RP0805BRD072KL
RP0805BRD072KL
    YAGEO(国巨)
    贴片电阻 0805 2kΩ ±0.1% 1/8W ±25ppm/℃
RP0805BRD072KL 数据手册
DATA SHEET THIN FILM CHIP RESISTORS AUTOMOTIVE GRADE RP series 0.1% TO 1%, TC10 TO TC50 sizes 0402/0603/0805/1206 Product specification – May 15, 2023 V. 2 RoHS compliant Product specification Chip Resistor Surface Mount SERIES RP 2 9 0402 to 1206 SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER This specification describes RP0402 to RP1206 high precision-high stability chip resistors made by thin film process. Part number is identified by the series name, size, tolerance, packaging type, temperature coefficient, taping reel and resistance value. GLOBAL PART NUMBER RP XXXX X X X XX XXXXX L (1) APPLICATIONS ⚫ Automotive electronics ⚫ Industrial and medical equipment ⚫ Test and measuring equipment ⚫ Telecommunications (2) (3) (4) (5) (6) (7) (1) SIZE 0402 / 0603 / 0805 / 1206 (2) TOLERANCE B = ± 0.1% C = ± 0.25% FEATURES ⚫ AEC-Q200 qualified ⚫ Total lead free without RoHS exemption ⚫ Halogen free epoxy ⚫ Superior resistance against sulfur containing atmosphere ⚫ Moisture sensitivity level: MSL 1 ⚫ Reducing environmentally hazardous wastes ⚫ High component and equipment reliability ⚫ Non-forbidden materials used in products/production D = ± 0.5% F = ± 1% (3) PACKAGING TYPE R = Paper taping reel (4) TEMPERATURE COEFFICIENT OF RESISTANCE B = ± 10 ppm/°C C = ± 15 ppm/°C D = ± 25 ppm/°C E = ± 50 ppm/°C (5) TAPING REEL 07 = 7 inch dia. Reel (6) RESISTANCE VALUE There are 2~4 digits indicated the resistor value. Letter R/K/M is decimal point Example: 100R = 100Ω 1K = 1,000Ω (7) DEFAULT CODE Letter L is the system default code for ordering only. (NOTE) O RDERING EXAMPLE The ordering code of a RP0402 chip resistor, TCR 25 value 56Ω with ± 0.5% tolerance, supplied in 7-inch tape reel is: RP0402DRD0756RL. NOTE 1. All our Rchip products meet RoHS compliant and Halogen Free. "LFP" of the internal 2D reel label mentions "Lead Free Process". 2. On customized label, "LFP" or specific symbol can be printed. www.yageo.com May, 15, 2023 V.2 Product specification Chip Resistor Surface Mount RP SERIES 3 9 0402 to 1206 MARKING RP0402 No marking ynsc007 Fig. 1 RP0603 E-96 series: including values 10/11/13/15/20/75 of E-24 series, 3 digits Fig. 2 Value = 12.4 Ω ynsc003 Fig. 3 Value = 56 KΩ E-24 series: exception values 10/11/13/15/20/75 of E -24 series, one short bar under marking letter RP0805 / RP1206 YNSC004 Fig. 4 Value = 10 KΩ Both E-24 and E-96 series: 4 digits First three digits for significant figure and 4th digit for number of zeros NOTE For further marking information, please see special data sheet “Chip resistors marking”. CONSTRUCTION The resistors are constructed out of a high grade ceramic body. Internal metal electrodes are added at each end connected by a resistive layer. This resistive layer is trimmed to its nominal value and on both ends a contact is made which will guarantee optimum solderability. This is achieved by applying several layers and for ease of soldering the outer layer consists of Ni/matte tin. Adding a special protective layer, passivation coating, on this series to enhance moisture resistance of the environment. OUTLINES Marking layer Overcoat Passivation layer Resistive layer Conductor layer Inner electorde Sputter conductor layer H Termination (Ni / matte tin) I2 Backside electorde (Ag) Ceramic substrate YNSC064-1 Fig. 5 Chip resistor outlines www.yageo.com May, 15, 2023 V.2 Product specification Chip Resistor Surface Mount RP SERIES 4 9 0402 to 1206 DIMENSIONS Table 1 TYPE L (mm) W (mm) H (mm) I1 (mm) I2 (mm) RP0402 1.00 ± 0.10 0.50 ± 0.05 0.30 ± 0.05 0.20 ± 0.10 0.25 ± 0.10 RP0603 1.60 ± 0.10 0.80 ± 0.10 0.45 ± 0.10 0.25 ± 0.15 0.25 ± 0.15 RP0805 2.00 ± 0.10 1.25 ± 0.10 0.50 ± 0.10 0.35 ± 0.20 0.35 ± 0.20 RP1206 3.10 ± 0.10 1.60 ± 0.10 0.55 ± 0.10 0.45 ± 0.20 0.40 ± 0.20 ELECTRICAL CHARACTERISTICS