RS2233YTSS16
RS2233YTSS16
    RUNIC(润石)
    TSSOP16
    多路复用芯片 4通道 SPDT 1.8V~5.5V TSSOP16
RS2233YTSS16 数据手册
RS2233 Wide-Bandwidth 4-Channel SPDT Video Analog Switch FEATURES • Wide Bandwidth: 220MHz • Single Supply Operation +1.8V to +5.5V • Low ON Resistance, 3Ω(TYP) Low Crosstalk: -58dB at 10MHz (TYP) • Rail-to-Rail Operation • Fast Switching Time • Operating Temperature Range: -40°C to +85°C • PACKAGES: SOIC-16(SOP16), SSOP-16, TSSOP-16 APPLICATIONS • Game Consoles • Audio and Video Switching • DVD Players • Personal Video Recorders • Supports defense, aerospace and medical applications • • DESCRIPTION The RS2233 is a CMOS analog IC configured as a quad, bidirectional, single-pole/double-throw (SPDT) switches. This CMOS device can operate from 1.8 V to 5.5 V. The select (IN) input control the data flow. The FET multiplexers/demultiplexers are disabled when the ̅̅̅̅) input is high. output-enable (OE The device are digitally-controlled analog switches. It has low on-resistance (3Ω TYP) and low crosstalk (-58dB at 10MHz TYP). The RS2233 is available in Green SOIC-16(SOP16), SSOP-16, TSSOP-16 packages. It operates over an ambient temperature range of -40°C to +85°C. Device Information (1) PART NUMBER RS2233 Desktop Video Editors Hard Disk Recorders REV A.2 (1) 1 / 13 PACKAGE BODY SIZE (NOM) SOIC-16(SOP16) 9.90mm×3.91mm SSOP-16 4.90mm×3.90mm TSSOP-16 5.00mm×4.40mm For all available packages, see the orderable addendum at the end of the data sheet. www.run-ic.com RS2233 Revision History Note: Page numbers for previous revisions may different from page numbers in the current version. Version Change Date A.1 2021/08/06 A.2 2021/12/09 Change Item Initial version completed (1) Change the Minimum operating voltage to 1.8V (2) Add the Junction temperature 2 / 13 www.run-ic.com RS2233 Pin Configuration and Function 2 4 1A 3 5 7 2A 6 4A 11 9 3A 12 OE 15 1B1 1B2 2B1 2B2 3B1 10 3B2 14 4B1 13 4B2 DECODER/DRIVERS 1 IN FUNCTION TABLE INPUTS FUNCTION 𝐎𝐄 IN L L A port =B1 port L H A port =B2 port H X Disconnect X=Don’t care NOTE: Input and output pins are identical and inter-changeable. Either may be considered an input or output; signals pass equally well in either direction. 3 / 13 www.run-ic.com RS2233 PIN CONFIGURATIONS (TOP VIEW) IN 1 16 VCC 1B1 2 15 OE 1B2 3 14 4B1 1A 4 2B1 5 2B2 6 11 3B1 2A 7 10 3B2 GND 8 9 RS2233 13 4B2 12 4A 3A SOIC-16(SOP16)/SSOP-16/ TSSOP-16 PIN DESCRIPTION PIN NAME FUNCTION SOIC-16(SOP16)/SSOP-16/TSSOP-16 IN 1 Select Input. 1B1 2 Analog Video I/O. 1B2 3 Analog Video I/O. 1A 4 Analog Video I/O. 2B1 5 Analog Video I/O. 2B2 6 Analog Video I/O. 2A 7 Analog Video I/O. GND 8 Ground. 3A 9 Analog Video I/O. 3B2 10 Analog Video I/O. 3B1 11 Analog Video I/O. 4A 12 Analog Video I/O. 4B2 13 Analog Video I/O. 4B1 14 Analog Video I/O. OE 15 Switch-Enable Input. VCC 16 Power Supply. 4 / 13 www.run-ic.com RS2233 SPECIFICATIONS Absolute Maximum Ratings (1) Over operating free-air temperature range (unless otherwise noted) (1) SYMBOL PARAMETER MIN MAX VCC Supply Voltage -0.3 6 VIN Input Voltage (All inputs) -0.3 VCC+0.3 IIK Input clamp current TJ Junction temperature Tstg Storage temperature VIO < 0 -65 UNIT V -50 mA 150 °C +150 °C (1) Stresses above these ratings may cause permanent damage. Exposure to absolute maximum conditions for extended periods may degrade device reliability. