*R5475N (SOT-23-5) is the discontinued product as of January, 2017.
Li-ION/POLYMER 1CELL PROTECTOR
No. EA-291-191004
R5475N/R5478N SERIES
OUTLINE
The R5475N/R5478Nxxxxx Series are high voltage CMOS-based protection ICs for over-charge/discharge of
rechargeable one-cell Lithium-ion (Li+) / Lithium polymer excess load current, further include a short circuit
protector for preventing large external short circuit current and Excess discharge-current.
Each of these ICs is composed of three voltage detectors, a reference unit, a delay circuit, a short circuit
protector, an oscillator, a counter, and a logic circuit. When the over-charge voltage crosses the detector
threshold from a low value to a high value, the output of COUT pin switches to low level after internal fixed delay
time. The conditions to release over-charge detector are different by mask options. In terms of so called “Latch
function” version, after detecting over-charge, the detector can be reset and the output of COUT becomes "H"
when a kind of load is connected to VDD after a charger is disconnected from the battery pack, and the cell
voltage becomes lower than over-charge detector threshold. If a charger is continue to be connected to the
battery pack, even the cell voltage becomes lower than over-charge detector threshold, over-charge state is not
released. On the other hand, in terms of so called, “ Released by voltage level” version, after detecting
over-charge, when the cell voltage reaches the released voltage from over-charge, the output of COUT becomes
“H”
The output of DOUT pin, the output of Over-discharge detector and Excess discharge-current detector,
switches to “L” level after internally fixed delay time, when discharged voltage crosses the detector threshold
from a high value to a value lower than VDET2.
The conditions to release over-discharge detector are also different by mask options. In terms of so called
“Latch function” version, after detecting over-discharge voltage, connect a charger to the battery pack, and
when the battery supply voltage becomes higher than over-discharge detector threshold, VD2 is released and
the voltage of DOUT pin becomes "H" level. On the other hand, in terms of so called “Released by voltage level”
version, in case that the charger is not connected, when the cell voltage becomes equal released voltage from
over-discharge, over-discharge detector is released. In case that a charger is connected, and when the cell
voltage becomes the released voltage from over-discharge, the over-discharge detector is released.
An excess discharge-current and short circuit state can be sensed and cut off through the built in excess
current detector, VD3, with DOUT being enabled to low level. Once after detecting excess discharge-current or
short circuit, the VD3 is released and DOUT level switches to high by detaching a battery pack from a load
system.
After detecting over-discharge, supply current will be kept extremely low by halting internal circuits' operation.
When the output of COUT is “H”, if V- pin level is set at Vss-2V, the delay time of detector can be shortened.
Especially, the delay time of over-charge detector can be reduced into approximately 1/57. Therefore, testing
time of protector circuit board can be reduced. Output type of COUT and DOUT are CMOS. 6-pin, SOT-23-6 is
available.
-1-
R5475N/R5478Nxxxxx
FEATURES
• Manufactured with High Voltage Tolerant Process ...Absolute Maximum Rating
30V
• Low supply current ..................................Supply current (At normal mode)
Typ. 3.0µA
C version: (detecting over-discharge)
D/J/K version: (detecting over-discharge)
Max. 0.1µA
Typ. 1.2µA/Max. 2.0µA
• High accuracy detector threshold .............Over-charge detector (Topt=25°C)
±25mV
(Topt=-5 to 55°C)
±30mV
±2.5%
±15mV
• Variety of detector threshold ................... Over-charge detector threshold
C/D version:
4.2V-4.5V step of 0.005V
J version:
3.65V
K version:
3.90V
Over-discharge detector threshold
C/D/J version:
2.1V-3.0V step of 0.100V
K version:
1.9V-3.0V step of 0.100V
Excess discharge-current threshold
0.05V-0.20V step of 0.005V
Short Detector Threshold
Fixed at 0.75V
• Internal fixed Output delay time ...............Over-charge detector Output Delay
(Select among the options)
1s
Over-discharge detector Output Delay
Excess discharge-current detector Output Delay
Short Circuit detector Output Delay
20ms
12ms(C Type) / 6ms(E Type)
300µs(C Type) / 200µs(E Type)
• Output Delay Time Shortening Function..At COUT is “H”, if V- level is set at –2V, the Output Delay time of
all items except short-circuit can be reduced. (Delay Time for
over-charge becomes about 1/57 of normal state.)
• Conditions for release over-charge detector
With Latch function (C version)
With Released voltage (D/J/K version)
• Conditions for Release over-discharge detector
Latch Type: (C version)
Released Voltage (D/J/K version)
• Ultra Small package .................................SOT-23-5(R5475N) , SOT-23-6(R5478N)
APPLICATIONS
• Li+ / Li Polymer protector of over-charge, over-discharge, excess-current for battery pack
• High precision protectors for cell-phones and any other gadgets using on board Li+ / Li Polymer battery
-2-
R5475N/R5478Nxxxxx
BLOCK DIAGRAMS
C version
VDD
DS Circuit
Oscillator
Counter
Logic
Circuit
VD1
Level
Shift
Short
Detector
Delay
Logic
Circuit
VD2
VD3
VSS
DOUT
COUT
V-
D/J/K version
VDD
DS Circuit
Oscillator
Counter
Logic
Circuit
VD1
Level
Shift
Short
Detector
Delay
Logic
Circuit
VD2
VD3
VSS
DOUT
-3-
COUT
V-
R5475N/R5478Nxxxxx
SELECTION GUIDE
In the R5475/R5478xxxxx Series, three of the input threshold for over-charge, over-discharge, and excess
discharge current detectors can be designated.
Part Number is designated as follows:
R547xN xxx x x-xx-xx ←Part Number
a
b cd e
f
Code
Contents
a
Package Type R5475N: SOT-23-5 , R5478N: SOT-23-6
Serial Number for the R5475/R5478 Series designating input four threshold for
b
over-charge, over-discharge, and excess discharge-current detectors.
