DATA SHEET
SURFACE-MOUNT CERAMIC
MULTILAYER CAPACITORS
Hi Q Series
Class 1, NP0
16V TO 500V
0.1 pF to 100 pF
Product Specification – May 4, 2022 V.17
RoHS compliant & Halogen Free
Product specification
Surface-Mount Ceramic Multilayer Capacitors
HiQ
NPO
16V to 500V
4SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER, PHYCOMP
This specification describes NP0
series chip capacitors with leadfree terminations.
CTC & 12NC
APPLICATIONS
GLOBAL PART NUMBER (PREFERRED )
Consumer electronics for
example
- Tuners
- Television receivers
- All types of cameras
Telecommunications
Data processing
FEATURES
Supplied in tape on reel
Nickel-barrier end termination
RoHS compliant
Halogen Free compliant
2
13
All part numbers are identified by the series, size, tolerance, TC material,
packing style, voltage, process code, termination and capacitance value.
YAGEO/ PHYCOMP BRAND ordering code
CQ
XXXX X X
(1)
NPO
(2) (3)
X
BN
XXX
(4)
(5)
(1) SIZE – INCH BASED (METRIC)
0100 (0402)
0201 (0603)
0402 (1005)
0603 (1608)
0805 (2012)
(2) TOLERANCE
0.1pF
B = ± 0.1 pF
0.2pF to 2.0 pF
A = ± 0.05 pF
B = ± 0.1 pF
C = ± 0.25 pF
2.1pF to 5.0pF
A = ± 0.05 pF
B = ± 0.1 pF
C = ± 0.25 pF
D = ± 0.5 pF
5.1pF to 9.9pF
B = ± 0.1 pF
C = ± 0.25 pF
D = ± 0.5 pF
10pF and over
F = ± 1%
G = ± 2%
J = ± 5%
(3) PACKING STYLE
R = Paper/PE taping reel; Reel 7 inch
P = Paper/PE taping reel; Reel 13 inch
(4) RATED VOLTAGE
7 = 16V
8 = 25V
9 = 50V
0=100V
A=200V
Y=250V
B=500V
(5) CAPACITANCE VALUE
2 significant digits + number of zeros
The 3rd digit signifies the multiplying factor, and letter R is decimal point
Example: 121 = 12 x 101 = 120 pF
www.yageo.com
May. 4, 2022 V.17
HiQ
16V to 500V
NPO
3
13
CONSTRUCTION
The capacitor consists of a
rectangular block of ceramic
dielectric in which a number of
interleaved metal electrodes are
contained. This structure gives
rise to a high capacitance per
unit volume.
The inner electrodes are
connected to the two end
terminations and finally covered
with a layer of plated tin (NiSn).
The terminations are lead-free. A
cross section of the structure is
shown in Fig.1.
terminations
electrodes
MLB457
ceramic material
Fig. 1 Surface mounted multilayer ceramic capacitor construction
OUTLINES
DIMENSION
For dimension see Table 1
Table 1 For outlines see fig. 2
TYPE
L1 (mm)
W (mm)
T (MM)
L2 / L3 (mm)
min.
max.
01005
0.4± 0.02
0.2± 0.02
0.2± 0.02
0.07
0.14
0.13
0201
0.6± 0.03
0.3± 0.03
0.10
0.20
0.20
0402
1.0± 0.05
0.5± 0.05
0603
1.6± 0.10
0.8± 0.10
0805
2.0± 0.20
1.25± 0.20
Refer to
table 2 to 5
L4 (mm)
min.
0.15
0.35
0.30
0.20
0.60
0.40
0.25
0.75
0.55
W
T
L2
L4
L1
L3
MBB211
Fig. 2 Surface mounted multilayer
ceramic capacitor dimension
www.yageo.com
May. 4, 2022 V.17
HiQ
16V to 500V
NPO
4
13
CAPACITANCE RANGE & THICKNESS FOR NP0
Table 2 Sizes from 0201 to 0402
01005
0201
0402
01005
0201
16V/25V
25V/50V
100V 50V to 250V
16V/25V
25V/50V
100V
50V to 250V
0.1 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
2.6 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.2 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
2.7 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.3 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
2.8 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.4 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
2.9 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.5 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
3.0 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.6 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
3.1 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.7 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
3.2 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.8 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
3.3 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.9 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
3.4 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
1.0 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
3.5 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
1.1 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
3.6 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
1.2 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
3.7 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
1.3 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
3.8 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
1.4 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
3.9 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
1.5 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
4.0 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
1.6 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
4.1 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
1.7 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
4.2 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
1.8 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
4.3 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
1.9 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
4.4 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
2.0 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
4.5 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
2.1 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
4.6 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
2.2 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
4.7 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
2.3 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
4.8 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
2.4 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
4.9 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
2.5 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
5.0 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
CAP.
