OR-3H7-4GB-TA1-GK
OR-3H7-4GB-TA1-GK
    ORIENT(奥伦德)
    SOP16_10.28X4.4MM
    单向光耦 Viso=3750Vrms VF(typ)=1.2V IF=50mA Vo=80V CTR=100~400% SOP16_10.28X4.4MM
OR-3H7-4GB-TA1-GK 数据手册
Shenzhen Orient Components Co ., Ltd OR-3H7-4 ORIENT Photo coupler Product Data Sheet Part Number: OR-3H7-4 Customer: Date: SHENZHEN ORIENT COMPONENTS CO.,LTD. Block A 3rd Floor No.4 Building,Tian’an Cyber Park,Huangge Rd,LongGangDist,Shenzhen,GD TEL:0755-29681816 FAX:0755-29681200 www.orient-opto.com Copyright© 2020 Orient .All rights Reserved 1 V2 Shenzhen Orient Components Co ., Ltd OR-3H7-4 1.Features 1. Current transfer ratio(CTR) : MIN. 50% at IF = 5mA, VCE = 5V, Ta=25 ℃ 2. High input-output isolation voltage.(VISO=3,750Vrms) 3. Collector and emitter Voltage : 80V(MIN) 4. Operating Temperature :-55 ℃ to 125 ℃ 5. In compliance with RoHS, REACH standards 6. MSL Class Ⅰ 2.Instructions The OR-3H7-4 series device contains four infrared led and four photo transistor detector. They are encapsulated in a 16-pin SOP, free of halogens and Sb2O3 3.Application Range 1.Mixed PCB substrate requiring high density installation 2.Programmable controller 3. System apparatus and measuring instruments 4.Max Absolute rated Value (Normal Temperature=25℃) Parameter Symbol Rated Value Unit Forward Current IF 50 mA Peak forward current(t=10us) IFM 1 A Reverse Voltage VR 6 V Power Dissipation P 70 mW Junction Temperature Tj 125 ℃ Collector and emitter Voltage VCEO 80 V Emitter and collector Voltage VECO 7 Collector Current IC 50 mA Power Dissipation PC 100 mW Junction Temperature Tj 125 ℃ Total Power Dissipation Ptot 170 mW *1 Insulation Voltage Viso 3750 Vrms Rated Impulse Insulation Voltage VIORM 630 V Operating Temperature Topr -55 to + 125 Storage Temperature Tstg -55 to + 150 *2 Soldering Temperature Tsol 260 Input Output ℃ *1. AC For 1 Minute, R.H. = 40 ~ 60% Isolation voltage shall be measured using the following method. (1) Short between anode and cathode on the primary side and between collector and emitter on the secondary side (2) The isolation voltage tester with zero-cross circuit shall be used. (3) The waveform of applied voltage shall be a sine wave. *2.soldering time is 10 seconds Copyright© 2020 Orient .All rights Reserved 2 V2 Shenzhen Orient Components Co ., Ltd OR-3H7-4 5.Opto-electronic Characteristics(Normal Temperature=25℃) Parameter Input Output Transforming Characteristics Symbol Min Typ.* Max Unit Condition Forward Voltage VF --- 1.2 1.4 V IF=20mA Reverse Current IR --- --- 5 μA VR=5V Terminal Capacitance Ct --- 30 250 pF V=0, f=1KHz Collector Dark Current ICEO --- --- 100 nA Collector-Emitter Breakdown Voltage BVCEO 80 --- --- V Emitter-Collector Breakdown Voltage BVECO 7 --- --- V *1 Current Transfer Ratio CTR 50 --- 600 % Collector Current IC 2.5 --- 30 mA VCE(sat) --- --- 0.4 V --- Ω Collector-Emitter Saturation Voltage VCE=20V IF=0mA IC=0.1mA IF=0mA IE=0.1mA IF=0mA IF=5mA VCE=5V IF=8mA IC= 2.4mA DC 500V Insulation Impedance Riso Floating Capacitance Cf --- 0.6 1 pF V=0, f=1MHz Response Time tr --- 2 18 μs VCE=5V, 5×1010 1×1011 40~60%R.H. IC=2mA, Descend Time tf --- 3 18 μs RL=100Ω, f=100Hz  Current Conversion Ratio = IC / IF × 100% Copyright© 2020 Orient .All rights Reserved 3 V2 Shenzhen Orient Components Co ., Ltd OR-3H7-4 6.Rank table of current transfer ratio CTR  MODEL NO. CTR Rank Min. Max. Condition Unit OR-3H7-4 GB 100 400 IF=5mA, VCE=5V, Ta=25℃ % No Mark 50 600 IF=5mA, VCE=5V, Ta=25℃ % Current Conversion Ratio = IC / IF × 100% 7.Order Information Part Number OR-3H7-4X-W-Y-Z Note X = CTR Rank(GB or None). W = Tape and reel option (TA1 or TA). Y = ‘V’ code for VDE safety (This options is not necessary). Z = ‘G’ code for Halogen free (This options is not necessary). * VDE Code can be selected. * Halogen Free Code can be selected. Option Description Packing quantity TA1 Surface mount lead form (low profile) + TA1 tape & reel option 2000 units per reel TA Surface mount lead form (low profile) + TA tape & reel option 2000 units per reel Copyright© 2020 Orient .All rights Reserved 4 V2 Shenzhen Orient Components Co ., Ltd OR-3H7-4 8.Naming Rule 1. Manufacturer : ORIENT. 