Designation of Output delay option of over-charge, and excess dis-
c
charge-current.
Designation of version symbols
C version: With Latch function after Over-charge and Over-discharge
D version: Released by voltage level from Over-charge and Over-discharge
d
J version: Released by voltage level from Over-charge and Over-discharge
Over-charge level = 3.65V Only
K version: Released by voltage level from Over-charge and Over-discharge
Over-charge level = 3.90V Only
e
Taping Type: TR (refer to Taping Specification)
f
FF:Using Pb-free solder.
PIN CONFIGURATIONS
SOT-23-5 (R5475N)
5
1
2
SOT-23-6 (R5478N)
4
6
5
4
3
1
2
3
-4-
R5475N/R5478Nxxxxx
PIN DESCRIPTION
Pin No.
Symbol
Description
SOT23-5
SOT23-6
4
1
DOUT
1
2
V-
5
3
COUT
Output of over-charge detection, CMOS output
4
NC
No Connection
2
5
VDD
Power supply pin, the substrate voltage level of the IC.
3
6
VSS
Vss pin. Ground pin for the IC
Output of over-discharge detection, CMOS output
Pin for charger negative input
ABSOLUTE MAXIMUM RATINGS
Symbol
VDD
V-
VSS=0V
Item
Ratings
Supply voltage
Input Voltage
V- pin
Unit
-0.3 to 12
V
VDD -30 to VDD +0.3
V
Output voltage
VCOUT
COUT pin
VDD -30 to VDD +0.3
V
VDOUT
DOUT pin
VSS -0.3 to VDD +0.3
V
Power dissipation
150
Topt
Operating temperature range
-40 to 85
°C
Tstg
Storage temperature range
-55 to 125
°C
PD
mW
*Note: Exposure to the condition exceeded Absolute Maximum Ratings may cause the permanent
damages and affects the reliability and safety of both device and systems using the device.
The functional operations cannot be guaranteed beyond specified values in the Recommended conditions.
Electronic and mechanical stress momentarily exceeded absolute maximum ratings may cause permanent
damage and may degrade the life time and safety for both device and system using the device in the field.
The functional operation at or over these absolute maximum ratings is not assured.
RECOMMENDED OPERATING CONDITIONS (ELECTRICAL CHARACTERISTICS)
All of electronic equipment should be designed that the mounted semiconductor devices operate within the
recommended operating conditions. The semiconductor devices cannot operate normally over the recommended operating conditions, even if they are used over such conditions by momentary electronic noise or
surge. And the semiconductor devices may receive serious damage when they continue to operate over the
-5-
R5475N/R5478Nxxxxx
Unless otherwise specified, Topt=25°C
*R5478N1xxEC
Symbol
VDD1
Item
Conditions
Operating input voltage
Voltage defined asVDD-VSS
Minimum operating Voltage for 0V
charging
Voltage defined asVDD-V-,
VDD-VSS=0V
VDET1
Over-charge threshold
Detect rising edge of supply voltage
R1=330Ω
R1=330Ω (Topt=-5 to 55°C)*Note1
tVDET1
Output delay of over-charge
tVREL1
Vst
Min.
Typ.
1.5
Max.
Unit
Note2
5.0
V
F
1.8
V
A
VDET1-0.025
VDET1-0.030
VDET1
VDET1
VDET1+0.025
VDET1+0.030
V
V
B
VDD=3.6V to 4.4V
0.7
1.0
1.3
s
B
Output delay of release from over-charge
VDD=4.5V to 3.6V, V-=0V to 0.4V
11
16
21
ms
C
VDET2
Over-discharge threshold
Detect falling edge of supply voltage
VDET2×0.975
VDET2
VDET2×1.025
V
D
tVDET2
Output delay of over-discharge
VDD=3.6V to 2.2V
14
ms
D
tVREL2
Output delay of release from over-discharge
VDD=2.2V to 3.6V
0.7
1.2
1.7
ms
D
VDET3
Detect rising edge of 'V-' pin voltage
VDET3-0.015
VDET3
VDET3+0.015
V
E
tVDET3
Output delay of excess discharge-current
VDD=3.0V, V-=0V to 0.4V
4
6
8
ms
E
VDD=3.0V, V-=3V to 0V
0.7
1.2
1.7
ms
tVREL3
Output delay of release from excess
discharge-current
E
Vshort
Short protection voltage
VDD=3.0V
0.50
0.75
0.95
V
E
Tshort
Output Delay of Short protection
VDD=3.0V, V-=0V to 3V
150
200
300
µs
E
Rshort
Reset resistance for Excess discharge-current protection
VDD=3.6V, V-=1V
25
50
75
kΩ
F
VDS
Delay Shortening Mode input voltage
VDD=4.4V
-2.6
-2.0
-1.4
V
G
VOL1
Nch ON voltage of COUT
Iol=50µA, VDD=4.5V
0.4
0.5
V
H
VOH1
Pch ON voltage of COUT
Ioh=-50µA, VDD=3.9V
V
I
VOL2
Nch ON voltage of DOUT
Iol=50µA, VDD=2.0V
V
J
VOH2
Pch ON voltage of DOUT
Ioh=-50µA, VDD=3.9V
V
K
Supply current
VDD=3.9V, V- =0V
7.0
µA
L
Standby current
VDD=2.0V
0.1
µA
L
IDD
IS
3.4
3.7
0.2
3.4
0.5
3.7
3.0
*Note1: Considering of variation in process parameters, we compensate for this characteristic related to temperature by laser-trim, however, this
specification is guaranteed by design, not mass production tested.
*Note2: indicates test circuits shown in page 17-20.
-6-
R5475N/R5478Nxxxxx
*R5475N/R5478N1xxCD
Symbol
VDD1
Item
Conditions
Min.
Typ.
