(MLV)
MULTILAYER CHIP VARISTOR
MLV
0.1J
174
10-6
30V, 0.1J
10-3
Current(A)
30V, 0.1J
10+0
48V, 0.1J
10+3
48V, >0.1J
MLV
INTRODUCTION FO FPV SERIES MULTILAYER
VB VS. TEMPERATURE
Voltag as Percent of
Average Breakdown Vdtage
Temperature Dependence of Voltage
100
90
80
70
60
50
40
30
10-9
10-7
10-8
10 -5
10 -6
10 -4
10 -3
10 -2
Current(A)
-40
25
85
125
ENERGY AND CAPACITANCE VS. TEMPERATURE
PERCENT OF RATED CALUE
TYPICAL CAPACITANCE VS TEMPERATURE
+25
100
+20
60
40
+10
+5
Av
-5
-10
-15
-55
50
60
70
80
-25
90 100 110 120 130 140 150
AMBIENT TEMPERATURE(
ag
e
25
-20
er
Reference
Capacitance Relative to 25
80
-40
-20
60
Temperature (
80
100
120
140
RELIABILITY TEST DATA
Heat resistance
(High-Temperature load)
Test Sample:FPV100505G3R3
Low Temperature Resistance
Test Sample:FPV160808G5R5
10
10
voltage(V)
10
voltage(V)
10 2
1
High Temperature life test:
10 -1
10
-2
10
-3
Vdc max applied at 85
hour
1000 hours
1
10
-5
10
-4
10
-3
10
-2
10
-1
1
10 10
2
10
-1
test at -40
10 -2
10
-6
10 10
2
hour
500 hours
-3
-6
10 10
3
-5
10
5
4
3
2
1
-2
-3
-4
-5
voltage(V)
10
1
10
-2
10
-3
Temal Shock Test
10+85 at 30 minute
-40
0 cycle
100 cycles
-6
10 10
-5
10
-4
10
-3
10
-2
10
-1
10
-2
10
-1
1
10 10
2
10
3
FPV20109G5R6, FPV321611G5R6
Test Sample:FPV100505G5R6,FOV160808G5R6
2
-1
-3
Resistamce to Solder Heat
Thermal Shock
(Temperature cycle)
10
10
Current(mA)
Current(mA)
10
-4
1
10 10
2
10
3
Resustance to solder heat Test
260 10 ,10sec
1005
Current(mA)
1608
2012
Chip Size
175
3216
MULTILAYER CHIP VARISTOR ARRAY
CVA
3216 - 4
(L
Product Code
3R3
G
W
P
M
T
T)
(mm)
Configuration
Product Series
2
S
Working DC
Voltage
Termination
Tolerance
Dimensions
3216
CVA Multilayer
Chip Varistor
Array
2010
3.2
2.0
1.6
1.0
0.9
0.5
4
2 Array
4Array
High
speed type
3R3
3.3V
P
180
18V
S
Plated
Non-plated
G General
type
K
10%
L
15%
M
20%
Packaging
Style
T
B
Tape
& Reel
Bulk
SHAPE AND DIMENSIONS & EQUIVALENT CIRCUIT
unit mm(inch)
Part No.
L
W
T
E1
E2
D
2010
2.0 0.15
1.0 0.15
0.5 0.1
0.20+0.15/-0.1
2.0 0.15
2.0 0.15
(0804)
(0.079 0.008)
(0.039 0.006)
(0.035 0.008)
(0.010+0.006/-0.004)
(0.079 0.006)
(0.079 0.006)
3216
3.2 0.2
1.6 0.2
0.9 0.1
0.35 0.2
0.3 0.2
0.8 0.1
(1206)
(0.126 0.008)
(0.063 0.008)
(0.035 0.008)
(0.014 0.008)
(0.012 0.008)
(0.031 0.004)
176
MLV
Multilayer Chip Varistor Array Electrical Characteristics Per Element
Reduced component placement costs.
PCB
Downsize PCB.
Use in multiple lines for transient voltage suppression.
Working voltage
PART Number
Varistor
voltage
@1mA DC
Maximum
Clamping
Voltage
8/20 s 1A
Energy
Absorb
10/1000 s
Peak
Current
8/20 s
Typical
Capacitance
@1MHz
DC
AC
Volts
Volts
VB
VB
Volts
Joules
Amps
pF
5.6
4
8
20%
19
0.1
30
225
CVA2010-2G9R0 L
9
6.4
12
15%
30
0.1
30
150
CVA2010-2G140 L
14
10
18
15%
35
0.1
30
125
CVA2010-2G180 L
18
12.7
24
15%
44
0.1
30
125
60
0.05
很抱歉,暂时无法提供与“FPV160808G260PKT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.11810
- 100+0.08840
- 1000+0.06850
- 4000+0.04970
- 8000+0.04710
- 40000+0.04370
- 国内价格
- 50+0.06800
- 500+0.06400
- 2000+0.05600
- 5000+0.05200
- 15000+0.04800
- 30000+0.04600
- 国内价格
- 50+0.09548
- 500+0.07398
- 1500+0.06210
- 4000+0.05336
- 24000+0.04709
- 48000+0.04374
