0402X474K160NT
0402X474K160NT
    FH(风华)
    贴片电容(MLCC) 0402 470nF ±10% 16V X5R
0402X474K160NT 数据手册
GENERAL MLCC ■ 通用型系列片式陶瓷电容器 General series of ceramic chip capacitors ◆ 特征 Feature *叠层独石结构,具有高可靠性能 There is high reliability on monolithic structure of laminated layers. *具有优良的焊接与耐焊性能,适用于回流焊接与波峰焊接 And its character of excellent soldering ability and soldering resistance ability is suitable for reflow soldering and peak soldering. *具有较高的容量且容量性能稳定 It includes high and stable capacitance. *高频类:此类介质材料的电容器为Ⅰ类电容器。其中 COG、COH 电容器电性能最稳定,几乎不随温度、电压和时间的变化而 变化,适用于低损耗,稳定性要求高的高频电路。 High Frequency Type: This kind of dielectric material is considered as Class Ⅰ capacitor. COG and COH capacitors have the most stable electrical performance, which almost does not change with the change of temperature, voltage or time, th ey are suitable for the low-loss and high stability requirement circuits. *X7R、X5R、X7S、X6S:此类介质材料的电容器为Ⅱ类电容器,具有较高的介电常数,容量比Ⅰ类电容器高,具有较稳定 的温度特性,适用于容量范围广,稳定性要求不高的电路中,如隔直、耦合、旁路、鉴频等电路中。 X7R、X5R、X7S、X6S:X7R、X5R、 X7S、X6S material is a kind of material has high dielectric constant. The capacitor made of this kind material is considered as Class Ⅱ capacitor whose capacitance is higher than that of class Ⅰ. These capacitors are classified as having a semi-stable temperature characteristic and used over a wide temperature range, such in these kinds of circuits, DC-blocking, decoupling, bypassing, frequency discriminating etc. 执行标准:GH/T 21041-2007 GH/T 21042-2007 Executive Standard: GH/T 21041-2007 GH/T 21042-2007 ◆ 应用 Application *应用于各种滤波、耦合、谐振、旁路、高频电子线路 It is suitable for all kinds of filter, coupled, harmonic vibration, bypassing and high frequency circuits. *中高压产品广泛应用在模拟或数字调制解调器、倍压电器、直流变送器、背光源驱动电路 High voltage products are widely used in analog and digit modem, voltage doubling appliance, DC transmitter and backlight drive circuit. GENERAL MLCC ◆型号表示法 How To Order 0805 CG 标称容量 Nominl Capacitance 尺寸规格 Size Code 尺寸 规格 Size Code 长×宽 (L×W) inch 长×宽 (L×W) mm 1005 0.01×0.005 0.40×0.20 0201 0.02×0.01 0.60×0.30 0402 0.04×0.02 1.00×0.50 0603 0.06×0.03 1.60×0.80 0805 0.08×0.05 2.00×1.25 1206 0.12×0.06 3.20×1.60 1210 0.12×0.10 3.20×2.50 1808 0.18×0.08 4.50×2.00 1812 0.18×0.12 4.50×3.20 2220 0.22×0.20 5.70×5.00 2225 0.22×0.25 5.70×6.30 表示方式 Express Method 实际值 Actual Value 表示方式 Express Method 实际值 Actual Value 0R5 0.5 6R3 6.3 1R0 1.0 500 50×100 102 10×102 201 20×101 介质种类 Dielectric Code 介质种类 Dielectric Code 介质材料 Dielectric CG C0G CH C0H HG HG LG LG PH PH RH RH SH SH TH TH UJ UJ SL SL X X5R B X7R X7S E Z5U F Y5V N 额定电压 Rated Voltage 单位(unit):V 注:头两位数字为有效数 字,第三位数字为 0 的个 数;R 为小数点。 Note: the first two digits are significant; third digit denotes number of zeros; R=decimal point. BS 500 J 102 误差 Tolerance A ±0.05pF B ±0.10pF C ±0.25pF D ±0.50pF F ±1% G ±2% J ±5% K ±10% M ±20% S -20% +50% Z -20% +80% 包装方式 Package Styles 表示方式 Express Method 包装方式 Package Styles B 散包装 Bulk Bag T 编带包装 Taping Package 注:头两位数字为有效数 字,第三位数字为 0 的个 数;R 为小数点。 Note: the first two digitsare significant; third digit denotes number of zeros; R=decimal point. 容量误差 Capacitance Tolerance 代码 Code T 备注 Note A、B、C、D 级误 差适用于容量≤ 10pF 的产品。 These Capacitance tolerance A , B, C, D are just applicable the capacitance that equals to or less than 10pF。 