Unit
Note2
5.0
V
F
1.8
V
A
charging
VDD-VSS=0V
VDET1
R1=330Ω
VDET1-0.025
VDET1-0.030
VDET1
VDET1
VDET1+0.025
VDET1+0.030
V
V
B
VREL1
Released Voltage from Over-charge
VREL1-0.05
VREL1
VREL1+0.05
V
B
tVDET1
VDD=3.6V to 4.4V
0.7
1.0
1.3
s
B
tVREL1
VDD=4.5V to 3.6V
11
16
21
ms
B
VDET2
VDET2×0.975
VDET2
VDET2×1.025
V
D
VREL2
Released Voltage from Over-discharge
VREL2×0.975
VREL2
VREL2×1.025
V
D
tVDET2
VDD=3.6V to 2.2V
14
ms
D
tVREL2
VDD=3V V-=3V to 0V
0.7
1.2
1.7
ms
E
VDET3
VDET3-0.015
VDET3
VDET3+0.015
V
E
tVDET3
8
12
16
ms
E
0.7
1.2
1.7
ms
Vst
tVREL3
discharge-current
1.5
Max.
E
Vshort
VDD=3.0V
0.50
0.75
0.95
V
E
Tshort
230
300
500
µs
E
Rshort
VDD=3.6V, V-=1V
25
50
75
kΩ
F
VDS
VDD=4.4V
-2.6
-2.0
-1.4
V
G
VOL1
Iol=50µA, VDD=4.5V
0.4
0.5
V
H
VOH1
Ioh=-50µA, VDD=3.9V
V
I
VOL2
Iol=50µA, VDD=2.0V
V
J
VOH2
Ioh=-50µA, VDD=3.9V
V
K
Supply current
VDD=3.9V, V- =0V
3.0
7.0
µA
L
Standby current
VDD=2.0V
1.2
2.0
µA
L
IDD
IS
3.4
3.7
0.2
3.4
0.5
3.7
*Note: Considering of variation in process parameters, we compensate for this characteristic related to temperature by laser-trim, however, this
-7-
R5475N/R5478Nxxxxx
*R5478N1xxCJ
Symbol
VDD1
Item
Conditions
Min.
Typ.
Unit
Note2
5.0
V
F
1.8
V
A
VDET1+0.025
VDET1+0.030
V
V
B
VREL1+0.05
V
B
charging
VDD-VSS=0V
VDET1
R1=330Ω
VDET1-0.025
VDET1-0.030
VREL1
VREL1-0.05
tVDET1
VDD=3.2V to 3.75V
0.7
1.0
1.3
s
B
tVREL1
VDD=3.9V to 3.2V
11
16
21
ms
B
VDET2
VDET2×0.975
VDET2
VDET2×1.025
V
D
VREL2
VREL2×0.975
VREL2
VREL2×1.025
V
D
tVDET2
VDD=3.2V to 2.2V
14
ms
D
tVREL2
VDD=2V to 3.1V
0.7
1.2
1.7
ms
E
VDET3
VDET3-0.015
VDET3
VDET3+0.015
V
E
tVDET3
8
12
16
ms
E
0.7
1.2
1.7
ms
Vst
tVREL3
discharge-current
1.5
Max.
VDET1
VDET1
VREL1
E
Vshort
VDD=3.0V
0.50
0.75
0.95
V
E
Tshort
230
300
500
µs
E
Rshort
VDD=3.2V, V-=1.0V
25
50
75
kΩ
F
VDS
VDD=4.4V
-2.6
-2.0
-1.4
V
G
VOL1
Iol=50µA, VDD=4.5V
0.4
0.5
V
H
VOH1
Ioh=-50µA, VDD=3.2V
V
I
VOL2
Iol=50µA, VDD=2.0V
V
J
VOH2
Ioh=-50µA, VDD=3.2V
V
K
Supply current
VDD=3.2V, V- =0V
3.0
7.0
µA
L
Standby current
VDD=2.0V
1.2
2.0
µA
L
IDD
IS
2.7
3.0
0.2
2.7
0.5
3.0
-8-
R5475N/R5478Nxxxxx
*R5478N1xxCK
Symbol
VDD1
Item
Conditions
Min.
Typ.
Unit
Note2
5.0
V
F
1.8
V
A
VDET1+0.025
VDET1+0.030
V
V
B
VREL1+0.05
V
B
charging
VDD-VSS=0V
VDET1
R1=330Ω
VDET1-0.025
VDET1-0.030
VREL1
VREL1-0.05
tVDET1
VDD=3.2V to 3.75V
0.7
1.0
1.3
s
B
tVREL1
VDD=3.9V to 3.2V
11
16
21
ms
B
VDET2
VDET2×0.975
VDET2
VDET2×1.025
V
D
VREL2
VREL2×0.975
VREL2
VREL2×1.025
V
D
tVDET2
VDD=3.2V to 1.9V
14
ms
D
tVREL2
VDD=1.9V to 3.1V
0.7
1.2
1.7
ms
E
VDET3
VDET3-0.015
VDET3
VDET3+0.015
V
E
tVDET3
8
12
16
ms
E
0.7
1.2
1.7
ms
Vst
tVREL3
discharge-current
1.5
Max.
VDET1
VDET1
VREL1
E
Vshort
VDD=3.0V
0.50
0.75
0.95
V
E
Tshort
230
300
500
µs
E
Rshort
VDD=3.2V, V-=1.0V
25
50
75
kΩ
F
VDS
VDD=4.4V
-2.6
-2.0
-1.4
V
G
VOL1
Iol=50µA, VDD=4.5V
0.4
0.5
V
H
VOH1
Ioh=-50µA, VDD=3.2V
V
I
VOL2
Iol=50µA, VDD=1.9V
V
J
VOH2
Ioh=-50µA, VDD=3.2V
V
K
Supply current
VDD=3.2V, V- =0V
3.0
7.0
µA
L
Standby current
VDD=2.0V
1.2
2.0
µA
L
IDD
IS
2.7
3.0
0.2
2.7
0.5
3.0
-9-
R5475N/R5478Nxxxxx
OPERATION
• VD1 / Over-Charge Detector
The VD1 monitors VDD pin voltage while charge the battery pack. When the VDD voltage crosses over-charge
detector threshold VDET1 from a low value to a value higher than the VDET1, the VD1 can detect over-charge and
an external charge control Nch MOSFET turn off with COUT pin being at "L" level.
