SVZ1VM471GCRE00RAXXX 数据手册
CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS
VZ series
Endurance: +105°C 2,000 hours
Standard substance
Recommended Applications: Display Card & System Board
RoHS Compliant and lead-free
SPECIFICATIONS
Items
Characteristics
Category Temperature Range
-55~+105°C
Rated Working Voltage Range
2.5~100 V dc
Nominal Capacitance Range
22~2200µF
Capacitance Tolerance
±20%(M)
(at 20°C,120Hz)
I≤0.2CV or 500μA, whichever is greater.
Where, I:Max.leakage current (µA),C:Nominal capacitance (µF),V: Rated voltage (V)
DC Leakage Current
2.5
Rated Voltage(V dc )
Dissipation Factor (tanδ)
6.3
10
16
25
0.08
tanδ (max.)
ESR(100kHz,20°C)
Value in characteristics table
Temperature Characteristic
(Impedance Ratio at 100kHz)
Z(+105°C)/Z(+20°C)≤1.25
Z(-55°C)/Z(+20°C)≤1.25
35
(at 20°C after 2 minutes)
50
63
(at 20°C,120Hz)
0.12
After applying rated voltage for 2,000 hours at 105°C, the capacitors shall meet the following requirements.
Endurance
Appearance
No significant damage
Capacitance Change
≤±20% of the initial value
D.F. (tanδ)
≤150% of the initial specified value
ESR
Leakage Current
≤The initial specified value
After subjecting to 90~95% RH for 2,000 hours at 60°C without voltage applied, the capacitors shall meet the specified values
for the Endurance characteristics listed above.
Humidity Test
After subjecting to 1,000 cycles each consisting of charge with the surge voltage specified at normal temperature for 30
seconds through a protective resistor and discharge for 5 minutes 30 seconds, the capacitors shall meet the following
requirements.
Surge Test
Appearance
Capacitance Change
≤ ± 20% of the initial value
D.F. (tanδ)
ESR
Leakage Current
*Note: If any doubt arises, measure the leakage current after the following voltage treatment.
Voltage treatment: DC rated voltage is applied to the capacitors for 120 minutes at 105°C.
DIMENSIONS[mm]
D
6.3
8
10
P±0.2
A±0.2
B±0.2
C±0.2
W
ØD'
L'
1.9
3.1
4.5
6.6
6.6
7.2
0.5~0.8
8.3
8.3
9.0
0.7~1.1
10.3
10.3
11.0
0.7~1.1
ØD-0.1~+0.5
L±0.5
ØD-0.1~+0.5
L±0.3
ØD-0.1~+0.5
L±0.3
PART NUMBERING SYSTEM
S
V
Z
0 J
M
2
7
1
E
E
R
A
X X X
Special code
Marking code
Terminal code
Size code
Capacitance code
Capacitance tolerance code
Voltage code
Series code
Category code
59
VZ series
VDC
(SV)
2.5
(2.9)
6.3
(7.2)
Cap
(µF)
330
390
470
560
680
220
270
330
470
560
1000
1500
2200
120
220
330
10
(11.5)
470
560
1000
1500
47
68
100
150
180
16
(18.4)
220
270
330
560
680
1000
22
27
47
56
68
25
(28.8)
100
150
220
330
470
560
680
22
27
33
47
68
35
(40.3)
100
150
220
270
330
470
22
33
47
68
50
(57.5)
82
100
120
150
220
Size
ΦDxL(mm)
6.3×6
6.3×6
6.3×6
6.3×6
6.3×9
6.3×6
6.3×6
6.3×6
6.3×9
6.3×9
8×11.5
8×11.5
10×12.5
6.3×6
6.3×6
6.3×9
6.3×9
6.3×9
8×9.5
8×11.5
10×12.5
8×11.5
10×12.5
10×12.5
6.3×6
6.3×6
6.3×6
6.3×6
6.3×9
6.3×6
6.3×9
6.3×9
6.3×9
8×9.5
6.3×9
8×11.5
10×12.5
8×11.5
10×12.5
10×12.5
6.3×6
6.3×6
6.3×6
6.3×9
6.3×6
6.3×6
6.3×9
6.3×6
6.3×9
6.3×9
8×11.5
10×12.5
8×11.5
8×11.5
10×12.5
10×12.5
10×12.5
6.3×6
6.3×6
6.3×6
6.3×9
6.3×6
6.3×6
6.3×9
6.3×9
8×9.5
8×11.5
8×11.5
8×11.5
8×11.5
10×12.5
10×12.5
10×12.5
6.3×6
6.3×6
6.3×9
8×11.5
10×12.5
8×11.5
8×11.5
10×12.5
8×11.5
10×12.5
10×12.5
ESR
(mΩ,20°C,100kHz)
(max.)