端头材料 Terminal Material Styles 端头类别 Termination Styles 纯银端头 Silver Solderable Termination 纯铜端头 Copper Solderable Termination 三层电镀端头 Nickel Barrier Termination 表示方式 Express Method S C N GENERAL MLCC ◆ 温度系数/特性 Temperature Coefficient /Characteristics 介质种类 Dielectric 参考温度点 Reference Temperature Point 标称温度系数 Temperature Coefficient 工作温度范围 Operation Temperature Range COG 20C 030 ppm/℃ -55℃~125℃ COH 20C 060 ppm/℃ -55℃~125℃ HG 20C -3330 ppm/℃ -25℃~85℃ LG 20C -7530 ppm/℃ -25℃~85℃ PH 20C -150 60 ppm/℃ -25℃~85℃ RH 20C -220 60 ppm/℃ -25℃~85℃ SH 20C -330 60 ppm/℃ -25℃~85℃ TH 20C -470 60 ppm/℃ -25℃~85℃ UJ 20C -750 120 ppm/℃ -25℃~85℃ SL 20C -1000~+140 ppm/℃ -25℃~85℃ X7R 20C 15% -55℃~125℃ X5R 20C 15% -55℃~85℃ X7S 20C 22% -55℃~125℃ X6S 20C 22% -55℃~105℃ Z5U 20C -56%~+22% 10℃~85℃ Y5V 20C -80%~+30% -25℃~85℃ 备注:Ⅰ类电容器标称温度系数和允许偏差是采用温度在 20C 和 85C 之间的电容量变化来确定的,而Ⅱ类电容器标称温度系数是按照工作 范围之间的电容量相对 20C 的电容量变化来确定的。 Note:Nominal temperature coefficient and allowed tolerance of class Ⅰare decided by the changing of the capacitance between 20C and 85C. Nominal temperature coefficient of class Ⅱare decided by the temperature of 20C. ◆产品结构 Product Structure W L 序号 NO ① T ② ③ ① ④ ② ③ ④ ⑤ ⑤ ◆产品尺寸 Product Dimensions L L T T WB T WB 名称 Name 陶瓷介质 Ceramic dielectric 内电极 Inner electrode 外电极 Substrate electrode 镍层 Nickel Layer 锡层 Tin Layer GENERAL MLCC ≤50V 通用产品 尺寸 Dimensions 型号 Type 英制表示 British expression 公制表示 Metric expression 1005 0402 0201 0603 介质种类 Dielectric W T WB 所有介质 All Dielectric 0.4±0.02 0.2±0.02 0.2±0.02 0.1±0.03 All 所有介质 All Dielectric 0.6±0.03 0.3±0.03 0.3±0.03 0.15±0.05 C<220nF 0.6±0.05 1.00±0.05 0.3±0.05 0.50±0.05 0.3±0.05 0.50±0.05 0.15±0.05 0.25±0.05 C≥220nF C<0.33uF 1.00±0.15 0.50±0.10 0.50±0.10 0.25±0.05 0.33uF≤C≤1uF 1.00±0.05 0.50±0.05 0.50±0.05 0.25±0.05 C<1uF 1.00±0.15 0.50±0.15 0.50±0.15 0.25±0.05 1uF≤C<10uF 1.00±0.20 0.50±0.20 0.50±0.20 0.25±0.05 C≥10uF 1.60±0.10 0.80±0.10 0.80±0.10 0.35±0.20 C≤1uF 1.60±0.20 0.80±0.20 0.80±0.20 0.35±0.20 C>1uF 2.00±0.20 1.25±0.20 0.70±0.10 0.50±0.20 C≤0.22uF 2.00±0.20 1.25±0.20 0.80±0.10 0.50±0.20 0.22uF<C≤2.2uF 2.00±0.20 1.25±0.20 1.25±0.20 0.50±0.20 2.2uF<C≤10uF 2.00±0.20 1.25±0.20 0.80±0.20 0.50±0.20 C≤2.2μF 2.00±0.20 1.25±0.20 1.25±0.20 0.50±0.20 C≥0.47μF 3.20±0.30 1.60±0.30 0.80±0.20 0.60±0.30 C≤10μF 3.20±0.30 1.60±0.30 1.60±0.30 0.60±0.30 C>10μF 3.20±0.30 1.60±0.30 0.80±0.20 0.60±0.30 C≤330nF 3.20±0.30 1.60±0.30 1.00±0.20 0.60±0.30 330nF<C<470nF 3.20±0.30 1.60±0.30 1.25±0.20 0.60±0.30 470nF≤C<2.2μF 3.20±0.30 1.60±0.30 1.60±0.30 0.60±0.30 C≥2.2μF 3.20±0.30 2.50±0.30 ≤2.80 0.60±0.30 All 1005 除 Y5V/Z5U 外 0603 0805 0805 1608 2012 2012 所有材料 All Dielectric Y5V/Z5U 除 Y5V/Z5U 外 Y5V/Z5U 1206 3216 除 Y5V/Z5U 外 1210 3225 特别说明 Special Instructions L Y5V/Z5U 0402 (mm) 所有介质 All Dielectric 所有介质 4.50±0.40 2.00±0.20 ≤2.20 0.60±0.30 All All Dielectric 所有介质 1812 4532 4.50±0.40 3.20±0.30 ≤3.50 0.60±0.30 All All Dielectric 所有介质 2220 5750 5.70±0.40 5.00±0.40 ≤3.50 0.60±0.30 All All Dielectric 所有介质 2225 5763 5.70±0.50 6.30±0.50 ≤6.20 0.60±0.30 All All Dielectric 备注:1、产品具体厚度“T”查阅本承认书中“容量范围及其电压”。2、可根据客户的特殊要求设计符合客户需求的产品。 Note:1、The specific thickness of the product can read "capacity range and voltage "in this approval sheet. 2、We can design according to customer special requirements 1808 4520 GENERAL MLCC >50V 中高压产品 型号 Type 尺寸 Dimensions (mm) 英制表示 British expression 公制表示 Metric expression L W T WB 0402 1005 1.00±0.05 0.50±0.05 0.50±0.05 0.25±0.05 0603 1608 1.60±0.10 0.80±0.10 0.80±0.10 0.35±0.20 ≤0.55 0.80±0.20 0805 2012 2.00±0.20 1.25±0.20 0.50±0.20 1.00±0.20 1.25±0.20 0.80±0.20 1.00±0.20 1206 3216 3.20±0.30 1.60±0.30 0.60±0.30 1.25±0.20 1.60±0.30 1210 3225 3.20±0.30 2.50±0.30 ≤2.80 0.60±0.30 1808 4520 4.50±0.40 2.00±0.20 ≤2.20 0.60±0.30 1812 4532 4.50±0.40 3.20±0.30 ≤3.50 0.60±0.30 2220 5750 5.70±0.40 5.00±0.40 ≤3.50 0.60±0.30 2225 5763 5.70±0.50 6.30±0.50 ≤6.20 0.60±0.30 备注:1、产品具体厚度“T”查阅本承认书中“容量范围及其电压”。2、可根据客户的特殊要求设计符合客户需求的产品。 