XL7OI-111-16M
XL7OI-111-16M
    YXC(扬兴科技)
    SMD2016_4P
    无源晶振 16MHz ±10ppm 12pF -40℃~+85℃
XL7OI-111-16M 数据手册
Crystal Unit YSX211SL Applications ‧Mobile phone, Bluetooth, WLAN ISM band radio. Small Size Features ‧Dimensions: 2.05 x 1.65 x 0.50mm. ‧High precision and high frequency stability. ‧Standard Frequency: 16~54MHz ‧Excellent heat resistance and environmental characteristics. Specifications(规格参数) Item Nominal Frequency Range(额定频率范围) Vibration Mode(震动模式) Load Capacitance(负载电容) Frequency Tolerance(频率偏差) (at 25℃ ) Frequency Versus Temperature Characteristics(频率-温度特性) Operating Temperature(工作温度) Storage Temperature(储存温度) Shunt Capacitance(静态电容) Level of Drive(激励电平) Aging (老化)(at 25℃ ) Symbol Specifications f_nom 16~54MHz or 96MHZ - AT Fundamental CL 8pF, 9pF, 12pF, or specify f_tol ±10ppm, or specify f_tem ±20ppm, or specify T_use -40~+85℃ or specify T_stg -55~+125℃ C0 3pF Max. DL 10~200μW Max.(100μW typical) f_age ±3ppm/year Max. Equivalent Series Resistance(等效串联电阻(ESR)) YSX211SL 16 ~ 30MHz 100 Ω Max. 31 ~ 54MHz 80 Ω Max. Dimensions and Recommended land pattern(外观尺寸及推荐焊盘) Dimensions (Unit: mm) Recommended land pattern(Unit: mm) www.yxc.hk 1
XL7OI-111-16M 价格&库存
很抱歉,暂时无法提供与“XL7OI-111-16M”相匹配的价格&库存,您可以联系我们找货
XL7OI-111-16M
  • 1+0.49852
  • 200+0.32136
  • 1500+0.27913
  • 3000+0.24720
库存:13861
XL7OI-111-16M
库存:16
XL7OI-111-16M
  • 5+0.62986
  • 50+0.50382
  • 150+0.44075
  • 500+0.39345
  • 3000+0.35565
库存:3483
XL7OI-111-16M
  • 1+0.30000
  • 100+0.28000
  • 300+0.26000
  • 500+0.24000
  • 2000+0.23000
  • 5000+0.22400
库存:17095
XL7OI-111-16M
  • 5+0.61840
  • 50+0.49460
  • 150+0.43240
  • 500+0.38570
  • 3000+0.34870
库存:3044
