XG1SI-111-16M
XG1SI-111-16M
    YXC(扬兴科技)
    SMD5032_2P
    无源晶振 16MHz ±10ppm 20pF -40℃~+85℃
XG1SI-111-16M 数据手册
Crystal Unit YSX530GA Applications ‧Industrial Control Consumers. Glass Sealed Features ‧Dimensions: 5.00 x 3.20 x 1.2 mm ‧2 pads SMD glass sealed crystal units. ‧Standard Frequency: 8~54MHz ‧Contains Pb in sealing glass exempted by ROHS directive. Specifications(规格参数) Item Nominal Frequency Range(额定频率范围) Vibration Mode(震动模式) Load Capacitance(负载电容) Frequency Tolerance(频率偏差) (at 25℃ ) Frequency Versus Temperature Characteristics(频率-温度特性) Operating Temperature(工作温度) Storage Temperature(储存温度) Shunt Capacitance(静态电容) Level of Drive(激励电平) Aging (老化)(at 25℃ ) Symbol Specifications f_nom 8~54MHz - AT Fundamental CL 10pF, 20pF, or specify f_tol ±10ppm, ±20ppm, or specify f_tem ±20ppm, or specify T_use -20~+70℃, -40~+85℃, or specify T_stg -55~+125℃ C0 5pF Max DL 1~300μW Max.(100μW typical) f_age ±3ppm/year Max. Equivalent Series Resistance(等效串联电阻(ESR)) YSX530GA 8 ~ 16MHz 80 Ω Max. 16 ~ 25MHz 40~60 Ω Max. 25 ~ 54MHz 30~40 Ω Max. Dimensions and Recommended land pattern(外观尺寸及推荐焊盘) Dimensions (Unit: mm) Recommended land pattern(Unit: mm) www.yxc.hk 1
XG1SI-111-16M 价格&库存
很抱歉,暂时无法提供与“XG1SI-111-16M”相匹配的价格&库存,您可以联系我们找货
XG1SI-111-16M
  • 1+1.10240
  • 50+0.84800
  • 1000+0.78122
库存:602
XG1SI-111-16M
  • 1+0.69570
库存:867
XG1SI-111-16M
  • 5+0.94500
  • 50+0.88200
  • 200+0.81900
  • 1000+0.75600
  • 2500+0.72450
  • 5000+0.69300
XG1SI-111-16M
  • 5+1.79000
  • 50+1.43079
  • 150+1.27689
  • 1000+1.08476
库存:1793
XG1SI-111-16M
  • 5+1.76240
  • 50+1.40830
  • 150+1.25380
  • 1000+1.06390
库存:1535