Note:1、The specific thickness of the product can read "capacity range and voltage "in this approval sheet. 2、We can design according to customer special requirements ◆ 容量范围及其电压 Capacitance Range and Operating Voltage 尺寸规格 Size Code 1005 0201 0402 0603 0805 6.3V 10V 16V 25V 50V 6.3V 10V 16V 25V 50V 6.3V 10V 16V 25V 50V 6.3V 10V 16V 25V 50V 6.3V 10V 16V 25V 50V 1206 容量范围 Capacitance 额定电压 Rated Voltage 6.3V 10V 16V 25V 50V —— COG(NPO)(PF) 0.1~220【0.2】 0.1~100【0.2】 0.1~100【0.2】 —— —— —— —— 0.1~1,000【0.3】 0.1~220【0.3】 3,300~4,700【0.5】 1,200~2,700【0.5】 1,200~2,700【0.5】 0.1~1,200【0.5】 0.1~1,000【0.5】 —— 12,000~22,000【0.8】 8,200~10,000【0.8】 0.1~6,800【0.8】 0.1~6,800【0.8】 —— 10,000~100,000【1.25】 10,000~33,000【1.25】 10,000~27,000【1.25】 0.1~8,200【0.8】 10,000~22,000【1.25】 —— —— —— —— 0.3~8,200【0.8】 10,000~100,000【1.6】 备注:1、【】对应容量的通用厚度,单位:mm 2、可根据客户的特殊要求设计符合客户需求的产品 Note:1、【】General thickness corresponds to the capacity,unit:mm 2、We can design according to the customer requirements. —— Y5V (Z5U)(PF) —— —— —— —— 10,000~100,000【0.3】 —— 10,000【0.3】 —— —— 1,000~1,000,000【0.5】 1,000~1,000,000【0.5】 1,000~220,000【0.5】 1,000~220,000【0.5】 1,000~100,000【0.5】 2,700,000~10,000,000【0.8】 2,700,000~10,000,000【0.8】 1,000~2,200,000【0.8】 1,000~2,200,000【0.8】 1,000~1,000,000【0.8】 2,700,000~22,000,000【0.8】 2,700,000~22,000,000【0.8】 2,700,000~10,000,000【0.8】 2,700,000~4,700,000【0.8】 1,000~2,200,000【0.8】 22,000,000~47,000,000【1.6】 22,000,000【1.6】 22,000,000【1.6】 4,700,000~10,000,000【0.8】 1,000~4,700,000【0.8】 GENERAL MLCC 容量范围 Capacitance 尺寸规格 Size Code 额定电压 Rated Voltage 1210 6.3V 10V 16V 25V 50V COG(NPO)(PF) —— —— —— —— 10~100,000【1.25】 Y5V (Z5U)(PF) 10,000,000~100,000,000【2】 10,000,000~47,000,000【2】 10,000,000~22,000,000【2】 6,800,000~10,000,000【1.25】 4,700~4,700,000【1.25】 50V 6.3V 10V 16V 25V 50V 10~100,000【1.6】 —— —— —— —— 10~100,000【1.25】 —— 10,000~100,000,000【1.6】 10,000~100,000,000【1.6】 10,000~22,000,000【1.6】 10,000~10,000,000【1.6】 10,000~10,000,000【1.6】 1808 1812 尺寸规格 Size Code 1005 0201 0402 0603 容量范围 Capacitance X7S(μF) X5R(μF) —— 0.015~0.1【0.2】 —— 0.015~0.01【0.2】 0.01~1【0.3】 0.015~2.2 【0.3】 0.01~0.22【0.3】 0.015~2.2 【0.3】 0.01~0.22【0.3】 0.015~2.2 【0.3】 0.015~0.22【0.3】 —— 0.015~0.1【0.3】 —— 0.0047~0.01【0.3】 —— 额定电压 Rated Voltage 4V/6.3V 10V/16V 4V 6.3V 10V 16V 25V 50V X7R (nF) —— 0.1~1【0.2】 —— —— 0.1~22【0.3】 0.1~22【0.3】 0.1~10【0.3】 0.1~1【0.3】 4V —— —— 6.3V 10V 16V 25V 50V 4V 0.1~470【0.5】 0.1~470【0.5】 0.1~220【0.5】 0.1~220【0.5】 0.1~100【0.5】 —— 0.1~0.47【0.5】 0.1~0.47【0.5】 0.047~0.22【0.5】 0.022~0.1【0.5】 0.0047~0.1【0.5】 —— 6.3V 0.15~4,700【0.8】 0.47~2.2【0.8】 10V 16V 25V 50V 0.15~2,200【0.8】 0.15~2,200【0.8】 0.15~1,000【0.8】 0.15~1,000【0.8】 0.47~2.2【0.8】 0.47~1【0.8】 0.47~1【0.8】 —— 0.47~22【0.8】 0.47~10【0.8】 0.47~10【0.8】 0.47~2.2【0.8】 4V —— —— 1~47【1.25】 6.3V 0.15~470【0.8】 560~10,000【1.25】 1~10【1.25】 1~47【1.25】 10V 0.15~470【0.8】 560~10,000【1.25】 1~10【1.25】 1~47 【1.25】 1~4.7【1.25】 1~22【1.25】 1~4.7【1.25】 1~22【1.25】 —— 1~4.7【1.25】 0805 16V 25V 50V 0.15~470【0.8】 560~10,000【1.25】 0.15~470【0.8】 560~4,700【1.25】 0.15~470【0.8】 560~2,200【1.25】 0.1~22 【0.5】 X6S(μF) —— —— 0.015~2.2【0.3】 0.015~2.2【0.3】 0.015~0.1【0.3】 0.015~0.1【0.3】 0.015~0.1【0.3】 —— 0.1~22 【0.5】 0.1~22 【0.5】 0.1~10 【0.5】 0.1~4.7 【0.5】 0.1~2.2 【0.5】 0.047~1【0.5】 0.47~47 【0.8】 0.1~22 【0.5】 0.1~10 【0.5】 0.1~4.7 【0.5】 0.1~1 【0.5】 —— 0.1~47 【0.8】 0.47~47 0.1~47 【0.8】 【0.8】 0.1~10 【0.8】 0.1~10 【0.8】 0.1uF~4.7 【0.8】 —— 0.1~0.47【0.8】 0.56~47【1.25】 0.1~0.47【0.8】 0.56~22【1.25】 0.1~0.47 【0.8】 0.56~47 【1.25】 0.1~0.47【0.8】 0.56~10【1.25】 0.1~0.47【0.8】 0.56~10【1.25】 —— GENERAL MLCC 尺寸规格 Size Code X7R (nF) X7S (μF) 4V —— 2.2~100【1.6】 0.1~1.5 2.2~100 【0.8】 【1.6】 2.2~100 【1.6】 6.3V 