FTMP0402HP-6R8MG-Z02
    TAI-TECH(台庆)
    IND_3.95X4.06MM_SM
    功率电感 6.8μH ±20% IND_3.95X4.06MM_SM 1.80mm 3.95 x 4.06mm 150mΩ 1.8A
FTMP0402HP-6R8MG-Z02 数据手册
Form No: Specification for Approval 3/09/01 s P FTMP0402HP-6R8MG-Z02 CUSTOMER P/N: DESCRIPTION: 10 p s REMARK: Customer Approval Feedback ■ 深圳市富麗磁元電子有限公司 Sales Dept. . SHENZHEN FERRITE CORES ELECTRONICS CO., LTD. 地址:深圳市福田區民田路 91 號華融大廈 22 樓 2209 室 Tel: (86 755) 8366 1328 Fax: (86 755) 8366 1689 □ 台慶精密電子(香港)有限公司 TAI-TECH ADVANCED ELECTRONICS (H.K.)CO.,LTD. 香港九龍旺角亞皆老街 80-86 號昌明大廈 7 字樓 I 室 Flat1,7/Floor,Cheong Ming Building, 80-86 Argyle Street, Mongkok, Kowloon, Hong Kong. Tel:(852) 2398 1368 Fax:(852) 2332 0675 http://www.taitech.com.hk E-mail: ferrite@taitech.com.hk □ 西北臺慶科技股份有限公司 TAI-TECH ADVANCED ELECTRONICS CO., LTD APPROVED CHECKED 譚勝 o on 梁雁婷 Joanna R&D Center APPROVED □ 慶邦電子元器件(泗洪)有限公司 TAIPAQ ADVANCED ELECTRONICS(SH) CO., LTD . □ 臺慶精密電子(昆山)有限公司 TAI-TECH ADVANCED ELECTRONICS (KUNSHAN) CO., LTD . ■ 注:此產品屬於工業級標準品,非車規產品!不能使用於 汽車前裝配件中,若客戶未明確告知而私自使用到汽車配 件中,產生任何後果,我司不予負責售後服務。 Peter Tzou CHECKED DRAWN 羅宜春 李 芳 YIchun Ro Fang Li TAI-TECH P2 SMD Power Inductor  FTMP0402HP-6R8MG-Z02 1. Features 1. Magnetic metal powder inductor. 2. Compact design. Halogen 3. High current,low DCR,high efficiency. 4. Very low acoustic noise and very low leakage flux noise. Halogen-free 5. High reliability. 6. 100% Lead(Pb)-Free and RoHS compliant. 7. Operating temperature -40~+125℃(Including self - temperature rise) 2. Applications Note PC power system,incl. IMVP-6 DC/DC converter . 3. Dimensions Recommend PC Board Pattern  C D H L  6R8 E B A A` G Series A(mm) A`(mm) FTMP0402HP 4.45±0.25 3.95±0.20 B(mm) C(mm) D(mm) 4. Part Numbering FTMP 0402 HP A B C A: Series B: Dimension C: Type D: Inductance E: Inductance Tolerance F: Control S/N - E(mm) 4.06±0.25 1.8±0.2 0.76±0.30 2.0±0.20 6R8 MG D E - Z02 F BxC H: Magnetic metal powder, P:PAD broaden. 6R8=6.8uH M=±20% One-way Black marking L(mm) G(mm) H(mm) 5.2 2.2 2.4 Note: 1. The above PCB layout reference only. 2. Recommend solder paste thickness at 0.12mm and above. TAI-TECH P3 5. Specification Part Number Inductance L0 (uH)±20% FTMP0402HP-6R8MG-Z02 6.80 I rms ( A ) I sat ( A ) Typ Max Typ Max DCR(mΩ) Typ.@25℃ 2.10 1.80 2.80 2.50 150 DCR(mΩ) Max.@25℃ 172   Note: 1. Test frequency : L : 100KHz /1.0V; 2. All test data referenced to 25℃ ambient. 3. Testing Instrument : L: HP4284A,CH11025,CH3302,CH1320 ,CH1320S LCR METER / Rdc:CH16502,Agilent33420A MICRO OHMMETER. 4. Heat Rated Current (Irms) will cause the coil temperature rise approximately Δt of 40℃. 5. Saturation Current (Isat) will cause L0 to drop approximately 30%; 6. The part temperature (ambient + temp rise) should not exceed 125℃under worst case operating conditions.Circuit design,component,PCB trace size and thickness,airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application. 7. Special inquiries besides the above common used types can be met on your requirement. TAI-TECH P4 6. Material List 4  5  3  NO Items Materials 1 Core Carbonyl Powder. 2 Wire Polyester Wire or equivalent. 