MCA1101-65-5
MCA1101-65-5
    ACEINNA(新纳)
    SOIC16_300MIL
    霍尔电流传感器 SOIC16_300MIL 4.5V~5.5V
MCA1101-65-5 数据手册
High Accuracy Current Sensor IC with 1.5MHz 3dB Bandwidth and Isolation ±5A, ±20A, ±50A, ±65A, 5V, Fixed Gain MCA1101-xx-5 FEATURES DESCRIPTION   The MCA1101 products are ±5A, ±20A, ±50A, ±65A fully integrated bi-directional analog output current sensors that deliver both high accuracy and high bandwidth. ACEINNA’s state-of-the-art Anisotropic Magneto Resistive (AMR) sensor technology provides inherently low noise, excellent linearity and repeatability. AMR based integrated current sensor Superior Range & Accuracy 0.6% typical total error @25°C (MCA1101-20-5) 2.0% max error over temperature (MCA1101-20-5)  Superior Frequency Response 1.5 MHz (typical 3dB BW)  Fast output response time (300ns typical)  Low Primary Resistance (0.9 mΩ)  Single 5V Supply Operation  Low power consumption (6.5mA typical)  Zero-Current Reference Pin (Vref)  Overcurrent fault detection  SOIC-16 package (RoHS/REACH compliant)  -40 to +105°C Operating Temperature Range  UL/IEC/EN60950-1 Certified 4.8 kV Dielectric Strength Voltage 1097 VRMS Basic Isolation Voltage 400 VRMS Reinforced Isolation Voltage APPLICATIONS Server, Telecom, & Industrial PWR Supplies Power Aggregation, Over-Current Protection Dynamic Current Sensing in Feedback Loops PFC and Inverter Control Motor Control Loops & Protection Automation, Robotics, Servo Systems Automotive & EV Power Systems Solar Inverters and Optimizers Grid-Tie and Storage Current Monitoring MPPT Circuit Current Monitoring Central Inverter Current Monitoring Consumer Motor Balance and Remote Device Monitoring Home Automation Control & IOT remote sensing A fully isolated current path is provided by a low resistance copper conductor integrated into the package making it suitable for both high-side and low side bi-directional current sensing. The high bandwidth of 1.5MHz (3dB) and low phase delay makes it ideal for current sense feedback loops in motor control, inverters, uninterruptible power supplies, battery management, power factor correction, high voltage distribution bus converters and power supply applications, including those with fast switching wide-bandgap SiC and GaN based power stages. These devices are factory-calibrated to achieve low offset error and provide a precise analog voltage output that is linearly proportional to the conduction current (AC or DC) with sensitivity (mV/A) compatible with A/D converters and analog control loops in power systems. The AMR sensor device structure is designed to eliminate sensitivity to stray and common mode magnetic fields. Due to the inherently low output noise of ACEINNA’s sensor technology, additional filtering is not required to reduce noise that reduces accuracy at low-level currents in systems with dynamic load profiles. The MCA1101 products in SOIC-16 package are simple to use with no or minimal external components (other than decoupling capacitor) enabling fast design, supports high isolation and are UL/IEC/EN60950-1 certified. VCC R1 IP+ VOC IP+ Primary Current IP+ Input GND IP+ Vref IP- Vout IP- Primary Current IP- Output GND IP- 33K R2 Optional circuitry for overcurrent detection GND VCC FAULTB VCC VCC To ADC pin on MCU or A/D input To ADC pin on MCU or A/D input R3 C1 100nF 10K Intterupt to MCU Figure 1 - Application circuit Information furnished by ACEINNA is believed