ---- ---- ---- ---- ---- 80 ---- ---- 80 ---- ---- 80 ---- ---- 80 ---- 1000 1500 ---- -10℃ Decay Time (Td) Response Time Temp 25℃ θ=ψ= 0 Rise Time (Tr) 60℃ Decay Time (Td) ψ=0° Viewing Angle Range ψ=90° θ ψ=180° 25℃ ψ=270° Contrast Ratio Cr θ=ψ= 0 25℃ Max Units Note % -- msec 6.3 Deg 6.4 --- 6.5 6.1 Electro-Optical Characteristics Test Method Response Time Detector Photo-detector Light Source for Reflective Type θo θ Liquid Crystal Polarizer Panel Light Source for Transmission Type JST-5000JGQ40R38-V06 Ver: A - 10 - 800RGB480dots-matrix 深圳市金顺通光电有限公司 SHENZHEN JINSHUNTONG PHOTOELECTRIC CO.,LTD _______________________________________________________________________________________________ 6.2 Definition of Operating Voltage, Vop Vop = (V10,ON +V90,OFF)/2 Brightness (%) Brightness Curve for Selected Segment Brightness Curve for 90% Non-selected Segment 100% 10% V10,ON 6.3 V90,OFF Driving Voltage Definition of Optical Response Time Non-selecte d Waveform Non-selected Waveform Brightness (%) Selected Waveform 100 90% 10% Rise Time, Tr JST-5000JGQ40R38-V06 Ver: A Decay Time, Td - 11 - Time (ms) 800RGB480dots-matrix 深圳市金顺通光电有限公司 SHENZHEN JINSHUNTONG PHOTOELECTRIC CO.,LTD _______________________________________________________________________________________________ 6.4 Definition of Viewing Angle θ and 12 O’clock Direction Normal : θ=0° θ φ=180° 9 O’clock Direction 3 O’clock Direction φ=90° φ=270° φ φ=0° Viewing Direction 6 O’clock Direction 6.5 Definition of Contrast ratio, CR CR = Brightness of Non-selected Segment (B2) Brightness of Selected Segment (B1) Brightness Curve for Brightness (%) Selected Segment Brightness Curve for 100% B2 Non-selected Segment Contrast CR,max B1 0% V,max JST-5000JGQ40R38-V06 Ver: A Driving Voltage - 12 - 800RGB480dots-matrix 深圳市金顺通光电有限公司 SHENZHEN JINSHUNTONG PHOTOELECTRIC CO.,LTD _______________________________________________________________________________________________ 7.INSPECTION CRITERIA 7.1 Inspection Conditions 7.11 Environmental conditions The environmental conditions for inspection shall be as follows Room temperature: 20±3°C Humidity: 65±20%RH 7.12 The external visual inspection With a single 20-watt fluorescent lamp as the light source, the inspection was in the distance of 30cm or more from the LCD to the inspector's eyes . 7.2 Light Method Fluorescent lamp perpendicular to the display surface. JST-5000JGQ40R38-V06 Ver: A - 13 - 800RGB480dots-matrix 深圳市金顺通光电有限公司 SHENZHEN JINSHUNTONG PHOTOELECTRIC CO.,LTD _______________________________________________________________________________________________ Inspection distance and angle Inspection should be performed within angleφ(φis usually 30°) from Z axis to each X and Y. Inspection distance in any direction within φmust be kept 30±5cm from the display surface. . 7.3 Classification of defects 7.3.1Major defect A major defect refers to a defect that may substantially degrade usability for product applications. 7.3.2 Minor defect A minor defect refers to a defect which is not considered to be able substantially degrade the product application or a defect that deviates from existing standards almost unrelated to the effective use of the product or its operation. 8.RELIABILITY 8.1MTBF The LCD module shall be designed to meet a minimum MTBF value of 50000 hours with normal. (25°C in the room without sunlight) JST-5000JGQ40R38-V06 Ver: A - 14 - 800RGB480dots-matrix 深圳市金顺通光电有限公司 SHENZHEN JINSHUNTONG PHOTOELECTRIC CO.,LTD _______________________________________________________________________________________________ 8.2 Tests NO. Test Item 1 High Temperature Storage 2 Low Temperature Storage 3 4 5 6 Test condition Criterion 80℃±2℃ 24H Restore 2H at 25℃ Power off -30℃±2℃24H Restore 2H at 25℃ Power off High Temperature Operation 70℃±2℃ 24H Restore 2H at 25℃ Power on Low Temperature Operation -20℃±2℃ 24H Restore 2H at 25℃ Power on High Temperature & 60℃±2℃ 90%RH 24H Humidity Operation Power on Temperature Cycle --30℃←→25℃←→80℃ 30min 5min 30min after 10 cycle, Restore 2H at 25℃ Power off 7 Vibration Test 10Hz~150Hz, 100m/s2, 120min 8 Shock Test Half-sinewave,300m/s2,11ms Aftertesting,cosmeti c and electrical defects should not happen. 