2. Part Number : 3H7-4. 3. Rank Code 4. Year Code 5. Week Code 6. VDE Code 7. HF Code 8. Anode. : CTR Rank : '21' means '2021' and so on. : 01 means the first week, 02 means the second week and so on. . : Halogen Free. * Halogen Free Mark can be selected. * VDE Mark can be selected. Copyright© 2020 Orient .All rights Reserved 5 V2 Shenzhen Orient Components Co ., Ltd OR-3H7-4 9.Outer Dimension 10.Recommended Foot Print Patterns (Mount Pad) (Unit:mm) Copyright© 2020 Orient .All rights Reserved 6 V2 Shenzhen Orient Components Co ., Ltd OR-3H7-4 11.Taping Dimensions (1)OR-3H7-4-TA1 (2)OR-3H7-4-TA type Symbol Dimensions: mm (in.) bandwidth W 16±0.3 (0.47) pitch P0 4±0.1 (0.15) F 7.5±0.1 (0.217) P2 2±0.1 (0.079) P1 12±0.1 (0.315) pitch interval Encapsulation type Quantity (pieces) Copyright© 2020 Orient .All rights Reserved TA1/TA 2000 7 V2 Shenzhen Orient Components Co ., Ltd OR-3H7-4 12.Package Dimension (1) package dimension (2)Packing Label Sample 1. 2. 3. 4. 5. MTL NO:Contents with "Order Information" in the specification. LOT NO:The production cycle of the product. BATCH:The CTR RANK of the product. Quantity:Product packaging quantity. Product Data: The data when product be made. Copyright© 2020 Orient .All rights Reserved 8 V2 Shenzhen Orient Components Co ., Ltd OR-3H7-4 13.Reliability Test Reliability Testing NO. 1 ITEMS QTY. (Pcs) RSH 22 Condition 260±5℃ Process 10s/3 times Standard JESD22-A106 168 hrs 2 HTSL 77 125℃ 500 hrs JESD22-A103 1000 hrs 168 hrs 3 LTSL 77 -55℃ 500 hrs JESD22-A119 1000 hrs 4 TC 77 5 TS 77 6 HTOL 77 H:125℃ 15min ∫5min L:-55℃ 15min H:100℃ 5min ∫15s L:-40℃ 5min 300 cycle JESD22-A104 300 cycle JESD22-A106 168 hrs 110°C IF=10mA Vce=5V 500 hrs JESD22-A108 1000 hrs 7 ESDHBM 22 ≥8KV 1Cycle 1 time JESD22-A114 8 SD 22 Pb-free 260±5℃ 5S/1 time JESD22-B102 168 hrs 9 HTRB 77 @125℃ Vce=80v 500 hrs JESD22-A103 1000 hrs 168 hrs 10 11 H3TRB Autoclave 77 77 85℃,85%RH Vce=80v 500 hrs Ta=121 ℃,100%RH,2atm 168h Copyright© 2020 Orient .All rights Reserved JESD22-A101 1000 hrs JESD22-A102 9 V2 Shenzhen Orient Components Co ., Ltd OR-3H7-4 14.Temperature Profile Of Soldering (1)IR Reflow soldering (JEDEC-STD-020C compliant) One time soldering reflow is recommended within the condition of temperature and time profile shown below. Do not solder more than three times. Profile item Conditions Preheat - Temperature Min (T Smin ) 150˚C - Temperature Max (T Smax ) 200˚C - Time (min to max) (ts) 90±30 sec Soldering zone - Temperature (TL ) 217˚C - Time (t L ) 60 sec Peak Temperature 260˚C Peak Temperature time 20 sec Ramp-up rate 3˚C / sec max. Ramp-down rate from peak temperature 3~6˚C / sec Reflow times ≤3 Copyright© 2020 Orient .All rights Reserved 10 V2 Shenzhen Orient Components Co ., Ltd OR-3H7-4 (2).Wave soldering (JEDEC22A111 compliant) One time soldering is recommended within the condition of temperature. Temperature 260+0/-5˚C Time 10 sec Preheat temperature 25 to 140˚C Preheat time 30 to 80 sec (3).Hand soldering by soldering iron Allow single lead soldering in every single process. One time soldering is recommended. Copyright© 2020 Orient .All rights Reserved Temperature 380+0/-5˚C Time 3 sec max 11 V2 Shenzhen Orient Components Co ., Ltd OR-3H7-4 15.Characteristics Curve Copyright© 2020 Orient .All rights Reserved 12 V2 Shenzhen Orient Components Co ., Ltd Copyright© 2020 Orient .All rights Reserved 13 OR-3H7-4 V2 Shenzhen Orient Components Co ., Ltd Copyright© 2020 Orient .All rights Reserved 14 OR-3H7-4 V2
OR-3H7-4GB-TA1-GK
物料型号为OR-3H7-4,是一款由深圳东方光电有限公司生产的光耦器件。
器件简介包括四个红外发光二极管和四个光电晶体管探测器,封装在16引脚SOP中,无卤素和Sb2O3。
引脚分配为1脚为阳极,2脚为阴极,3至7脚为发光二极管,9至15脚为集电极和发射极。
参数特性包括最小电流传输比CTR 50%,输入输出隔离电压3,750Vrms,工作温度范围-55℃至125℃。
功能详解涉及器件的电流转换比、隔离电压、集电极与发射极电压等。
应用信息包括高密度安装的混合PCB基板、可编程控制器、系统设备和测量仪器。
封装信息为16引脚SOP封装,符合RoHS和REACH标准。
OR-3H7-4GB-TA1-GK 价格&库存
很抱歉,暂时无法提供与“OR-3H7-4GB-TA1-GK”相匹配的价格&库存,您可以联系我们找货