to be accurate and reliable. However, no responsibility is assumed by ACEINNA for its use, or for any infringements of patents or other rights of third parties which may result from its use. No license is granted by implication or otherwise under any patent or patent rights of ACEINNA. ACEINNA reserves the right to change this specification without notification. ORDERING PART NUMBER Ordering Part Number Part Marking (See Page 12) Current Range Gain VCC (Typical) Dielectric Strength Package Qty per Reel MCA1101-5-5 MCA1101-20-5 MCA1101-50-5 MCA1101-65-5 MCA11055 MCA11205 MCA11505 MCA11656 ±5 Amp ±20 Amp ±50 Amp ±65 Amp Fixed Fixed Fixed Fixed 5.0V 5.0V 5.0V 5.0V 4800V 4800V 4800V 4800V 16 Lead SOIC 16 Lead SOIC 16 Lead SOIC 16 Lead SOIC 1000 pcs 1000 pcs 1000 pcs 1000 pcs Note: Evaluation boards are available for each product version (order EVB-MCx1101-xx-x) PIN DESCRIPTION Pin # 16L SOIC Name 1,2,3,4 IP+ Input of Primary Current Path for Sensing, Fused internally 5,6,7,8 IP- Output of Primary Current Path for Sensing, Fused internally 9 10 11 12 FAULTB VCC GND Vout 13 Vref 14 GND 15 GND 16 VOC Description Overcurrent FAULTB open drain output. Active low. System Power Supply Recommended to connect to ground Analog Output Signal linearly proportional to Primary Path Current Pin 1 Zero Current Analog Reference Output Used during initial factory calibration. This pin should be connected to ground or left floating during normal operation. Connect to ground Input pin. Voltage on this pin defines the overcurrent detection OCD threshold level. Briefly driving this pin to VCC resets and rearms OCD circuit. 16-pin SOIC BLOCK DIAGRAM Figure 2 - Block diagram for fixed gain output products Phone: 978.965.3200 Fax: 978.965.3201 Document: 6020-1102-01 Rev G E-mail: info@aceinna.com www.aceinna.com Page 2 of 14 Table 1 – ABSOLUTE MAXIMUM RATINGS Stresses above these ratings may cause permanent damage. Exposure to absolute maximum conditions for extended periods may degrade device reliability. These are stress ratings only, and functional operation at these or any other conditions beyond those specified is not implied. Parameters / Test Conditions Symbol Value Unit Supply Voltage VCCMAX V FAULTB Output Voltage V FAULTB -0.5 to 6 -0.5V to VCC+0.5V V Sensor Current (IP+, IP-), 5Amp products IPMAX ±10 A Sensor Current (IP+, IP-), 20Amp products IPMAX ±50 A Sensor Current (IP+, IP-), 50Amp products IPMAX ±100 A Sensor Current (IP+, IP-), 65Amp products IPMAX ±100 A Maximum Device Junction Temperature TJMAX 150 °C Storage Temperature TSTG -65 to +150 °C TA -40 to 105 °C ESD Human Body Model / per ANSI/ESDA/JEDEC JS-001 HBM 2000 V ESD Charged Device Model / per JEDEC specification JESD22-C101 CDM 1500 V MSL Rating MSL 3 TSOLDER 260 Operating Ambient Temperature Range Maximum Soldering Temperature, 10 seconds. Phone: 978.965.3200 Fax: 978.965.3201 Document: 6020-1102-01 Rev G E-mail: info@aceinna.com °C www.aceinna.com Page 3 of 14 Table 2 – ISOLATION CHARACTERISTICS Parameters / Test Conditions Dielectric Strength Test Voltage (Agency type-tested for 60 seconds per UL standard 60950-1 (edition 2). Production tested at 3kVrms per UL 60950-1. Working Voltage for Basic Isolation. Maximum approved working voltage according to UL 60950-1 (edition 2)- (VPK/DC / VRMS) Symbol Value Unit VISO 4800 V VWVBI 1550 / 1097 V VWVRI 565 / 400 V Clearance distance (Minimum distance through