9 PRECAUTIONS FOR USING LCD MODULE 9.1 HANDING PRECAUTIONS (1) The display panel is made of glass. Do not subject it to a mechanical shock or impact by dropping it. (2) If the display panel is damaged and the liquid crystal substance leaks out, be sure not to get any in your mouth. If the substance contacts your skin or clothes, wash it off using soap and water. (3) Do not apply excessive force to the display surface or the adjoining areas since this may cause the color tone to vary. (4) The polarizer covering the display surface of the LCD module is soft and easily scratched. Handle this polarizer carefully. (5) If the display surface becomes contaminated,breathe on the surface and gently wipe it with a soft dry cloth. If it is heavily contaminated, moisten a cloth with one of the following solvents: JST-5000JGQ40R38-V06 Ver: A - 15 - 800RGB480dots-matrix 深圳市金顺通光电有限公司 SHENZHEN JINSHUNTONG PHOTOELECTRIC CO.,LTD _______________________________________________________________________________________________ - Isopropyl alcohol - Ethyl alcohol (6) Solvents other than those above mentioned may damage the polarizer. Especially, do not use the following: - Water - Ketone - Aromatic solvents (7) Extra care to minimize corrosion of the electrode. Water droplets, moisture condensation or a current flow in a high-humidity environment accelerates corrosion of the electrode. (8) Install the LCD Module by using the mounting holes. When mounting the LCD Module, make sure it is free of twisting, warping and distortion. In particular, do not forcibly pull or bend the I/O cable or the backlight cable. (9) Do not attempt to disassemble or process the LCD Module. (10) NC terminal should be open. Do not connect anything. (11) If the logic circuit power is off, do not apply the input signals. (12) To prevent destruction of the elements by static electricity, be careful to maintain an optimum work environment. - Be sure to ground the body when handling he LCD Module. - Tools required for assembling, such as soldering irons, must be properly grounded. -To reduce the amount of static electricity generated, do not conduct assembling and other work under dry conditions. -The LCD Module is coated with a film to protect the display surface. Exercise care when peeling off this protective film since static electricity may be generated. 9.2 STORAGE PRECAUTIONS When storing The LCD Module, avoid exposure to direct sunlight of fluorescent lamps. Keep the modules in bags (avoid high temperature/ high humidity and low temperatures below 0℃). Whenever possible, the LCD Module should be stored in the same conditions in which they were shipped from our company. 9.3 OTHERS Liquid crystals solidify under low temperature (below the storage temperature range) leading to defective orientation or the generation of air bubbles (black or white). Air bubbles may also be generated if the module is subject to a low temperature. If the LCD Module have been operating for a long time showing the same display patterns the display patterns may remain on the screen as ghost images and a slight contrast JST-5000JGQ40R38-V06 Ver: A - 16 - 800RGB480dots-matrix 深圳市金顺通光电有限公司 SHENZHEN JINSHUNTONG PHOTOELECTRIC CO.,LTD _______________________________________________________________________________________________ irregularity may also appear. A normal operating status can be recovered by suspending use for some time. It should be noted that this phenomenon does not adversely affect performance reliability. To minimize the performance degradation of the LCD Module resulting from destruction caused by static electricity etc. exercise care to avoid holding the following sections when handling the modules. - Exposed area of the printed circuit board. - Terminal electrode sections. 