Rated ripple current
(mArms/105°C,100kHz)
Leakage Current
(µA)(max.)
Part Number
15
15
15
15
30
30
22
15
15
40
40
30
30
25
60
25
25
25
25
25
50
50
35
50
50
30
50
30
30
30
22
30
30
22
22
22
60
60
60
50
45
45
40
40
40
30
30
30
30
30
30
30
80
80
60
30
30
30
30
30
30
30
30
2700
2800
2900
3000
4300
2800
3000
2100
3500
3700
4300
4400
5600
2700
2700
3000
3100
3400
3400
3600
5000
4200
4400
4400
1700
2000
2400
2400
2600
2500
2700
2500
2600
2800
2600
4000
5000
3500
4000
4100
1600
1100
1800
2000
1800
1800
2400
2100
2500
2500
2600
2800
2700
2800
3100
3300
3300
1100
1100
1100
1500
1100
1100
1800
2100
2800
3000
3000
2400
2500
2700
2700
3000
800
850
1400
2000
2000
2000
2000
2100
2000
2100
2300
500
500
500
500
500
500
500
500
592
706
1260
1890
2772
500
500
500
660
940
940
1120
1120
2000
2000
3000
500
500
500
500
500
576
576
704
864
864
1056
1056
1056
1792
2176
3200
500
500
500
500
500
500
500
500
750
1100
1100
1650
500
2350
2350
2800
3400
500
500
500
500
500
500
500
700
700
700
1050
1540
1890
1890
2310
3290
500
500
500
680
820
820
1000
1000
1200
1500
2200
SVZ0EM331E06E00RAXXX
SVZ0EM391E06E00RAXXX
SVZ0EM471E06E00RAXXX
SVZ0EM561E06E00RAXXX
SVZ0EM681E09E00RAXXX
SVZ0JM221E06E00RAXXX
SVZ0JM271E06E00RAXXX
SVZ0JM331E06E00RAXXX
SVZ0JM471E09E00RAXXX
SVZ0JM561E09E00RAXXX
SVZ0JM102FBRE00RAXXX
SVZ0JM152FBRE00RAXXX
SVZ0JM222GCRE00RAXXX
SVZ1AM121E06E00RAXXX
SVZ1AM221E06E00RAXXX
SVZ1AM221E09E00RAXXX
SVZ1AM331E09E00RAXXX
SVZ1AM471E09E00RAXXX
SVZ1AM471F9RE00RAXXX
SVZ1AM561FBRE00RAXXX
SVZ1AM561GCRE00RAXXX
SVZ1AM102FBRE00RAXXX
SVZ1AM102GCRE00RAXXX
SVZ1AM152GCRE00RAXXX
SVZ1CM470E06E00RAXXX
SVZ1CM680E06E00RAXXX
SVZ1CM101E06E00RAXXX
SVZ1CM151E06E00RAXXX
SVZ1CM151E09E00RAXXX
SVZ1CM181E06E00RAXXX
SVZ1CM181F09E00RAXXX
SVZ1CM221E09E00RAXXX
SVZ1CM271E09E00RAXXX
SVZ1CM271F9RE00RAXXX
SVZ1CM331E09E00RAXXX
SVZ1CM331FBRE00RAXXX
SVZ1CM331GCRE00RAXXX
SVZ1CM561FBRE00RAXXX
SVZ1CM681GCRE00RAXXX
SVZ1CM102GCRE00RAXXX
SVZ1EM220E06E00RAXXX
SVZ1EM270E06E00RAXXX