In terms of C version, to reset the VD1 making the COUT pin level to "H" again after detecting over-charge, in
such conditions that a time when the VDD voltage is down to a level lower than over-charge voltage, by connecting a kind of loading to VDD after disconnecting a charger from the battery pack. Output voltage of COUT pin
becomes "H", and it makes an external Nch MOSFET turn on, and charge cycle is available. In other words,
once over-charge is detected, even if the supply voltage becomes low enough, if a charger is continuously
connected to the battery pack, recharge is not possible. Therefore this over-charge detector has no hysteresis.
To judge whether or not load is connected, the built-in excess-discharge current detector is used. In other
words, by connecting some load, V- pin voltage becomes equal or more than excess-discharge current detector
threshold, and reset the over-charge detecting state.
In terms of D/J/K version, after detecting over-charge, if VDD pin voltage is lower than released from
over-charge, even if a charger is connected, over-charge detector is released. Further, in case that VDD pin level
is lower than detector threshold and higher than released voltage from over-charge, if a charger is removed and
some load is connected, over-charge detector is also released.
After detecting over-charge with the VDD voltage of higher than VDET1, connecting system load to the battery
pack makes load current allowable through parasitic diode of external charge control FET.
The COUT level would be "H" when the VDD level is down to a level below the VDET1 by continuous drawing of
load current.
Internal fixed output delay times for over-charge detection and release from over-charge exist. Even when
the VDD pin level becomes equal or higher level than VDET1 if the VDD voltage would be back to a level lower than
the VDET1 within a time period of the output delay time, VD1 would not output a signal for turning off the charge
control FET. Besides, after detecting over-charge, while the VDD is lower than over-charge detector, even if a
charger is removed and a load is connected, if the voltage is recovered within output delay time of release from
over-charge, over-charge state is not released.
A level shifter incorporated in a buffer driver for the COUT pin makes the "L" level of COUT pin to the V - pin
voltage and the "H" level of COUT pin is set to VDD voltage with CMOS buffer.
• VD2 / Over-Discharge Detector
The VD2 is monitoring a VDD pin voltage. When the VDD voltage crosses the over-discharge detector threshold
VDET2 from a high value to a value lower than the VDET2, the VD2 can detect an over-discharge and the external
discharge control Nch MOSFET turns off with the DOUT pin being at "L" level.
In terms of C version, to reset the VD2 with the DOUT pin level being "H" again after detecting over discharge,
it is necessary to connect a charger to the battery pack. When the VDD voltage stays under over-discharge
detector threshold VDET2, charge-current can flow through parasitic diode of an external discharge control
MOSFET, then after the VDD voltage comes up to a value larger than VDET2, then, DOUT becomes "H" and discharging process would be able to advance through ON state MOSFET for discharge control.
Connecting a charger to the battery pack makes the DOUT level being "H" instantaneously when the VDD
voltage is higher than VDET2.
In terms of D/J/K version, released operation by connecting a charger is same as C version. However, without
a charger, if VDD pin voltage is equal or more than the released voltage from over-discharge, DOUT pin becomes
“H” immediately.
- 10 -
R5475N/R5478Nxxxxx
When a cell voltage equals to zero, if the voltage of a charger is equal or more than 0V-charge minimum
voltage (Vst), COUT pin becomes "H" and a system is allowable to charge.
An output delay time for over-discharge detection is fixed internally. When the VDD level is down to a equal or
lower level than VDET2 if the VDD voltage would be back to a level higher than the VDET2 within a time period of the
output delay time, VD2 would not output a signal for turning off the discharge control FET. Output delay time
for release from over-discharge is also set.
After detecting over-discharge by VD2, supply current would be reduced and be into standby by halting
unnecessary circuits and consumption current of IC itself is made as small as possible.
The output type of DOUT pin is CMOS having "H" level of VDD and "L" level of VSS.
• VD3 /Excess discharge-current Detector, Short Circuit Protector
Both of the excess current detector and short circuit protection can work when the both of control FETs are
in "ON" state.
When the V- pin voltage is up to a value between the short protection voltage Vshort /VDD and excess
discharge-current threshold VDET3, VD3 operates and further soaring of V- pin voltage higher than Vshort
makes the short circuit protector enabled. This leads the external discharge control Nch MOSFET turns off
An output delay time for the excess discharge-current detector is internally fixed.
A quick recovery of V- pin level from a value between Vshort and VDET3 within the delay time keeps the discharge
control FET staying "H" state. Output delay time for Release from excess discharge-current detection is also
set.
When the short circuit protector is enabled, the DOUT would be "L" and the delay time is also set.
The V - pin has a built-in pull-down resistor to the Vss pin, that is, the resistance to release from excess-discharge current.
After an excess discharge-current or short circuit protection is detected, removing a cause of excess discharge-current or external short circuit makes an external discharge control FET to an "ON" state automatically with the V- pin level being down to the VSS level through built-in pulled down resistor. The reset resistor of
excess discharge-current is off at normal state. Only when detecting excess discharge-current or short circuit,
the resistor is on.
Output delay time of excess discharge-current is set shorter than the delay time for over-discharge detector.
Therefore, if VDD voltage would be lower than VDET2 at the same time as the excess discharge-current is detected,
the R5478xxxxxx is at excess discharge-current detection mode. By disconnecting a load, VD3 is automatically
released from excess discharge-current.
• DS (Delay Shorten) function
Output delay time of over-charge, over-discharge, and release from those detecting modes can be shorter
than those setting value by forcing equal or less than the delay shortening mode voltage to V- pin.
