Automotive
Commom Mode Choke CUW Series
AEC-Q200
RoHS Compliant
Halogen Free
REACH Compliant
■ Part Numbering
CUW
Series Name
43
Dimensions Code
(mm)
43
4.5x3.2x2.6
T
Category
T
M
513
Inductance
(uH)
513
51
104
100
T
Tolerance
T
AU
Internal Code
±30%
www.chilisin.com.tw
Automotive
AEC-Q200
CUW43T - AU Type
■ Dimensions
■ Recommended Land Pattern
unit:mm
unit:mm
■ Electrical Characteristics
Part No.
CUW43T-113□-AU
CUW43T-223□-AU
CUW43T-513□-AU
CUW43T-104□-AU
Test
Rated Withstamd Insulation
Impedance
Inductance Test Freq.
Freq.
RDC
Irms
Voltage
Voltage Resistance
(uH)
(Ω)Min. (Ω)Typ. (MHz) (Ω)Max. (mA)Max.(Vdc)Max.
(MΩ)Min.
(Vdc)
11
22
51
100
100kHz,0.1V 300
100kHz,0.1V 500
100kHz,0.1V 1000
100kHz,0.1V 2000
Tol.
600
1200
10
10
0.6
1
250
200
50
50
125
125
10
10
30
30
2800
5800
10
10
1
2
200
150
50
50
125
125
10
10
30
30
Note: When ordering, please specify tolerance code. Tolerance: T=±30%
1. Operating temperature range -40℃~125℃(Including self - temperature rise)
2. RDC: SINGLE WIRE TEST VALUE
3. Irms for 40℃ rise above 25℃ ambient.
4. Measure Equipment:
Z: HP4286A / HP4287A / AgilentE4991A
L: HP4284A+HP42841A/HP4285A+HP42841A
RDC: CHROMA MILLIOM METER MODE 16502
Irms: HP4284A+HP42841A/HP4285A+HP42841A
Insulation Resistance: HP4339B
"Please be sure to request approval specifications that provide further details of the products. Kindly note that the
content of these specifications are subject to change or may be discontinued without advance notice.Please
contact our sales department before ordering."
www.chilisin.com.tw
Automotive
AEC-Q200
CUW43T - AU Type
■ Characteristics Graph
Typical Impedance vs. Frequency Charateristics
100000
COMMON MODE
10000
104
513
IMPEDANCE(Ω)
1000
223
113
100
104
10
223
513
113
1
NORMAL MODE
0.1
1
10
100
1000
Frequency(MHz)
www.chilisin.com.tw
Automotive
AEC-Q200
CUW43M - AU Type
■ Dimensions
unit:mm
unit:mm
Part No.
CUW43M-113□-AU
CUW43M-223□-AU
CUW43M-513□-AU
CUW43M-104□-AU
Rated
Resistanc Tolerance
Irms
Voltage
Voltage
(mA)Max. (Vdc)Max.
(MΩ)Min.
(Vdc)
Inductance
(uH)
Test Freq.
RDC
(Ω)Max.
11
22
100kHz,100mV
100kHz,100mV
0.5
0.6
360
310
50
50
125
125
10
10
30
30
51
100
1MHz,200mV
1MHz,200mV
1
2
230
200
50
50
125
125
10
10
30
30
www.chilisin.com.tw
Automotive
AEC-Q200
CUW43M - AU Type
100000
COMMON MODE
10000
104
IMPEDANCE(Ω)
1000
513
223
113
100
10
104
513
223
113
1
NORMAL MODE
0.1
1
10
Frequency(MHz)
100
1000
www.chilisin.com.tw
Automotive
AEC-Q200
■ Packaging
Tape Dimensions
Reel Dimensions
Dimensions in mm
TYPE
CUW43
A0
3.6
B0
4.9
K0
2.7
D
1.5
Tape Dimensions
E
F
W
1.75
5.5
12
P
8
P0
4
P2
2
A
330
Reel Dimensions
B
C
D
100
13
13.4
Quantity
PCS / REEL
2500
www.chilisin.com.tw
很抱歉,暂时无法提供与“CUW43T-513T-AU”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.06442
- 50+1.68880
- 150+1.52788
- 500+1.32700
- 2500+1.11910