10. USING LCD MODULES 10.1 LIQUID CRYSTAL DISPLAY MODULES LCD is composed of glass and polarizer. Pay attention to the following items when handling. (1) Please keep the temperature within specified range for use and storage. Polarization degradation, bubble generation or polarizer peel-off may occur with high temperature and high humidity. (2) Do not touch, push or rub the exposed polarizers with anything harder than a HB pencil lead (glass, tweezers, etc). (3) N-hexane is recommended for cleaning the adhesives used to attach front/rear polarizers and reflectors made of organic substances, which will be damaged by chemicals such as acetone, toluene, toluene, ethanol and isopropyl alcohol. (4) When the display surface becomes dusty, wipe gently with absorbent cotton or other soft material like chamois soaked in petroleum ether. Do not scrub hard to avoid damaging the display surface. (5) Wipe off saliva or water drops immediately, contact with water over a long period of time may cause deformation or color fading. (6) Avoid contacting oil and fats. (7) Condensation on the surface and contact with terminals due to cold will damage, stain or polarizers. After products are tested at low temperature they must be warmed up in a container before coming is contacting with room temperature air. (8) Do not put or attach anything on the display area to avoid leaving marks on. (9) Do not touch the display with bare hands. This will stain the display area and degrade insulation between terminals (some cosmetics are determinate to the polarizers). (10)As glass is fragile, it tends to become or chipped during handling especially on the edges. Please avoid dropping or jarring. 10.2 INSTALLING LCD MODULE JST-5000JGQ40R38-V06 Ver: A - 17 - 800RGB480dots-matrix 深圳市金顺通光电有限公司 SHENZHEN JINSHUNTONG PHOTOELECTRIC CO.,LTD _______________________________________________________________________________________________ Attend to the following items when installing the LCM. (1) Cover the surface with a transparent protective plate to protect the polarizer and LC cell. (2) When assembling the LCM into other equipment, the spacer to the bit between the LCM and the fitting plate should have enough height to avoid causing stress to the module surface, refer to the individual specifications for measurements. The measurement tolerance should be ±0.1mm. 10.3 ELECTRO-STATIC DISCHARGE CONTROL Since this module uses a CMOS LSI, the same careful attention should be paid for electrostatic discharge as for an ordinary CMOS IC. (1) Make certain that you are grounded when handing LCM. (2) Before removing LCM from its packing case or incorporating it into a set, be sure the module and your body have the same electric potential. (3) When soldering the terminal of LCM, make certain the AC power source for the soldering iron does not leak. (4) When using an electric screwdriver to attach LCM, the screwdriver should be of ground potentiality to minimize as much as possible any transmission of electromagnetic waves produced sparks coming from the commutator of the motor. (5) As far as possible, make the electric potential of your work clothes and that of the workbenches to the ground potential. (6) To reduce the generation of static electricity , be careful that the air in the work is not too dried. A relative humidity of 50%-60% is recommended. (7) 10.4 PRECAUTION FOR SOLDERING TO THE LCM (1) Observe the following when soldering lead wire, connector cable and etc. to the LCM. -Soldering iron temperature: 280 ±10°C. -Soldering time: 3-4 sec. -Solder: eutectic solder. If soldering flux is used, be sure to remove any remaining flux after finishing to soldering operation. (This does not apply in the case of a non-halogen type of flux.) It is recommended that you protect the LCD surface with a cover during soldering the prevent any damage due to flux spatters. (2) When soldering the electroluminescent panel and PC board, the panel and board should not be detached more than three times. This maximum number is determined by the temperature and time conditions mentioned above, though there may be some variance depending on the temperature of the soldering iron. (3) When removing the electroluminescent panel from the PC board, be sure the solder has JST-5000JGQ40R38-V06 Ver: A - 18 - 800RGB480dots-matrix 深圳市金顺通光电有限公司 SHENZHEN JINSHUNTONG PHOTOELECTRIC CO.,LTD _______________________________________________________________________________________________ completely melted, otherwise the soldered pad on the PC board could be damaged. 