XL2SI-111-13.56M
XL2SI-111-13.56M
    YXC(扬兴科技)
    SMD3225_4P
    无源晶振 13.56MHz ±10ppm 20pF -40℃~+85℃
XL2SI-111-13.56M 数据手册
Crystal Unit YSX321SL Applications Features ‧Smart Wearable ‧Dimensions: 3.20 x 2.50 x 0.70 mm.. ‧High precision and high frequency stability. IOT Communication ‧Standard Frequency: 8~54MHz ‧Extremely good for reducing EMI effect. Specifications(规格参数) Item Nominal Frequency Range(额定频率范围) Vibration Mode(震动模式) Load Capacitance(负载电容) Frequency Tolerance(频率偏差) (at 25℃ ) Frequency Versus Temperature Characteristics(频率-温度特性) Operating Temperature(工作温度) Storage Temperature(储存温度) Shunt Capacitance(静态电容) Level of Drive(激励电平) Aging (老化)(at 25℃ ) Symbol Specifications f_nom 8~64MHz - AT Fundamental CL 10pF, 20pF, or specify f_tol ±10ppm, ±20ppm, or specify f_tem ±20ppm, or specify T_use -40~+85℃ or specify T_stg -55~+125℃ C0 7pF Max. DL 1~200μW Max.(100μW typical) f_age ±3ppm/year Max. Equivalent Series Resistance(等效串联电阻(ESR)) YST321SL 8 ~ 11.2892MHz 150 Ω Max. 12 ~ 16MHz 80 Ω Max. 17 ~ 64MHz 50 Ω Max. Dimensions and Recommended land pattern(外观尺寸及推荐焊盘) Dimensions (Unit: mm) Recommended land pattern(Unit: mm) www.yxc.hk 1
XL2SI-111-13.56M 价格&库存
很抱歉,暂时无法提供与“XL2SI-111-13.56M”相匹配的价格&库存,您可以联系我们找货
XL2SI-111-13.56M
  • 1+0.31500
  • 100+0.29400
  • 300+0.27300
  • 500+0.25200
  • 2000+0.24150
  • 5000+0.23520
库存:18180
XL2SI-111-13.56M
  • 5+0.50800
  • 50+0.39760
  • 150+0.34230
  • 500+0.30110
  • 3000+0.26820
  • 6000+0.25170
库存:1188
XL2SI-111-13.56M
  • 5+0.51732
  • 50+0.40522
  • 150+0.34917
  • 500+0.30716
  • 3000+0.27357
  • 6000+0.25672
库存:3255
XL2SI-111-13.56M
  • 20+0.84360
  • 100+0.50320
  • 800+0.35220
  • 3000+0.25160
  • 6000+0.23910
  • 30000+0.22140
XL2SI-111-13.56M
  • 1+0.43146
  • 200+0.27744
  • 1500+0.24174
  • 3000+0.21420
库存:3094