0.2~330【0.8】 470~1,500【1.25】 2,200~22,000【1.6】 2.2~22 【1.6】 2.2~100 【1.6】 0.1~1.5 2.2~100 【0.8】 【1.6】 10V 1206 16V 25V 50V 1210 1808 1812 容量范围 Capacitance 额定电压 Rated Voltage 0.2~330【0.8】 470~1,500【1.25】 2,200~22,000【1.6】 0.2~330【0.8】 470~1,500【1.25】 2,200~22,000【1.6】 0.2~330【0.8】 470~1,500【1.25】 2,200~22,000【1.6】 0.2~330【0.8】 470~1,500【1.25】 2,200~10,000【1.6】 X5R(μF) X6S(μF) 2.2~22 【1.6】 2.2~47 【1.6】 0.1~1.5 2.2~47 【0.8】 【1.6】 1~1.5 【0.8】 2.2~10 【1.6】 2.2~47 【1.6】 0.1~1.5 2.2~47 【0.8】 【1.6】 0.1~1.5 2.2~10 【0.8】 【1.6】 1~1.5 【0.8】 2.2~10 【1.6】 2.2~22 【1.6】 1~1.5 【0.8】 2.2~10 【1.6】 2.2~10 【1.6】 —— 4V —— —— 4.7~10【1.6】12~330 【2.5】 0.1~0.47【1.25】 0.56~10【1.6】 12~330【2.5】 6.3V 0.22~470【1.25】 560~47,000【1.6】 4.7~10【1.6】 12~100【2.5】 4.7~10【1.6】12~330 【2.5】 0.1~0.47【1.25】 0.56~10【1.6】 12~100【2.5】 10V 0.22~470【1.25】 560~47,000【1.6】 —— 4.7~10【1.6】12~100 【2.5】 16V 0.22~470【1.25】 560~22,000【1.6】 2,2~10【1.6】 15~22【2.5】 4.7~10【1.6】12~100 【2.5】 25V 0.22~470【1.25】 560~22,000【1.6】 2,2~10【1.6】 15~22【2.5】 4.7~10【1.6】 12~47【2.5】 0.1~0.47【1.25】 0.56~10【1.6】 12~100【2.5】 0.1~0.47【1.25】 0.56~10【1.6】 12~47【2.5】 0.1~0.47【1.25】 0.56~22【1.6】 50V 0.22~470【1.25】 560~10,000【1.6】 1~10【1.6】 4.7~10【1.6】 —— 6.3V 0.22~4,700【1.6】 —— 4.7~100【1.6】 —— 10V 0.22~4,700【1.6】 —— 4.7~47【1.6】 —— 16V 0.22~4,700【1.6】 —— 4.7~22【1.6】 —— 25V 0.22~4,700【1.6】 —— 4.7~10【1.6】 —— 50V 0.22~4,700【1.6】 —— —— —— 6.3V —— —— 10~100【2.5】 —— 10V —— —— 10~47【2.5】 —— —— 4.7~22【2.5】 —— —— 4.7~10【2.5】 —— —— —— —— 16V 25V 50V 0.47~1,000【1.6】 1,200~6,800【2.5】 0.47~1,000【1.6】 1,200~4,700【2.5】 0.47~1,000【1.6】 1,200~4,700【2.5】 备注:1、【】对应容量的通用厚度,单位:mm 2、可根据客户的特殊要求设计符合客户需求的产品 Note:1、【】General thickness corresponds to the capacity,unit:mm 2、We can design according to the customer requirements. GENERAL MLCC ■ 中高压电容器 High Voltage MLCC 中高压多层片状陶瓷电容器是在多层片状陶瓷电容器的工艺技术、设备基础上,通过采用特 殊工艺制作的一种具有良好高压可靠性的产品,该产品适合于表面贴装,适合于多种直流高 压线路,可以有效的改善电子线路的性能。 Middle & high voltage MLCC is a kind of special design 、 special technology MLCC that bases on the technology of general MLCC. This kind of MLCC has stable high voltage reliability and suitable to SMT. Middle & high MLCC is widely applicable for many direct high voltage circuits in which it can improve the performance of the circuit. ◆ 应用 Application *模拟或数字调制解调器 Analog & Digital Modems *日光灯启动辉器照明电路 Lighting Ballast Circuits *直流变送器 DC-DC Converters *局域网/广域网接口界面 LAN/WAN Interface *倍压电器 Voltage Multipliers *背光源驱动电路 Back-lighting Inverters ◆ 容量范围及其电压 Capacitance Range and Operating Voltag 尺寸规格 Size Code 0402 0603 工作电压 Rated Voltage 100V 100V 200V NPO(pF) 0.1~100【0.5】 0.1~1,000【0.8】 0.1~470【0.8】 250V 0.1~470【0.8】 100V 0805 200V~250V 500V~630V 1000V 1206 0.1~3,300【0.8】 0.1~1,000【0.8】 1,200~1,500【1.25】 0.1~330【0.8】 470~560【1.25】 0.1~100【1.25】 100V 0.1~3,300【0.8】 200V~250V 0.1~1,800【0.8】 2,000~2,700【1.25】 500V~630V 1000V 2000V 0.1~10【0.8】 11~470【1】 560~1,500【1.25】 0.1~120【1】 150~1,000【1.25】 0.1~39【1】 47~68【1.25】 82~270【1.6】 容量范围 Capacitance X7R(nF) 0.15~4.7【0.5】 0.150~100【0.8】 0.15~10【0.8】 0.15~10【0.8】 0.150~56 68~220 0.15~18 20~22 0.150~5.6 6.8~10 【0.8】 【1.25】 【0.8】 【1.25】 【0.8】 【1.25】 —— 0.150~56【0.8】 68~330【1.25】 470~1,000【1.6】 0.150~27【0.8】 33~150【1.25】 180~220【1.6】 Y5V(nF) —— 2.2~100【0.8】 —— —— 10~100【0.8】 10~47【0.8】 —— —— 15~470【0.8】 10~220【0.8】 0.150~2.7【0.8】 3.3~33【1.25】 —— 0.150~1【0.8】 1.1~12【1.25】 —— 0.150~2.7【1.25】 —— 0.15~220【1.25】 15~1,000【1.25】 330~2,200【1.6】 0.150~150【1.25】 1.0~3,300【1.25】 15~470【1.25】 200V~250V 180~220【1.25】 1.0~1,200【1.25】 0.150~56【1.25】 500V~630V —— 1210 1,500~2,200【1.6】 68~100【1.6】 1.0~680【1.25】 0.150~3.9【1.25】 1000V —— 820~1,200【1.6】 4.7~22【1.6】 1.0~270【1.25】 0.150~2.7【1.25】 2000V —— 300~470【1.6】 3.3~10【1.6】 备注:1、【】对应容量的通用厚度,单位:mm 2、可根据客户的特殊要求设计符合客户需求的产品 Note:1、【】General thickness corresponds to the capacity,unit:mm 2、We can design according to the customer requirements. 