XL7OI-111-32M
XL7OI-111-32M
    YXC(扬兴科技)
    SMD2016_4P
    无源晶振 32MHz ±10ppm 12pF -40℃~+85℃
XL7OI-111-32M 数据手册
Crystal Unit YSX211SL Applications ‧Mobile phone, Bluetooth, WLAN ISM band radio. Small Size Features ‧Dimensions: 2.05 x 1.65 x 0.50mm. ‧High precision and high frequency stability. ‧Standard Frequency: 16~54MHz ‧Excellent heat resistance and environmental characteristics. Specifications(规格参数) Item Nominal Frequency Range(额定频率范围) Vibration Mode(震动模式) Load Capacitance(负载电容) Frequency Tolerance(频率偏差) (at 25℃ ) Frequency Versus Temperature Characteristics(频率-温度特性) Operating Temperature(工作温度) Storage Temperature(储存温度) Shunt Capacitance(静态电容) Level of Drive(激励电平) Aging (老化)(at 25℃ ) Symbol Specifications f_nom 16~54MHz or 96MHZ - AT Fundamental CL 8pF, 9pF, 12pF, or specify f_tol ±10ppm, or specify f_tem ±20ppm, or specify T_use -40~+85℃ or specify T_stg -55~+125℃ C0 3pF Max. DL 10~200μW Max.(100μW typical) f_age ±3ppm/year Max. Equivalent Series Resistance(等效串联电阻(ESR)) YSX211SL 16 ~ 30MHz 100 Ω Max. 31 ~ 54MHz 80 Ω Max. Dimensions and Recommended land pattern(外观尺寸及推荐焊盘) Dimensions (Unit: mm) Recommended land pattern(Unit: mm) www.yxc.hk 1
XL7OI-111-32M 价格&库存
很抱歉,暂时无法提供与“XL7OI-111-32M”相匹配的价格&库存,您可以联系我们找货
XL7OI-111-32M
  • 5+0.50290
  • 50+0.39530
  • 150+0.32570
  • 500+0.29710
  • 1000+0.27680
  • 3000+0.25920
库存:2326
XL7OI-111-32M
  • 20+0.94000
  • 100+0.56070
  • 800+0.39250
  • 3000+0.28040
  • 6000+0.26630
  • 30000+0.24670
XL7OI-111-32M
  • 1+0.30000
  • 100+0.28000
  • 300+0.26000
  • 500+0.24000
  • 2000+0.23000
  • 5000+0.22400
库存:17213
XL7OI-111-32M
  • 5+0.57143
  • 50+0.45479
  • 150+0.39647
库存:19
XL7OI-111-32M
  • 1+0.45629
  • 200+0.29458
  • 1500+0.25647
  • 3000+0.22660
库存:3792
