THROUGH-HOLE
LOW-PROFILE HEADER 8
G b p s
(2.00 mm) .0787" PITCH • TMM SERIES
TMM
Board Mates:
CLT, SQT, SQW, ESQT,
TLE, SMM, MMS
Cable Mates:
TCSD
TMM
-1
NO. PINS
PER ROW
LEAD
STYLE
02 thru 50
–F
Specify
LEAD
STYLE
from
chart
SPECIFICATIONS
PLATING
OPTION
OTHER
OPTION
–S
= Gold flash
on post,
Matte Tin on tail
–RA &
–RE
= Single
Row
= Right-angle
(Lead Style
–01 only)
(2 positions
minimum,
–Q row)
–D
–L
= Double
Row
= 10 µ" (0.25 µm)
Gold on post,
Matte Tin on tail
Insulator Material:
Black Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Sn or Au over
50 µ” (1.27 µm) Ni
Current Rating (SMM/TMM):
3.2 A per row
(2 pins powered)
Operating Temp Range:
-55 °C to +105 °C with Tin;
-55 °C to +125 °C with Gold
Voltage Rating:
281 VAC mated with SQW;
250 VAC mated with SQT
ROW
OPTION
–Q
–RC
= Four
Row
–S
= 30 µ" (0.76 µm)
Gold on post,
Matte Tin on tail
= Retention Clip
(Mates with
TCSD)
(Double row only,
4 positions
minimum, only
available –06
lead style)
–T
= Matte Tin
–“XXX”
= Polarized
Position
(Specify position
of omitted pin)
PROCESSING
Lead–Free Solderable:
Yes
No. of positions x
(2.00) .0787
(1.97)
.078
D
APPLICATION
–RA & –RE
–RC
(3.94)
.155
Retention Clip Option (–RC)
ALSO AVAILABLE
Other plating
(MOQ Required)
–Q –RA
OPTION
D
–RA
(1.27)
.050
–RE
(3.56)
.140
LEAD
STYLE
(8.00)
.315
A
–01
–02
(8.20)
.323
–03
10 YEAR MFG
WITH 30 µ" GOLD
EXTENDED LIFE
PRODUCT
HIGH MATING
CYCLES
(1.50)
.059
B
A
B
C
(3.20)
.126
(3.50)
.138
(3.70)
.146
(3.00)
.118
(4.00)
.158
(2.70)
.106
–04
(5.69)
.224
(1.91)
.075
–05
(5.43)
.214
(1.65)
.065
–06
(9.58)
.377
(3.20)
.126
(2.29)
.090
(4.88)
.192
C
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
–S
–D
–Q
samtec.com?TMM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
F-221
很抱歉,暂时无法提供与“TMM-111-03-G-D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+26.189461+3.35933
- 50+22.4875450+2.88448
- 100+19.13654100+2.45465
- 500+16.31457500+2.09267
- 1000+14.550821000+1.86644