100V 1.0~6,800【1.25】 GENERAL MLCC ◆ 容量范围及其电压 Capacitance Range and Operating Voltag 尺寸规格 Size Code 1808 1812 1825 2220 2225 容量范围 Capacitance X7R(nF) 0.220~2,200【1.6】 0.22~220【1.6】 0.220~68【1.6】 0.15~22【1.6】 0.15~10【1.6】 0.15~4.7【1.6】 0.15~2.2【1.6】 —— 0.27~560【1.6】 680~1,000【2】 0.27~220【1.6】 330~560【2】 0.27~100【1.6】 120~220【2】 0.27~47【1.6】 56【2】 工作电压 Rated Voltage 100V 200V~250V 500V~630V 1000V 2000V 3000V 4000V 5000V NPO(pF) 2.0~4,700【1.6】 2.0~3,900【1.6】 2.0~2,700【1.6】 2.0~1,000【1.6】 2.0~470【1.6】 2.0~330【1.6】 2.0~33【1.6】 2.0~33【1.6】 100V 3.0~10,000【1.25】 200V~250V 3.0~6,800【1.25】 500V~630V 3.0~1,000【1.25】 1,200~4,700【1.6】 1000V 3.0~1,200【1.6】 2000V 3.0~1,000【1.6】 0.27~12【1.6】 —— 3000V 3.0~560【1.6】 0.27~4.7【1.6】 —— 4000V 3.0~220【1.6】 0.27~3.3【1.6】 —— 5000V 3.0~68【1.6】 —— —— 100V 3.0~22,000【1.6】 12~2,200【1.6】 150~2,200【1.6】 200V-250V 3.0~8,200【1.6】 12~100【1.6】 120~1,200【2.5】 100~470【1.6】 500V-630V 3.0~5,600【1.6】 1~470【1.6】 —— 1000V 3.0~1,800【1.6】 1~100【1.6】 —— 2000V 3.0~1,000【1.6】 1~22【1.6】 —— 3000V 3.0~680【1.6】 1~10【1.6】 —— 4000V 3.0~470【1.6】 1~6.8【1.6】 —— 5000V 3.0~82【1.6】 —— —— Y5V(nF) 150~1,000【1.25】 10~390【1.25】 —— —— —— —— —— —— 150~2,200【1.6】 100~470【1.6】 —— —— 100V 5.0~27,000【1.6】 22~2,200【1.6】 150~1,500【1.6】 200V~250V 5.0~12,000【1.6】 22~1,200【1.6】 100~1,000【1.6】 500V~630V 5.0~6,800【1.6】 1.5~470【1.6】 —— 1.5~33【1.6】 39~150【2】 1.5~6.8【1.6】 22~47【2】 1000V 5.0~3,900【1.6】 2000V 5.0~1,000【1.6】 3000V 5.0~680【1.6】 1.5~12【2】 —— 4000V 5.0~560【1.6】 1.5~8.2【2】 —— 5000V 5.0~120【1.6】 —— —— 100V 5.0~27,000【1.6】 200V~250V 5.0~12,000【1.6】 500V~630V 5.0~6,800【1.6】 2.2~470【1.6】 —— 1000V 5.0~3,900【1.6】 2.2~100【1.6】 —— 2000V 5.0~1,000【1.6】 2.2~47【1.6】 —— 3000V 5.0~680【1.6】 2.2~15【1.6】 —— 4000V 5.0~560【1.6】 2.2~6.8【1.6】 —— 2.2~1,500【1.6】 2,200【2】 2.2~680【1.6】 1,000~2,200【2】 —— —— 250~3,300【1.6】 220~2,200【1.6】 5000V 5.0~120【1.6】 —— —— 备注:1、【】对应容量的通用厚度,单位:mm 2、可根据客户的特殊要求设计符合客户需求的产品 Note:1、【】General thickness corresponds to the capacity,unit:mm 2、We can design according to the customer requirements. GENERAL MLCC ◆ 中高压电容器介质耐电强度的测试方法: Measurement method of dielectric withstanding voltage for high voltage MLCC 额定电压范围 Rated voltage range 耐电性能的测试方法 Measuring Method 施加额定电压的 200%, 5 秒, 最大电流不超过 50mA Force 200%Rated voltage for 5 second. Max..current should not exceed 50 mA. 施加额定电压的 150%, 5 秒, 最大电流不超过 50mA Force 150%Rated voltage for 5 second. Max..current should not exceed 50 mA. 施加额定电压的 120%, 5 秒, 最大电流不超过 50mA Force 120%Rated voltage for 5 seconds. Max..current should not exceed 50 mA. 施加额定电压的 120%, 5 秒, 最大电流不超过 10mA Force 120%Rated voltage for 5 seconds. Max..current should not exceed 10 mA. 100V≤Vr<500V 500V≤Vr≤1000V 1000V<Vr≤2000V 2000V<Vr≤5000V ◆ 可靠性测试 Reliability Test 项目 Item Ⅰ类 ClassⅠ 技术规格 Technical Specification 标称容量 Capacitance 应符合指定的误差级别 Should be within the specified tolerance. 容量 Capacitance Ⅱ类 ClassⅡ 应符合指定的误差级别 Should be within the specified tolerance. Ⅰ类 ClassⅠ C≤10 nF, Ri≥50000MΩ C>10 nF, Ri•CR≥500S 绝缘电阻(IR) Insulation Resistance 测 试 方 法 Test Method and Remarks ≤1000pF >1000 pF C≤25 nF, Ri≥10000MΩ C>25 nF, Ri•CR>100S Y5V Z5U C≤25 nF, Ri≥4000MΩ C>25 nF, Ri•CR>100S Ⅱ类 ClassⅡ 损耗角正切 (DF, tanδ) Dissipation Factor Ⅰ类 ClassⅠ ≤0.56% 1.5[(150/Cr)+7]×10-4 ≤0.15% ≤0.15% 测试电压 Measuring Voltage 1.0±0.2Vrms 测试温度: 25℃±3℃ Test Temperature: 25℃±3℃ C≤10µF: 测试频率: 1KHz±10% 测试电压: 1.0±0.2Vrms Test Frequency: 1KHz±10% Test Voltage: 