DATA SHEET
CURRENT SENSOR - LOW TCR
AUTOMOTIVE GRADE
PA_E series
5%, 1%, 0.5%
sizes 2512
Product specification – January 31, 2018 V.10
RoHS compliant & Halogen free
Chip Resistor Surface Mount
SERIES
PA_E
2
10
2512
SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER
This specification describes PA
series current sensor - low TCR
with lead-free terminations made by
metal substrate.
Global part numbers are identified by the series, size, tolerance, packing
type, temperature coefficient, taping reel and resistance value.
GLOBAL PART NUMBER
PA XXXX X X X XX XXXX E
(1)
APPLICATIONS
Consumer goods
Computer
Telecom / Datacom
Industrial / Power supply
Alternative Energy
Car electronics
FEATURES
AEC-Q200 qualified
Halogen-free Epoxy
RoHS compliant
Reduce environmentally
hazardous wastes
(2) (3) (4)
(5)
(6)
(7)
(1) SIZE
2512
(2) TOLERANCE
D= ± 0.5%
F = ± 1%
J = ± 5%
(3) PACKAGING TYPE
K = Embossed taping reel
(4) TEMPERATURE COEFFICIENT OF RESISTANCE
F = ± 100 ppm/°C
M = ± 75ppm/°C
E = ± 50ppm/°C
(5) TAPING REEL
High component and
equipment reliability
07 = 7 inch dia. Reel & standard power (1W)
Non-forbidden materials used
in products/production
7T = 7 inch dia. Reel & 3 x standard power (3W)
Low resistances applied to
current sensing
Anti-sulfur
7W = 7 inch dia. Reel & 2 x standard power (2W)
(6) RESISTANCE VALUE
0.5 mΩ to 100 mΩ
(7) DEFAULT CODE
Letter E is the system default code for ordering only. (Note)
Resistance rule of global part
number
Resistance code rule
Example
XUXX
0U5 = 0.5mΩ
0RXXX
0R001 = 1 mΩ
(1 to 100 mΩ)
0R05 = 50 mΩ
ORDERING EXAMPLE
The ordering code of a PA2512 1W chip
resistor, TC100, value 0.003Ω with ±1%
tolerance, supplied in 7-inch tape reel is:
PA2512FKF070R003E
NOTE
1. All our RChip products are RoHS compliant. "LFP" of the internal 2D reel label mentions
"Lead-Free Process"
www.yageo.com
Jan. 31, 2018 V.10
3
PA_E
SERIES
10
2512
MARKING
PA2512
4 digits
The "m" is used as decimal point; the other 3 digits are significant and the unit is
milliohm
Fig. 1
Value = 0.5 mΩ
001
Fig. 2
Fig. 3
PA2512: 0.5mΩ and 0.75mΩ
4 digits
The “R” is used as a decimal point; the other 3 digits are significant
PA2512: 1mΩ to 4 mΩ
Value = 1 mΩ
Value = 5 mΩ
4 digits
PA2512: 5 mΩ to 100 mΩ
CONSTRUCTION
The resistors are constructed using outstanding TCR level material, which makes Yageo P A resistors excellent
for current sensing application in battery charger circuit & DC -DC converter.
The composition of the resistive material is adjusted to give the approximate required resistance and is
covered with a protective coating. Marking is printed on the top side of the resistor.
Finally, the three external terminations (Cu / Ni / matte Tin) are added, as shown in Fig. 4.
Outlines
Fig. 4 Chip resistor outlines
www.yageo.com
Jan. 31, 2018 V.10
4
PA_E
SERIES
10
2512
DIMENSION
Table 1 For outlines, please refer to Fig. 4
TYPE
RESISTANCE RANGE
PA2512
L (mm)
W (mm)
H (mm)
I1 (mm)
I2 (mm)
0.5mΩ ≤ R ≤ 0.75mΩ
6.35±0.25
3.18±0.25
0.63±0.25
2.72±0.25
2.72±0.25
1mΩ ≤ R ≤ 4mΩ
6.35±0.25
3.18±0.25
0.63±0.25
2.21±0.25
2.21±0.25
5mΩ ≤ R ≤ 6mΩ
6.35±0.25
3.18±0.25
0.63±0.25
1.19±0.25
1.19±0.25
7mΩ ≤ R ≤ 100mΩ
6.35±0.25
3.18±0.25
0.63±0.25
0.76±0.25
0.76±0.25
Note:
1. For relevant physical dimensions, please refer to construction outlines.
2. Please contact with sales offices, distributors and representatives in your region before ordering.
ELECTRICAL CHARACTERISTICS
Table 2
TYPE
PA
Fig. 4
SIZE
POWER RATING
TOLERANCE
1W
± 0.5%
2512
2W
± 1%
3W
± 5%
RESISTANCE RANGE
OF RESISTANCE
± 50ppm/°C
0.5mΩ ≤ R ≤ 100mΩ
± 75ppm/°C
± 100ppm/°C
Note: Please contact with sales offices, distributors and representatives in your region before ordering.
FUNCTIONAL DESCRIPTION
OPERATING TEMPERATURE RANGE
PA2512 Range: –55°C to +170°C
POWER RATING
Standard rated power at 70°C:
For detail power value, please refer to Table 2.
RATED VOLTAGE
The DC or AC (rms) continuous working voltage
corresponding to the rated power is determined by
the following formula:
V = (PxR )
Where
Fig. 5 Maximum dissipation (P max ) in percentage of rated power
as a function of the operating ambient temperature (T amb)
V = Continuous rated DC or
AC (rms) working voltage (V)
P = Rated power (W)
R = Resistance value (Ω)
www.yageo.com
Jan. 31, 2018 V.10
SERIES
PA_E
5
10
2512
PACKING STYLE AND PACKAGING QUANTITY
Table 3 Packing style and packaging quantity
PACKING STYLE
Embossed taping reel (K)
REEL DIMENSION
PA2512
7" (178 mm)
4,000
EMBOSSED TAPE
Fig. 6 Embossed Tape
Table 4 Dimensions of embossed tape for relevant chip resistors size
SIZE
Unit: mm
SYMBOL
A0
B0
W
E
F
P0
P1
P2
Ø D0
Ø D1
T
PA2512 3.40± 0.15 6.70± 0.15 12.00± 0.30 1.75± 0.10 5.50± 0.10 4.00± 0.10 4.00± 0.10 2.00± 0.10 1.55± 0.05 1.50± 0.10 0.80± 0.15
www.yageo.com
Jan. 31, 2018 V.10
PA_E
SERIES
6
10
2512
REEL SPECIFICATION
Fig. 7 Reel
HBK039
Table 5 Dimensions of reel specification for relevant chip resistors size
QUANTITY
PER REEL
SIZE
PA2512
REEL SIZE
8 mm
TAPE WIDE
12 mm
TAPE WIDE
7" (Ø 178 mm)
4000
SYMBOL
A
178.0± 1.0
Unit: mm
N
60.0+1/-0
C
13.50± 0.5
D
21.0± 0.8
W1
13.6± 0.5
W2 MAX.
16.5± 0.5
LEADER/TRAILER TAPE SPECIFICATION
Fig. 8 Leader/Trailer Tape
CCB325
www.yageo.com
Jan. 31, 2018 V.10
PA_E
SERIES
7
10
2512
FOOTPRINT AND SOLDERING PROFILES
For recommended soldering profiles, please refer to data sheet “Chip resistors mounting”.