- 11 -
R5475N/R5478Nxxxxx
TIMING CHART
1. Over-charge (Latch Type) voltage, Excess charge current Operation
Connect Charger
Connect
Load
Connect Charger
Connect
Load
Disconnect
Charger and
Connect Load
VDET1
VDD
t
VDD
V-
VDET3
VSS
t
tVDET1
tVDET1
VDD
COUT
tVREL1
tVREL1
t
V−
Charge Current
Charge/
Discharge
Current
t
Discharge Current
- 12 -
R5475N/R5478Nxxxxx
2. Over-charge (Released by voltage Type) voltage, Excess charge current Operation
Connect Charger
Disconnect
Charger
Connect Charger
Connect
Load
Charger OPEN
Connect Load
VDET1
VREL1
VDD
t
VDD
V-
VDET3
VSS
t
tVDET1
tVDET1
VDD
COUT
tVREL1
tVREL1
V-
t
t
Charge Current
Charge/
Discharge
Current
Discharge Current
- 13 -
R5475N/R5478Nxxxxx
3. Over-discharge (Latch Type), Excess discharge current, Short circuit
Connect Load
Connect
Charger
Connect Load
Connect
Charger
Excess
Discharge
Current
Short
Open
Open
VDD
VDET2
t
VDD
Vshort
V-
VDET3
VSS
t
tVDET2
tVDET3
tVDET2
tshort
VDD
DOUT
tVREL2
tVREL2
tVREL3
tVREL3
t
VSS
Charge Current
Charge /
Discharge
Current
t
Discharge Current
- 14 -
R5475N/R5478Nxxxxx
4. Over-discharge (Released by voltage Type), Excess discharge current, Short circuit
Connect
Charger
Connect Load
VDD
Excess
Discharge
Short
Current
Open
Open
VDET2
t
VDD
Vshort
V-
VDET3
VSS
t
tVDET2
tVDET2
tVDET3
tshort
VDD
DOUT
tVREL2
tVREL2
tVREL3
tVREL3
t
VSS
Charge Current
Charge/
Discharge
Current
t
Discharge Current
- 15 -
R5475N/R5478Nxxxxx
TYPICAL APPLICATION
R1
330Ω
VDD
C1
0.01uF
R5478
VVSS
DOUT
COUT
R2
1kΩ
APPLICATION HINTS
R1 and C1 will stabilize a supply voltage to the R5478xxxxxx. A recommended R1 value is less than 1kΩ. A
larger value of R1 leads higher detection voltage, makes some errors because of some conduction current may
flow in the R5478xxxxxx.
Further, to stabilize the operation of the R5478, use the C1 with the value in the range from 0.001uF to
0.01uF. To choose the most suitable value of C1, fully evaluation is necessary.
R1 and R2 can operate also as parts for current limit circuit against reverse charge or applying a charger
with excess charging voltage to the R5478xxxxxx, battery pack. Small value of R1 and R2 may cause
over-power consumption rating of power dissipation of the R5478xxxxx. Thus, the total value of 'R1+R2' should
be equal or more than 1kΩ.
On the other hand, if large value of R2 is set, release from over-discharge by connecting a charger might not
be possible. Recommended R2 value is equal or less than 10kΩ.
The typical application circuit diagram is just an example. This circuit performance largely depends on the
PCB layout and external components. In the actual application, fully evaluation is necessary.
Over-voltage and the over current beyond the absolute maximum rating should not be forced to the protection IC and external components.
We are making our continuous effort to improve the quality and reliability of our products, but semiconductor products are likely to fail with certain probability. In order prevent any injury to persons or damages to
property resulting from such failure, customers should be careful enough to incorporate safety measures in
their design, such as redundancy feature, fire-containment feature and fail-safe feature.
We do not assume any liability or responsibility for any loss or damage arising from misuse or inappropriate
use of the products.
- 16 -
R5475N/R5478Nxxxxx
TEST CIRCUITS
1, Minimum Operating Voltage for 0V Charging(0V battery charge function “available”)(Test circuit A)
The minimum operating voltage for 0V charging (Vst) is defined as the voltage between the VDD pin and the
V- pin at which COUT goes to “H” (VDD - 0.1V or higher) when the voltage V2 is gradually decreased from the
starting condition of V1 = 0V ,V2 = -0.3V.
2, Over-charge Threshold Voltage (Test circuit B)
The over-charge threshold voltage(VDET1) is defined as the voltage between the VDD pin and the VSS pin
at which COUT goes from “H” to “L” when the voltage V1 is gradually increased from the starting condition of
V1 = 3.5V with R1=330Ω between VDD and Pack+.
3, Release voltage from Over-charge (Test circuit B) *Except EC version
The release voltage from over-charge (VREL1) is defined as the voltage between the VDD pin and the VSS
pin at which COUT goes from “L” to “H” when the voltage V1 is then gradually decreased with R1=330Ω
4, Output Delay of Over-charge (Test circuit B)
The output delay of over-charge (tVDET1) is the time needed for COUT to change from “H” to “L” just after the
voltage V1 momentarily increases (within 10µs) from over-charge threshold voltage (VDET1) – 0.2V to
over-charge threshold voltage (VDET1) + 0.2V under the set conditions of V2 = 0V.
5, Release Delay for VD1 (Test circuit B) *Except EC version
The release Delay for VD1 (tVREL1) is the time needed for COUT to change from “L” to “H” just after the
voltage V1 momentarily decreases (within 10µs) from over-charge threshold voltage (VDET1) + 0.2V to
overcharge release voltage (VREL1) - 0.2V under the set conditions of V2 = 0V.
6, Release Delay for VD1 (Test circuit C) *for EC version
voltage V2 momentarily increases (within 10µs) from 0V to excess discharge-current threshold (VDET3) +
0.1V under the set conditions of V1 from over-charge threshold voltage (VDET1) + 0.2V to over-charge
threshold voltage (VDET1) - 0.2V.
7, Overdischarge Threshold Voltage (Test circuit D)
The overdischarge threshold voltage(VDET2) is defined as the voltage between the VDD pin and the VSS pin
at which DOUT goes from “H” to “L” when the voltage V1 is gradually decreased from the starting condition of
V1 = 3.5V , V2 = 0V.