1.0±0.2Vrms C>10µF X7R、X5R、X7S、X6S、Y5V: 测试频率: 120±24 Hz 测试电压:0.5±0.1Vrms Test Frequency: 120±24 Hz Test Voltage: 0.5±0.1Vrms Z5U: 测试频率:1±0.1KHz 测试电压:0.5±0.05Vrms Test Frequency: 1±0.1KHz Test Voltage: 0.5±0.05Vrms X7R/X5 R/X7S/X 6S DF 测试频率 Measuring Frequency 1MHz±10% 1KHz±10% 测试电压:额定电压(最高 500V) 测试时间: 60±5 秒 测试湿度:≤75% 测试温度: 25℃±3℃ 测试充放电电流:≤50mA Measuring Voltage: Rated Voltage(Max 500V) Duration: 60±5s Test Humidity: ≤75% Test Temperature: 25℃±3℃ Test Current: ≤50mA 标称容量 Capacitance Cr<5 pF 5pF≤Cr<50 pF 50pF≤Cr≤1000 pF >1000 pF 测试频率 Measuring Frequency 1MHz±10% 1MHz±10% 1MHz±10% 1KHz±10% 测试电压 Measuring Voltage 1.0±0.2Vrms GENERAL MLCC 项目 Item 技术规格 Technical Specification 电压 50V 25V 损耗角正切 (DF, tanδ) Dissipation Factor Ⅱ类 Class Ⅱ 16V 10V ≤6.3 V 介质耐电强度 (DWV) Dielectric Withstanding Voltage DF(×10-4) 0201 测 试 方 法 Test Method and Remarks 0402 0603 0805 1206 及 以上 ≤250 ≤3.3nF ≤10nF ≤100nF ≤330nF ≤680nF ≤350 ≤10nF —— —— —— ≤1μF ≤500 —— —— —— ≤680nF —— ≤1000 —— ≤1μF ≤2.2μF ≤4.7μF ≤10μF ≤250 ≤3.3nF ≤10nF ≤150nF ≤330nF ≤680nF ≤350 ≤10nF ≤100nF ≤330nF —— ≤2.2μF ≤500 —— —— —— ≤1μF —— ≤750 —— —— —— ≤2.2μF ≤4.7μF ≤1000 ≤100nF ≤2.2μF ≤10μF ≤22μF ≤22μF 250 ≤3.3nF ≤10nF ≤150nF ≤330nF ≤680nF ≤350 ≤15nF ≤100nF ≤330nF —— ≤2.2μF ≤500 —— ≤220nF ≤680nF ≤2.2μF —— ≤750 —— —— —— ≤4.7μF ≤4.7μF ≤1000 ≤100nF ≤4.7μF ≤10μF ≤22μF ≤47μF ≤250 ≤3.3nF ≤10nF ≤150nF ≤330nF ≤680nF ≤350 ≤15nF ≤100nF ≤330nF —— ≤2.2μF ≤500 —— —— ≤680nF ≤2.2μF —— ≤750 —— ≤1μF ≤2.2μF ≤4.7μF ≤10μF ≤1000 ≤2.2μF ≤10μF ≤22μF ≤47μF ≤100μF ≤250 ≤3.3nF —— ≤150nF —— ≤680nF ≤350 ≤15nF ≤100nF ≤330nF —— ≤2.2μF ≤500 —— ≤220nF ≤680nF —— ≤750 —— ≤1μF —— —— 10μF~2 2μF ≤1000 ≤4.7μF ≤22μF ≤47μF ≤47μF ≤100μF 不应有介质被击穿或损伤 No breakdown or damage. C≤10µF 测试频率: 1KHz±10% 测试电压: 1.0±0.2Vrms Test Frequency: 1KHz±10% Test Voltage: 1.0±0.2Vrms C>10µF X7R、 X5R、X7S、X6S、Y5V 测试频率: 120±24 Hz 测试电 压:0.5±0.1Vrms Test Frequency: 120±24Hz Test Voltage: 0.5±0.1Vrms Z5U: 测试频率:1±0.1KHz 测试电 压:0.5±0.05Vrms Test Frequency: 1±0.1KHz Test Voltage: 0.5±0.05Vrms ≤10μF 测量电压:Ⅰ类:300%额定电压 Ⅱ类:250%额定电压 时间: 1~5 秒 充/放电电流:不应超过 50mA (这部分说明不包括中高压 MLCC) Measuring Voltage: ClassⅠ:300% Rated voltage ClassⅡ:250% Rated voltage Duration: 1~5s Charge/ Discharge Current: 50mA max. (This method excludes high-voltage MLCC) GENERAL MLCC 项目 Item 技术规格 Technical Specification 可焊性 Solderability 上锡率应大于 95% 外观:无可见损伤. At least 95% of the terminal electrode is covered by new solder. Visual Appearance: No visible damage. 项目 Item 耐焊接热 Resistance to Soldering Heat NPO至SL X7R/X5R/X7S/X Y5V、Z5U NPO to SL 6S ≤±0.5%或±0.5PF, 取较大值 -10~+20 ΔC/C -5~+10% ≤ ± 0.5% or ± % 0.5PF,whichever is larger 同初始标准 DF Same to initial value. 同初始标准 IR Same to initial value. 外观:无可见损伤 上锡率:≥95% Appearance : No visible damage.At least 95% of the terminal electrode is covered by new solder. 测 试 方 法 Test Method and Remarks 将电容在 80~120℃的温度下预热 10~30 秒. Preheating conditions:80 to 120℃; 10~30s. 有铅焊料:(Sn/Pb:63/37) 无铅焊料: 浸锡温度: 235±5℃ 浸锡温度: 245±5℃ 浸锡时间: 2±0.5s 浸锡时间: 2±0.5s Solder Temperature: Solder Temperature: 235±5℃ 245±5℃ Duration: 2±0.5s Duration: 2±0.5s 将电容在 100~200℃的温度下预热 10±2 分钟. 浸锡温度: 265±5℃ 浸锡时间: 10±1s 然后取出溶剂清洗干净,在 10 倍以上的显微镜底下观察. 放置时间:24±2 小时 放置条件:室温 Preheating conditions: 100 to 200℃; 10±2min. Solder Temperature: 265±5℃ Duration: 10±1s Clean the capacitor with solvent and examine it with a 10X(min.) microscope. Recovery Time: 24±2h Recovery condition: Room temperature 试验基板:Al2O3 或 PCB 弯曲深度:1mm 施压速度:1mm/sec. 单位:mm 应在弯曲状态下进行测量。 抗弯曲强度 Resistance to Flexure of Substrate (Bending Strength) 外观:无可见损伤. Appearance: No visible damage. ΔC/C 端头结合强度 Termination Adhesion ≤±10% 外观无可见损伤 No visible damage. 