UMPS-05-03.5-G-V-S-W-TR
    SAMTEC(申泰)
    CONN_15.05X6.2MM_SM
    电源连接器 间距2.00mm 5Pin 1Row 立贴 CONN_15.05X6.2MM_SM
UMPS-05-03.5-G-V-S-W-TR 数据手册
ULTRA MICRO POWER SYSTEM (2.00 mm) .0787" PITCH UMPT/UMPS compared to another small form factor power solution FEATURES & BENEFITS mPower® • Up to 18 A per blade (1 blade powered) • Design flexibility as a power-only system or a two-piece system for power/signal applications Traditional Power Solutions • Use with Samtec’s high-speed connector systems for a unique power/signal system • Choice of 2 to 10 positions CREEPAGE & CLEARANCE • 5 mm to 20 mm stack heights available • Tin or 10 µ" Gold plated power blades; 30 µ" Gold plating available to meet specific regulations UMPT/UMPS • Optional weld tabs • Cable-to-board and cable-to-cable systems in development CREEPAGE 2.20 mm CLEARANCE 1.65 mm Selectively loading contacts achieves customer specific creepage and clearance requirements. KEY SPECIFICATIONS PITCH STACK HEIGHTS INSULATOR MATERIAL CONTACT MATERIAL PLATING OPERATING TEMP RANGE 2.00 mm 5 to 16, 18, 20 mm Black LCP Copper Alloy Sn or Au over 50 µ" (1.27 µm) Ni -55 °C to +105 °C with Tin F-221 (Rev 28OCT22) -55 °C to +125 °C with Gold VOLTAGE RATING LEAD-FREE SOLDERABLE 460 VAC/ 650 VDC Yes samtec.com/mPOWER Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. MAX 18 A ULTRA MICRO POWER SOCKET - UMPS - NO. OF POSITIONS –02, –03, –04, –05, –06, –07, –08, –09, –10 LEAD STYLE - m p s - PLATING OPTION –03.5 V “X”R –W = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail –05.5 - OPTION –L = (03.5 mm) .138" –TR = Weld Tab Through-hole (Leave blank for no weld tab) –S = (05.5 mm) .217" = Tape & Reel –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) = 30 µ” (0.76 µm) Gold on contact, Matte Tin on tail –07.5 = (07.5 mm) .295" –T = Matte Tin UMPS UMPT/UMPS CURRENT RATING (PER CONTACT) Board Mates: UMPT NO. OF POSITIONS -S- PINS –T –L 1 18.3 A 16.2 A 2 14.5 A 14.6 A 3 14.2 A 12.6 A 4 12.9 A 12.3 A 5 12.9 A N/A 10 N/A 9.4 A A A B C –02 (9.05) .356 (7.65) .301 –03 (11.05) .435 (9.65) .380 (8.00) .315 –04 (13.05) .514 (11.65) .459 (10.00) .394 (6.20) .244 (6.00) .236 –05 (15.05) .593 (13.65) .537 (12.00) .472 –06 (17.05) .671 (15.65) .616 (14.00) .551 –07 (19.05) .750 (17.65) .695 (16.00) .630 –08 (21.05) .829 (19.65) .774 (18.00) .709 –09 (23.05) .907 (21.65) .852 (20.00) .787 –10 (25.05) .986 (23.65) .931 (22.00) .866 Ratings are derated 20% with 30 °C rise to maximum allowable temperature. B LEAD STYLE D C UMPS–04–03.5–X-V–S–W SHOWN D –03.5 (4.15) .163 –05.5 (6.15) .242 –07.5 (8.15) .321 View complete specifications at: samtec.com?UMPS SIGNAL CONNECTOR MATED HEIGHT 5 mm ADM6/ADF6 X BTH/BSH, BTS/BSS X BTE/BSE ERM5/ERF5 X LPAM/LPAF X QMS/QFS QRM8/QRF8 QTE/QSE, QTH/QSH QTS/QSS SEAM/SEAF SEAM8/SEAF8 ST4/SS4 ST5/SS5 TEM/SEM 7 mm 9 mm 10 mm 11 mm 12 mm X X X X X X X X X X X X X X X ERM6/ERF6 ERM8/ERF8 6 mm X X 13 mm 14 mm 15 mm 16 mm 18 mm X X X X X X X X X 20 mm X X X 8 mm X X X X X X X X X X X X X X X X X X X X X X X X Notes: Some lengths, styles and otpons are non-standard, non-returnable samtec.com/mPOWER F-221 (Rev 28OCT22) Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
