SEAM-40-02.0-S-06-2-A-K-TR
    SAMTEC(申泰)
    SMD,P=1.27mm
    板对板连接器 立贴 针脚数:240Pin 间距:1.27mm 排数:6
SEAM-40-02.0-S-06-2-A-K-TR 数据手册
HIGH-DENSITY OPEN-PIN-FIELD ARRAYS (1.27 mm) .050" PITCH FEATURES & BENEFITS • Maximum grounding & routing flexibility • Up to 560 single-ended I/Os or 140 differential pairs • Rugged Edge Rate® contacts • Variety of designs and options: Right-Angle, Guide Posts, 85 Ω Elevated Risers, 85 Ω Tuned, Press-Fit and Press-Fit Right-Angle, Guide Post Field Termination Kits 10 YEAR MFG WITH 30 µ" GOLD • Compatible with UMPT/UMPS for power/signal flexibility EXTENDED LIFE PRODUCT • Cable mates (SEAC Series) and Jack Screw Standoffs (JSO Series) also available HIGH MATING CYCLES • Standards: VITA 47, VITA 57.1 FMC, VITA 57.4 FMC+, VITA 74 VNX, PISMO™ 2 • Supports high-speed protocols such as Ethernet, PCI Express®, Fibre Channel & InfiniBand (1.12 mm) .044" Nominal Wipe Solder Charges MAXIMUM GROUNDING & ROUTING FLEXIBILITY Power / Signal Applications Differential Pair Single-Ended Power KEY SPECIFICATIONS PITCH STACK HEIGHTS 1.27 mm x 1.27 mm 7 mm 18.5 mm TOTAL PINS 40 - 560 INSULATOR MATERIAL Black LCP CONTACT MATERIAL PLATING OPERATING TEMP RANGE Au or Sn over -55 °C to +125 °C Copper Alloy 50 µ" (1.27 µm) Ni CURRENT RATING WORKING VOLTAGE LEAD-FREE SOLDERABLE 2.7 A per pin (10 adjacent pins powered) 7 mm stack height 240 VAC Yes Note: Some lengths, styles and options are non-standard, non-returnable F-221 (Rev 01JUN21) samtec.com/SEARAY Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. (1.27 mm) .050" PITCH • SEAM/SEAF SERIES SERIES - POSITIONS PER ROW SEAM –10, –15, –20, –30, –40, –50 Terminal SEAF SEAM & SEAF: -10 only available in -04 Row Socket - - LEAD STYLE PLATING OPTION - NO. OF ROWS –L Specify LEAD STYLE from chart –04 = 10 µ" (0.25 µm) Gold on contact area, Matte Tin on solder tail = 30 µ" (0.76 µm) Gold on contact area, Matte Tin on solder tail SEAF: -15 only available in -04 or -10 Row with -5.0 Lead Style SEAM –1 –A –05 –08 = Lead-Free Solder Charge = Alignment Pin –K –2 –10 Polyimide Film Pick & Place Pad –TR = Tape & Reel SEAM: -04, -05 & -06 (Rows not available with -06.5 Lead Style) B Board Mates: SEAF, SEAFP Standoffs: JSO - A - K - "X" R SOLDER TYPE = Tin/Lead Alloy Solder Charge –06 –S SEAM: -15 only available in -04 Row with -02.0 Lead Style, and -10 Row with any Lead Style; - No. of positions x (1.27) .050 + (4.98) .196 A No. of positions x (1.27) .050 + (3.58) .141 –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) LEAD STYLE A –02.0 (5.61) .221 –03.0 (6.60) .260 NO. OF ROWS B –04 (7.06) .278 –05, –06 (9.60) .378 –03.5 (7.11) .280 –08 (12.14) .478 –06.5 (10.16) .400 –10 (14.68) .578 –07.0 (10.59) .417 –09.0 (12.60) .496 –11.0 (14.61) .575 ALSO AVAILABLE View complete specifications at: samtec.com?SEAM SEAF Board Mates: SEAM, SEAMP, SEAR, SEAMI Standoffs: JSO See website for 14 row option. LEAD STYLE B No. of positions x (1.27) .050 + (5.82) .229 (1.27) .050 A NO. OF ROWS B (5.66) .223 –05.0 (5.05) .199 –04 –06.0 (6.05) .238 –05, –06 (8.20) .323 –06.5 (6.55) .258 –08 (10.74) .423 –07.5 (7.54) .297 –10 (13.28) .523 A No. of positions x (1.27) .050 + (3.58) .141 View complete specifications at: samtec.com?SEAF STANDARDS MATED HEIGHTS SEAM LEAD STYLE SEAF LEAD STYLE VITA 47 –05.0 –06.0 –06.5 –07.5 –02.0 7 mm 8 mm 8.5 mm 9.5 mm –03.0 8 mm 9 mm 9.5 mm 10.5 mm –03.5 8.5 mm 9.5 mm 10 mm 11 mm –06.5 11.5 mm 12.5 mm 13 mm 14 mm –07.0 12 mm 13 mm 13.5 mm 14.5 mm –09.0 14 mm 15 mm 15.5 mm 16.5 mm –11.0 16 mm 17 mm 17.5 mm 18.5 mm VITA 57.1 FMC VITA 57.4 FMC+ VITA 74 VNX PISMOTM2 Visit www.samtec.com/standards for more information. Notes: IPC-A-610F and IPC J-STD-001F Class 3 solder joint. samtec.com/SEARAY Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-221 (Rev 01JUN21)
SEAM-40-02.0-S-06-2-A-K-TR 价格&库存
很抱歉,暂时无法提供与“SEAM-40-02.0-S-06-2-A-K-TR”相匹配的价格&库存,您可以联系我们找货
  • 200+142.51526200+18.28045
  • 400+121.26610400+15.55482
  • 600+103.76225600+13.30960
库存:874
    • 1+162.50760
    • 10+155.37960
    • 30+143.03520
    库存:10
    • 1+146.078481+18.73751
    • 10+124.1191910+15.92078
    • 25+116.3467825+14.92382
    • 50+110.7936850+14.21152
    • 100+107.55772100+13.79644
    库存:874
