Shenzhen Orient Components Co ., Ltd
OR-352
ORIENT
Photocoupler
Product Data Sheet
Part Number:
OR-352
Customer:
Date:
SHENZHEN ORIENT COMPONENTS CO.,LTD.
Block A 3rd Floor No.4 Building,Tian’an Cyber Park,Huangge Rd,LongGang Dist,Shenzhen,GD
TEL:0755-29681816
FAX:0755-29681200
www.orient-opto.com
Copyright© 2019 Orient .All rights Reserved
1
V2
OR-352
1. Features
Current transfer ratio(CTR : MIN. 1000% at IF = 1mA, VCE = 2V)
High input -output isolation voltage (VISO=3,750Vrms)
High collector-emitter voltage (VCEO =300V)
SOP-4 package
-55 ℃ to 110℃
In compliance with RoHS, REACH standards
MSL Class Ⅰ
2. Instructions
The OR-352 series device consists of an infrared led, phototransistor detector.
They are encapsulated in a 4 pin SOPencapsulation.
Pin pitch of OR-352 is 2.54mm
3. Application Range
Hybrid substrates that require high densitymounting.
Programmable controllers
System appliance, measuring instruments
4. Max Absolute rated Value (Normal Temperature=25℃)
Parameter
Input
Output
Symbol
Rated Value
Unit
Forward Current
IF
50
mA
Junction Temperature
TJ
125
Reverse Voltage
VR
6
V
Consume Power
P
70
mW
Collector and emitter Voltage
V CEO
300
Emitter and collector Voltage
V ECO
0.1
Collector Current
IC
150
mA
Consume Power
PC
150
mW
Total Consume Power
Ptot
170
mW
*1 Insulation Voltage
Viso
3750
Vrms
Working Temperature
Topr
-55 to + 110
Deposit Temperature
Tstg
-55 to + 125
*2 Soldering Temperature
Tsol
260
2
V
V2
OR-352
*1. AC For 1 Minute, R.H. = 40 ~ 60%
Isolation voltage shall be measured using the following method.
(1) Short between anode and cathode on the primary side and between collector and emitter on the
secondary side.
(2) The isolation voltage tester with zero-cross circuit shall be used.
(3) The waveform of applied voltage shall be a sine wave.
*2. soldering time is 10 seconds.
5. Opto-electronic Characteristics
Symbol
Condition
Min
Typ.*
Max
Unit
Forward Current
VF
IF=10mA
1.2
1.4
V
Reverse Voltage
IR
VR=4V
10
μA
Collector capacitance
Ct
V=0, f=1KHz
30
250
pF
ICEO
V CE=200V,
IF=0mA
200
nA
Collector and Emitter
attenuation Voltage
BV CEO
IC=0.1mA
IF=0mA
300
V
Emitter and Collector
attenuation Voltage
BV ECO
IE=0.01mA
IF=0mA
0.1
V
1000
15000
10
150
mA
1.2
V
Ω
Parameter
Input
Collector to emitter Current
Output
*1.Current conversion ratio
CTR
IC
Collector Current
Transforming
Characteristics
Collector and Emitter Saturation
Voltage
V CE(sat)
Insulation Impedance
Riso
Floating Capacitance
Cf
Response Time
tr
Descend Time
tf
IF=1mA
VCE=2V
IF=20mA
IC=100mA
DC500V
40~60%R.H.
V=0, f=1MHz
VCC=2V,
IC=20mA
RL=100Ω
5×1010 1×1011
0.6
1
pF
100
300
μs
μs
Current Conversion Ratio = IC / IF ×100%
3
V2
OR-352
6. Order Information
Part Number
OR-352-X-Y-Z
Note
X = Tape and reel option (TP or TP1).
Y = ‘V’ code for VDE safety (This options is not necessary).
Z = ‘G’ code for Halogen free.
* VDE Code can be selected.
Option
Description
Packing quantity
None
Standard SMD Option
100 units per tube
TP
Surface mount lead form (low profile) + TP tape & reel option
3000 units per reel
TP1
Surface mount lead form (low profile) + TP1 tape & reel option
3000 units per reel
4
V2
OR-352
7. Naming Rule
(1) ORIENT .
(2) 352
denotes Part Number.
(3)
denotes Year Code.
(4)
denotes Week Code.
(5)
denotes Day Code.
(6)
Anode.
* Halogen Free Mark can be selected.
* VDE Mark can be selected.
5
V2
OR-352
8. Outer Dimension
9. Recommended Foot Print Patterns (Mount Pad)
unit:mm
6
V2
OR-352
10. Taping Dimensions
(1)OR-352-TP
2.54±0.1
(2)OR-352-TP1
Description
Symbol
Dimension in mm(inch)
Tape wide
W
12±0.3(0.472)
Pitch of sprocket holes
P0
4±0.1(0.157)
F
5.5±0.1(0.217)
P2
2±0.1(0.079)
P1
8±0.1(0.315)
Distance of compartment
to compartment
Package Type
TP/TP1
Quantities(pcs)
3000
7
V2
OR-352
11. Package Dimension
(1) package dimension
(2)Packing Label Sample
1.
2.
3.
4.
5.
MTL NO:Contents with "Order Information" in the specification.
LOT NO:The production cycle of the product.
BATCH:The CTR RANK of the product.
Quantity:Product packaging quantity.
Product Data: The data when product be made.
8
V2
OR-352
12. Reliability Test
9
V2
OR-352
13. Temperature Profile Of Soldering
(1) IR Reflow soldering (JEDEC-STD-020C compliant)
One time soldering reflow is recommended within the condition of temperature and time profile shown
below. Do not solder more than three times.
Profile item
Conditions
Preheat
150˚C
- Temperature Min (T Smin )
200˚C
- Temperature Max (T Smax )
90±30 sec
- Time (min to max) (ts)
Soldering zone
- Temperature (TL )
217˚C
- Time (t L )
60 sec
Peak Temperature
260˚C
Peak Temperature time
20 sec
Ramp-up rate
3˚C / sec max.
Ramp-down rate from peak temperature
3~6˚C / sec
Reflow times
≤3
10
V2
OR-352
(2) Wave soldering (JEDEC22A111 compliant)
One time soldering is recommended within the condition of temperature.
Temperature
260+0/-5˚C
Time
10 sec
Preheat temperature
5 to 140˚C
Preheat time
30 to 80 sec
(3) Hand soldering by soldering iron
Allow single lead soldering in every single process. One time soldering is recommended.
Temperature
380+0/-5˚C
Time
3 sec max
11
V2
OR-352
14. Characteristics Curve
12
V2
13
OR-352
V2
很抱歉,暂时无法提供与“OR-352-TP-G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.63372
- 50+1.28499
- 150+1.13552
- 500+0.94911
- 3000+0.85925
- 国内价格
- 1+1.17700
- 200+0.90530
- 1500+0.78650
- 3000+0.73040
