CSRV0204FTDG5100
CSRV0204FTDG5100
    VIKING(光颉)
    MELF0204
    MELF电阻 MELF0204 510Ω ±1% 2/5W ±50ppm/℃
CSRV0204FTDG5100 数据手册
Data Sheet Customer: Product: Metal Film Precision MELF Resistor-CSRV Series Size: 0102/0204/0207 Issued Date: 30-Jun-20 Edition: REV.B6 VIKING TECH CORPORATION VIKING TECH CORPORATION KAOHSIUNG BRANCH VIKING ELECTRONICS (WUXI) CO., LTD. ( ) No.70 Guangfu N. Rd., Hukou Township, Hsinchu County 303, Taiwan No.248-3, Sin-Sheng Rd., Cian-Jhen Dist., Kaohsiung, 806, Taiwan TEL:886-3-5972931 FAX:886-3-5972935•886-3-5973494 E-mail:sales@viking.com.tw TEL:886-7-8217999 FAX:886-7-8228229 E-mail:sales@viking.com.tw No.22 Xixia Road, Machinery & Industry Park, National Hi-Tech Industrial Development Zone of Wuxi, Wuxi, Jiangsu Province, China Zip Code:214028 TEL:86-510-85203339 FAX:86-510-85203667•86-510-85203977 E-mail:china@viking.com.tw Produced by (QC) Checked (QC) Approved by (QC) Prepared by (Sales) 30-Jun-20 30-Jun-20 30-Jun-20 30-Jun-20 Susan Huang J.C. Liu J.C. Liu Accepted by (Customer) CSRV Series Metal Film Precision MELF Resistor Features AEC-Q200 Compliance Thin film technology Excellent overall stability Sn termination on Ni barrier layer Tight tolerance down to ±0.1% Extremely low TCR down to ±5 PPM/°C High power rating up to 1 Watts SMD enabled structure Lead-free and RoHS compliant Applications Automotive(non-safety parts) Industrial Telecommunication Medical Equipment Measurement/Testing Equipment TECHNICAL SPECIFICATIONS DESCRIPTION CSRV0102 CSRV0204 CSRV0207 Resistance range 1Ω-1MΩ; 0Ω 0.1Ω-3.4MΩ; 0Ω 0.1Ω-3.4MΩ; 0Ω ±5%;±1%;±0.5%;±0.25%;±0.1% Resistance tolerance ±100ppm/℃; ±50ppm/℃; ±25ppm/℃; ±15ppm/℃ Temperature coefficient Operation mode Standard Power rating P70 1/8W 1/5W Operating voltage Umax. 150V 200V ±100ppm/℃; ±50ppm/℃; ±25ppm/℃; ±15ppm/℃; ±10ppm/℃; ±5ppm/℃ High power Standard High power Standard High power 0.3W 1/4W 2/5W 1/2W 1W 200V 200V 200V 300V 350V -55℃~155℃ Operating temperature range Max. resistance change at P70 for resistance range, ΔR/R max., after 1000 h ≦0.5% ≦0.5% ≦0.5% Construction & Dimension www.viking.com.tw  Insulation Coating  Electrode Cap  Trimming Line  Resistor Layer  Ceramic Rod  Marking Type L (mm) L1 min. (mm) ΦD (mm) ΦD1 (mm) K (mm) Weight 1,000EA (g) CSRV0102 2.20±0.10 1.1 1.10±0.10 D +0/-0.15 0.45±0.05 7.7 CSRV0204 3.50±0.2 1.7 1.40±0.15 D +0/-0.2 0.8±0.1 18.7 CSRV0207 5.90±0.2 2.9 2.20±0.20 D +0/-0.2 1.3±0.1 80.9 For detail questions, contact sales@viking.com.tw 1 Edition: REV.B6 Revision: 30-Jun-2020 CSRV Series Metal Film Precision MELF Resistor Part Numbering Part Number Part Number CSRV0204DTDV1001 CSRV0204JT-VR0R0 C S R V 0 2 0 4 D T C S R V 0 2 0 4 J T Product Type CSRV Dimensions (L×ΦD) 0102: 2.2x1.1 0204: 3.5x1.4 0207: 5.9x2.2 Resistance Tolerance B: ±0.1% C: ±0.25% D: ±0.5% F: ±1% J: ±5% TCR (PPM/°C) Packaging Code T: Taping Reel Recommend Land Pattern D S: ±5 B: ±10 N: ±15 C: ±25 D: ±50 E: ±100 -: Jumper V 1 0 0 1 V R 0 R 0 Power Rating T: 1W U: 1/2W V: 1/4W G: 2/5W P: 1/5W W: 1/8W L: 0.3W Resistance 0010: 1Ω 0100: 10Ω 2201: 2200Ω 1001: 1KΩ 1004: 1MΩ R050: 0.05Ω 22R1: 22.1Ω R0R0: 0Ω Derating Curve Derating Curve 100 A Type A (mm) B (mm) C (mm) CSRV0102 1.0 0.8 1.5 CSRV0204 1.6 1.2 1.6 CSRV0207 3.0 1.7 2.4 Power ratio (%) B . C 80 Except for 5ppm 60 5ppm 40 20 0 0 20 40 60 80 100 120 140 160 Ambient Temperature ( ℃ ) Soldering Condition IR Reflow Soldering Wave Soldering (For R>10Ω) (1) Time of IR reflow soldering at maximum temperature point 260C:10s (2) Time of wave soldering at maximum temperature point 260C:10s (3) Time of soldering iron at maximum temperature point 410C:5s www.viking.com.tw For detail questions, contact sales@viking.com.tw 2 Edition: REV.B6 Revision: 30-Jun-2020 CSRV Series Metal Film Precision MELF Resistor Standard Electrical Specifications Item Type 0102 Power Rating at 70 C 1/8W Operating Max. Max. Temp. Operating Overload Range Voltage Voltage -55 ~ +155C 150V 300V Resistance Range ±0.1% ±0.25% ±0.5% 100Ω-56KΩ 49.9Ω100Ω-82KΩ 200KΩ - TCR (PPM/ C) ±1% ±5% 49.9Ω390KΩ 1Ω-1MΩ - 0204 200V 400V 200V 400V 1Ω-1MΩ 0207 600V ±10 10Ω-300KΩ ±15 10Ω-3.4MΩ 1Ω-3.4MΩ ±25 1Ω-3.4MΩ 0.2Ω-3.4MΩ ±50 0.1Ω-1MΩ ±100 0Ω(
CSRV0204FTDG5100 价格&库存
很抱歉,暂时无法提供与“CSRV0204FTDG5100”相匹配的价格&库存,您可以联系我们找货
CSRV0204FTDG5100
  • 10+0.7840510+0.10057
  • 100+0.25812100+0.03311
  • 1000+0.125981000+0.01616
  • 3000+0.099553000+0.01277
  • 9000+0.096039000+0.01232
库存:5715
CSRV0204FTDG5100
  • 3000+0.08625
库存:36000