Tape Width
8mm
CAP.
Tape Width
0402
8mm
NOTE
1. Values in shaded cells indicate thickness class in mm
www.yageo.com
May. 4, 2022 V.17
HiQ
NPO
16V to 500V
5
13
Table 3 Sizes from 0201 to 0402
CAP.
01005
0201
0402
CAP.
01005
0201
0402
16V/25V
25V/50V
100V 50V to 250V
16V/ 25V
25V/50V
100V
50V to 250V
5.1 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
8.2 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
5.2 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
8.3 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
5.3 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
8.4 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
5.4 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
8.5 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
5.5 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
8.6 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
5.6 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
8.7 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
5.7 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
8.8 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
5.8 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
8.9 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
5.9 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
9.0 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
6.0 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
9.1 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
6.1 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
9.2 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
6.2 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
9.3 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
6.3 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
9.4 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
6.4 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
9.5 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
6.5 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
9.6 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
6.6 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
9.7 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
6.7 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
9.8 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
6.8 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
9.9 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
6.9 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
10 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
7.0 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
12 pF
0.2± 0.02
0.3± 0.03
0.5± 0.05
7.1 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
15 pF
0.2± 0.02
0.3± 0.03
0.5± 0.05
7.2 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
18 pF
0.3± 0.03
0.5± 0.05
7.3 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
22 pF
0.3± 0.03
0.5± 0.05
7.4 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
27 pF
0.3± 0.03
0.5± 0.05
7.5 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
33 pF
0.3± 0.03
0.5± 0.05
7.6 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
39 pF
0.3± 0.03
0.5± 0.05
7.7 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
47 pF
0.5± 0.05
7.8 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
56 pF
0.5± 0.05
7.9 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
68 pF
0.5± 0.05
8.0 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
82 pF
0.5± 0.05
8.1 pF
0.2± 0.02
0.3± 0.03
0.3± 0.03
0.5± 0.05
100 pF
0.5± 0.05
Tape Width
8mm
Tape Width
8mm
NOTE
www.yageo.com
May. 4, 2022 V.17
HiQ
16V to 500V
NPO
6
13
Table 4 Sizes from 0603 to 0805
CAP.
0603
0805
50V 100V/250V
CAP.
50V 100V/250V
0.1 pF
0.8± 0.1
0.8± 0.1
0.2 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.3 pF
0.8± 0.1
0.8± 0.1
0.4 pF
0.8± 0.1
0.5 pF
500V
0603
0805
50V 100V/250V
50V 100V/250V
500V
2.6 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
0.6± 0.1 0.85± 0.1
2.7 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
2.8 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
2.9 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
3.0 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
0.6 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
3.1 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
0.7 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
3.2 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
0.8 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
3.3 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
0.9 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
3.4 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
1.0 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
3.5 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
1.1 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
3.6 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
1.2 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
3.7 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
1.3 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
3.8 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
1.4 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
3.9 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
1.5 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
4.0 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
1.6 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
4.1 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
1.7 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
4.2 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
1.8 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
4.3 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
1.9 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
4.4 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
2.0 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
4.5 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
2.1 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
4.6 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
2.2 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
4.7 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
2.3 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
4.8 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
2.4 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
4.9 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
2.5 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
5.0 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
Tape Width
8mm
Tape Width
8mm
NOTE
www.yageo.com
May. 4, 2022 V.17
Table 5 Sizes from 0603 to 0805
CAP.
0603
0805
50V 100V/250V
50V 100V/250V
CAP.
