PB05.12
PB05.12
    ASTM(博钺)
    FUSE_6.5X2.6MM_SM
    一次性保险丝(熔断) 12A 125V FUSE_6.5X2.6MM_SM
PB05.12 数据手册
Rev.: Sep, 2022 PB05 Fast Acting SMD 125VAC/DC Fuses E355868 PB05 Series Description PB05 SMD fuse for the small size and good electrical performance, reliability and quality. Rated Current 0.5A~15A Electrical Characteristics 1.0In 2.0In 4 hour minimum 5sec maximum Features ➢ ➢ ➢ ➢ Designed to UL 248-14 Compatible with reflow and wave soldering One time positive disconnect RoHS compliant Specification Rated Voltage Rated Current (V) (A) Part No. Breaking Capacity (A) 1 Typical Cold. Resistance (mOhms) 2 Typical Voltage Drop (mV) Typical PreArcing I2t (A2Sec) 3 PB05.0.5A PB05.0.63A PB05.0.8A PB05.1A PB05.1.5A PB05.2 0.5A 0.63A 0.8A 1A 1.5A 2A 281 230 137 105 62 27 185 180 150 140 125 96 0.48 1.05 1.7 2.7 4.9 1.5 PB05.2.5 PB05.3 PB05.4 PB05.5 PB05.6.3 PB05.7 2.5A 3A 4A 5A 6.3A 7A 18.2 17.8 12.9 10.2 7.70 7.20 60 86 85 81 80 80 5.5 3.1 5.2 8.5 15 19.5 6.30 5.10 3.95 3.15 78 77 76 75 24 38 57 105 125Vac/Vdc PB05.8 PB05.10 PB05.12 PB05.15 8A 10A 12A 15A 50A 1. AC Interrupting Rating (measured at designated voltage, 100% power factor); DC Interrupting Rating (measured at designated voltage, time constant of less than 50 microseconds, battery source) 2.6±0.5 2. DC Cold Resistance are measured at
PB05.12 价格&库存
很抱歉,暂时无法提供与“PB05.12”相匹配的价格&库存,您可以联系我们找货