Table 2 Resistance Range (E-24/E-96 series)(Ω) & Tolerance(1) TYPE Operating Temperature Range Max. Power Working Rating Voltage Max. Overload Voltage T.C.R. (ppm/°C)(2) ±0.1% ±0.25% (B) (C) ±0.5% (D) ±1% Unit weight (F) (mg/pcs) ± 50 (E) RP0402 1/16W 50 V 100 V ± 25 (D) ± 15 (C) 10 ≤ R ≤ 240K 0.572 10 ≤ R ≤ 1M 2.128 10 ≤ R ≤ 1M5 4.642 10 ≤ R ≤ 1M5 10.116 ± 10 (B) ± 50 (E) RP0603 1/10W 75V 150 V ± 15 (C) ± 10 (B) ± 50 (E) –55 °C to +155 °C RP0805 ± 25 (D) 1/8W 150 V 300 V ± 25 (D) ± 15 (C) ± 10 (B) ± 50 (E) RP1206 1/4W 200 V 400 V ± 25 (D) ± 15 (C) ± 10 (B) NOTE : 1. Global part number (code 7) 2. Global part number (code 9) www.yageo.com May, 15, 2023 V.2 Product specification Chip Resistor Surface Mount RP SERIES 5 9 0402 to 1206 FOOTPRINT AND SOLDERING PROFILES For recommended footprint and soldering profiles, please see the special data sheet “Chip resistors moun ting”. PACKING STYLE AND PACKAGING QUANTITY Table 3 Packing style and packaging quantity REEL DIMENSION QUANTITY PER REEL Paper taping reel 7" (178 mm) 10,000 Units RP0603 Paper taping reel 7" (178 mm) 5,000 Units RP0805 Paper taping reel 7" (178 mm) 5,000 Units RP1206 Paper taping reel 7" (178 mm) 5,000 Units PRODUCT TYPE PATKING STYLE RP0402 NOTE: for paper tape and reel specification/dimensions, please see the special data sheet “packing” document. TEMPERATURE COEFFICIENT OF RESISTANCE RESISTANCE RANGE DESCRIPTION FUNCTIONAL toE910 mΩ PT040 OPERATING TEMPERATUR100 E RmΩ ANG 2 ± 200 ppm/°C Range: –55 °C to +155 °C PT060 ± 200 ppm/°C P 3 OWER RATING Each PT080type rated power at 70 °C: ± 200 ppm/°C RP0402=1/16 W 5 100 MΩ RP0603=1/10 WTO 910 MΩ PT120 RP0805=1/8 W 100 mΩ 6 RP1206=1/4 W PT201 0 R ATED VOLTAGE ± 100 ppm/°C PT251 The DC or AC (rms) continuous working voltage ± 100 ppm/°C 2 corresponding to the rated power is determined by the following formula: V= handbook, halfpage MLB206_1 P (%Prated) 100 50 > 100 mΩ 0 ±5575 ppm/°C0 50 70 100 155 o Tamb ( C) ± 75 dissipation ppm/°C (P max) in percentage of rated power Fig. 6 Maximum as a function of the operating ambient temperature (T amb) (PxR) Or max. working voltage whichever is less Where V=Continuous rated DC or AC (rms) working voltage (v) P=Rated power R=Resistance value (Ω) www.yageo.com May, 15, 2023 V.2 Product specification Chip Resistor Surface Mount RP SERIES 6 9 0402 to 1206 TESTS AND REQUIREMENTS Table 4 Test condition, procedure and requirements TEST TEST METHOD PROCEDURE REQUIREMENTS Short Time Overload IEC60115-1 4.13 2.5 times of rated voltage or maximum ± (0.05%+0.05Ω) High Temperature Exposure AEC-Q200 Test 3 Moisture Resistance overload voltage, the less of the above, for 5 sec at room temperature 1,000 hours at Tamb = 155 °C, unpowered ± (0.3%+0.05Ω) AEC-Q200 Test 6 Each temperature / humidity cycle is defined at ± (0.1%+0.05Ω) MIL-STD-202 Method 106 8 hours (method 106F), 3 cycles / 24 hours for MIL-STD-202 Method 108 10d. with 25 °C / 65 °C 95% R.H, without steps 7a & 7b, unpowered Parts mounted on test-boards, without condensation on parts Biased Humidity AEC-Q200 Test 7 1,000 hours; 85 °C / 85% RH MIL-STD-202 Method 103 10% of operating power ± (0.1%+0.05Ω) Measurement at 24± 4 hours after test conclusion Life AEC-Q200 Test 8 MIL-STD-202 Method 108 Resistance to Soldering Heat AEC-Q200 Test 15 Thermal Shock AEC-Q200 Test 16 Solderability - Wetting AEC-Q200 Test 18 MIL-STD-202 Method 210 MIL-STD-202 Method 107 J-STD-002 1,000 hours at 70± 5 °C, RCWV applied for 1.5 hours on, 0.5 hour off, still air required ± (0.1%+0.05Ω) Condition B, no pre-heat of samples Lead-free solder, 260± 5 °C, 10± 1 seconds immersion time Procedure 2 for SMD: devices fluxed and cleaned with isopropanol ± (0.05%+0.05Ω) -55/+125 °C Number of cycles is 300. Devices mounted Maximum transfer time is 20 seconds. Dwell time is 15 minutes. Air – Air ± (0.1%+0.05Ω) Electrical Test not required Magnification 