FOOTPRINT
Fig. 9 Single resistor chips recommended dimensions of footprints
Table 6 Footprint dimensions
SIZE
PA2512
RESISTANCE
RANGE
Unit: mm
A
B
C
D
0.5mΩ ≤ R < 1mΩ
7.36
0.50
3.43
3.68
1mΩ ≤ R ≤ 4mΩ
7.37
1.27
3.05
3.68
5mΩ ≤ R ≤ 6mΩ
7.40
3.18
2.11
3.68
7mΩ ≤ R ≤ 100mΩ
7.36
4.06
1.65
3.68
www.yageo.com
Jan. 31, 2018 V.10
PA_E
SERIES
8
10
2512
TESTS AND REQUIREMENTS
Table 8 Test condition, procedure and requirements
TEST
TEST METHOD
Short time
overload
IEC60115-1 4.13
High Temperature
Exposure
MIL-STD-202-Method 108
PROCEDURE
REQUIREMENT
5 times of rated power for 5 seconds at
room temperature
± (0.5%+0.0005Ω)
1,000 hours at maximum operating
temperature depending on specification,
unpowered
± (1.0%+0.0005Ω)
No visible damage
No direct impingement of forced air to
the parts Tolerances: 170± 3ºC
Temperature
Cycling
JESD22-A104C
1,000 cycles, -55/+125ºC for 1 cycle per
hour
± (0.5%+0.0005Ω)
Moisture
Resistance
MIL-STD-202-Method 106
Each temperature / humidity cycle is
defined at 8 hours (method 106F), 3
cycles / 24 hours for 10d with 25ºC /
65ºC 95% R.H, without steps 7a & 7b,
unpowered
± (0.5%+0.0005Ω)
Biased
Humidity
MIL-STD-202 Method 103
1,000 hours; 85ºC / 85% RH
± (0.5%+0.0005Ω)
Operational Life/
Endurance
10% of operating power
1,000 hours at 125± 3ºC, de-rated voltage
applied for 1.5 hours on, 0.5 hour off, stillair required
± (1.0%+0.0005Ω)
1,000 hours at 70± 2ºC applied RCWV
± (1.0%+0.0005Ω)
1.5 hours on, 0.5 hour off, still air required
Resistance to
Solvents
MIL-STD-202 Method 215
Immerse in isopropyl alcohol for 5 min
with ultrasonic at room temperature
No Visible damage
Mechanical Shock
MIL-STD-202 Method 213
Three shocks in each direction shall be
applied along the three mutually
perpendicular axes of the test specimen.
± (0.5%+0.0005Ω)
Peak value: 100 g’s
Duration: 6 ms
Velocity change: 12.3 ft/s
Waveform: Half sine
Vibration
MIL-STD-202 Method 204
5 g’s for 20 min., 12 cycles each of 3
orientations
± (0.5%+0.0005Ω)
Test from 10-2000 Hz.
Resistance to
Soldering Heat
MIL-STD-202-method 210
Condition B, no pre-heat of samples
± (0.5%+0.0005Ω)
Leadfree solder, 260ºC, 10 seconds
immersion time
No visible damage
Procedure 2 for SMD: devices fluxed and
cleaned with isopropanol
Thermal Shock
MIL-STD-202 Method 107
-55/+125ºC, Number of cycles is 300.
Devices mounted.
± (0.5%+0.0005Ω)
No visible damage
Maximum transfer time is 20 seconds.
Dwell time is 15 minutes. Air -Air
www.yageo.com
Jan. 31, 2018 V.10
TEST
TEST METHOD
Electrostatic
Discharge
AEC-Q200-002
Solderability
- Wetting
J-STD-002B test B
PA_E
SERIES
PROCEDURE
9
10
2512
REQUIREMENT
Human Body Model, 1 pos + 1 neg.
± (1.0%+0.0005Ω)
Discharges 2512=2KV
No visible damage
(a) Method B, aging 4 hours at 155ºC dry
heat, dipping at 235± 3ºC for 5± 0.5
seconds.
Well tinned
(>95% covered)
No visible damage
(b) Method B, steam aging 8 hours,
dipping at 215± 3ºC for 5± 0.5
seconds.
(c) Method D, steam aging 8 hours,
dipping at 260± 3 ºC for 7± 0.5
seconds.
Flammability
UL94
Try to inflame a specimen by a needle
flame
No ignition of specimen;
V-0
Board Flex /
Bending
AEC-Q200-005
Chips mounted on a 90mm glass epoxy
resin PCB (FR4), Bending for 2512=2 mm
± (1.0%+0.0005Ω)
Holding time: Min.60 seconds
Terminal
Strength (SMD)
AEC-Q200-006
Flame Retardance
Temperature
Coefficient of
Resistance (T.C.R.)
Applied a 17.7N (1.8Kg) for 60± 1
seconds.
