XKHGI-112-32.768K
XKHGI-112-32.768K
    YXC(扬兴科技)
    SMD2012_2P
    无源晶振 32.768kHz ±20ppm 12.5pF -40℃~+85℃
XKHGI-112-32.768K 数据手册
Crystal Unit 32.768KHZ YSX2012SK Small Size Applications Features ‧RTC ‧Dimensions: 2.00 x 1.20 x 0.60mm.. ‧Standard Frequency: 32.768KHz ‧Ultra-thin thickness 0.6mm ‧Reflow is possible. Specifications(规格参数) Item Symbol Specifications f_nom 32.768KHz Frequency Tolerance(频率偏差) (at 25℃ ) CL 7pF, 9pF, 12.5pF, or specify f_tol ±10ppm, ±20ppm, or specify Operating Temperature(工作温度) B ( - 0.03 ± 0.01 ) * 10-6 / ℃2 T_use -40~+85℃, or specify T_stg -55~+125℃ C0 1.3pF Max. C1 7.5fF DL 0.1μW Max f_age ±3ppm/year Max. Nominal Frequency(额定频率范围) Load Capacitance(负载电容) Parabolic Coefficient(频率温度系数) Storage Temperature(储存温度) Shunt Capacitance(静态电容) Motional Capacitance(动态电容) Level of Drive(激励电平) Aging (老化)(at 25℃ ) Equivalent Series Resistance(等效串联电阻(ESR)) YSX2012SK 90K Ω Max. Dimensions and Recommended land pattern(外观尺寸及推荐焊盘) Dimensions (Unit: mm) Recommended land pattern(Unit: mm) www.yxc.hk 1
XKHGI-112-32.768K 价格&库存
很抱歉,暂时无法提供与“XKHGI-112-32.768K”相匹配的价格&库存,您可以联系我们找货
XKHGI-112-32.768K
  • 1+1.52550
  • 10+1.22660
  • 50+1.02560
  • 150+0.95470
  • 500+0.89280
  • 1000+0.83840
库存:6489
XKHGI-112-32.768K
  • 1+0.86560
  • 30+0.83468
  • 100+0.80377
  • 500+0.74194
  • 1000+0.71103
  • 2000+0.69248
库存:2378
XKHGI-112-32.768K
  • 1+1.36990
  • 100+1.06090
  • 750+0.88374
  • 1500+0.80340
  • 3000+0.74469
库存:3194
XKHGI-112-32.768K
  • 5+1.76829
  • 50+1.40022
  • 150+1.24254
  • 500+1.04577
库存:1396
XKHGI-112-32.768K
  • 5+1.60455
  • 50+1.27057
  • 600+1.25786
  • 1200+1.23270
  • 3000+1.19572
库存:12000