8, Released Voltage from Over-discharge (Test circuit E) *Except EC version
The released voltage from over-discharge (VREL2) is defined as the voltage between the VDD pin and the
VSS pin at which DOUT goes from “L” to “H” when the voltage V1 is then gradually increased under the set
conditions of V2 = V1.
9, Output Delay of Over-discharge (Test circuit D)
The output delay of over-discharge (tVDET2) is the time needed for DOUT to change from “H” to “L” just after
the voltage V1 momentarily decreases (within 10µs) from over-discharge threshold voltage (VDET2) + 0.2V to
over-discharge threshold voltage (VDET2) - 0.2V under the set conditions of V2 = 0V.
10, Release Delay for VD2 (Test circuit E) *Except EC version
The release delay for VD2 (tVREL2) is the time needed for DOUT to change from “L” to “H” just after the
voltage V1 momentarily increases (within 10µs) from over-discharge threshold voltage (VDET2) - 0.2V to
- 17 -
R5475N/R5478Nxxxxx
over-discharge release voltage (VREL2) + 0.2V under the set conditions of V2 = V1.
11, Release Delay for VD2 (Test circuit D) *For EC version
over-discharge release voltage (VREL2) + 0.2V under the set conditions of V2 = 0V.
12, Excess discharge-current threshold (Test circuit E)
Excess discharge-current threshold (VDET3) is defined as the voltage between the V- pin and the VSS pin at
which DOUT goes from “H” to “L” when the voltage V2 is then gradually increased from the starting condition
of V1 = 3.0V , V2 = 0V.
13, Output delay of excess discharge-current, Release Delay for VD3 (Test circuit E)
The output delay of excess discharge-current (tVDET3) is the time needed for DOUT to go to “L” after the
voltage V2 momentarily increases (within 10µs) from 0V to 0.40V under the set conditions of V1 =3.0V.
The Release Delay for VD3 (tVREL3) is the time needed for DOUT to go to “H” after the voltage V2 momentarily decreases (within 10µs) from 3.0V to 0V under the set conditions of V1 =3.0V.
14, Short Protection Voltage (Test circuit E)
The short protection voltage (Vshort) is defined as the voltage between the V- pin and the VSS pin whose
delay time for changing DOUT from “H” to “L” lies between the minimum and the maximum value of load
short-circuiting delay time when the voltage V2 is increased rapidly (within 10µs) from the starting
condition of V1 = 3.0V , V2 = 0V.
15, Delay Time for Short Protection (Test circuit E)
The delay time for short protection (tshort) is the time needed for DOUT to go to “L” after the voltage V2
momentarily increases (within 10µs) from 0V to 3.0V under the set conditions of V1 =3.0V.
16, Reset Resistance for Excess Current Protection (Test circuit F)
The Reset Resistance for Excess Current Protection (Rshort) is the resistance between the V- pin and the
VSS pin under the set conditions of V1 =3.6V, V2 = 1.0V.
17, Delay Time Shortening Mode Voltage (Test circuit G)
The Delay Time Shortening Mode Voltage (VDS) is the voltage is defined as the voltage between the V- pin
and VSS pin at which tVDET1 becomes about 1/57 at V2 = 0V when the voltage V2 is then gradually decreased from the starting condition of V2 = 0V.
18, Nch ON-Voltage of COUT (Test circuit H)
The Nch ON-Voltage of COUT (VoL1) is the resistance at the COUT pin under the set conditions of V1 = 4.5V,
V2 = 0V, I3 = 50uA.
19, Pch ON-Voltage of COUT (Test circuit I)
The Pch ON-Voltage of COUT (VoH1) is the Voltage at the COUT pin under the set conditions of V1 = 3.9V for
EC,CD version / 3.8V for CK version / 3.5V for CJ version, V2 = 0V, I3 = -50uA.
20, Pch ON-Voltage of DOUT (Test circuit J)
Pch ON-Voltage of DOUT (VoH2) is the Voltage at the DOUT pin under the set conditions of V1 = 3.9V for
EC,CD version / 3.8V for CK version / 3.5V for CJ version, V2 = 0V, I4 = -50uA.
- 18 -
R5475N/R5478Nxxxxx
21, Nch ON-Voltage of DOUT (Test circuit K)
Nch ON-Voltage of DOUT (VoL2) is the Voltage at the DOUT pin under the set conditions of V1 = 2.0V, V2 = 0V,
I4 = 50uA.
22, Supply Current (Test circuit L)
The supply current (IDD) is the current that flows through the VDD pin(IDD) under the set conditions of V1 =
3.9V for EC,CD version / 3.8V for CK version / 3.5V for CJ version and V2 = 0V (normal status).
23, Standby Current (Test circuit L)
The standby current (Istandby) is the current that flows through the VDD pin(IDD) under the set conditions of
V1 = V2 = 2.0V (overdischarge status).
V1 : The voltage between VDD pin and VSS pin.
V2 : The voltage between V- pin and VSS pin.
I3 : The current flow into COUT pin.
I4 : The current flow into DOUT pin.