施加的力:5N Applied Force: 5N 项目 Item 预处理※(2 类):上限类别温度,1 小时 恢复:24±1h Preheating conditions: up-category temperature, 1h Recovery time: 24±1h 初始测量 Initial Measurement 循环次数:5 次,一个循环分以下 4 步: Cycling Times: 5 times, 1 cycle, 4 steps: ΔC/C 温度循环 Temperature Cycle Test Board: Al2O3 or PCB Warp: 1mm Speed: 1mm/sec. Unit: mm The measurement should be made with the board in the bending position. C0G ≤±1%或±1PF,取 较大值 ≤±1% or ±1pF , whichever is larger X7R/X7S/ X6S/X5R -10% ~ +10% Y5V/Z5U -20% ~ +20% 阶段 Step 1 2 3 4 时间:10±1S Duration: 10±1S 温度(Temperature)(℃) 时间(Time) 下限温度(Low- category temp.): (NPO/X7R/X7S/X6S/X5R:-55 Y5V:-25 Z5U:+10) 30min 常温(Normal temp.) : +20℃ 2~3min 上限温度(Up- category temp.) (NPO/X7R/X7S: +125 Y5V/Z5U/X5R:+85 X6S:+105) 30min 常温(Normal temp.) : +20℃ 2~3min 试验后放置(恢复)时间:24±2h Recovery time after test: 24±2h GENERAL MLCC 项目 Item 技术规格 Technical Specification 测 试 方 法 Test Method and Remarks Ⅰ类: ±7.5%或±0.75pF,取两者之中较大者 Ⅱ类: B,X,BS,DS: ≤±12.5% E,F: ≤±30% ClassⅠ: ±7.5% or ±0.75pF, whichever is larger. ClassⅡ: B,X,BS,DS: ≤±12.5% E,F: ≤±30% ≤2 倍初始标准 Not more than twice of initial value. ΔC/C DF ClassⅠ 耐湿负荷 Humidity load IR Clas s Ⅱ X7R/ X7S/ X6S/ X5R Y5V/ Z5U Ri≥5000MΩ或 Ri•CR≥50S 取两者之中较 小者. Ri≥5000MΩ或 Ri•CR≥50S whichever is smaller. Ri≥1000MΩ或 Ri•CR≥10S 取两者之中较 小者. Ri≥1000MΩ或 Ri•CR≥10S whichever is smaller. Ri≥400MΩ或 Ri•CR≥10S 取两者之中较 小者. Ri≥400MΩ或 Ri•CR≥10S whichever is smaller. 温度:40±2℃ 湿度:90~95%RH 电压:额定电压 时间:500 小时 放置条件:室温 放置时间:24 小时(Ⅰ类);48 小时(Ⅱ类) Temperature: 40±2℃ Humidity: 90~95%RH Voltage: Rated Voltage Duration: 500h Recovery conditions: Room temperature Recovery Time: 24h (Class1) or 48h (Class2) 外观:无损伤 Appearance: No visible damage. ΔC /C C0G ±2%或±1pF,取两者之中较大者 ±2% or ±1pF, whichever is larger. X7R -20% ~ +20% Y5V -30% ~ +30% DF ≤2 倍初始标准 Not more than twice of initial value. C0G Ri≥4000MΩ或 Ri•CR≥40S 取两者之中较小 者 Ri≥4000MΩ或 Ri•CR≥40S whichever is smaller. IR Ri≥2000MΩ或 Ri•CR≥50S 取两者之中较小 寿命试验 Life Test X7R 者. Ri≥2000MΩ或 Ri•CR≥50S whichever is smaller. 外观:无损伤 Appearance: No visible damage. 低压产品(<100V) 电压:2 倍额定工作电压,除了表 1 外 时间:1000 小时 温度:125℃(NPO、X7R、X7S) 85℃(X5R、Y5V)105℃(X6S) 充电电流:不应超过 50mA 放置条件:室温 放置时间:24 小时(Ⅰ类),或 48 小时(Ⅱ类), Low-Voltage(<100V) Applied Voltage: 2*Ur,except the table 1 Duration: 1000h Temperature:125℃(NPO、X7R、X7S) 85℃(X5R、 Y5V)105℃(X6S) Charge/ Discharge Current: 50mA max. Recovery Conditions: Room Temperature Recovery Time: 24h (Class 1), or 48h (Class2) 表 1(table 1) 容量 0402≥330nF 0603≥470nF ΔC/C 中高压产品 寿命试验 Middle &high voltage Life Test DF IR Ⅰ类:≤±2%或±1pF 取两者之中较大者 Ⅱ类:B,X,BS,DS: ≤±20% E,F: ≤±30% ClassⅠ:≤±2% or ±1pF, whichever is larger. ClassⅡ: B,X,BS,DS: ≤±20% E,F: ≤±30% ≤2 倍初始标准 Not more than twice of initial value. Ⅰ类:Ri≥4000MΩ或 Ri•CR≥40S 取两者之中较 小者. ClassⅠ: Ri≥4000MΩ或 Ri•CR≥40S whichever is smaller. Ⅱ类:Ri≥2000MΩ或 Ri•CR≥50S 取两者之中较 小者. ClassⅡ: Ri≥2000MΩ或 Ri•CR≥50S whichever is smaller. 外观:无损伤 Visual Appearance: No visible damage. 试验电压 0201≥47nF 容量 试验电压 0805≥1uF 1.5Ur 1206≥10uF 1.5Ur 1210≥10uF 中高压产品: 100V≤额定电压≤200V:1.5 倍工作电压 200V<额定电压≤500V:1.3 倍工作电压 500V<额定电压: 1.2 倍工作电压 时间:1000 小时 充电电流:不应超过 50mA 温度:125℃(NPO X7R、X7S);85℃(X5R、Y5V)105℃(X6S) 放置条件:室温 放置时间:24 小时(Ⅰ类),或 48小时(Ⅱ类), Applied Voltage: 100V≤Rated Voltage≤200V:1.5 Multiple 200V<Rated Voltage≤500V: 1.3 Multiple 500V<Rated Voltage: 1.2 Multiple Duration: 1000h Charge/ Discharge Current: 50mA max. Temperature:125℃(NPO X7R、X7S);85℃(X5R、 Y5V)105℃(X6S) Recovery Conditions: Room Temperature Recovery Time: 24h (Class 1), or 48h (Class2) GENERAL MLCC ◆包装 Package * 塑料压纹带卷盘结构 Embossed Plastic Taping Top cover tape 面胶 Carrier tape(paper)传送带 Chip hole(Pocket)芯片孔 Polystyrene reel 胶盘 * 仅适用于 1005 规格,压纹带尺寸如下: The emboss plastic applies only to 1005 type,the dimensions as follows: D0 P0 E W F B0 K0 P1 A0 Unit:mm W P0 P1 E F D0 A0 B0 K0 4±0.05 2±0.04 1±0.02 0.9±0.05 1.8±0.02 0.8±0.04 0.24±0.02 0.45±0.02 0.24±0.02 * 纸带卷盘结构 Paper Taping Top cover tape 面胶 Carrier tape(paper)传送带 Chip hole(Pocket) 芯片孔 Polystyrene reel 胶盘 Bottom tape 底胶 GENERAL MLCC * 1005、0201、0402 纸带编带尺寸大小 Dimensions of paper taping for 1005、0201、0402 type 代号 Code 1005 0201 0402 W1 L1 D C B P1 P2 P0 d t 0.24±0.0 2 0.37 0.10 0.65 0.10 0.45±0. 