UMPT-05-06.5-G-V-S-W-TR
    SAMTEC(申泰)
    CONN_17.3X7.6MM_SM
    电源连接器 间距2.00mm 5Pin 1Row 立贴 CONN_17.3X7.6MM_SM
UMPT-05-06.5-G-V-S-W-TR 数据手册
ULTRA MICRO POWER SYSTEM (2.00 mm) .0787" PITCH UMPT/UMPS compared to another small form factor power solution FEATURES & BENEFITS mPower® • Up to 18 A per blade (1 blade powered) • Design flexibility as a power-only system or a two-piece system for power/signal applications Traditional Power Solutions • Use with Samtec’s high-speed connector systems for a unique power/signal system • Choice of 2 to 10 positions CREEPAGE & CLEARANCE • 5 mm to 20 mm stack heights available • Tin or 10 µ" Gold plated power blades; 30 µ" Gold plating available to meet specific regulations UMPT/UMPS • Optional weld tabs • Cable-to-board and cable-to-cable systems in development CREEPAGE 2.20 mm CLEARANCE 1.65 mm Selectively loading contacts achieves customer specific creepage and clearance requirements. KEY SPECIFICATIONS PITCH STACK HEIGHTS INSULATOR MATERIAL CONTACT MATERIAL PLATING OPERATING TEMP RANGE 2.00 mm 5 to 16, 18, 20 mm Black LCP Copper Alloy Sn or Au over 50 µ" (1.27 µm) Ni -55 °C to +105 °C with Tin F-221 (Rev 16NOV22) -55 °C to +125 °C with Gold VOLTAGE RATING LEAD-FREE SOLDERABLE 460 VAC/ 650 VDC Yes samtec.com/mPOWER Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. MAX 18 A ULTRA MICRO POWER TERMINAL - UMPT NO. OF POSITIONS - –02, –03, –04, –05, –06, –07, –08, –09, –10 UMPT Board Mates: UMPS Cable Mates: UMPC* (*UMPT requires -P or -M option for mating) - LEAD STYLE –01.5 = (01.5 mm) .059" –02.5 = (02.5 mm) .098" –06.5 = (06.5 mm) .256" – 07.5 = (07.5 mm) .295" – 12.5 = (12.5 mm) .492" (–W option required) m p s -V-S- PLATING OPTION WELD TAB –L (Leave blank for no weld tab) = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail –W = Weld Tab Through-hole (Required for –12.5 lead style) –S = 30 µ" (0.76 µm) Gold on contact, Matte Tin on tail NO. OF POSITIONS LEAD STYLE C –01.5 (4.80) .189 –02.5 (5.80) .228 –06.5 (9.55) .376 –07.5 (10.80) .425 C - B –12.5 UMPT–04–01.5–X-V–S–W SHOWN –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) –P = Plastic top latch (15.80) .622 A B A (9.70) .382 (–P & No latch) (–M latch) B –02 (11.30) .445 –03 (13.30) .524 (11.70) .460 (15.30) .602 (13.60) .535 (13.30) .524 (11.60) .457 –04 (15.30) .602 (13.70) .539 (17.30) .681 (15.60) .614 –05 (17.30) .681 (15.70) .618 (19.30) .760 (17.60) .693 –06 (19.30) .760 (17.70) .697 (21.30) .839 (19.60) .772 –07 (21.30) .839 (19.70) .776 (23.30) .917 (21.60) .850 –08 (23.30) .917 (21.70) .854 (25.30) .996 (23.60) .929 –09 (25.30) .996 (23.70) .933 (27.30) 1.075 (25.60) 1.007 –10 (27.30) 1.075 (25.70) 1.012 (29.30) 1.154 (27.60) 1.087 View complete specifications at: samtec.com?UMPT NO. OF POSITIONS - 01 –02, –03, –04, –05, –06, –07, –08, –09, –10 - PLATING OPTION - RA - –L WELD TAB –WT = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail = Weld Tab Through-hole = 30 µ" (0.76 µm) Gold on contact, Matte Tin on tail Board Mates: UMPS Cable Mates: UMPC* (*UMPT requires -P or -M option for mating) - - LATCH OPTION = Tape & Reel –P –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) –M = Metal side latches –T “X”R –TR (Leave blank for no latch) = Plastic top latch –S UMPT-RA = Matte Tin (9.75) .384 NO. OF POSITIONS A –02 B B (13.60) .535 (11.10) .437 (11.55) .455 –03 (15.60) .614 (13.10) .516 (13.55) .533 –04 (17.60) .693 (15.10) .594 (15.55) .612 –05 (19.60) .772 (17.10) .673 (17.55) .691 –06 (21.60) .850 (19.10) .752 (19.55) .770 –07 (23.60) .929 (21.10) .831 (21.55) .848 –08 (25.60) 1.008 (23.10) .909 (23.55) .927 –09 (27.60) 1.087 (25.10) .988 (25.55) 1.006 –10 (29.60) 1.165 (27.10) 1.067 (27.55) 1.085 A (13.30) .524 UMPT–04–01–X–RA–WT–P SHOWN Note: Some lengths, styles and options are non-standard, non-returnable. = Tape & Reel –M = Matte Tin “X”R –TR (Leave blank for no latch) (Only available on –02.5 lead style) (Weld tab required) = Metal side latches (7.60) .299 UMPT - LATCH OPTION –T A Note: Some lengths, styles and options are non-standard, non-returnable. - (9.65) .380 B UMPT–04–01–X–RA–WT–M SHOWN (–P & No latch) (–M latch) View complete specifications at: samtec.com?UMPT-RA samtec.com/mPOWER F-221 (Rev 16NOV22) Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
UMPT-05-06.5-G-V-S-W-TR 价格&库存
很抱歉,暂时无法提供与“UMPT-05-06.5-G-V-S-W-TR”相匹配的价格&库存,您可以联系我们找货
  • 300+35.67096300+4.57552
  • 600+29.11764600+3.73493
  • 1500+27.267431500+3.49760
库存:653
    • 1+37.32480
    • 10+36.10440
    • 30+35.28360
    库存:19
    • 1+50.073991+6.42300
    • 10+42.5858510+5.46249
    • 25+39.9113925+5.11944
    • 50+38.0058250+4.87501
    • 100+36.19082100+4.64220
    库存:653