- 19 -
R5475N/R5478Nxxxxx
A
G
VDD
VDD
V
V-
VCOUT
VSS
COUT
V
VSS
OSCILLOSCOPE
B
VDD
H
COUT
V-
V
VDD
V-
VSS
C
VDD COUT A
I
COUT
V-
V-
VSS
V
VSS
VDD
J
DOUT
V-
V
V
VSS
VDD
D
COUT A
VDD
V-
VSS
DOUT A
VSS
E
V
VDD
VDD DOUT A
K
DOUT
V-
V-
VSS
VSS
F
VDD
A
V-
L
DOUT
VDD
A
V
VSS
VVSS
- 20 -
V
R5475N/R5478Nxxxxx
Typical Characteristics were obtained with using those above circuits:
Test Circuit A: Typical characteristics 1)
Test Circuit B: Typical characteristics 2)
Test Circuit C: Typical characteristics 3) 4)
Test Circuit D: Typical characteristics 5) 6) 7)
Test Circuit E: Typical characteristics 8) 9) 10) 11) 12)
Test Circuit F: Typical characteristics 13)
Test Circuit G: Typical characteristics 14)
Test Circuit H: Typical characteristics 15)
Test Circuit I: Typical characteristics 16)
Test Circuit J: Typical characteristics 17)
Test Circuit K: Typical characteristics 18)
Test Circuit L: Typical characteristics 19) 20)
- 21 -
R5475N/R5478Nxxxxx
TYPICAL CHARACTERISTICS
1)
2)
Minimum Operating Voltage for 0V Cell Charging vs. Temperature
Over-Charge Threshold vs. Temperature
2
1.8
1.6
1.4
1.2
1
0.8
0.6
0.4
0.2
100
4.31
4.3
4.29
4.28
4.27
4.26
4.25
-50
4)
Temperature Topt
(°C)
100
Output Delay of Release from Over-charge vs. Temperature
R5478N128EC
Over-charge Released Delay Time
tVREL1(ms)
30
1.6
1.4
1.2
1
0.8
0.6
0.4
0.2
25
10
5
Temperature Topt
-50
100
(°C)
Over discharge Threshold vs. Temperature
R5478N128EC
6)
2.82
2.81
2.8
2.79
2.78
2.77
-50
Temperature Topt
- 22 -
100
30
25
10
5
Temperature Topt
(°C)
(°C)
35
-50
100
Temperature Topt
Output Delay of Over-discharge vs. Temperature
R5478N128EC
Over-discharge Detector Output Dekay
Time tVDET2(ms)
2.83
Over-discharge Detector Threshold
VDET2(V)
4.32
(°C)
1.8
-50
5)
Temperature Topt
Output Delay of Over-charge vs. Temperature
R5478N128EC
Over-charge Detector Output Delay Time
tVDET1(s)
3)
R5478N128EC
Over-charge Detector Threshold VDET1(V)
0V cell Charge Minimum Operating
Voltage Vst(V)
R5478N128EC Vdd-Vss=0V
100
(°C)
R5475N/R5478Nxxxxx
Output Delay of Release from Over-discharge vs.
Temperature
R5478N128EC
1.8
Excess Discharge Current Detector
Threshold VDET3(V)
1.6
1.4
1.2
0.06
0.055
1
0.8
0.6
0.05
0.045
0.4
0.2
Temperature Topt
100
(°C)
Output Delay of Excess Discharge-current vs.
Temperature
R5478N128EC
18
Output Delay Time for Excess
discharge current Detecting
tVDET3(ms)
Excess Discharge-current Threshold vs.
Temperature
R5478N128EC
0.065
-50
9)
8)
16
14
12
10
8
6
4
2
Temperature Topt
100
0.04
0.035
-50
100
1.6
1.4
1.2
1
0.8
0.6
0.4
0.2
Temperature Topt
(°C)
100
12) Output Delay of Short Protection vs. Temperature
R5478N128EC
R5478N128EC
0.95
700
0.9
Short Detector Output Delay Time
tshort(us)
Short Detector Threshold Vshort(V)
(°C)
1.8
(°C)
11) Short Detector Voltage vs. Temperature
Temperature Topt
10) Output Delay of Release from Excess Dichargecurrent vs. Temperature
R5478N128EC
Output Delay Time for Release Excess
Discharge Current tVREL3(ms)
Output Delay for Release from Overdischarge tVREL2(ms)
7)
0.85
0.8
0.75
0.7
0.65
0.6
0.55
0.5
-50
Temperature Topt
100
(°C)
600
500
400
300
200
100
- 23 -
Temperature Topt
(°C)
100
R5475N/R5478Nxxxxx
13) Reset Resistance for Excess Discharge
current Protection vs. Temperature
R5478N128EC
14) V- pin Test time shortening input Voltage vs.
Temperature
R5478N128EC
V- pin Test shortening input Voltage
VIH(V)
Release Resistance for Excess Discharge
Current Rshort(kohm)
80
70
60
50
40
-1.4
-1.6
-1.8
-2
-2.2
-2.4
-2.6
-50
30
-50
Temperature Topt
(°C)
100
16) Pch On Voltage (COUT pin) vs. Temperature
Ioh=-50uA, Vdd=3.9V
R5478N128EC
3.9
0.5
0.4
0.3
0.2
0.1
Temperature Topt
100
Pch ON Voltage (Cout pin) Voh1(V)
Nch ON Voltage (Cout pin) Vol1(V)
100
(°C)
15) Nch On Voltage (COUT pin) vs. Temperature
IOL=50uA,Vdd=4.5V
R5478N128EC
3.8
3.7
3.6
3.5
-50
(°C)
17) Nch On Voltage (DOUT pin) vs. Temperature
Iol=50uA, VDD=2V
R5478N128EC
0.4
0.3
0.2
0.1
Temperature Topt
Temperature Topt
(°C)
100
18) Pch ON Voltage of DOUT vs. Temperature
Ioh=-50uA, Vdd=3.9V
R5478N128EC
Pch ON Voltage (Dout pin) Voh2 (V)
Nch ON Voltage (Dout pin) Vol2(V)
Temperature Topt
100
3.9
3.8
3.7
3.6
3.5
-50
(°C)
- 24 -
Temperature Topt
100
(°C)
R5475N/R5478Nxxxxx
19) Supply Current vs. Temperature
Vdd=3.9V, V-=0V
R5478N128EC
20) Standby Current vs. Temperature
Vdd=3.9V, V-=0V
R5478N128EC
6
0.1
Standby Current Is(uA)
Supply Current Idd (uA)
5
4
3
2
1
0.08
0.06
0.04
0.02
Temperature Topt
100
(°C)
- 25 -
Temperature Topt
(°C)
100
R5475N/R5478Nxxxxx
R5475N/R5478N Series
Code
R5478N128EC
R5478N176EC
R5478N101CD
R5478N102CD
R5478N106CD
R5478N110CD
R5478N120CD
R5478N149CD
R5478N163CD
R5478N173CD
R5478N187CD
R5478N204CD
R5478N205CD
R5478N215CD
R5478N216CD
R5478N217CD
R5478N218CD
R5478N184CJ
R5478N185CJ
R5478N242CD
R5478N248CD
R5478N203CK
R5475N110CD
(as of 2012/07/04)
Vdet1
(V)
4.280
4.280
4.250
4.350
4.275
4.280
4.325
4.280
4.280
4.200
4.250
4.200
4.200
4.200
4.170
4.325
4.250
3.650
3.650
4.180
4.280
3.900
4.280
Vrel1
(V)
4.050
4.150
4.075
4.080
4.125