50X SMD conditions: (a) Method B, aging 4 hours at 155 °C dry heat, dipping at 235± 3 °C for 5± 0.5 seconds. (b) Method B, steam aging 8 hours, dipping at 215± 3 °C for 5± 0.5 seconds. (c) Method D, steam aging 8 hours, dipping at 260± 3 °C for 7± 0.5 seconds Well tinned No visible damage (>95% covered) No visible damage www.yageo.com May, 15, 2023 V.2 Product specification Chip Resistor Surface Mount TEST RP SERIES TEST METHOD PROCEDURE REQUIREMENTS Board Flex / Bending AEC-Q200 Test 21 Chips mounted on a 90mm glass epoxy resin PCB (FR4) Bending for 0402: 5 mm 0603/0805: 3 mm 1206: 2mm Holding time: minimum 60 second ± (0.1%+0.05Ω) Temperature Coefficient of Resistance (T.C.R.) IEC 60115-1 4.8 At +25/–55 °C and +25/+125°C Formula: Refer to table 2 AEC-Q200-005 T.C.R= 7 9 0402 to 1206 R2 - R1 × 106(ppm/°C) R1( t 2 − t1) Where t1=+25 °C or specified room temperature t2=–55 °C or +125 °C test temperature R1=resistance at reference temperature in ohms R2=resistance at test temperature in ohms Flower of Sulfur ASTM-B-809-95* Sulfur 750 hours, 105°C, unpowered. ± (2.0%+0.05Ω) * Modified www.yageo.com May, 15, 2023 V.2 Product specification Chip Resistor Surface Mount RP SERIES 8 9 0402 to 1206 REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 2 May 15, 2023 - - Extend Resistance value of 0603 to 1M Version 1 Nov. 07, 2022 - - Extend temperature coefficient of resistance range (B=± 10ppm/°C) - Add unit weight Version 0 Jul. 25, 2022 - - First issue of this specification www.yageo.com May, 15, 2023 V.2 Product specification Chip Resistor Surface Mount LEGAL DISCLAIMER YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. YAGEO may make changes, modifications and/or improvements to product related information at any time and without notice. YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum exten t permitted by law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non -infringement and merchantability. YAGEO products are designed for general purpose applications under normal operation and usage conditions. Please contact YAGEO for the applications listed below which require especially high reliability for the prevention of defects which might directly cause damage to the third party's life, body or property: Aerospace equipment (artificial satellite, rocket, etc.), Atomic energy -related equipment, Aviation equipment, Disaster prevention equipment, crime prevention equipment, Electric heating apparatus, burning equipment, Highly public information network equipment, data-processing equipment , Medical devices, Military equipment, Power generation control equipment, Safety equipment, Traffic signal equipment, Transportation equipment and Undersea equipment, or for any other application or use in which the failure of YAGEO products could result in personal injury or death, or serious property damage. P articularly YAGEO Corporation and its affiliates do not recommend the use of commercial, automotive, and/or COTS grade products for high reliability applications or manned space flight. Information provided here is intended to indicate product specifications only. YAGEO reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com
RP0805BRD072KL 价格&库存
很抱歉,暂时无法提供与“RP0805BRD072KL”相匹配的价格&库存,您可以联系我们找货
RP0805BRD072KL
    RP0805BRD072KL
    • 5000+0.540435000+0.06990
    • 10000+0.5176110000+0.06694
    • 15000+0.5054915000+0.06538
    • 25000+0.4914525000+0.06356
    • 35000+0.4829035000+0.06246
    • 50000+0.4744250000+0.06136
    库存:4602
    RP0805BRD072KL
    • 1+1.056211+0.13660
    • 10+0.9175110+0.11866
    • 25+0.8539325+0.11044
    • 50+0.8063450+0.10429
    • 100+0.76143100+0.09848
    • 250+0.70653250+0.09138
    • 500+0.66910500+0.08654
    • 1000+0.634791000+0.08210
    库存:4602
    RP0805BRD072KL
      • 1+3.60110
      • 100+2.56550
      • 1000+1.74170
      • 2500+1.25980
      • 5000+0.89750
      库存:545
