BG125-05-A-1-1-0440-N-D
    GCT
    SMD,P=2.54mm
    排母 间距:2.54mm 1x5P 立贴
BG125-05-A-1-1-0440-N-D 数据手册
Dimensions 1.02 Ø 2.54 G B±0.38 R2 Type 5.08 2.54 Pin 1 Ø Pin 1 Insulator Height = 5.0mm: Pin Size = 0.75mm x 0.25mm Insulator Height = 7.5mm: Pin Size = 0.60mm x 0.25mm Insulator Height = 5.0mm: Min. Insertion Depth = 1.55mm Insulator Height = 7.5mm: Min. Insertion Depth = 2.16mm 2.19 C+1.0 1.02 Recommended PCB Layouts Top Entry General Tolerance ±0.05 Solder Area C A Environmental & Mechanical Operating Temperature: -40° to +105°C Soldering Process: Nylon 6T (Standard) IR Reflow: 260°C for 10 sec. Wave: 230°C for 5-10 sec. Manual Solder: 350°C for 3-5 sec LCP (Option) IR Reflow: 260°C for 10 sec. Wave: 250°C for 5-10 sec. Manual Solder: 350°C for 3-5 sec 1 2 X XXXX X X No. of Contacts 02 to 40 Contact Plating A = Gold Flash All Over (Standard) B = Selective Gold Flash Contact Area/ Tin On Tail C = Tin All Over G = 10µ" Gold Contact Area/Tin On Tail I = 30µ" Gold Contact Area/Tin On Tail Electrical Current Rating: 3 Amp Per Pin Insulator Resistance: 1000 MΩ min. Contact Resistance: 20 mΩ max. Dielectric Withstanding: AC 600 V B X Height H 1 = 5.00mm (Standard) 2 = 7.50mm Mates with(subject to pin length) BG020 BG030 BG031 BG055 BG060 BG075 BG035 BG080 For bottom entry applications, stringent soldering control & pin alignment are required as lead to pad misalignment could cause incorrect mating. 3 4 Type 1 = R1 Type 2 = R2 Type 20.32 9 20.32 23.36 22.86 10 22.86 25.90 25.40 11 25.40 28.44 27.94 12 27.94 30.98 30.48 13 30.48 33.52 33.02 14 33.02 36.06 35.56 15 35.56 38.60 38.10 16 38.10 41.14 40.64 17 40.64 43.68 43.18 18 43.18 46.22 45.72 19 45.72 48.76 48.26 20 48.26 51.30 50.80 21 50.80 53.84 53.34 22 53.34 56.38 55.88 23 55.88 58.92 58.42 24 58.42 61.46 60.96 25 60.96 64.00 63.50 26 63.50 66.54 66.04 27 66.04 69.08 68.58 Packing Options C = Tape and Reel with Film (Standard) A = Tape and Reel B = Tape and Reel with Cap D = Tube E = Tube with Cap F = Tube with Film 28 68.58 71.62 71.12 29 71.12 74.16 73.66 30 73.66 76.70 76.20 Insulator Material N = Nylon 6T (Standard) L = LCP X Request Samples and Quotation Product Description BG125 2.54mm Pitch Socket Single Row, Surface Mount, Vertical, Dual Entry By Detail Revision Date 5 CC Tolerances (Except as Noted) BG125 H PCN H3 13/10/19 X. ± 0.30 X.° ± 5° X.X° ± 3° X.X ± 0.20 X.XX ± 0.15 X.XX° ± 2° X.XXX ± 0.10 X.XXX° ± 1° Length 10.16 12.70 17.78 Part Number 30th October 2006 10.66 13.20 20.82 Dimension C (Footprint Width) (1/100mm) 0440 = 4.40mm (Standard when 'H' = 5.00mm) 0420 = 4.20mm (Standard when 'H' = 7.50mm) Drawing Date 7.62 10.16 17.78 Ordering Grid XX 4 5 8 Solder Area BG125 5.08 7.62 15.24 C Material Contact: Phosphor Bronze Insulator Material: Standard: Polyamide, Nylon 6T, UL 94V-0 Options: Polymer, LCP, UL 94V-0 5.58 8.12 18.28 0.15 Specifications 2.54 5.08 15.74 2.54 D 2 3 15.24 1.02 Recommended PCB Layouts B (H=7.5) 12.70 Pin 1 Bottom Entry General Tolerance ±0.05 B (H=5.0) 6 H E (Minimum Insertion Depth) B±0.38 5.08 A 7 Pin 1 2.54 2 1.0 F 2.54 1.02 C+1.0 A±0.25 5.08 Pin 1 Pin 1 Number of Contacts 2.7 5.09 C+1.0 A±0.25 2.54 C+1.0 2.54 2.7 R1 Type 2.19 1. 02 H Angle 6 Units: Metric (mm) C 3rd Angle Projection 7 31 76.20 79.24 78.74 32 78.74 81.78 81.28 33 81.28 84.32 83.82 34 83.82 86.86 86.36 35 86.36 89.40 88.90 36 88.90 91.94 91.44 37 91.44 94.48 93.98 38 93.98 97.02 96.52 39 96.52 99.56 99.06 40 99.06 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE 102.10 101.60 www.gct.co Not to Scale Drawn By AJO 8 Sheet No. 1/1
BG125-05-A-1-1-0440-N-D 价格&库存
很抱歉,暂时无法提供与“BG125-05-A-1-1-0440-N-D”相匹配的价格&库存,您可以联系我们找货
    • 1+6.00480
    • 10+4.80600
    • 30+4.20120
    • 100+3.61800
    库存:131