air from IP leads to signal leads) DCL 7.5 mm Creepage distance (Minimum distance along package body from IP leads to signal leads) DCR 8.2 mm Symbol Value Unit Junction-to-Ambient Thermal Resistance (Note 1) RJA 27 C/W Junction-to-Lead Thermal Resistance RJC 10 C/W Working Voltage for Reinforced Isolation (VPK/DC / VRMS) Table 3 – THERMAL CHARACTERISTICS Parameters / Test Conditions Note 1 – The RJA measured on the EB0011- evaluation board with 800mm2 of 4oz copper on each layer (top and bottom ), thermal vias connecting the layers. The performance values include the power consumed by the PCB. Table 4 – ELECTRICAL CHARACTERISTICS COMMON TO ALL VERSIONS Unless otherwise noted: 4.5V ≤ VCC ≤ 5.5V, -40°C ≤ TA ≤ 105°C, I (Vout) = I (Vref) = 0 (Recommended Operating Conditions). Typical values are for VCC = 5V and TA = 25°C. Parameter Symbol Test Conditions Min Typ Max Unit 2 4 mV Vout Output Load Regulation VoutLR Increase I (Vout) from 0 to -250µA. Measure change in Vout voltage Source Current VoutSRC Vout shorted to GND 50 mA Sink Current VoutSNK Vout shorted to VCC 30 mA Frequency Response (-3dB) VoutBW (Note 2) CVoutMAX (Note 2) Capacitive Loading Resistive Loading RLMIN Response Time tRESP Noise Density Noise (Input Referred) IND VoutNOISE 1500 kHz 200 Minimum load resistance on Vout & Vref. (Note 2 and Note 3) IP± = 0 to ±100% step input, interval from 80% of the IP to 80% of the Vout. (Note 2) Input Referred, VCC=5V, TA = 25°C, CL=200pF, 10 kHz~1MHz IP± = 0, Measure (Vout – Vref). BW defined from DC to 10 kHz. (Note 2) 10 pF kohm 300 ns 10 µA/Hz 10 mA (rms) Note 2 – Guaranteed by design and characterization. Not production tested. Note 3 – Vref pin supply capability limited to Fixed Gain mode. Phone: 978.965.3200 Fax: 978.965.3201 Document: 6020-1102-01 Rev G E-mail: info@aceinna.com www.aceinna.com Page 4 of 14 Table 5 – ELECTRICAL CHARACTERISTICS COMMON TO ALL VERSIONS Unless otherwise noted: 4.5V ≤ VCC ≤ 5.5V, -40°C ≤ TA ≤ 105°C, I (Vout) = I (Vref) = 0 (Recommended Operating Conditions). Typical values are for VCC = 5V and TA = 25°C. Parameter Symbol Test Conditions Min Typ Max Unit 2.164 2.175 2.185 V 2 4 mV Vref Output Output Voltage Vref I (Vref) = 0 to -1mA, Fixed Gain Products Load Regulation VrefLR Increase I (Vref) from 0 to -250µA. Measure change in Vref voltage. (Note 3) Source Current VrefSRC Vref shorted to GND. (Note 3) 10 mA Sink Current VrefSNK Vref shorted to VCC. (Note 3) 10 mA (Note 2) 100 pF 5.5 V Capacitive Loading CVrefMAX VCC Bias Supply Supply Voltage VCC 4.5 Supply Current IVCC VCC=5.0 V 6.5 8 mA Power Up Time TVCC Time from VCC > 4.5V to valid Vout and Vref (Note 2) 0.75 1.25 ms RPC Measure resistance between IP+ and IPMCA1101-50, MCA1101-65 Versions (Note 2) Measure resistance between IP+ and IPMCA1101-20, MCA1101-5 Versions (Note 2) Primary Side Input Primary Conductor Resistance 0.9 mΩ 1.3 Note 2 – Guaranteed by design and characterization. Not production tested. Note 3 – Vref pin supply capability limited to Fixed Gain mode. Phone: 978.965.3200 Fax: 978.965.3201 Document: 6020-1102-01 Rev G E-mail: info@aceinna.com www.aceinna.com Page 5 of 14 Table 6 – PERFORMANCE CHARACTERISTICS- 65A VERSIONS (MCA1101-65-5) Unless otherwise noted: 4.5V < VCC < 5.5V, I(Vout) = I(Vref) = 0, Typical values are for VCC = 5V and TA = 25°C. Parameter Symbol Test Conditions Min Typ Max Unit +65 A NOMINAL Vout TRANSFER FUNCTION