02 0.670. 10 1.15 0.10 8.00 0.10 8.00 0.10 8.00 0.10 3.50 0.05 3.50 0.05 3.50 0.05 1.75 0.10 1.75 0.10 1.75 0.10 2.00 0.05 2.00 0.05 2.00 0.05 2.00 0.05 2.00 0.05 2.00 0.05 4.000 .10 4.000 .10 4.000 .10 1.50 -0/+0.10 1.50 -0/+0.10 1.50 -0/+0.10 0.30 Below 0.80 Below 0.80 Below * 适合‘0603,0805,1206’常规尺寸产品的纸带尺寸 Dimensions of paper taping for 0603,0805,1206 types. Unit:mm 代号Code 纸带规格 paper size A B C D* 1.10 1.90 8.00 3.50  0.10  0.10  0.10  0.05 1.45 2.30 8.0 3.50 0805  0.15  0.15  0.15  0.05 1.80 3.40 8.00 3.50 1206  0.20  0.20  0.20  0.05 注意:*表示此处对尺寸的要求非常精确。 Note: The place with “*” means where needs exactly dimensions. 0603 E F G* H J T 1.75  0.10 1.75  0.10 1.75  0.10 4.00  0.10 4.00  0.10 4.00  0.10 2.00  0.10 2.00  0.10 2.00  0.10 4.00  0.10 4.00  0.10 4.00  0.10 1.50 -0/+0.10 1.50 -0/+0.10 1.50 -0/+0.10 1.10 Max 1.10 Max 1.10 Max GENERAL MLCC * 塑胶卷盘结构 Embossed taping Top cover tape 面胶 Carrier tape(paper)传送带 Chip hole(Pocket)芯片孔 Polystyrene reel 胶盘 * 塑胶带尺寸结构(适合‘0805~1812’型产品) Dimensions of embossed taping for 0805~1812 type 代号 Code 规格 Tape size 0805 1206 1210 1808 1812 2220/2225 A B C D* E F G* H J T 1.55  0.20 1.95  0.20 2.70  0.10 2.20  0.10 3.66  0.10 6.2 ±0.1 2.35  0.20 3.60  0.20 3.42  0.10 4.95  0.10 4.95  0.10 6.7 ±0.1 8.00  0.20 8.00  0.20 8.00  0.10 12.00  0.10 12.00  0.10 12.00  0.10 3.50  0.05 3.50  0.05 3.50  0.05 5.50  0.05 5.50  0.05 5.50  0.05 1.75  0.10 1.75  0.10 1.75  0.10 1.75  0.10 1.75  0.10 1.75  0.10 4.00  0.10 4.00  0.10 4.00  0.10 4.00  0.10 8.00  0.10 8.00  0.10 2.00  0.10 2.00  0.10 2.00  0.05 2.00  0.05 2.00  0.05 2.00  0.05 4.00  0.10 4.00  0.1 4.00  0.10 4.00  0.10 4.00  0.10 4.00  0.10 1.50 -0/+0.10 1.50 -0/+0.10 1.55 -0/+0.10 1.50 -0/+0.10 1.55 -0/+0.10 1.55 -0/+0.10 1.50 Max 1.85 Max 3.2 Max 3.0 Max 4.0 Max 2.4  0.10 备注:*表示此处对尺寸的要求非常精确。 Note:The place with “*” means where needs exactly dimensions. GENERAL MLCC * 传送带的前后结构 Structure of leader part and end part of the carrier paper 尾部(空带) End (Vacant position) 芯片传送 Chip carrier 大于 150 mm over 150mm 空带 Vacant position 大于 150 mm over 150mm 带头(面胶面) Leader part(cover) tape) 大于 150 mm /Over 150 mm 传送方向/ Moving Direction * 卷盘尺寸 Reel dimensions (unit: mm) 卷盘型号 A B C D 7′REEL φ178±2.0 3.0 φ13±0.5 φ21±0.8 13′REEL φ330±2.0 3.0 φ13±0.5 φ21±0.8 E φ50 或更大 φ50 or more φ50 或更大 φ50 or more F G 10.0±1.5 12max 10.0±1.5 12max * 关于卷带的说明:面胶剥离强度 Taping specification:top tape peeling strength * 纸带 Paper Tapin Cover tape peeling direction 面胶剥离方向 Cover tape 面胶 0~15° Carrier tape 传 送 带 GENERAL MLCC * 塑料胶盘 Embossed Taping Cover tape peeling direction 面胶剥离方向 Cover tape 面胶 0~15° Carrier tape 传送带 标准:0.1N
0402X474K160NT 价格&库存
很抱歉,暂时无法提供与“0402X474K160NT”相匹配的价格&库存,您可以联系我们找货
0402X474K160NT
    • 10000+0.01120
    库存:1240000
    0402X474K160NT
      • 1+0.13210
      • 100+0.07630
      • 1000+0.05010
      • 5000+0.03440
      • 10000+0.02560
      库存:207550
      0402X474K160NT
        • 100+0.02422
        • 1000+0.01900
        • 3000+0.01625
        • 10000+0.01498
        库存:22498
        0402X474K160NT
          • 1+0.08250
          库存:10250