10.5 PRECAUTIONS FOR OPERATION (1) Viewing angle varies with the change of liquid crystal driving voltage (Vo). Adjust Vo to show the best contrast. (2) Driving the LCD in the voltage above the limit will shorten its lifetime. (3) Response time is greatly delayed at temperature below the operating temperature range. However, this does not mean the LCD will be out of the order. It will recover when it returns to the specified temperature range. (4) If the display area is pushed hard during operation, the display will become abnormal. However, it will return to normal if it is turned off and then on. (5) Condensation on terminals can cause an electrochemical reaction disrupting the terminal circuit. Therefore, it must be used under the relative condition of 40°C, 50% RH. (6) When turning the power on, input each signal after the positive/negative voltage becomes stable. 10.6 STORAGE (1) (2) (3) (4) When storing LCDS as spares for some years, the following precaution are necessary. Store them in a sealed polyethylene bag. If properly scaled, there is no need for desiccant. Store them in a dark place. Do not expose to sunlight or fluorescent light, keep the temperature between 0°C and 35°C. The polarizer surface should not come in contact with any other objects. (We advise you to store them in the container in which they were shipped.) Environmental conditions: -Do not leave them for more than 168hrs. at 60 °C. -Should not be left for more than 48hrs. at –20 °C. 10.7 SAFETY (1) It is recommended to crush damaged or unnecessary LCDs into pieces and wash them off with solvents such as acetone and ethanol, which should later be burned. (2) If any liquid leaks out of a damaged glass cell and comes in contact with the hands, wash off thoroughly with soap and water. 10.8 LIMITED WARRANTY JST-5000JGQ40R38-V06 Ver: A - 19 - 800RGB480dots-matrix 深圳市金顺通光电有限公司 SHENZHEN JINSHUNTONG PHOTOELECTRIC CO.,LTD _______________________________________________________________________________________________ Unless agreed between JINSHUNTONG and customer, JINSHUNTONG will replace or repair any of its LCD and modules which are found to be functionally defective when inspected in accordance with JINSHUNTONG LCD acceptance standards (copies available upon request) for a period of one year from date of shipments. Cosmetic/visual defects must be returned to JINSHUNTONG within 90 days of shipment. Confirmation of such date shall be based on freight documents. The warranty liability of JINSHUNTONG is limited to repair and/or replacement on the terms set forth above. JINSHUNTONG will not be responsible for any subsequent or consequential events. 10.9. RETURN LCM UNDER WARRANTY No warranty can be granted if the precautions stated above have been disregarded. The typical examples of violations are: -Broken LCD glass. -PCB eyelet’s damaged or modified. -PCB conductors damaged. -Circuit modified in any way, including addition of components. -PCB tampered with by grinding, engraving or painting varnish. -Soldering to or modifying the bezel in any manner. Module repairs will be invoiced to the customer upon mutual agreement. Modules must be returned with sufficient description of the failures or defects. Any connectors or cable installed by the customer must be removed completely without damaging the PCB eyelet’s conductors and terminals. JST-5000JGQ40R38-V06 Ver: A - 20 - 800RGB480dots-matrix
JST-5000JGQ40R38-V06 价格&库存
很抱歉,暂时无法提供与“JST-5000JGQ40R38-V06”相匹配的价格&库存,您可以联系我们找货