MCA1101-65-5, Vout = Vref + IIN x 27mV/A Input Range Sensitivity IIN GAIN Calibrated Range -65 MCA1101-65-5 (Fixed Gain) 27 mV/A DC ACCURACY IIN = 0, TA = 0C to 85C (Note 4) -180 ±40 120 IIN = 0, TA = -40C to 0C (Note 5) -300 ±100 300 IIN = IFS, TA = 0C to 85C (Note 4) -1.5 ±0.5 1.5 IIN = IFS, TA = -40C to 0C (Note 5) -2.4 ±0.8 2.4 IIN = IFS, TA = 0C to 85C (Note 4) -1.5 ±0.5 1.5 IIN = IFS, TA = -40C to 0C (Note 5) -1.5 ±0.5 1.5 IIN = ±15A ~ ±65A, TA = 0C to 85C (Note 4) -7.5 ±3.0 7.5 IIN = ±15A ~ ±65A, TA = -40C to 0C (Note 5) -8.0 ±4.0 8.0 IOFFSET(D) (Note 6) -300 70 300 mA Sensitivity Drift ES(D) (Note 6) -1.3 0.3 1.3 % Total Error Drift ETOT(D) (Note 6) -1.7 ±0.4 1.7 %FS Zero Current Offset Sensitivity Error Linearity Error Total Error IOFFSET mA ES % EL %FS ETOT % RD LIFETIME DRIFT CHARACTERISTICS Zero Current Offset Drift Note 4: Typ values are 1. Min/max values are guaranteed by production test Note 5: Guaranteed by design and characterization. Typ values are 1, min/max values are 3. Note 6: Worst case numbers are based on 3 lots qualification data, taking the worst shifts from among HTOL (1000 hours), HTSL (1000 hours), THB (1000 hours), and TCT (700 cycles). Typical numbers are 1 . Phone: 978.965.3200 Fax: 978.965.3201 Document: 6020-1102-01 Rev G E-mail: info@aceinna.com www.aceinna.com Page 6 of 14 Table 7 – PERFORMANCE CHARACTERISTICS- 50A VERSIONS (MCA1101-50-5) Unless otherwise noted: 4.5V < VCC < 5.5V, I(Vout) = I(Vref) = 0, Typical values are for VCC = 5V and TA = 25°C. Parameter Symbol Test Conditions Min Typ Max Unit +50 A NOMINAL Vout TRANSFER FUNCTION MCA1101-50-5, Vout = Vref + IIN x 35mV/A Input Range Sensitivity IIN GAIN Calibrated Range -50 MCA1101-50-5 (Fixed Gain) 35 mV/A DC ACCURACY IIN = 0, TA = 0C to 85C (Note 4) -120 ±40 120 IIN = 0, TA = -40C to 0C (Note 5) -300 ±100 300 IIN = IFS, TA = 0C to 85C (Note 4) -1.5 ±0.5 1.5 IIN = IFS, TA = -40C to 0C (Note 5) -2.4 ±0.8 2.4 IIN = IFS, TA = 0C to 85C (Note 4) -1.5 ±0.5 1.5 IIN = IFS, TA = -40C to 0C (Note 5) -1.5 ±0.5 1.5 IIN = ±15A ~ ±50A, TA = 0C to 85C (Note 4) -2.5 ±1.5 2.5 IIN = ±15A ~ ±50A, TA = -40C to 0C (Note 5) -3.6 ±1.5 3.6 IOFFSET(D) (Note 6) -300 70 300 mA Sensitivity Drift ES(D) (Note 6) -1.3 0.3 1.3 % Total Error Drift ETOT(D) (Note 6) -1.7 ±0.4 1.7 %FS Zero Current Offset Sensitivity Error Linearity Error Total Error IOFFSET mA ES % EL %FS ETOT % RD LIFETIME DRIFT CHARACTERISTICS Zero Current Offset Drift Note 4: Typ values are 1. Min/max values are guaranteed by production test Note 5: Guaranteed by design and characterization. Typ values are 1, min/max values are 3. Note 6: Worst case numbers are based on 3 lots qualification data, taking the worst shifts from among HTOL (1000 hours), HTSL (1000 hours), THB (1000 hours), and TCT (700 cycles). Typical numbers are 1 . Phone: 978.965.3200 Fax: 978.965.3201 Document: 6020-1102-01 Rev G E-mail: info@aceinna.com www.aceinna.com Page 7 of 14 Table 8 – PERFORMANCE CHARACTERISTICS- 20A VERSIONS (MCA1101-20-5) Unless otherwise noted: 4.5V < VCC < 5.5V, I(Vout) = I(Vref) = 0, Typical values are for VCC = 5V and TA = 25°C. Parameter Symbol Test Conditions Min Typ Max Unit +20 A NOMINAL Vout TRANSFER FUNCTION MCA1101-20-5, Vout = Vref + IIN x 90mV/A Input Range Sensitivity IIN GAIN Calibrated Range -20 MCA1101-20-5 (Fixed Gain) 90 mV/A DC ACCURACY IIN = 0, TA = 0C to 85C (Note 4) -60 ±20 60 IIN = 0, TA = -40C to 0C (Note 5) -200 ±60 200 IIN = IFS, TA = 0C to 85C (Note 4) -0.7 ±0.3 0.7 IIN = IFS, TA = -40C to 0C (Note 5) -1.2 ±0.4 1.2 IIN = IFS, TA = 0C to 85C (Note 4) -0.7 ±0.3 0.7 IIN = IFS, TA = -40C to 0C (Note 5) -1.5 ±0.5 1.5 IIN = ±6A ~ ±20A, TA = 0C to 85C (Note 4) -2.0 ± 0.6 2.0 IIN = ±6A ~ ±20A, TA = -40C to 0C (Note 5) -3.0 ±1.0 3.0 IOFFSET(D) (Note 6) -300 60 300 mA Sensitivity Drift ES(D) (Note 6) -1.2 0.3 1.2 % Total Error Drift ETOT(D) (Note 6) -2.0 ±0.4 2.0 %FS Zero Current Offset Sensitivity Error Linearity Error Total Error IOFFSET mA ES % EL %FS ETOT % RD LIFETIME DRIFT CHARACTERISTICS Zero Current Offset Drift Note 4: Typ values are 1. Min/max values are guaranteed by production test Note 5: Guaranteed by design and characterization. Typ values are 1, min/max values are 3. Note 6: Worst case numbers are based on 3 lots qualification data, taking the worst shifts from among HTOL (1000 hours), HTSL (1000 hours), THB (1000 hours), and TCT (700 cycles). Typical numbers are 1 . Phone: 978.965.3200 Fax: 978.965.3201 Document: 6020-1102-01 Rev G E-mail: info@aceinna.com www.aceinna.com Page 8 of 14 Table 9 – PERFORMANCE CHARACTERISTICS- 5A VERSIONS (MCA1101-5-5) Unless otherwise noted: 4.5V < VCC < 5.5V, I(Vout) = I(Vref) = 0, Typical values are for VCC = 5V and TA = 25°C. Parameter Symbol Test Conditions Min Typ Max Unit +5 A NOMINAL Vout TRANSFER FUNCTION MCA1101-5-5, Vout = Vref + IIN x 350mV/A Input Range Sensitivity IIN GAIN Calibrated Range -5 MCA1101-5-5 (Fixed Gain) 350 mV/A DC ACCURACY IIN = 0, TA = 0C to 85C (Note 4) -60 ±20 60 IIN = 0, TA = -40C to 0C (Note 5) -60 ±20 60 IIN = IFS, TA = 0C to 85C (Note 4) -1.0 ±0.4 1.0 IIN = IFS, TA = -40C to 0C (Note 5) -1.5 ±0.5 1.5 IIN = IFS, TA = 0C to 85C (Note 4) -0.5 ±0.3 0.5 IIN = IFS, TA = -40C to 0C (Note 5) -0.75 ±0.4 0.75 IIN = ±3A ~ ±5A, TA = 0C to 85C (Note 4) -2.0 ±1.0 2.0 IIN = ±3A ~ ±5A, TA = -40C to 0C (Note 5) -3.0 ±2.0 3.0 IOFFSET(D) (Note 6) -300 70 300 mA Sensitivity Drift ES(D) (Note 6) -1.3 0.3 1.3 % Total Error Drift ETOT(D) (Note 6) -6 ±1.5 6 %FS Zero Current Offset Sensitivity Error Linearity Error Total Error IOFFSET mA ES % EL %FS ETOT % RD LIFETIME DRIFT CHARACTERISTICS Zero Current Offset Drift Note 4: Typ values are 1. Min/max values are guaranteed by production test Note 5: Guaranteed by design and characterization. Typ values are 1, min/max values are 3. Note 6: Worst case numbers are based on 3 lots qualification data, taking the worst shifts from among HTOL (1000 hours), HTSL (1000 hours), THB (1000 hours), and TCT (700 cycles). Typical numbers are 1 . Phone: 978.965.3200 Fax: 978.965.3201 Document: 6020-1102-01 Rev G E-mail: info@aceinna.com www.aceinna.com Page 9 of 14 Table 10 – OCD ELECTRICAL CHARACTERISTICS Unless otherwise noted: 4.5V < VCC < 5.5V, -40°C ≤ TA ≤ 105°C, I(Vout) = I(Vref) = 0, Typical values are for VCC = 5V and TA = 25°C. Parameter Symbol Test Conditions Min Typ Max Unit OVERCURRENT FAULT CHARACTERISTICS FAULTB Response Time FAULTB Range tRESPONSE I FAULTB Time from IP > I FAULTB to when FAULTB pin is pulled below V FAULTB ; input current step from 0 to 1.5 ×I FAULTB For parts rated for IP=5A; VOC voltage between 0V and 1.0V For parts rated for IP=5A; VOC voltage between 1.4V and 1.6V For parts rated for IP=5A; VOC voltage between 2.V0 and 2.5V For parts rated for IP=20A; VOC voltage between 0V and 1.0V For parts rated for IP=20A; VOC voltage between 1.4V and 2.5V