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those specified is not implied. ESD Ratings V(ESD) Electrostatic discharge VALUE UNIT Human-body model (HBM) ±6000 V Machine Model (MM) ±400 V Recommended Operating Conditions Over operating free-air temperature range (unless otherwise noted) SYMBOL PARAMETER MIN MAX UNIT VCC Supply Voltage 1.8 5.5 V TA Operating temperature -40 +85 °C Thermal Information RS2233 THERMAL METRIC 16 PINS UNIT SOIC-16(SOP-16) SSOP-16 TSSOP-16 76 118.7 111.3 °C/W RϴJA Junction-to-ambient thermal resistance RϴJC(top) Junction-to-case(top) thermal resistance 42.1 66.4 45.3 °C/W RϴJB Junction-to-board thermal resistance 34.8 62.2 56.9 °C/W ѰJT Junction-to-top characterization parameter 26.9 20.9 5.4 °C/W ѰJB Junction-to-board characterization parameter 34.7 61.7 56.3 °C/W RϴJC(bot) Junction-to-case(bottom) thermal resistance N/A N/A N/A °C/W 5 / 13 www.run-ic.com RS2233 PACKAGE/ORDERING INFORMATION PRODUCT RS2233 ORDERING NUMBER RS2233YS16 TEMPERATURE RANGE -40°C~+85°C RS2233YSS16 -40°C~+85°C RS2233YTSS16 -40°C~+85°C SOIC-16(SOP16) PACKAGE MARKING (1) RS2233 PACKAGE OPTION Tape and Reel,4000 SSOP-16 RS2233 Tape and Reel,4000 TSSOP-16 RS2233 Tape and Reel,4000 PACKAGE LEAD NOTE: (1) There may be additional marking, which relates to the lot trace code information (data code and vendor code), the logo or the environmental category on the device. 6 / 13 www.run-ic.com RS2233 ELECTRICAL CHARACTERISTICS VCC = +1.8V to +5.5 V, FULL= -40°C to +85°C, Typical values are at TA = +25°C. (unless otherwise noted) PARAMETER SYMBOL CONDITIONS VCC TA MIN TYP MAX UNITS 5.5V FULL 1.8V FULL 1.1 2.5V to 5.5V FULL 2 1.8V FULL 0.4 2.5V to 5.5V FULL 0.5 V DC CHARACTERISTICS On-Resistance RON IA =13mA 3 Ω High-level control input Voltage VIH Low-level control input Voltage VIL Input High Current IIH ̅̅̅̅ = VCC VIN and VOE 5.5V +25°C ±1 μA Input Low Current IIL ̅̅̅̅ = 0V VIN and VOE 5.5V +25°C ±1 μA Analog Output Leakage Current IO VB1 or VB2 =3.3V/0.3V VA= 0.3V/3.3V 5.5V +25°C ±1 μA Clamp Diode Voltage VIK II = -18mA 5.5V +25°C -0.9 V 5.5V +25°C 30 ns 5.5V +25°C 13 ns 5.5V +25°C 220 MHz 5.5V +25°C -54 dB 5.5V +25°C -58 dB V DYNAMIC CHARACTERISTICS Turn-On Time tON Turn-Off Time tOFF -3dB Bandwidth BW RL = 75Ω, CL = 20pF, Test Circuit 1 RL = 75Ω, CL = 20pF, Test Circuit 1 RL = 150Ω, Test Circuit 3 Channel-to-Channel Crosstalk XTALK Off Isolation OIRR Input/Enable Capacitance CIN f = 1MHz,Test Circuit 5 5.5V +25°C 4 pF Switch OFF Capacitance COFF f = 1MHz,Test Circuit 5 5.5V +25°C 5 pF Switch ON Capacitance CON f = 1MHz,Test Circuit 5 5.5V +25°C 8 pF 5.5V +25°C 0.5 % 5.5V +25°C 0.03 。 Differential Gain DG Differential Phase DP RIN = 10Ω, RL = 150Ω, f = 10MHz, Test Circuit 4 RL = 150Ω, f = 10MHz, Test Circuit 5 RL = 150Ω, f = 3.58MHz, Test Circuit 2 RL = 150Ω, f = 3.58MHz, Test Circuit 2 POWER REQUIREMENTS Power Supply Range VCC Power Supply Current ICC Supply Current per Input @ TTL HIGH ΔICC FULL ̅̅̅̅ = 5V/0V VIN and VOE 5.5V +25°C ̅̅̅̅ = 3.4V VIN or VOE 5.5V +25°C 7 / 13 1.8 0.1 5.5 V 1 μA 300 μA www.run-ic.com RS2233 Parameter Measurement Information IN VOLTAGE WAVEFORMS t AND t TIMES Test tON tOFF VCC RL CL VB1 VB2 5V±0.5V 75Ω 20pF GND 3V 5V±0.5V 75Ω 20pF 3V GND 5V±0.5V 75Ω 20pF GND 3V 5V±0.5V 75Ω 20pF 3V GND NOTES: 1.CL includes probe and jig capacitance. 