FS-1540
FS-1540
    FUSHENG(福声电子)
    MIC_15X15MM_SM
    扬声器 15.00 x 15.00mm 4Pins -40℃~+85℃
FS-1540 数据手册
SPECIFICATION FOR APPROVAL 規 格 書 Customer ( 客 戶 名 稱 ): Customer P/N(客戶番號): Our P/N (本廠番號): FS-1540 Approval Date(日期) : 2019.12.26 Environment Request(環 境 標 准): □ Non-RoHS (非 RoHS 標準) □REACH (REACH 標準) CUSTOMER’S ■ RoHS (RoHS 標準) □ Others (其他) APPROVED SIGNATURE 泰州福聲電子科技有限公司 Taizhou Fusheng Electronic Technology Co.,Ltd. Adds: No168 of FengHuang Road West,Hailing District ,Taizhou . 地址: 江 蘇 省 泰 州 市 海 陵 區 鳳 凰 西 路 168 號 Tel: +86-523-86219066 Fax: +86-523- 81601108 Http://www.tzfsdz.com DESINGER SIGNATURE DATE E-mail: sales@electronic-tech.cn CHECKED APPROVED A. SCOPE This specification applies speaker,FS-1540 B. SPECIFICATION No. Item Unit Specification Condition 1 Dimension mm 15 x 15 x H4.0 See appearance drawing 2 Sound Pressure Level dB 87±3dB 3 Power Rating W 0.5 MAX.0.8 4 Impedance ohm 8±15%Ω At 1.0KHz 1.0V 5 Resonance Frequency Hz 850±20% At 1.0V 6 Frequency Rang Hz Fo~20K Output S.P.L. ±10dB at 1.0,1.6, 2.0, 3.2KHzAverage 0dB=20μPa Measurement is as shown in fig (2),Input: 2.0V=0.5W at 0.1m Must be free audible noise, From Fo~20K Hz frequency range, Input: 2.0V 0.5W 7 Buzze & Rattle 8 Distortion 9 Housing Material LCP(Black) PIN(Plating Au) 10 Leading Pin SMD Type 11 Weight (MAX) % 12 Operating Temperature 13 Storage Temperature 14 Environmental Protection Regulation 5% Max. At 1kHz, 0.5W gram 2.1 ℃ -40~ +85 ℃ -40 ~ +85 RoHS C. APPEARANCE DRAWING + Lead - Tol : ± 0.5 Lead + Unit: mm Recomended Land Pattern: 镀金 D.Frequency Response E. Electrical And Acoustical Measuring Condition Standard testcondition ofspeaker Pow erAm plifier M icrophone Speaker Standard Baffle Board R ecom m ended In IEC 268-5 W here 1650m m x1350m m Audio Analyzer JH D S Type 6160S F. RELIABILITY TEST No. 1 2 3 Item Test condition Evaluation standard 90% min. lead terminals Solderability Lead terminals are immersed in rosin for 5 seconds and shall be wet with solder. (Spring Contact then immersed in solder bath of +270±5℃ for 3±1 (Except the edge of excepted) seconds. terminal) Soldering Heat Lead terminal are immersed up to 1.5mm from Resistance sounder’s body in solder bath of +260±5℃ for 3±1 (Spring Contact seconds. excepted) Terminal Pull Strength No interference in operation (1) Spring Contact: Applied 3N (0.306kg) load to the Spring Contact for 30 sec. No damage and cutting off (2) Terminal : Applied 9.8N (1.0kg) load to the Terminal for 30 sec. 4 Vibration Test Speaker shall be measured after being applied vibration of amplitude of 1.5mm with 10 to 55Hz band of vibration frequency to each of 3 per-pendicular directions for 2 hours. 5 Drop Test Drop the speakers contained in normal box onto the board 40mm thick 10 times from the height of 75cm G. ENVIRONMENTAL TEST No. Item Test conditions 1 High temp. Test After being placed in a chamber at +85℃ for 240 hours 2 Low temp. Test 3 4 After being placed in a chamber at -40℃ for 240 hours. Evaluation standard Being placed for 6 hours After being placed in a chamber at +40℃and 95±5%RH at +25℃, speaker shall Humidity test be measured. No relative humidity for 240 hours. obstacle to be harmful to The part shall be subjected to 5 cycles. One cycle shall be normal operation; consist of: damages, cracks, rusts, +85℃ etc. Should not be audible at 2.0V sine wave between +25℃ Fo~20KHz. Fo should Temp. cycle test meet initial one. S.P.L. -40℃ deviation of unit should be 2hrs 0.5hrs 1hrs 0.5hrs 2hrs within ±3dB 6hrs H. RELIABILITY TEST No. 1 Item Load test Test conditions Evaluation standard Being placed for 1 hours at +25℃, receiver shall be measured. No obstacle to be harmful to normal operation; damages, 0.5W white noise is applied for 24 hours, at room temp. cracks, rusts, etc. Should not be audible at 2.0V sine wave between Fo~20KHz. S.P.L. deviation of unit should be within ±3dB TEST CONDITION. Standard Test Condition 一般测试条件 Judgment Test Condition 争议时测试条件 : : : : a) Temperature : +5 ~ +35℃ a) 温度 : +5 ~ +35℃ a) Temperature : +25 ± 2℃ a) 温度 : +25 ± 2℃ b) Humidity : 45-85% b) 湿度 : 45-85% b) Humidity : 60-70% b) 湿度 : 60-70% c) Pressure : 860-1060mbar c) 气压 : 860-1060mbar c) Pressure : 860-1060mbar c) 气压 : 860-1060mbar PACKING STANDARD 1 R eel:600PC S (+) + + (-) I. + C arton B ox (10 Inner B ox) Inner B ox (1Layer R eel) Inner B ox 330m m x330m m x30m m 1x600PC S=600PC S C arton B ox 350m m x350m m x370m m 10x600PC S=6,000PC S
FS-1540 价格&库存
很抱歉,暂时无法提供与“FS-1540”相匹配的价格&库存,您可以联系我们找货