For parts rated for IP=50A; VOC voltage between 0V and 2.5V For parts rated for IP=65A; VOC voltage between 0V and 2.5V FAULTB Output Low Voltage V FAULTB In fault condition; RFPU = 2-10 kΩ FAULTB Output High Voltage V FAULTB In fault condition; RFPU = 2-10 kΩ FAULTB Pull-Up Resistance OCD Threshold Setting Error RFPU VOC Input Range 0.2 6 7.5 10 24 A 30 60 78 0.2 2 V VCC V 10 kΩ 6 E FAULTB VVOd uS For setting OCD trig threshold 0 VCC/2 V VCC V VOC high input level to reset OCD VIHocd VCC0.5 VOC High State Duration THVOC 1 Phone: 978.965.3200 Fax: 978.965.3201 Document: 6020-1102-01 Rev G % E-mail: info@aceinna.com μs www.aceinna.com Page 10 of 14 AMR TECHNOLOGY Anisotropic magnetoresistance (AMR) makes use of a common material, Permalloy, to act as a magnetometer. Permalloy is an alloy containing roughly 80% nickel and 20% iron. The alloy’s resistance depends on the angle between the magnetization and the direction of current flow. In a magnetic field, magnetization rotates toward the direction of the magnetic field and the rotation angle depends on the external field’s magnitude. Permalloy’s resistance decreases as the direction of magnetization rotates away from the direction in which current flows, and is lowest when the magnetization is perpendicular to the direction of current flow. The resistance changes roughly as the square of the cosine of the angle between the magnetization and the direction of current flow. Permalloy is deposited on a silicon wafer and patterned as a resistive strip. The film’s properties cause it to change resistance in the presence of a magnetic field. In a current sensor application, two of these resistors are connected in a Wheatstone bridge configuration to permit the measurement of the magnitude of the magnetic field produced by the current. AMR properties are well behaved when the film’s magnetic domains are aligned in the same direction. This configuration ensures high sensitivity, good repeatability, and minimal hysteresis. During fabrication, the film is deposited in a strong magnetic field that sets the preferred orientation, or “easy” axis, of the magnetization vector in the Permalloy resistors. AMR has better sensitivity than other methods and reasonably good temperature stability. The AMR sensor has sensitivity which is approximately a linear function of temperature. voltage threshold Vout and Vref are released and will drive to approximately half the VCC supply voltage and an initial calibration will commence. Once the initial calibration has completed the MCA1101 becomes active. Vout will slew to indicate the value of current flowing in the IP+/- conductor. Current flow in the IP+/- conductor with a VCC voltage less than the under-voltage threshold will not cause damage to the sensor. OVERCURRENT DETECTION (OCD) The MCA1101 have fast and accurate overcurrent fault detection circuitry. The overcurrent fault threshold (I FAULTB ) is user-configurable via an external resistor divider and supports a range of 120% to 200% of the full-scale primary input (IP). The overcurrent fault threshold (I FAULTB ) is set via a resistor divider from VCC to ground on the VOC pin. The voltage on the VOC pin (VVOC), may range from 0 ×VCC to 0.5 ×VCC. For +/-5A parts For VVOC between 0 ×VCC and 0.225 ×VCC the I threshold level is 1.2×IP. For VVOC between 0.225 ×VCC and 0.35 ×VCC the I threshold level is 1.5×IP. For VVOC between 