± (1.0%+0.0005Ω)
AEC-Q200-001
Apply voltage from 9V to 32V to increase
the surface temp to 350ºC
No flame,
no explosion
MIL-STD-202 Method 304
At +25/+150ºC
Refer to table 2
No visible damage
Formula:
T.C.R=
R 2 R1
x106(ppm/ºC)
R1( t 2 t1)
Where
t1=+25ºC or specified room temperature
t2=+150ºC test temperature
R1=resistance at reference temperature in
ohms
R2=resistance at test temperature in ohms
Flower-of-Sulfur
(FOS)
Modified ASTM B809-95
Sulfur 105ºC, 750 hours, unpowered.
± (1.0%+0.0005Ω)
www.yageo.com
Jan. 31, 2018 V.10
PA_E
SERIES
10
10
2512
REVISION HISTORY
REVISION
DATE
CHANGE NOTIFICATION
DESCRIPTION
POWER
RESISTANCE RANGE
TOLERANCE
- Extend 0.5% Tolerance
1/10W,
Version 90603
Nov. 21,
2017 1/5W, 3/10W, 2/5W, 1/2W
5 mΩfor
≦ 3W
R < 100 mΩ
- Extend resistor value
Version 10
TYPE Jan. 31, 2018
0805
Oct. 23, 2017
1206
Version 8
Version 7
1/8W, 1/4W, 1/3W, 1/2W
1/4W, 1/2W
1/2W,
1W Jul. 24,
2017
Version 6
Apr. 19, 2017 material, which makes Yageo PF
resistors excellent for current
Version 5
Nov.sensing
30, 2016
application
in battery
charger circuit & DC-DC
Version 4
Oct.converter.
27, 2016 The composition of the resistive
PF
Version 32010
Mar. 31, 2016 approximate required resistance
and is covered with a protective
Version 2
Dec.coating,
31, 2015which
- printed with the
resistance value.
Version 1
Dec. 18, 2015 terminations (Ni / matte Tin) are
Version 0
Mar. 18, 2015
2512
4527
OF RESISTANCE
4 mΩ ≦ R < 100 mΩ
- Update footprint dimensions
3 mΩ ≦ R < 100 mΩ
- Add part number coding details for the relationship between taping reel
and rated power
- Modify the error of test procedure
± 1%
± 2%
- Update TCR
± 5%
5 mΩ ≦ R < 100 mΩ
±75 ppm/°C
- Update tests and requirements
- New datasheet for automotive grade current sensor –PA_E series.
1W, 2W
1 mΩ ≦ R < 100 mΩ
3W
1 mΩ ≦ R ≦ 50 mΩ
2W, 3W, 5W
6 mΩ ≦ R < 1Ω
NOTE: 1. PLEASE CONTACT WITH SALES OFFICES, DISTRIBUTORS AND REPRESENTATIVES IN YOUR REGION BEFORE ORDERING
“ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itself are unchanged. Any
product change will be announced by PCN.”
www.yageo.com
Jan. 31, 2018 V.10
LEGAL DISCLAIMER
YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any
errors, inaccuracies or incompleteness contained in any product related information, including but not limited
to product specifications, datasheets, pictures and/or graphics. YAGEO may make changes, modifications and/or
improvements to product related information at any time and without notice.
YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any
particular purpose or the continuing production of any of its products. To the maximum exten t permitted by
law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product, (ii)
any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all
implied warranties, including warranties of fitness for a particular purpose, non -infringement and
merchantability.
YAGEO products are designed for general purpose applications under normal operation and usage conditions.
Please contact YAGEO for the applications listed below which require especially high reliability for the
prevention of defects which might directly cause damage to the third party's life, body or property: Aerospace
equipment (artificial satellite, rocket, etc.), Atomic energy -related equipment, Aviation equipment, Disaster
prevention equipment, crime prevention equipment, Electric heating apparatus, burning equipment, Highly
public information network equipment, data-processing equipment , Medical devices, Military equipment, Power
generation control equipment, Safety equipment, Traffic signal equipment, Transportation equipment and
Undersea equipment, or for any other application or use in which the failure of YAGEO products could result
in personal injury or death, or serious property damage. P articularly YAGEO Corporation and its affiliates
do not recommend the use of commercial, automotive, and/or COTS grade products for high
reliability applications or manned space flight.
Information provided here is intended to indicate product specifications only. YAGEO reserves all the rights
for revising this content without further notification, as long as products are unchanged. Any product change
www.yageo.com