2.All input pulses are supplied by generators having the following characteristics: PRR≤10MHz,ZO=50Ω,tr≤2.5ns,tf≤2.5ns. 3. The outputs are measured one at a time, with one transition per measurement. Test Circuit 1. Test Circuit for Voltage Waveform and Switch Time NOTES: Differential gain and phase are measured at the output of the ON channel. For example, when V IN = 0, VOE = 0, and 1A is the input, the output is measured at 1B1. Test Circuit 2. Test Circuit for Differential Gain/Phase Measurement 8 / 13 www.run-ic.com RS2233 Parameter Measurement Information NOTES: Frequency response is measured at the output of the ON channel. For example, when V IN = 0, VEN = 0, and 1A is the input, the output is measured at 1B1. All unused analog I/O ports are left open. Test Circuit 3. Test Circuit for Frequency Response (BW) NOTE: 1. A 50Ω termination resistor is needed for the network analyzer. Test Circuit 4. Test Circuit for Crosstalk (XTALK) NOTE: 1. A 50Ω termination resistor is needed for the network analyzer. Test Circuit 5. Test Circuit for Off Isolation (OIRR) 9 / 13 www.run-ic.com RS2233 PACKAGE OUTLINE DIMENSIONS SOIC-16(SOP16) e E1 b 5.2 E 1.27 0.6 D 1.27 RECOMMENDED LAND PATTERN (Unit: mm) A2 A c θ A1 L Dimensions In Millimeters Dimensions In Inches Symbol Min Max Min Max A 1.350 1.750 0.053 0.069 A1 0.100 0.250 0.004 0.010 A2 1.350 1.550 0.053 0.061 b 0.330 0.510 0.013 0.020 c 0.170 0.250 0.006 0.010 D 9.800 10.200 0.386 0.402 E 3.800 4.000 0.150 0.157 E1 5.800 6.200 0.228 0.244 e 1.270(BSC) 0.050(BSC) L 0.400 1.270 0.016 0.050 θ 0° 8° 0° 8° 10 / 13 www.run-ic.com RS2233 SSOP-16 e E1 b 5.588 E 1.651 D 0.635 0.406 RECOMMENDED LAND PATTERN (Unit: mm) A2 H C A A1 θ L Dimensions In Millimeters Dimensions In Inches Symbol Min Max Min Max A 1.350 1.750 0.053 0.069 A1 0.100 0.250 0.004 0.010 A2 1.350 1.550 0.053 0.061 b 0.200 0.300 0.008 0.012 c 0.170 0.250 0.007 0.010 D 4.700 5.100 0.185 0.200 E 3.800 4.000 0.150 0.157 E1 5.800 6.200 0.228 0.244 e 0.635(BSC) 0.025(BSC) L 0.400 1.270 0.016 0.050 θ 0° 8° 0° 8° 11 / 13 www.run-ic.com RS2233 TSSOP-16 e b 5.94 E1 E 1.78 D 0.65 0.42 RECOMMENDED LAND PATTERN (Unit: mm) A2 H C A A1 θ L Dimensions In Millimeters Dimensions In Inches Symbol Min Max A Min Max 1.200 0.047 A1 0.050 0.150 0.002 0.006 A2 0.800 1.050 0.031 0.041 b 0.190 0.300 0.007 0.012 c 0.090 0.200 0.004 0.008 D 4.860 5.100 0.191 0.201 E 4.300 4.500 0.169 0.177 E1 6.200 6.600 0.244 0.260 e L 0.650(BSC) 0.500 H θ 0.026(BSC) 0.700 0.02 0.25TYP 1° 0.028 0.01TYP 7° 12 / 13 1° 7° www.run-ic.com RS2233 TAPE AND REEL INFORMATION REEL DIMENSIONS TAPE DIMENSION Reel Diameter Reel Width(W1) DIRECTION OF FEED NOTE: The picture is only for reference. Please make the object as the standard. KEY PARAMETER LIST OF TAPE AND REEL TSSOP-16 Reel Diameter 13’’ Reel Width(mm) 12.4 A0 (mm) 6.90 B0 (mm) 5.60 K0 (mm) 1.20 P0 (mm) 4.0 P1 (mm) 8.0 P2 (mm) 2.0 W (mm) 12.0 Pin1 Quadrant Q1 SSOP-16 13’’ 12.4 8.30 6.70 2.10 4.0 8.0 2.0 12.0 Q1 SOIC-16(SOP16) 13’’ 16.4 6.50 10.30 2.10 4.0 8.0 2.0 16.0 Q1 Package Type 13 / 13 www.run-ic.com
RS2233YTSS16 价格&库存
很抱歉,暂时无法提供与“RS2233YTSS16”相匹配的价格&库存,您可以联系我们找货
RS2233YTSS16
  • 5+2.53820
  • 50+1.90120
  • 800+1.88219
  • 1600+1.84455
库存:861
RS2233YTSS16
  • 1+0.73250
库存:4