0.35 ×VCC and 0.5×VCC the I threshold level is 2×IP. For +/-20A parts For VVOC between 0 ×VCC and 0.225 ×VCC the I threshold level is 1.2×IP. For VVOC between 0.225 ×VCC and 0.5 ×VCC the I threshold level is 1.5×IP. FAULTB FAULTB FAULTB FAULTB FAULTB FUNCTIONAL DESCRIPTION Figure 2 provide block diagrams of the fixed gain. The AMR sensor monitors the magnetic field generated by the current flowing through the U shaped IP+/IP- package lead frame. The AMR sensor produces a voltage proportional to the magnetic field created by the positive or negative current in the IP+/IPcurrent loop while rejecting external magnetic interference. The sensor voltage is fed into a differential amplifier whose gain is temperature compensated. This is followed by an instrumentation amplifier output stage that provides a voltage that indicates the current passing through the IP+/IP- pins. To provide both positive and negative current data the Vout output pin is referenced to the Vref output pin. The voltage on the Vref output is typically one half of the full scale positive and negative range of the Vout current sense output signal. With no current flowing in the IP+/IP- pins, the voltage on the Vout output will typically equal the voltage on the Vref output. Positive IP+/IPcurrent causes the voltage on Vout to increase relative to Vref while negative IP+/IP- current will cause it to decrease. GAIN For +/-50A parts For VVOC between 0 ×VCC and 0.5 ×VCC the I level is 1.2×IP. FAULTB threshold For +/-65A parts For VVOC between 0 ×VCC and 0.5 ×VCC the I level is 1.2×IP. FAULTB threshold If the input current exceeds the OCD threshold value I FAULTB the output pin FAULTB will transition low and stay low, even if input current drops below the threshold. In order to reset the FAULTB output the user needs to bring VOC pin to VCC and hold it there for at least THvoc. . Once the OCD function is reset the VOC voltage should return back to its normal operating voltage Vvoc. A switch SW1 on Figure 1 can be used for this. Other methods are available as well. If OCD function is used, an OCD reset must be applied to the VOC pin after system power up, to put the OCD function and FAULTB pin in a known state. The sensor resistors are biased by an internal 4.35V reference voltage and the voltage on the Vref output is 2.175V (typical). This arrangement provides a fixed gain and enhanced supply rejection. The Vout pin drives to approximately 3.9V at full positive current and 0.3V at full negative current. The FAULTB output is active low open drain. A pull-up resistor POWER UP / DOWN FAULTB low output voltage is below 200mV. The value of pullup resistor is 2-10kOhm. An under-voltage lockout circuit monitors the voltage on the VCC pin. If the VCC voltage is less than the under-voltage threshold the MCA1101 is in an inactive state. Vout and Vref both drive to ground. If the VCC voltage exceeds the under- Phone: 978.965.3200 Fax: 978.965.3201 Document: 6020-1102-01 Rev G should be connected between FAULTB and VCC. The VCC voltage will determine the high level of FAULTB signal. E-mail: info@aceinna.com www.aceinna.com Page 11 of 14 FREQUENCY RESPONSE The MCA1101 offers a low noise and wideband response, with a 3dB bandwidth of > 1.5MHz, as shown in the plots below. Vout response time is the time interval from 80% of the IP to 80% of the Vout. The response time is 300ns typical. Gain vs. Frequency 5 