4.080
4.100
4.100
4.050
3.900
3.900
4.100
4.170
4.125
4.050
3.650
3.450
4.080
4.080
3.800
4.080
Vdet2
(V)
2.800
2.300
2.500
2.500
2.300
2.300
2.300
2.900
3.000
2.800
3.000
2.500
3.000
2.500
2.500
2.300
2.800
2.500
2.500
2.500
2.300
2.000
2.300
Vrel2
(V)
3.000
3.000
3.000
3.000
3.000
3.100
3.200
2.900
3.200
3.000
3.200
3.000
3.000
3.000
3.000
3.000
3.000
3.000
2.800
2.500
3.000
Vdet3
(V)
0.050
0.130
0.200
0.200
0.100
0.125
0.150
0.125
0.100
0.100
0.150
0.200
0.200
0.100
0.100
0.200
0.150
0.200
0.200
0.200
0.150
0.100
0.125
tVdet1
(s)
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
tVdet2
(ms)
tVdet3
(ms)
6
6
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
12
R5478 N 128 E C
Package Type
R5475N : SOT23-5
R5478N : SOT23-6
Function Version
C : Over-Charge = Latch
Over-Discharge = Latch
D : Over-Charge = Auto-Release Over-Discharge = Auto Release
J : Over-Charge = Auto-Release Over-Discharge = Auto Release
Vdet1=3.65V only
K : Over-Charge = Auto-Release Over-Discharge = Auto Release
Vdet1=3.90V only Vdet2=1.9~3.0V
Delay Time Version
Voltage Version
Return from
Over-Charge
Latch
R5478N xxx EC
R5475N xxx CD Auto-Release
R5478N xxx CD Auto-Release
R5478N xxx CJ Auto-Release
R5478N xxx CK Auto-Release
Code
0V
tShort
Package
(μs) Charge
200
OK
SOT-23-6
200
OK
SOT-23-6
300
OK
SOT-23-6
300
OK
SOT-23-6
300
OK
SOT-23-6
300
OK
SOT-23-6
300
OK
SOT-23-6
300
OK
SOT-23-6
300
OK
SOT-23-6
300
OK
SOT-23-6
300
OK
SOT-23-6
300
OK
SOT-23-6
300
OK
SOT-23-6
300
OK
SOT-23-6
300
OK
SOT-23-6
300
OK
SOT-23-6
300
OK
SOT-23-6
300
OK
SOT-23-6
300
OK
SOT-23-6
300
OK
SOT-23-6
300
OK
SOT-23-6
300
OK
SOT-23-6
300
OK
SOT-23-5
Return from
tVdet1
(s)
Over-Discharge
Latch
1
Auto-Release
1
Auto-Release
1
Auto-Release
1
Auto-Release
1
- 26 -
tVdet2
(ms)
tVdet3
(ms)
6
12
12
12
12
tShort
(μs)
200
300
300
300
300
1. The products and the product specifications described in this document are subject to change or discontinuation of
production without notice for reasons such as improvement. Therefore, before deciding to use the products, please refer
to our sales representatives for the latest information thereon.
2. The materials in this document may not be copied or otherwise reproduced in whole or in part without prior written
consent of our company.
3. Please be sure to take any necessary formalities under relevant laws or regulations before exporting or otherwise
taking out of your country the products or the technical information described herein.
4. The technical information described in this document shows typical characteristics of and example application circuits
for the products. The release of such information is not to be construed as a warranty of or a grant of license under
our company's or any third party's intellectual property rights or any other rights.
5. The products listed in this document are intended and designed for use as general electronic components in standard
applications (office equipment, telecommunication equipment, measuring instruments, consumer electronic products,
amusement equipment etc.). Those customers intending to use a product in an application requiring extreme quality and
reliability, for example, in a highly specific application where the failure or misoperation of the product could result in
human injury or death (aircraft, spacevehicle, nuclear reactor control system, traffic control system, automotive and
transportation equipment, combustion equipment, safety devices, life support system etc.) should first contact us.
6. We are making our continuous effort to improve the quality and reliability of our products, but semiconductor products
are likely to fail with certain probability. In order to prevent any injury to persons or damages to property resulting from
such failure, customers should be careful enough to incorporate safety measures in their design, such as redundancy
feature, fire containment feature and fail-safe feature. We do not assume any liability or responsibility for any loss or
damage arising from misuse or inappropriate use of the products.
7. Anti-radiation design is not implemented in the products described in this document.
8. The X-ray exposure can influence functions and characteristics of the products. Confirm the product functions and
characteristics in the evaluation stage.
9. WLCSP products should be used in light shielded environments. The light exposure can influence functions and
characteristics of the products under operation or storage.
10. There can be variation in the marking when different AOI (Automated Optical Inspection) equipment is used. In the case
of recognizing the marking characteristic with AOI, please contact our sales or our distributor before attempting to use
AOI.
11. Please contact our sales representatives should you have any questions or comments concerning the products or
the technical information.
Official website
https://www.nisshinbo-microdevices.co.jp/en/
Purchase information
https://www.nisshinbo-microdevices.co.jp/en/buy/