SVZ1EM470E06E00RAXXX
SVZ1EM470E09E00RAXXX
SVZ1EM560E06E00RAXXX
SVZ1EM680E06E00RAXXX
SVZ1EM101E09E00RAXXX
SVZ1EM101E06E00RAXXX
SVZ1EM151E09E00RAXXX
SVZ1EM221E09E00RAXXX
SVZ1EM221FBRE00RAXXX
SVZ1EM331GCRE00RAXXX
SVZ1EM331FBRE00RAXXX
SVZ1EM471FBRE00RAXXX
SVZ1EM471GCRE00RAXXX
SVZ1EM561GCRE00RAXXX
SVZ1EM681GCRE00RAXXX
SVZ1VM220E06E00RAXXX
SVZ1VM270E06E00RAXXX
SVZ1VM330E06E00RAXXX
SVZ1VM470E09E00RAXXX
SVZ1VM470E06E00RAXXX
SVZ1VM680E06E00RAXXX
SVZ1VM680E09E00RAXXX
SVZ1VM101E09E00RAXXX
SVZ1VM101F9RE00RAXXX
SVZ1VM101FBRE00RAXXX
SVZ1VM151FBRE00RAXXX
SVZ1VM221FBRE00RAXXX
SVZ1VM271FBRE00RAXXX
SVZ1VM271GCRE00RAXXX
SVZ1VM331GCRE00RAXXX
SVZ1HM220E06E00RAXXX
SVZ1HM330E06E00RAXXX
SVZ1HM470E09E00RAXXX
SVZ1HM680FBRE00RAXXX
SVZ1HM820GCRE00RAXXX
SVZ1HM820FBRE00RAXXX
SVZ1HM101FBRE00RAXXX
SVZ1HM101GCRE00RAXXX
SVZ1HM121FBRE00RAXXX
SVZ1HM151GCRE00RAXXX
SVZ1HM221GCRE00RAXXX
60
Conductive Polymer
SMD Type
STANDARD RATINGS
VZ series
STANDARD RATINGS
VDC
(SV)
63
(72.5)
80
(92.0)
100
(115.0)
Cap
(µF)
22
33
47
56
100
27
47
68
22
47
Size
ΦDxL(mm)
ESR
(mΩ,20°C,100kHz)
(max.)
6.3×6
6.3×9
8×9.5
8×11.5
10×12.5
8×11.5
10×12.5
10×12.5
8×11.5
10×12.5
80
60
60
40
40
50
50
50
50
50
450
500
1000
1400
1600
600
900
900
600
900
Leakage Current
(µA)(max.)
500
500
592
706
1260
500
752
1088
500
940
Part Number
SVZ1JM220E06E00RAXXX
SVZ1JM330E09E00RAXXX
SVZ1JM470F9RE00RAXXX
SVZ1JM560FBRE00RAXXX
SVZ1JM101GCRE00RAXXX
SVZ1BM270FBRE00RAXXX
SVZ1BM470GCRE00RAXXX
SVZ1BM680GCRE00RAXXX
SVZ1KM220FBRE00RAXXX
SVZ1KM470GCRE00RAXXX
※ Specifications subject to change without notice.
61
SVZ1VM471GCRE00RAXXX 价格&库存
很抱歉,暂时无法提供与“SVZ1VM471GCRE00RAXXX”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.89440
- 10+2.32200
- 30+2.07360
- 100+1.77120
- 400+1.63080
- 800+1.52280
- 国内价格
- 1+2.09935
- 50+1.59335
- 400+1.56200
- 国内价格
- 1+1.87040
- 10+1.75840
- 50+1.59040
- 150+1.47840
- 300+1.40000
- 500+1.36640
- 国内价格
- 10+2.30120
- 30+2.05460
- 100+1.75360
- 400+1.61450
- 800+1.50760