500V
HiQ
NPO
0603
16V to 500V
7
13
0805
50V
100V/250V
50V 100V/250V
500V
5.1 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
8.2 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
5.2 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
8.3 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
5.3 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
8.4 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
5.4 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
8.5 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
5.5 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
8.6 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
5.6 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
8.7 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
5.7 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
8.8 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
5.8 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
8.9 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
5.9 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
9.0 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
6.0 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
9.1 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
6.1 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
9.2 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
6.2 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
9.3 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
6.3 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
9.4 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
6.4 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
9.5 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
6.5 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
9.6 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
6.6 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
9.7 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
6.7 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
9.8 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
6.8 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
9.9 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
6.9 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
10 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
7.0 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
12 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
7.1 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
15 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
7.2 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
18 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
7.3 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
22 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
7.4 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
24 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
7.5 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
27 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
7.6 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
33 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
7.7 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
39 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
7.8 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
47 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
7.9 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
56 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
8.0 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
68 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1 0.85± 0.1
8.1 pF
0.8± 0.1
0.8± 0.1 0.6± 0.1
0.6± 0.1 0.85± 0.1
82 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
100 pF
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
Tape Width
8mm
Tape Width
8mm
NOTE
www.yageo.com
May. 4, 2022 V.17
HiQ
NPO
16V to 500V
8
13
THICKNESS CLASSES AND PACKING QUANTITY
Table 6
Ø 180 MM / 7 INCH
Paper/PE
Blister
Ø 330 MM / 13 INCH
Paper/PE
Blister
SIZE
CODE
THICKNESS
CLASSIFICATION
TAPE WIDTH
QUANTITY PER REEL
01005
0.2 ± 0.02 mm
8 mm
20,000
80,000
0201
0.3 ± 0.03 mm
8 mm
15,000
50,000
0402
0.5 ± 0.05 mm
8 mm
10,000
50,000
0603
0.8 ± 0.1 mm
8 mm
4,000
15,000
0805
0.6 ± 0.1 mm
8 mm
4,000
20,000
0805
0.85 ± 0.1 mm
8 mm
4,000
15,000
QUANTITY
PER BULK CASE
ELECTRICAL CHARACTERISTICS
NP0 DIELECTRIC CAPACITORS; NISN TERMINATIONS
Unless otherwise stated all electrical values apply at an ambient temperature of 20± 1 °C, an atmospheric
pressure of 86 to 106 kPa, and a relative humidity of 63 to 67%.
Table 7
VALUE
DESCRIPTION
Capacitance range
0.1 pF to 100 pF
Capacitance tolerance
C < 10 pF
± 0.05 pF, ± 0.1 pF, ± 0.25 pF, ± 0.5 pF
C ≥ 10 pF
± 1%, ± 2%, ± 5%
C < 30 pF
Q ≥ ( 400 + 20C )
Q value
C: pF
C ≥ 30 pF
Q ≥ 1000
Insulation resistance after 1 minute at Ur (DC)
Rins ≥ 10 GΩ or Rins × Cr ≥ 500 seconds whichever is less
Maximum capacitance change as a function of temperature
(temperature characteristic/coefficient):
± 30 ppm/°C
Operating temperature range:
–55 °C to +125 °C
SOLDERING RECOMMENDATION
Table 8
SOLDERING
METHOD
SIZE
01005
0201
0402
0603
0805
Reflow
O
O
O
O
O
Wave
O
O
www.yageo.com
May. 4, 2022 V.17
HiQ
NPO
16V to 500V
9
13
TESTS AND REQUIREMENTS
Table 9 Test procedures and requirements
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
Mounting
IEC 6038421/22
4.3
The capacitors may be mounted on printed-circuit boards or
ceramic substrates
No visible damage
Visual
inspection
and
dimension
check
4.4
Any applicable method using × 10 magnification
In accordance with specification
Capacitance
4.5.1
Class 1:
f = 1 MHz for C ≤ 1 nF, measuring at voltage 1 Vrms at 20 °C
Within specified tolerance
f = 1 KHz for C > 1 nF, measuring at voltage 1 Vrms at 20 °C
Q value
4.5.2
Class 1:
f = 1 MHz for C ≤ 1 nF , measuring at voltage 1 Vrms at 20 °C
Insulation
resistance
4.5.3
At Ur (DC) for 1 minute
www.yageo.com
May. 4, 2022 V.17
TEST
Temperature
coefficient
TEST METHOD
4.6
HiQ
NPO
16V to 500V
PROCEDURE
REQUIREMENTS
Capacitance shall be measured by the steps shown in the
following table.
Class1:
∆ C/C: ± 30ppm
10
13
The capacitance change should be measured after 5 min at
each specified temperature stage.