3 Clip 100% Pb free solder(Ni+Sn---Plating) 4 paint Epoxy resin 5 Ink Halogen-free ketone 1  2  7. Reliability and Test Condition Item Performance Operating temperature -40~+125℃ (Including self - temperature rise) Storage temperature 1. -10~+40℃,50~60%RH (Product with taping) 2. -40~+125℃(on board) Test Condition Electrical Performance Test Inductance Refer to standard electrical characteristics list. DCR HP4284A,CH11025,CH3302,CH1320,CH1320S LCR Meter. CH16502,Agilent33420A Micro-Ohm Meter. Saturation Current (Isat) Approximately △L30%. Saturation DC Current (Isat) will cause L0 to drop △L(%) Heat Rated Current (Irms) Approximately △T40℃ Heat Rated Current (Irms) will cause the coil temperature rise △T(℃). 1.Applied the allowed DC current 2.Temperature measured by digital surface thermometer Reliability Test Preconditioning: Run through IR reflow for 2 times.( IPC/JEDECJ-STD-020DClassification Reflow Profiles) Temperature: 125±2℃(Inductor) Applied current:rated current Duration:1000±12hrs Measured at room temperature after placing for 24±2 hrs. Life Test Preconditioning: Run through IR reflow for 2 times.( IPC/JEDECJ-STD-020DClassification Reflow Profiles) Humidity:85±2﹪R.H, Temperature:85℃±2℃ Duration:1000hrs Min. with 100% rated current Measured at room temperature after placing for 24±2 hrs. Load Humidity Moisture Resistance Thermal shock Vibration Appearance:No damage. Impedance:within±15% of initial value Inductance:within±10% of initial value Q:Shall not exceed the specification value. RDC:within ±15% of initial value and shall not exceed the specification value Preconditioning: Run through IR reflow for 2 times.( IPC/JEDECJ-STD-020DClassification Reflow Profiles) 1. Baked at50℃ for 25hrs, measured at room temperature after placing for 4 hrs. 2. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and keep 3 hours, cool down to 25℃ in 2.5hrs. 3. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and keep 3 hours, cool down to 25℃ in 2.5hrs,keep at 25℃ for 2 hrs then keep at -10℃ for 3 hrs 4. Keep at 25℃ 80-100%RH for 15min and vibrate at the frequency of 10 to 55 Hz to 10 Hz, measure at room temperature after placing for 1~2 hrs. Preconditioning: Run through IR reflow for 2 times.( IPC/JEDECJ-STD-020DClassification Reflow Profiles) Condition for 1 cycle Step1:-40±2℃ 30±5min Step2:25±2℃ ≦0.5min Step3:125±2℃ 30±5minNumber of cycles: 500 Measured at room fempraturc after placing for 24±2 hrs. Preconditioning: Run through IR reflow for 2 times.( IPC/JEDECJ-STD-020DClassification Reflow Profiles) Oscillation Frequency: 10~2K~10Hz for 20 minutes Equipment: Vibration checker Total Amplitude:1.52mm±10% Testing Time : 12 hours(20 minutes, 12 cycles each of 3 orientations)。 TAI-TECH Item P5 Performance Bending Shock Solder ability Appearance:No damage. Impedance:within±15% of initial value Inductance:within±10% of initial value Q:Shall not exceed the specification value. RDC:within ±15% of initial value and shall not exceed the specification value More than 95% of the terminal electrode should be covered with solder。 Test Condition Shall be mounted on a FR4 substrate of the following dimensions: >=0805 inch(2012mm):40x100x1.2mm =0805 inch(2012mm):1.2mm 0805:1kg ,
FTMP0402HP-6R8MG-Z02 价格&库存
很抱歉,暂时无法提供与“FTMP0402HP-6R8MG-Z02”相匹配的价格&库存,您可以联系我们找货