RESPONSE TIME Gain(dB) 0 1 10 100 1000 10000 -5 -10 -15 -20 Figure 5 - Vout response time Freq(KHz) APPLICATIONS INFORMATION Figure 3 - Gain vs. Frequency The MCA1101 detects current by measuring the magnetic field generated by that current. Therefore it’s important to consider the effect of externally generated magnetic fields, whether from another current flowing in the system, a magnet, or electromagnetic component. Phase vs. Frequency 10 Phase(°) -40 1 10 100 1000 10000 -90 -140 -190 -240 Freq(KHz) Figure 4 - Phase vs. Frequency In order to provide immunity to external fields, MCA1101 senses a differential field generated by the primary current, which flows through a U-shaped conductor inside the package. Therefore, to first order, the sensor will reject any common mode field originating from outside of its package. However, it’s still prudent to minimize the exposure to external fields. The MCA1101 is most sensitive to magnetic fields in the X-Y plane (i.e. the plane of the PCB surface), and is relatively insensitive to fields in the Z direction (perpendicular to the PCB surface). Thus when laying out the PCB, care should be taken to avoid a current passing directly underneath the device itself, because the magnetic field generated by that current will be parallel to the PCB surface. When laying out the PCB, the traces carrying the input and output currents should approach the two sets of 4 input/output pins in a symmetric manner, from a direction perpendicular to the edge of the package (see Figure 6 below). Figure 6 - Layout for current traces Note: The via break in the metal at either end of the package. The purpose of these is to prevent the input current from approaching the input pins from the lateral direction Phone: 978.965.3200 Fax: 978.965.3201 Document: 6020-1102-01 Rev G E-mail: info@aceinna.com www.aceinna.com Page 12 of 14 DEVICE MARKING Production information is printed on the package surface by laser marking. Markings consist of 3 lines of characters including ACEINNA logo. Line 1 Line 1: ACEINNA Logo Line 2 Line 3 Line 2: Part Marking Line 3: Date Code PART MARKING (Line 2) M C A 1 1 XX 5 Supply voltage, VCC: 5 – 5V Nominal current rating: 05 - 5A, A 20 - 20A, 50 - 50A 65 – 65A Internal code Internal code Output gain version: A - Fixed Gain Product family: MC - Magnetic current sensor DATE CODE (Line 3) X YY WW LLL Lot number Date code: Week number Date code: Last 2 digits of the Year Internal code (letter A-Z or a number 0-9) Phone: 978.965.3200 Fax: 978.965.3201 Document: 6020-1102-01 Rev G E-mail: info@aceinna.com www.aceinna.com Page 13 of 14 PACKAGE OUTLINE & RECOMMENDED LAND PATTERN INFORMATION – 16-pin SOIC PACKAGE OUTLINE DRAWING 9¡ã ¡À 2¡ã SYMBOL D ZD 16 R E MCXXXXXX XXXXXXXX H L DETAIL-A 1 h X 45¡ã 0,08 A A1 DETAIL-A J K 7¡ã ¦Á A2 C MIN MAX 2.44 2.64 A1 0.10 0.30 A2 2.24 2.44 0.46 B 0.36 C 0.23 0.32 D 10.11 10.31 E 7.40 7.60 1.27 BSC H 10.11 10.51 h 0.31 0.71 J 0.381 REF K 9° BSC L R ZD RECOMMENDED LAND PATTERN MILLIMETERS A e e B SOIC-16LD α 0.51 1.01 0.76 REF 0.66 REF 0° 8° Unit: mm 0.6 1.27 16 2.2 11.4 Note: Recommended land pattern reference IPC7351B; Adjust as necessary to meet application requirements and PCB layout tolerances. 1 Phone: 978.965.3200 Fax: 978.965.3201 Document: 6020-1102-01 Rev G E-mail: info@aceinna.com www.aceinna.com Page 14 of 14
MCA1101-65-5 价格&库存
很抱歉,暂时无法提供与“MCA1101-65-5”相匹配的价格&库存,您可以联系我们找货