Step
Temperature(°C)
a
25± 2
b
Lower temperature± 3°C
c
25± 2
d
Upper Temperature± 2°C
e
25± 2
(1) Class I
Temperature Coefficient shall be calculated from the
formula as below
C2 - C1
10 6 [ppm/°C]
Temp, Coefficient =
C1xΔT
C1: Capacitance at step c
C2: Capacitance at 125°C
∆T: 100°C (=125°C -25°C)
Adhesion
4.7
A force applied for 10 seconds to the line joining the
terminations and in a plane parallel to the substrate
Force
size ≥ 0603: 5N
size = 0402: 2.5N
size = 01005 / 0201: 1N
Bending
Strength
4.8
Mounting in accordance with IEC 60384-22 paragraph 4.3
No visible damage
Conditions: bending 1 mm at a rate of 1 mm/s, radius jig
5 mm
∆C/C
Measuring frequency: 1 ± 0.2GHz at room temperature.
0.2pF ≤ C ≤ 1pF : 350mΩ / C max
ESR (0201 to
0805)
NP0: within ± 1% or 0.5 pF
whichever is greater
1pF < C ≤ 5pF : 300mΩ max
5pF < C ≤ 10pF : 250mΩ max
C : Nominal cap (pF)
Measuring frequency: 500 ± 50MHz at room temperature. 10pF < C ≤ 100pF :400mΩ max
ESR (01005)
Measuring frequency: 1 ± 0.2 GHz at room temperature.
0.2pF to 1pF: 700 mΩ /C max
1.1pF to 5pF: 500 mΩ max
5.1pF to 15pF: 300 mΩ max
C: Nominal Cap. (pF)
www.yageo.com
May. 4, 2022 V.17
TEST
TEST METHOD
Resistance to IEC 60384soldering heat 21/22
4.9
HiQ
NPO
16V to 500V
11
13
PROCEDURE
REQUIREMENTS
Precondition: 150 +0/–10 °C for 1 hour, then keep for 24
± 1 hours at room temperature
Dissolution of the end face plating shall
not exceed 25% of the length of the
edge concerned
Preheating: for size ≤ 1206: 120 °C to 150 °C for 1 minute
Preheating: for size >1206: 100 °C to 120 °C for 1 minute
and 170 °C to 200 °C for 1 minute
Solder bath temperature: 260 ± 5 °C
Dipping time: 10 ± 0.5 seconds
∆C/C
NP0: within ± 0.5% or 0.5 pF
Recovery time: 24 ± 2 hours
Q value within initial specified value
Rins within initial specified value
Solderability
4.10
Preheated the temperature of 80 °C to 140 °C and
maintained for 30 seconds to 60 seconds.
The solder should cover over 95% of
the critical area of each termination
Test conditions for lead containing solder alloy
Temperature: 235 ± 5 °C
Dipping time: 2 ± 0.2 seconds
Depth of immersion: 10 mm
Alloy Composition: 60/40 Sn/Pb
Number of immersions: 1
Test conditions for lead-free containing solder alloy
Temperature: 245 ± 5 °C
Dipping time: 3 ± 0.3 seconds
Alloy Composition: SAC305
Rapid change
of
temperature
4.11
Preconditioning;
24 ± 1 hours at room temperature
No visual damage
5 cycles with following detail:
30 minutes at lower category temperature
30 minutes at upper category temperature
NP0: within ± 1% or 1 pF
∆C/C
Recovery time 24 ± 2 hours
Q value meet initial specified value
Rins meet initial specified value
www.yageo.com
May. 4, 2022 V.17
TEST
Damp heat
with Ur load
HiQ
NPO
16V to 500V
TEST METHOD
PROCEDURE
REQUIREMENTS
IEC 6038421/22
1. Preconditioning, class 2 only:
No visual damage after recovery
4.13
150 +0/-10 °C /1 hour, then keep for
24 ± 1 hour at room temp
2. Initial measure:
Spec: refer to initial spec C
3. Damp heat test:
500 ± 12 hours at 40 ± 2 °C;
90 to 95% R.H. 1.0 Ur applied
4. Recovery:
Class 1: 6 to 24 hours
5. Final measure: C
12
13
∆C/C
NP0: within ± 7.5% or 0.75pF
Q value:
≥30pF: Q ≥ 200
≤30pF: Q ≥ 100+10C/3
I.R.:
NP0: ≥ 500 MΩ or Rins x Cr ≥ 25s
whichever is less
P.S. If the capacitance value is less than the minimum value
permitted, then after the other measurements have been
made the capacitor shall be preconditioned according to
“IEC 60384 4.1” and then the requirement shall be met.
