PED3312M
PED3312M
    SEMIONE(芯电元)
    DFN-8-EP(3x3)
    MOSFETs N-沟道 18V 22A 6mΩ@2.5V
PED3312M 数据手册
PED3312M N-Channel Enhancement Mode Power MOSFET Description The PED3312M uses advanced trench technology to provide excellent RDS(ON), low gate charge and operation with gate voltages as low as 2.5V. This device is suitable for use as a load switch or in PWM applications. It is ESD protected. General Features Schematic diagram ● VDS = 18V,ID =22 A RDS(ON) < 4.5 mΩ @ VGS=4.5V RDS(ON) < 4.7 mΩ @ VGS=3.8V RDS(ON) < 6mΩ @ VGS=2.5V ESD Rating: 2000V HBM ● High Power and current handing capability ● Lead free product is acquired Marking and pin Assignment ● Surface Mount Package Application ●PWM application ●Load switch DFN3x3-8L top view Absolute Maximum Ratings (TA=25℃unless otherwise noted) LIMITS Drain-Source Voltage SYMBOL VDS Gate-Source Voltage VGS ±10 PARAMETERS/TEST CONDITIONS Continuous Drain Current TA = 25 °C ID TA = 70 °C Pulsed Drain Current (Note 1) Avalanche Current Avalanche Energy Power Dissipation L = 0.1mH TA = 25 °C www.semi-one.com 1 16 80 IAS 20 EAS 26 TJ, Tstg Operating Junction & Storage Temperature Range V 22 IDM PD TA = 70 °C 18 UNITS 3.6 2.4 -55 to 150 A mJ W °C 2017. Feb. V1.0 PED3312M Thermal Characteristic Thermal Resistance,Junction-to-Ambient (Note 2) RθJA ℃/W 34.7 Notes: 1. Pulse width limited by maximum junction temperature. 2. The value of RJA is measured with the device mounted on 1in2 FR-4 board with 2oz. Copper, in a still air environment with TA =25°C. Electrical Characteristics (TA=25℃unless otherwise noted) Parameter Symbol Condition Min Typ Max Unit Off Characteristics Drain-Source Breakdown Voltage BVDSS VGS=0V ID=250μA 18 20 - V Zero Gate Voltage Drain Current IDSS VDS=20V,VGS=0V - - 1 μA Symbol Condition Min Typ Max Unit IGSS VGS=±10V,VDS=0V - - ±10 μA VGS(th) VDS=VGS,ID=250μA 0.45 0.8 1.2 V VGS=4.5V, ID= 8A - 3.4 4.5 mΩ VGS=3.8V, ID=7A - 3.5 4.7 mΩ VGS=2.5V, ID=6A - 4.4 6 mΩ VDS=5V,ID=5A - 40 - S - 3140 - PF - 352 - PF - PF Parameter Gate-Body Leakage Current On Characteristics (Note 2) Gate Threshold Voltage Drain-Source On-State Resistance Forward Transconductance RDS(ON) gFS Dynamic Characteristics (Note 3) Input Capacitance Clss Output Capacitance Coss Reverse Transfer Capacitance Crss - 320 Turn-on Delay Time td(on) - 20 nS Turn-on Rise Time tr VDD=10V,RL=1.35Ω - 40 nS td(off) VGS=5V,RGEN=3Ω - 72 nS - 16 nS - 35 nC - 3 - nC - 10 - nC - - 1.2 V - - 26 A VDS=10V,VGS=0V, F=1.0MHz Switching Characteristics (Note 3) Turn-Off Delay Time Turn-Off Fall Time tf Total Gate Charge Qg Gate-Source Charge Qgs Gate-Drain Charge Qgd VDS=10V,ID=7A, VGS=4.5V Drain-Source Diode Characteristics Diode Forward Voltage (Note 2) VSD Diode Forward Current (Note 1) IS VGS=0V,IS=1A Notes: 1. Surface Mounted on FR4 Board, t ≤ 10 sec. 2. Pulse Test: Pulse Width ≤ 300μs, Duty Cycle ≤ 2%. 3. Guaranteed by design, not subject to production www.semi-one.com 2 2017. Feb. V1.0 PED3312M TYPICAL ELECTRICAL AND THERMAL CHARACTERISTICS Vdd Vgs Rgen td(on) Rl Vin D ton tr td(off) 90% Vout VOUT G toff tf 90% INVERTED 10% 10% 90% S VIN 50% 50% 10% PULSE WIDTH Figure 2:Switching Waveforms PD Power(W) Rdson On-Resistance(mΩ) Figure 1:Switching Test Circuit TJ-Junction Temperature(℃) ID- Drain Current (A) Figure 3 Power Dissipation ID- Drain Current (A) Normalized On-Resistance Figure 4 Drain-Source On-Resistance TJ-Junction Temperature(℃) Vds Drain-Source Voltage (V) Figure 5 Output CHARACTERISTICS www.semi-one.com Figure 6 Drain-Source On-Resistance 3 2017. Feb. V1.0 C Capacitance (pF) ID- Drain Current (A) PED3312M Vds Drain-Source Voltage (V) Vgs Gate-Source Voltage (V) Figure 8 Capacitance vs Vds Rdson (mΩ) Is- Reverse Drain Current (A) Figure 7 Transfer Characteristics Vgs Gate-Source Voltage (V) Vds Drain-Source Voltage (V) Figure 10 Capacitance vs Vds Figure 9 Rdson vs Vgs ID- Drain Current (A) Vgs Gate-Source Voltage (V) 2 IDM =80A ID=22A 10 7 5 3 2 1.0 7 5 3 2 DC 10 PW≤10μs 10 0μ 1m s s 10 ms 0m op s era tio Operation in this area is limited by RDS(on). 0.1 7 Ta=25°C 5 Single pulse 3 When mounted on ceramic substrate 2 (900mm2✕0.8mm) 1unit 0.01 2 3 5 7 1.0 2 3 0.01 2 3 5 7 0.1 n 5 7 10 2 3 5 Vds Drain-Source Voltage (V) Qg Gate Charge (nC) Figure 11 Gate Charge www.semi-one.com 100 7 5 3 2 Figure 12 4 Safe Operation Area 2017. Feb. V1.0 r(t),Normalized Effective Transient Thermal Impedance PED3312M Square Wave Pluse Duration(sec) Figure 13 Normalized Maximum Transient Thermal Impedance www.semi-one.com 5 2017. Feb. V1.0 PED3312M www.semi-one.com 6 2017. Feb. V1.0
PED3312M 价格&库存
很抱歉,暂时无法提供与“PED3312M”相匹配的价格&库存,您可以联系我们找货
