4399
4399
    ADAFRUIT
    杜邦线 50.00mm
4399 数据手册
A C B P1 1 D E P2 50±5 4 YELLOW 3 Blue 2 Red 1 Black 1 4 YELLOW 3 Blue 2 Red 1 Black 2 3 2 3 1 2 2 Note: 1x per barcode bag P4399A (1pcs装袋贴条码) Wire Diagram Bill Of Material 3 CONN P1 CONN P2 COLOR 3 KWQS230 TER. PH1.0 Phosphor Bronze, Tin Plating PCS 8 1 1 Black 2 KWQS230 CONN. 1.0 mm SH Housing 4P Black PCS 2 2 Red KWQS221 Wire NAME UL1571 28AWG(7/0.127TS) WIRE OD:0.8mm 2 1 No. 3 3 Blue 4 4 Yellow Vendor mm Material Name and Name Unit DRAWN(製圖): DESCRIPTION(內容): Qty GENERAL TOLERANCE LINEAR 1.0PITCH HOUSING WIRE HARNESS CHECKED(確認): Jack Wu A4 PART NO: (料 號) SCALE(比例 ): 1:XX THIRD ANGLE PROJECTION A DWG NO(圖號): CBH-100-04-050-A KWRD191015-006 B X.: ±0.30 X.X: ±0.20 APPROVAL(核准): Kane He C ANGLES REV DESCRIPTION DATE ORIGINAL Oct-15-2019 UNIT: 1 ±3.0° IN INCHES 2 X°: ±5.0° X.X°: REV: A/1 X.XX: ±0.15 X.XX°: ±2.0° SHEET: 3 X.XXX: ±0.10 X.XXX°: ±1.0° 1/2 4 D 3 E FILE NO: KW-4E-09
很抱歉,暂时无法提供与“4399”相匹配的价格&库存,您可以联系我们找货