Endurance
4.14
2. Initial measure:
3. Endurance test:
Temperature: NP0: 125 °C
Specified stress voltage applied for 1,000 hours:
Applied 2.0 x Ur for 16V to 100V product.
Applied 1.5 x Ur for 200V to 250V product.
Applied 1.3 x Ur for 500V product.
4. Recovery time: 24 ± 2 hours
5. Final measure: C
No visual damage
∆C/C
NP0: within ± 3% or 0.3pF
Q value:
≥30pF: Q ≥ 350
10pF to 30pF: Q ≥ 275+5C/2
≤10pF: Q ≥ 200+10C
NP0: ≥ 1,000 MΩ or Rins x Cr ≥ 50Ω.F
whichever is less
Voltage proof
IEC 60384-1
4.6
Specified stress voltage applied for 1 minute
Ur ≤ 100 V: series applied 2.5 Ur
100 V < Ur ≤ 200 V series applied (1.5 Ur + 100)
200 V < Ur ≤ 500 V series applied (1.3 Ur + 100)
Ur > 500 V: 1.3 Ur
I: 7.5 mA
No breakdown or flashover
www.yageo.com
May. 4, 2022 V.17
HiQ
NPO
16V to 500V
13
13
REVISION HISTORY
REVISION DATE
CHANGE NOTIFICATION
DESCRIPTION
Version 17
May 04, 2022
- Add 01005 0.1pF to 15pF, 16V to 25V capacitance range.
Version 16
May 14, 2021
- Add 0201 to 0603 0.1pF, 0201, 100V and 0805, 500V capacitance range
Version 15
Mar.30, 2018
- Add 0603/100V, 250V capacitance range
Version 14
Feb. 14, 2018
- Revised ESR requirements (0.2pF to 1pF)
Version 13
Jul. 5, 2016
- Add 0201/50V and 0402/100V, 250V Capacitance range
Version 12
Feb. 23, 2016
- Size update
Version 11
Mar 19, 2014
- Size update
Version 10
Mar 19, 2014
- Tests and requirements
Version 9
Feb. 27, 2014
- Tolerance update
Version 8
Oct. 28, 2013
- Rated voltage update
Version 7
Oct. 09, 2013
Version 6
Jun. 24, 2013
- Tolerance update
Version 5
Apr. 15, 2013
- Tolerance update
Version 4
Mar. 28, 2013
- Capacitance range & thickness update
Version 3
Feb. 07, 2013
Version 2
Dec. 25, 2012
Version 1
Dec. 03, 2012
Version 0
Nov. 23, 2012
- New datasheet for HiQ NP0 series with RoHS compliant
www.yageo.com
May. 4, 2022 V.17
LEGAL DISCLAIMER
YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any
errors, inaccuracies or incompleteness contained in any product related information, including but not limited
to product specifications, datasheets, pictures and/or graphics. YAGEO may make changes, modifications and/or
improvements to product related information at any time and without notice.
YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any
particular purpose or the continuing production of any of its products. To the maximum exten t permitted by
law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product, (ii)
any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all
implied warranties, including warranties of fitness for a particular purpose, non -infringement and
merchantability.
YAGEO products are designed for general purpose applications under normal operation and usage conditions.
Please contact YAGEO for the applications listed below which require especially high reliability for the
prevention of defects which might directly cause damage to the third party's life, body or property: Aerospace
equipment (artificial satellite, rocket, etc.), Atomic energy -related equipment, Aviation equipment, Disaster
prevention equipment, crime prevention equipment, Electric heating apparatus, burning equipment, Highly
public information network equipment, data-processing equipment , Medical devices, Military equipment, Power
generation control equipment, Safety equipment, Traffic signal equipment, Transportation equipment and
Undersea equipment, or for any other application or use in which the failure of YAGEO products could result
in personal injury or death, or serious property damage. P articularly YAGEO Corporation and its affiliates
do not recommend the use of commercial, automotive, and/or COTS grade products for high
reliability applications or manned space flight.
Information provided here is intended to indicate product specifications only. YAGEO reserves all the rights
for revising this content without further notification, as long as products are unchanged. Any product change
will be announced by PCN.
www.yageo.com
